查看: 3435|回复: 2
STM32与MFC522通信,IC卡读写
ID:472833 发表于 2019-1-25 14:41 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "mfrc522.h"
#include "stm32f0xx.h"
#include <delay.h>
//#include <string.h>
#define MAXRLEN 18
//功    能:寻卡
//参数说明: req_code[IN]:寻卡方式
//                0x52 = 寻感应区内所有符合14443A标准的卡
//                0x26 = 寻未进入休眠状态的卡
//                    pTagType[OUT]:卡片类型代码
//                0x4400 = Mifare_UltraLight
//                0x0400 = Mifare_One(S50)
//                0x0200 = Mifare_One(S70)
//                0x0800 = Mifare_Pro(X)
//                0x4403 = Mifare_DESFire
//返    回: 成功返回MI_OK
char PcdRequest(unsigned char req_code,unsigned char *pTagType)
   char status;
   unsigned int  unLen;
   unsigned char ucComMF522Buf[MAXRLEN];
//  unsigned char xTest ;
   ClearBitMask(Status2Reg,0x08);
   WriteRawRC(BitFramingReg,0x07);
//  xTest = ReadRawRC(BitFramingReg);
//  if(xTest == 0x07 )
//   { LED_GREEN  =0 ;}
// else {LED_GREEN =1 ;while(1){}}
   SetBitMask(TxControlReg,0x03);
   ucComMF522Buf[0] = req_code;
   status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,1,ucComMF522Buf,&unLen);//功    能:通过RC522和ISO14443卡通讯
//     if(status  == MI_OK )
//   else {LED_GREEN =1 ;}
   if ((status == MI_OK) && (unLen == 0x10))
       *pTagType     = ucComMF522Buf[0];
       *(pTagType+1) = ucComMF522Buf[1];
   {   status = MI_ERR;   }
   return status;
//功    能:防冲撞
//参数说明: pSnr[OUT]:卡片序列号,4字节
//返    回: 成功返回MI_OK
char PcdAnticoll(unsigned char *pSnr)
    char status;
    unsigned char i,snr_check=0;
    unsigned int  unLen;
    WriteRawRC(BitFramingReg,0x00);
    ClearBitMask(CollReg,0x80);
    ucComMF522Buf[0] = PICC_ANTICOLL1;
    ucComMF522Buf[1] = 0x20;
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,2,ucComMF522Buf,&unLen);
    if (status == MI_OK)
             for (i=0; i<4; i++)
             *(pSnr+i)  = ucComMF522Buf[i];
             snr_check ^= ucComMF522Buf[i];
         if (snr_check != ucComMF522Buf[i])
    SetBitMask(CollReg,0x80);
    return status;
//功    能:选定卡片
//参数说明: pSnr[IN]:卡片序列号,4字节
//返    回: 成功返回MI_OK
char PcdSelect(unsigned char *pSnr)
    char status;
    unsigned char i;
    unsigned int  unLen;
    ucComMF522Buf[1] = 0x70;
    ucComMF522Buf[6] = 0;
    for (i=0; i<4; i++)
            ucComMF522Buf[i+2] = *(pSnr+i);
            ucComMF522Buf[6]  ^= *(pSnr+i);
    CalulateCRC(ucComMF522Buf,7,&ucComMF522Buf[7]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,9,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x18))
    {   status = MI_OK;  }
    return status;
//功    能:验证卡片密码
//参数说明: auth_mode[IN]: 密码验证模式
//                 0x60 = 验证A密钥
//                 0x61 = 验证B密钥
//          addr[IN]:块地址
//          pKey[IN]:密码
//          pSnr[IN]:卡片序列号,4字节
//返    回: 成功返回MI_OK
char PcdAuthState(unsigned char auth_mode,unsigned char addr,unsigned char *pKey,unsigned char *pSnr)
    char status;
    unsigned int  unLen;
    unsigned char i,ucComMF522Buf[MAXRLEN];
    ucComMF522Buf[0] = auth_mode;
    ucComMF522Buf[1] = addr;
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+2] = *(pKey+i);   }
    for (i=0; i<6; i++)
    {    ucComMF522Buf[i+8] = *(pSnr+i);   }
//   memcpy(&ucComMF522Buf[2], pKey, 6);
//   memcpy(&ucComMF522Buf[8], pSnr, 4);
    status = PcdComMF522(PCD_AUTHENT,ucComMF522Buf,12,ucComMF522Buf,&unLen);
    if ((status != MI_OK) || (!(ReadRawRC(Status2Reg) & 0x08)))
    return status;
//功    能:读取M1卡一块数据
//参数说明: addr[IN]:块地址
//          pData[OUT]:读出的数据,16字节
//返    回: 成功返回MI_OK
char PcdRead(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_READ;
    CalulateCRC(ucComMF522Buf,2,&ucComMF522Buf[2]);
    status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,4,ucComMF522Buf,&unLen);
    if ((status == MI_OK) && (unLen == 0x90))
//   {   memcpy(pData, ucComMF522Buf, 16);   }
        for (i=0; i<16; i++)
        {    *(pData+i) = ucComMF522Buf[i];   }
    return status;
//功    能:写数据到M1卡一块
//          pData[IN]:写入的数据,16字节
//返    回: 成功返回MI_OK
char PcdWrite(unsigned char addr,unsigned char *pData)
    char status;
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_WRITE;
    if ((status != MI_OK) || (unLen != 4) || ((ucComMF522Buf[0] & 0x0F) != 0x0A))
        //memcpy(ucComMF522Buf, pData, 16);
        {    ucComMF522Buf[i] = *(pData+i);   }
        CalulateCRC(ucComMF522Buf,16,&ucComMF522Buf[16]);
        status = PcdComMF522(PCD_TRANSCEIVE,ucComMF522Buf,18,ucComMF522Buf,&unLen);
    return status;
//功    能:命令卡片进入休眠状态
//返    回: 成功返回MI_OK
char PcdHalt(void)
    unsigned int  unLen;
    ucComMF522Buf[0] = PICC_HALT;
    ucComMF522Buf[1] = 0;
    return MI_OK;
//用MF522计算CRC16函数
void CalulateCRC(unsigned char *pIndata,unsigned char len,unsigned char *pOutData)
    unsigned char i,n;
    ClearBitMask(DivIrqReg,0x04);
    WriteRawRC(CommandReg,PCD_IDLE);
    SetBitMask(FIFOLevelReg,0x80);
    for (i=0; i<len; i++)
    {   WriteRawRC(FIFODataReg, *(pIndata+i));   }
    WriteRawRC(CommandReg, PCD_CALCCRC);
    i = 0xFF;
    do
        n = ReadRawRC(DivIrqReg);
        i--;
    while ((i!=0) && !(n&0x04));
    pOutData[0] = ReadRawRC(CRCResultRegL);
    pOutData[1] = ReadRawRC(CRCResultRegM);
//功    能:复位RC522
//返    回: 成功返回MI_OK
char PcdReset(void)
    RST_H;
    delay_10ms(1);
    RST_L;
    delay_10ms(1);
    RST_H;
          delay_10ms(10);
                if(ReadRawRC(0x02) == 0x80)
                        //LED_ON;
                        delay_10ms(10);
                        //LED_OFF;
                        delay_10ms(10);
                        //LED_ON;
                        delay_10ms(10);
                        //LED_OFF;
                        delay_10ms(10);
    WriteRawRC(CommandReg,PCD_RESETPHASE);
    WriteRawRC(ModeReg,0x3D);            //和Mifare卡通讯,CRC初始值0x6363
    WriteRawRC(TReloadRegL,30);
    WriteRawRC(TReloadRegH,0);
    WriteRawRC(TModeReg,0x8D);
    WriteRawRC(TPrescalerReg,0x3E);
    WriteRawRC(TxAutoReg,0x40);
    return MI_OK;
//设置RC632的工作方式
char M500PcdConfigISOType(unsigned char type)
   if (type == 'A')                     //ISO14443_A
/*     WriteRawRC(CommandReg,0x20);    //as default
       WriteRawRC(ComIEnReg,0x80);     //as default
       WriteRawRC(DivlEnReg,0x0);      //as default
           WriteRawRC(ComIrqReg,0x04);     //as default
           WriteRawRC(DivIrqReg,0x0);      //as default
           WriteRawRC(Status2Reg,0x0);//80    //trun off temperature sensor
           WriteRawRC(WaterLevelReg,0x08); //as default
       WriteRawRC(ControlReg,0x20);    //as default
           WriteRawRC(CollReg,0x80);    //as default
       WriteRawRC(ModeReg,0x3D);//3F
/*           WriteRawRC(TxModeReg,0x0);      //as default???
           WriteRawRC(RxModeReg,0x0);      //as default???
           WriteRawRC(TxControlReg,0x80);  //as default???
           WriteRawRC(TxSelReg,0x10);      //as default???
       WriteRawRC(RxSelReg,0x86);//84
//      WriteRawRC(RxThresholdReg,0x84);//as default
//      WriteRawRC(DemodReg,0x4D);      //as default
//      WriteRawRC(ModWidthReg,0x13);//26
       WriteRawRC(RFCfgReg,0x7F);   //4F
        /*   WriteRawRC(GsNReg,0x88);        //as default???
           WriteRawRC(CWGsCfgReg,0x20);    //as default???
       WriteRawRC(ModGsCfgReg,0x20);   //as default???
              WriteRawRC(TReloadRegL,30);//tmoLength);// TReloadVal = 'h6a =tmoLength(dec)
  //     PcdSetTmo(106);
           delay_10ms(1);
       PcdAntennaOn();
   else{ return (char)-1; }
   return MI_OK;
//功    能:读RC632寄存器
//参数说明:Address[IN]:寄存器地址
//返    回:读出的值
unsigned char ReadRawRC(unsigned char Address)
     unsigned char i, ucAddr;
     unsigned char ucResult=0;
     NSS_L;
     ucAddr = ((Address<<1)&0x7E)|0x80;
     for(i=8;i>0;i--)
         SCK_L;
                  if(ucAddr&0x80)
                 MOSI_H;
                                 MOSI_L;
         SCK_H;
         ucAddr <<= 1;
     for(i=8;i>0;i--)
         SCK_L;
         ucResult <<= 1;
         SCK_H;
                 if(READ_MISO == 1)
                 ucResult |= 1;
     NSS_H;
     SCK_H;
     return ucResult;
//功    能:写RC632寄存器
//          value[IN]:写入的值
void WriteRawRC(unsigned char Address, unsigned char value)
    SCK_L;
    NSS_L;
    ucAddr = ((Address<<1)&0x7E);
    for(i=8;i>0;i--)
                if(ucAddr&0x80)
                MOSI_H;
                        MOSI_L;
        SCK_H;
        ucAddr <<= 1;
        SCK_L;
    for(i=8;i>0;i--)
                if(value&0x80)
                MOSI_H;
                        MOSI_L;
        SCK_H;
        value <<= 1;
        SCK_L;
    NSS_H;
    SCK_H;
//功    能:置RC522寄存器位
//参数说明:reg[IN]:寄存器地址
//          mask[IN]:置位值
void SetBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x0;
    tmp = ReadRawRC(reg);
    WriteRawRC(reg,tmp | mask);  // set bit mask
//功    能:清RC522寄存器位
//          mask[IN]:清位值
void ClearBitMask(unsigned char reg,unsigned char mask)
    char tmp = 0x0;
    WriteRawRC(reg, tmp & ~mask);  // clear bit mask
//参数说明:Command[IN]:RC522命令字
//          pInData[IN]:通过RC522发送到卡片的数据
//          InLenByte[IN]:发送数据的字节长度
//          pOutData[OUT]:接收到的卡片返回数据
//          *pOutLenBit[OUT]:返回数据的位长度
char PcdComMF522(unsigned char Command,
                 unsigned char *pInData,
                 unsigned char InLenByte,
                 unsigned char *pOutData,
                 unsigned int  *pOutLenBit)
    char status = MI_ERR;
    unsigned char irqEn   = 0x00;
    unsigned char waitFor = 0x00;
    unsigned char lastBits;
    unsigned char n;
    unsigned int i;
    switch (Command)
       case PCD_AUTHENT:
          irqEn   = 0x12;
          waitFor = 0x10;
          break;
       case PCD_TRANSCEIVE:
          irqEn   = 0x77;
          waitFor = 0x30;
          break;
       default:
         break;
    WriteRawRC(ComIEnReg,irqEn|0x80);
    ClearBitMask(ComIrqReg,0x80);
    for (i=0; i<InLenByte; i++)
    {   WriteRawRC(FIFODataReg, pInData[i]);    }
    WriteRawRC(CommandReg, Command);
    if (Command == PCD_TRANSCEIVE)
    {    SetBitMask(BitFramingReg,0x80);  }
//    i = 600;//根据时钟频率调整,操作M1卡最大等待时间25ms
i = 2000;
    do
         n = ReadRawRC(ComIrqReg);
         i--;
    while ((i!=0) && !(n&0x01) && !(n&waitFor));
    ClearBitMask(BitFramingReg,0x80);
    if (i!=0)
         if(!(ReadRawRC(ErrorReg)&0x1B))
             status = MI_OK;
             if (n & irqEn & 0x01)
             {   status = MI_NOTAGERR;   }
                       n = ReadRawRC(FIFOLevelReg);
                      lastBits = ReadRawRC(ControlReg) & 0x07;
                if (lastBits)
                {   *pOutLenBit = (n-1)*8 + lastBits;   }
                {   *pOutLenBit = n*8;   }
                if (n == 0)
                {   n = 1;    }
                if (n > MAXRLEN)
                {   n = MAXRLEN;   }
                for (i=0; i<n; i++)
                {   pOutData[i] = ReadRawRC(FIFODataReg);    }
   SetBitMask(ControlReg,0x80);           // stop timer now
   return status;
//开启天线
//每次启动或关闭天险发射之间应至少有1ms的间隔
void PcdAntennaOn()
    unsigned char i;
    i = ReadRawRC(TxControlReg);
    if (!(i & 0x03))
        SetBitMask(TxControlReg, 0x03);
//关闭天线
void PcdAntennaOff()
    ClearBitMask(TxControlReg, 0x03);
//等待卡离开
void WaitCardOff(void)
        char          status;
  unsigned char        TagType[2];
                status = PcdRequest(REQ_ALL, TagType);
                if(status)
                        if(status)
                                if(status)
                                        return;
                delay_10ms(100);
// Delay 10ms
void delay_10ms(unsigned int _10ms)
        unsigned int i, j;
        for(i=0; i<_10ms; i++)
                delay_ms(10);
void MFRC522_GPIO_init(void)
  GPIO_InitTypeDef  GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = MF522_RST_PIN;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;
  GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;
  GPIO_Init(MF522_RST_PORT, &GPIO_InitStructure);
  /* Configure the GPIO pin */
  GPIO_InitStructure.GPIO_Pin = MF522_MISO_PIN;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
  GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
  GPIO_Init(MF522_MISO_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = MF522_MOSI_PIN;
  GPIO_Init(MF522_MOSI_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = MF522_SCK_PIN;
  GPIO_Init(MF522_SCK_PORT, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = MF522_NSS_PIN;
  GPIO_Init(MF522_NSS_PORT, &GPIO_InitStructure);
void MFRC522_init(void)//初始化模块
        MFRC522_GPIO_init();
        delay_10ms(10);
        PcdReset();                                //复位
        PcdAntennaOff();  //关闭天线
        PcdAntennaOn();   //开天线
        M500PcdConfigISOType( 'A' ); //ISO14443_A工作方式
        delay_10ms(10);
        delay_10ms(10);
        delay_10ms(10);
ID:472833 发表于 2019-1-25 14:42 | 只看该作者
int kahao(char src[], int start, int bit) {
    strncpy(carNumber, src + start, bit);
    ACCLOG("car_number:%s\n", carNumber);
    return 0;
//获取卡的过期时间
int jieMika(char src[]) {
    /*读卡解密部分 */
    strncpy(overTime, src, 6);
    ACCLOG("overTime:%s\n", overTime);
    if (atoi(overTime) >= atoi(mostTime)) {
        return 1;
    } else {
        return 0;
//判断卡的权限
int check_card(char src[],int n){
  for(int i=0;i<n;i++)
      if(strncmp(src + (i * 3),community_pass,3)==0)
        return 1;
      if(strncmp(src + (i * 3),community_pass,3)!=0&&i==(n-1))
        return 0;
//判断卡的权限
int check_carNumber(char src[]) {
    char kami[5] = "";
    strncpy(kami, src + (part * 4), 4);
    ACCLOG("16numer:%s\n", kami);
    memset((char *) &twoNumber, 0, sizeof(twoNumber));
    for (int i = 0; i < 4; i++) {
        printhextobin(kami[i]);
    ACCLOG("2number:%s\n", twoNumber);
    int aa = atoi(swipe) - atoi(swipe) / 16 * 16;
    char last[2] = "";
    strncpy(last, twoNumber + (aa - 1), 1);
    if (atoi(last) == 0) {
        return 1;
    } else {
        return 0;
//读取卡的内容
int find_car_new(int sanqu)
    int n=0,m=0,x=0,j,k,a = 0;
    action=0;
    char i;
    char status;
    if(!status){
        status = PcdRequest(REQ_ALL, TagType);//寻卡
        if(!status){
          status = PcdAnticoll(SelectedSnr);//防冲撞
          if(!status){
            status = PcdSelect(SelectedSnr);//选定卡片
            if(!status){
              status = PcdAuthState(KEYA, (sanqu * 4 + 0), DefaultKey[0], SelectedSnr);//验证卡片密码
              if(!status){
                status = PcdRead((sanqu * 4 + n), buf1);  //读取M1卡一块数据
                n++;
                if(!status){
                  memset((char *) &car_str[0], 0, sizeof(car_str[0]));
                  char tempChar[2];
                  for (i = 0; i < 16; i++) {
                    int intNumber = (int) buf1[i];
                    sprintf(tempChar, "%x", intNumber);
                    int isZero = (int) tempChar[1];
                    if (isZero == 0) {
                      sprintf(&car_str[0][i * 2], "%s", "0");
                      car_str[0][i * 2 + 1] = tempChar[0];
                    } else {
                      car_str[0][i * 2] = tempChar[0];
                      car_str[0][i * 2 + 1] = tempChar[1];
                  ACCLOG("car_code1:%s\n", car_str[0]);
                  n++;
                  if(!status){
                    status = PcdRead((sanqu * 4 + n), buf2);  //读取M1卡一块数据
                    memset((char *) &car_str[1], 0, sizeof(car_str[1]));
                    char tempChar[2];
                      int intNumber = (int) buf2[i];
                      if (isZero == 0) {
                        sprintf(&car_str[1][i * 2], "%s", "0");
                        car_str[1][i * 2 + 1] = tempChar[0];
                      } else {
                        car_str[1][i * 2] = tempChar[0];
                        car_str[1][i * 2 + 1] = tempChar[1];
                    if(strncmp(car_str[1],"0000",4)!=0){
                      m=1;
                      ACCLOG("car_code2:%s\n", car_str[1]);
                      if(!status){
                        status = PcdRead((snr * 4 + n), buf3);  //读取M1卡一块数据
                        memset((char *) &car_str[2], 0, sizeof(car_str[2]));
                        char tempChar[2];
                          if (isZero == 0) {
                            sprintf(&car_str[2][i * 2], "%s", "0");
                            car_str[2][i * 2 + 1] = tempChar[0];
                          } else {
                            car_str[2][i * 2] = tempChar[0];
                            car_str[2][i * 2 + 1] = tempChar[1];
                        if(strncmp(car_str[2],"0000",4)!=0){
                          m=2;
                          ACCLOG("car_code3:%s\n", car_str[2]);
                    if(jieMika(car_str[0])==1){
                      do{
                        for(j=0;j<=m;j++){
                          if(strncmp(car_str[j],"0000",4)!=0)
                            strncpy(quhao + (j * 4) + a * 4,car_str[j]+8,4);
                            strncpy(card_pass + (j * 3) + a * 3,car_str[j]+13,3);
                            x++;
                            if(strncmp(car_str[j]+16,"0000",4)!=0){
                              strncpy(quhao + ((j + 1) * 4) + a * 4,car_str[j]+24,4);
                              strncpy(card_pass + ((j + 1) * 3) + a * 3,car_str[j]+29,3);
                              x++;
                              if(j==m)
                                n=0;
                            }else
                              n=0;
                          }else{
                            n=0;
                          a++;
                      }while(n!=0);
                      if(strncmp(car_str[m]+8,community_num,4)==0){
                        if(strncmp(car_str[m]+12,"ffff",4)==0){
                          soundBee(1);
                          ACCLOG("this is universal_card...\n");
                          sendMessage(carNumber, 2);
                          car_return = 1;
                          action=1;
                          return 1;
                        }else if(check_card(card_pass,x)==1){
                          soundBee(1);
                          ACCLOG("open door...\n");
                          car_return = 1;
                          action=1;
                          return 1;
                        }else{
                          soundBee(0);
                          ACCLOG("car has no power...\n");
                          sendMessage(carNumber, 6);
                          car_return = 3;
                          action=1;
                          return 3;
                      }else{
                        soundBee(0);
                        ACCLOG("not our community...\n");
                        car_return = 3;
                        action=1;
                        return 3;
                    }else{
                      soundBee(0);
                      ACCLOG("card is overtiem...\n");
                      sendMessage(carNumber, 5);
                      car_return = 3;
                      action=1;
                      return 3;
                  ACCLOG("too fast...\n");
                  soundBee(2);
                  car_return = 5;
                  return 5;
    car_return = 0;
    return 0;
ID:1 发表于 2019-1-25 18:31 | 只看该作者
本帖需要重新编辑补全电路原理图,源码,详细说明与图片即可获得100+黑币(帖子下方有编辑按钮)
