查看: 3190|回复: 0
基于stc15f104w单片机的软件iic oled显示iic.h oled.h头文件下载
ID:442609 发表于 2021-6-18 12:55 | 显示全部楼层 |阅读模式
  1. void oled_init(void)//初始化ssd1306
  2. {
  3.         delay_ms(500);//延时(必须有)
  4.         oled_wr_byte(0xAE,0);//关闭oled面板
  5.         oled_wr_byte(0x00,0);//设置低位列地址
  6.         oled_wr_byte(0x10,0);//设置高位列地址
  7.         oled_wr_byte(0x40,0);//设置起始行地址设置映射RAM显示起始行(0x00~0x3F)
  8.         oled_wr_byte(0x81,0);//--设置对比度控制寄存器
  9.         oled_wr_byte(0xCF,0);//设置SEG输出电流亮度
  10.         oled_wr_byte(0xA1,0);//设置分段/列映射0xa0左右反置 0xa1型正常
  11.         oled_wr_byte(0xC8,0);//设置COM/行扫描方向0xc0上下反置 0xc8型正常
  12.         oled_wr_byte(0xA6,0);//设置正常显示
  13.         oled_wr_byte(0xA8,0);//设置复用比(1到64)
  14.         oled_wr_byte(0x3F,0);//1/64负载
  15.         oled_wr_byte(0xD3,0);//设置显示偏移映射RAM计数器(0x00~0x3F)
  16.         oled_wr_byte(0x00,0);//不补偿
  17.         oled_wr_byte(0xD5,0);//设置显示时钟分频比/振荡器频率
  18.         oled_wr_byte(0x80,0);//设置分频比,将时钟设置为100帧/秒
  19.         oled_wr_byte(0xD8,0);
  20.         oled_wr_byte(0x05,0);
  21.         oled_wr_byte(0xD9,0);//设置预充电时间
  22.         oled_wr_byte(0xF1,0);//将预充电设置为15个时钟,放电设置为1个时钟
  23.         oled_wr_byte(0xDA,0);//设置com引脚硬件配置
  24.         oled_wr_byte(0x12,0);//
  25.         oled_wr_byte(0xDB,0);//设置vcomh
  26.         oled_wr_byte(0x40,0);//设置VCOM取消选择级别
  27.         oled_wr_byte(0x20,0);//设置页面寻址模式(0x00/0x01/0x02)
  28.         oled_wr_byte(0x02,0);//
  29.         oled_wr_byte(0x8D,0);//设置电荷泵启用/禁用
  30.         oled_wr_byte(0x14,0);//设置(0x10)禁用
  31.         oled_wr_byte(0xA4,0);//禁用整个显示打开(0xa4/0xa5)
  32.         oled_wr_byte(0xA6,0);//禁用反转显示打开(0xa6/a7)
  33.         oled_wr_byte(0xAF,0);//打开oled面板
  34.         fill_picture(0x00);//初始清屏
  35.         oled_set_pos(0,0);//初始光标
  36. }
  1. #include"iic.h"
  2. int main()
  3. {
  4.         oled_init();//初始化
  5.         oled_showchinese(0,0,1);//显示汉字
  6.         oled_showchinese(16,0,0);
  7.         oled_showchinese(32,0,2);
  8.         oled_showchinese(48,0,2);
  9.         oled_showchinese(64,0,3);
  10.         oled_showchinese(80,0,4);
  11.         oled_showchinese(112,0,5);
  12.   delay_ms(3000);
  13.         oled_showstring(0,2,"Presented by",32);//显示字符串
  14.         oled_showstring(0,3,"DarkStar244",32);
  15.         oled_showstring(0,4,"114514",16);
  16.         oled_wr_byte(0x2e,0);//关滚动
  17.         oled_wr_byte(0x29,0);//方向,29右,2a左
  18.         oled_wr_byte(0x00,0);//空字节
  19.   oled_wr_byte(0x04,0);//水平起始页
  20.         oled_wr_byte(0x0cf,0);//水平滚动速度
  21.         oled_wr_byte(0x01,0);//水平结束页
  22.         oled_wr_byte(0x00,0);//每次垂直滚动位移
  23.         oled_wr_byte(0x2f,0);//开滚动
  24.   while (1){;}
  25. }
下载:
iic.rar (5.06 KB, 下载次数: 42)
参与人数 1黑币 +40 收起 理由
admin + 40 共享资料的黑币奖励!
