查看: 3795|回复: 1
51单片机电子密码锁程序 能实现密码锁功能,输入错误报警等
ID:103072 发表于 2016-1-25 21:34 | 显示全部楼层 |阅读模式
能实现密码锁功能,输入错误报警等
#include <REG51.h>
#include<intrins.h>
#define LCM_Data  P0
#define uint  unsigned int
#define w 6    //??????
sbit lcd1602_rs=P2^7;
sbit lcd1602_rw=P2^6;
sbit lcd1602_en=P2^5;
sbit Scl=P3^4;   //24C02????
sbit Sda=P3^5;   //24C02????
sbit ALAM = P2^1;  //??
sbit KEY = P3^6;  //??
sbit open_led=P2^2;  //?????
bit  operation=0;  //?????
bit  pass=0;   //??????
bit  ReInputEn=0;  //????????
bit  s3_keydown=0;  //3??????
bit  key_disable=0;  //??????
unsigned char countt0,second; //t0?????,????
void Delay5Ms(void);
unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};            //???????
unsigned char code start_line[] = {"password:       "};
unsigned char code name[]    = {"===Coded Lock==="};            //????
unsigned char code Correct[]  = {"     correct    "};            //????
unsigned char code Error[]    = {"      error     "};             //????
unsigned char code codepass[] = {"      pass      "};
unsigned char code LockOpen[] = {"      open      "};            //OPEN
unsigned char code SetNew[]  = {"SetNewWordEnable"};
unsigned char code Input[]    = {"input:          "};            //INPUT
unsigned char code ResetOK[]  = {"ResetPasswordOK "};
unsigned char code initword[] = {"Init password..."};
unsigned char code Er_try[]  = {"error,try again!"};
unsigned char code again[]  = {"input again     "};
unsigned char InputData[6];          //???????
unsigned char CurrentPassword[6]={1,3,1,4,2,0};      //?????
unsigned char TempPassword[6];
unsigned char N=0;    //????????
unsigned char ErrorCont;   //??????
unsigned char CorrectCont;   //??????
unsigned char ReInputCont;    //??????
unsigned char code initpassword[6]={0,0,0,0,0,0};
//=====================5ms??==============================
void Delay5Ms(void)
unsigned int TempCyc = 5552;
while(TempCyc--);
//===================400ms??==============================
void Delay400Ms(void)
unsigned char TempCycA = 5;
unsigned int TempCycB;
while(TempCycA--)
  TempCycB=7269;
  while(TempCycB--);
//================================24C02=========================================
void mDelay(uint t) //??
uchar i;
    while(t--)
     for(i=0;i<125;i++)
void Nop(void)    //???
  _nop_();
  _nop_();
  _nop_();
  _nop_();
void Start(void)
  Sda=1;
  Scl=1;
  Nop();
  Sda=0;
  Nop();
void Stop(void)
  Sda=0;
  Scl=1;
  Nop();
  Sda=1;
  Nop();
void Ack(void)
Sda=0;
Nop();
Scl=1;
Nop();
Scl=0;
void NoAck(void)
  Sda=1;
  Nop();
  Scl=1;
  Nop();
  Scl=0;
/*???????,Data????????*/
void Send(uchar Data)
    uchar BitCounter=8;
    uchar temp;
    do
     temp=Data;
     Scl=0;
     Nop();
     if((temp&0x80)==0x80)
     Sda=1;
     Sda=0;
     Scl=1;
     temp=Data<<1;
     Data=temp;
     BitCounter--;
    while(BitCounter);
    Scl=0;
uchar Read(void)
    uchar temp=0;
uchar temp1=0;
uchar BitCounter=8;
Sda=1;
do{
Scl=0;
Nop();
Scl=1;
Nop();
if(Sda)
temp=temp|0x01;
temp=temp&0xfe;
if(BitCounter-1)
temp1=temp<<1;
temp=temp1;
BitCounter--;
while(BitCounter);
return(temp);
void WrToROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Send(*(PData+i));
  Ack();
  Stop();
  mDelay(20);
void RdFromROM(uchar Data[],uchar Address,uchar Num)
  uchar i;
  uchar *PData;
  PData=Data;
  for(i=0;i<Num;i++)
  Start();
  Send(0xa0);
  Ack();
  Send(Address+i);
  Ack();
  Start();
  Send(0xa1);
  Ack();
  *(PData+i)=Read();
  Scl=0;
  NoAck();
  Stop();
//=======================================LCD1602===============================
#define yi 0x80 //LCD????????,??LCD1602??????D7???1(100000000=80)
#define er 0x80+0x40 //LCD???????(???????????????0x40)
void delay(uint xms)//????,????
uint x,y;
for(x=xms;x>0;x--)
  for(y=110;y>0;y--);
write_1602com(uchar com)//****????????****
lcd1602_rs=0;//??/????????
lcd1602_rw=0; //???????
P0=com;//????
delay(1);
lcd1602_en=1;//?????,????????????
delay(1);
lcd1602_en=0;//en????,?????,??????
write_1602dat(uchar dat)//***????????****
lcd1602_rs=1;//??/????????
P0=dat;//????
delay(1);
lcd1602_en=1; //en????,?????????
delay(1);
lcd1602_en=0; //en????,?????,??????
void lcd_init(void)
write_1602com(0x38);//????????,??:16*2???,5*7??,8???
write_1602com(0x0c);//????????
write_1602com(0x06);//?????,??????
write_1602com(0x01);//???
unsigned char coding(unsigned char m)
unsigned char k;
switch(m)
  case (0x11): k=1;break;
  case (0x21): k=2;break;
  case (0x41): k=3;break;
  case (0x81): k='A';break;
  case (0x12): k=4;break;
  case (0x22): k=5;break;
  case (0x42): k=6;break;
  case (0x82): k='B';break;
  case (0x14): k=7;break;
  case (0x24): k=8;break;
  case (0x44): k=9;break;
  case (0x84): k='C';break;
  case (0x18): k='*';break;
  case (0x28): k=0;break;
  case (0x48): k='#';break;
  case (0x88): k='D';break;
return(k);
unsigned char keynum(void)
  unsigned char row,col,i;
  P1=0xf0;
  if((P1&0xf0)!=0xf0)
     Delay5Ms();
        Delay5Ms();
     if((P1&0xf0)!=0xf0)
      row=P1^0xf0;          //????
   i=0;
   P1=a;           //????
   while(i<4)
     if((P1&0xf0)!=0xf0)
        col=~(P1&0xff);   //????
        break;            //????????
        i++;
        P1=a;
   return 0;
  while((P1&0xf0)!=0xf0);
  return (row|col);    //??????????
  else return 0;            //???????0
void OneAlam(void)
ALAM=0;
Delay5Ms();
    ALAM=1;
void TwoAlam(void)
ALAM=0;
Delay5Ms();
    ALAM=1;
    Delay5Ms();
ALAM=0;
Delay5Ms();
    ALAM=1;
void ThreeAlam(void)
ALAM=0;
Delay5Ms();
    ALAM=1;
    Delay5Ms();
ALAM=0;
Delay5Ms();
    ALAM=1;
    Delay5Ms();
ALAM=0;
Delay5Ms();
    ALAM=1;
//===================?????N???,?H??????============================
void DisplayOne(void)
// DisplayOneChar(9+N,1,'*');
write_1602com(yi+5+N);
write_1602dat('*');
void DisplayChar(void)
unsigned char i;
if(pass==1)
  //DisplayListChar(0,1,LockOpen);
  write_1602com(er);
  for(i=0;i<16;i++)
   write_1602dat(LockOpen);
  if(N==0)
   //DisplayListChar(0,1,Error);
   write_1602com(er);
   for(i=0;i<16;i++)
    write_1602dat(Error);
   //DisplayListChar(0,1,start_line);
   write_1602com(er);
   for(i=0;i<16;i++)
    write_1602dat(start_line);
void DisplayInput(void)
unsigned char i;
if(CorrectCont==1)
  //DisplayListChar(0,0,Input);
  write_1602com(er);
  for(i=0;i<16;i++)
   write_1602dat(Input);
void ResetPassword(void)
unsigned char i;
unsigned char j;
if(pass==0)
  pass=0;
  DisplayChar();
  ThreeAlam();
     if(ReInputEn==1)
   if(N==6)
    ReInputCont++;
    if(ReInputCont==2)
     for(i=0;i<6;)
      if(TempPassword==InputData) //????????????
       i++;
       write_1602com(er);
       for(j=0;j<16;j++)
        write_1602dat(Error[j]);
       ThreeAlam();   //????
       pass=0;
       ReInputEn=0;   //??????,
       ReInputCont=0;
       DisplayChar();
       break;
     if(i==6)
      //DisplayListChar(0,1,ResetOK);
      write_1602com(er);
      for(j=0;j<16;j++)
       write_1602dat(ResetOK[j]);
      TwoAlam();    //??????
       WrToROM(TempPassword,0,6);  //??????24C02??
      ReInputEn=0;
     ReInputCont=0;
     CorrectCont=0;
     OneAlam();
     //DisplayListChar(0, 1, again);   //????????
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(again[j]);
     for(i=0;i<6;i++)
      TempPassword=InputData;  //?????????????
   N=0;      //???????????
void Alam_KeyUnable(void)
P1=0x00;
  ALAM=~ALAM;
  Delay5Ms();
void Cancel(void)
unsigned char i;
unsigned char j;
//DisplayListChar(0, 1, start_line);
write_1602com(er);
for(j=0;j<16;j++)
  write_1602dat(start_line[j]);
TwoAlam();    //???
for(i=0;i<6;i++)
  InputData=0;
KEY=1;     //???
ALAM=1;     //???
operation=0;   //???????
pass=0;     //????????
ReInputEn=0;   //??????????
ErrorCont=0;   //??????????
CorrectCont=0;   //??????????
ReInputCont=0;   //??????????
open_led=1;
s3_keydown=0;
key_disable=0;
N=0;     //?????????
void Ensure(void)
unsigned char i,j;
RdFromROM(CurrentPassword,0,6);      //?24C02???????
    if(N==6)
     if(ReInputEn==0)       //?????????
   for(i=0;i<6;)
    if(CurrentPassword==InputData)
     i++;
     ErrorCont++;
     if(ErrorCont==3)   //??????????,???????
      write_1602com(er);
      for(i=0;i<16;i++)
      do
      Alam_KeyUnable();
      while(1);
      TR0=1;    //????
      key_disable=1;   //????
      pass=0;
      break;
   if(i==6)
    CorrectCont++;
    if(CorrectCont==1)    //??????,??????????,??,
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(LockOpen[j]);
     TwoAlam();   //???????
     KEY=0;           //??
     pass=1;           //??????
     TR0=1;           //????
     open_led=0;          //??????
     for(j=0;j<6;j++)        //?????
      InputData=0;
    else         //????????,????????
     //DisplayListChar(0,1,SetNew);
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(SetNew[j]);
     TwoAlam();             //??????
     ReInputEn=1;         //????????
   else   //=========================???????????????131420???????============
   {  if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
     WrToROM(initpassword,0,6);     //?????????24C02??
     //DisplayListChar(0,1,initword);   //???????
     write_1602com(er);
     for(j=0;j<16;j++)
      write_1602dat(initword[j]);
     TwoAlam();
     Delay400Ms();
     TwoAlam();
     N=0;
     write_1602com(er);
     for(j=0;j<16;j++)
      ThreeAlam();          //?????
     pass=0;
  else          //????????????,??????,
   //DisplayListChar(0,1,Er_try);
   write_1602com(er);
   for(j=0;j<16;j++)
    write_1602dat(Er_try[j]);
   ThreeAlam();
  write_1602com(er);
  for(j=0;j<16;j++)
  pass=0;
N=0;          //??????????,?????????
operation=1;
void main(void)
  unsigned char KEY,NUM;
unsigned char i,j;
  P1=0xFF;
TMOD=0x11;
  TL0=0xB0;
  TH0=0x3C;
  EA=1;
  ET0=1;
  TR0=0;
  Delay400Ms();  //????,?LCM??????
  lcd_init();  //LCD???
write_1602com(yi);//?????????????0?????????
for(i=0;i<16;i++)
  write_1602dat(name);//????????????????
write_1602com(er);//????????????,??2????????
for(i=0;i<16;i++)
  write_1602dat(start_line);//?????????,????
write_1602com(er+9); //??????
write_1602com(0x0f); //???????
  Delay5Ms(); //????(???)
  N=0;              //?????????
  if(key_disable==1)
   Alam_KeyUnable();
   ALAM=1;        //???
  KEY=keynum();
  if(KEY!=0)
   if(key_disable==1)
    second=0;
    NUM=coding(KEY);
     switch(NUM)
      case ('A'):  ;      break;
      case ('B'):  ;         break;
      case ('C'):  ;      break;
      case ('D'): ResetPassword();  break;      //??????
      case ('*'): Cancel();    break;      //??????
      case ('#'): Ensure();     break;    //???,
      default:
       //DisplayListChar(0,1,Input);
       write_1602com(er);
       for(i=0;i<16;i++)
          operation=0;
       if(N<6)
//????????6??,???????,??6??????
        OneAlam();        //?????
        //DisplayOneChar(6+N,1,'*');
         for(j=0;j<=N;j++)
         write_1602com(er+6+j);
         write_1602dat('*');
        InputData[N]=NUM;
        N++;
       else       //????????6?,????
        N=6;
         break;
void  time0_int(void) interrupt 1
  TL0=0xB0;
  TH0=0x3C;
  //TR0=1;
  countt0++;
   if(countt0==20)
  countt0=0;
  second++;
  if(pass==1)
   if(second==1)
    open_led=1;   //????
    TR0=0;    //????
    TL0=0xB0;
     TH0=0x3C;
    second=0;
   if(second==3)
    TR0=0;
    second=0;
    key_disable=0;
    s3_keydown=0;
    TL0=0xB0;
    TH0=0x3C;
       TR0=1;
密码锁.rar
53.92 KB, 下载次数: 1252, 下载积分: 黑币 -5
参与人数 1黑币 +25 收起 理由
admin + 25 共享资料的黑币奖励!
ID:157011 发表于 2016-12-22 23:06 | 显示全部楼层
楼主   有仿真图吗
