查看: 5063|回复: 0
MSP430F6736 PWM 无法调整duty cycle
ID:101175 发表于 2015-12-30 09:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大大:
      以下是我的source code ,照理说当我调整TA1CCR1 的数据时duty cycle就会随之改变,但是不管我数值改多少duty cycle都没有变,会是我clock选择的问题吗?
在麻烦各位前辈帮帮我看一下了>< 谢谢.
int main(void)
  // Stop watchdog
  WDTCTL = WDTPW + WDTHOLD;
  UCS_init();
  P8DIR |= BIT4;
  P8SEL |= BIT4;
  InitSystemCLK();
  TA1CCR1 = 0;
  __enable_interrupt();
  // LPM0 (shut down the CPU) with interrupts enabled
  //__bis_SR_register(CPUOFF | GIE);
// This will be called when timer counts to TACCR1.
#pragma vector=TIMER1_A0_VECTOR
__interrupt void TIMER1_A0_ISR(void)
  int new_ccr1 = 2000;
  // Clear interrupt flag
  TA1CCTL1 &= ~CCIFG;
  TA1CCR1 = new_ccr1 ;
void UCS_init(void)
   // Set Vcore to accomodate for max. allowed system speed
   PMM_setVCore(PMM_BASE,PMMCOREV_3);  // Used PMM_CORE_LEVEL_3
  // Initialize LFXT1
    UCSCTL6 &= ~(XT1OFF);                   // Enable XT1
    UCSCTL6 |= XCAP_3;                      // Internal load cap 12pF
  // Loop until XT1 fault flag is cleared
    do
        UCSCTL7 &= ~XT1LFOFFG;             // Clear XT1 fault flags
    } while (UCSCTL7 & XT1LFOFFG);         // Test XT1 fault flag
  // Use 32.768kHz XTAL as reference
  //  LFXT_Start(XT1DRIVE_3);
  // Setup UCS
    UCSCTL3 |= SELREF_0;                   // Set DCO FLL reference = REFO
    UCSCTL4 |= SELA_0;                     // Set ACLK = REFO
  // Initialize DCO to 2.45MHz
    __bis_SR_register(SCG0);               // Disable the FLL control loop
    UCSCTL0 = 0x0000;                      // Set lowest possible DCOx, MODx
    UCSCTL1 = DCORSEL_7;                   // Set RSELx for DCO = 24 MHz
    UCSCTL2 = FLLD_0 | 611;                 // Set DCO Multiplier for 20MHz
                                                            // (N + 1) * FLLRef = Fdco
                                                             // (611 + 1) * 32768 = 20MHz
                                                             // Set FLL Div = fDCOCLK/2
    __bic_SR_register(SCG0);               // Enable the FLL control loop
  // Worst-case settling time for the DCO when the DCO range bits have been
  // changed is n x 32 x 32 x f_MCLK / f_FLL_reference. See UCS chapter in 5xx
  // UG for optimization.
  // 32 x 32 x 12 MHz / 32,768 Hz = 375000 = MCLK cycles for DCO to settle
  __delay_cycles(625000);
  // Loop until XT1, XT2 & DCO fault flag is cleared
  do
      UCSCTL7 &= ~(XT2OFFG | XT1LFOFFG | DCOFFG);
      // Clear XT2,XT1,DCO fault flags
      SFRIFG1 &= ~OFIFG;                 // Clear fault flags
  } while (SFRIFG1 & OFIFG);             // Test oscillator fault flag
     __no_operation();
void InitSystemCLK(void)
   // Setup TA1
   // PWM period
    TA1CCR0 = 4500;
    TA1CTL = TASSEL_2 | MC_1 ;       // SMCLK, upmode, clear TAR
    TA1CCTL0 = OUTMOD_7 | CCIE;      // CCR0 interrupt enabled
