查看: 5513|回复: 4
51单片机12864液晶做的密码锁程序
ID:76556 发表于 2015-4-10 01:51 | 显示全部楼层 |阅读模式
#include <reg51.h>
/**********端口定义*************/
sbit RS = P1^0;
sbit RW = P1^1;
sbit E = P1^5;
sbit KEY_IN1 = P2^4;
sbit KEY_IN2 = P2^5;
sbit KEY_IN3 = P2^6;
sbit KEY_IN4 = P2^7;
sbit KEY_OUT1 = P2^3;
sbit KEY_OUT2 = P2^2;
sbit KEY_OUT3 = P2^1;
sbit KEY_OUT4 = P2^0;
unsigned char Key_Buff[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
#define  Date P0   //定义Date口为数据口P0
void Delays_Lcd(unsigned int x)                //延时子函数
{  unsigned int i,j;
   for(i=45;i>0;i--)
      for(j=x;j>0;j--);
void T0_Init()
EA = 1;
TMOD = 0x01;
TH0 = 0xFC;
TL0 = 0x67;
ET0 = 1;
TR0 = 1;
void Write_Instruction(unsigned char Parameter) //写指令(Write/Instruction)。。形参(Parameter)
RS=0;
RW=0;
E=0;
Date=Parameter;
E=1;
Delays_Lcd(0);
E=0;
void Write_Date(unsigned char Parameter) //写数据(Write/Date)。。形参(Parameter)
RS=1;
RW=0;
E=0;
Date=Parameter;
E=1;
Delays_Lcd(0);
E=0;
void init_Lcd()                                                //液晶初始化(init/lcd)
Write_Instruction(0x01);
Write_Instruction(0x0c);
Write_Instruction(0x30);
void Position_Lcd(unsigned char x,unsigned char y)        //进入点设定,,液晶显示位置(Lcd/Position)
unsigned char  Position;
if(x==1)
        {x=0x80;}
else if(x==2)
        {x=0x90;}
else if(x==3)
        {x=0x88;}
else if(x==4)
        {x=0x98;}
Position=x+y;
Write_Instruction(Position);     //显示地址
void Staret()
unsigned char code TV1[]={"输入密码"};
unsigned char code TV2[]={":"};
unsigned char Num1;
RS=0;
RW=0;
E=0;
init_Lcd();
Position_Lcd(1,2);
Num1=0;
while(TV1[Num1]!='\0')                //教材P176页讲述了TV1[Num1]!='\0'的意思特别是'\0'的意思("空"在储存器中的存储形式是"\0")
         Write_Date(TV1[Num1]);
         Num1++;
Position_Lcd(2,0);
Num1=0;
while(TV2[Num1]!='\0')                //教材P176页讲述了TV1[Num1]!='\0'的意思特别是'\0'的意思("空"在储存器中的存储形式是"\0")
         Write_Date(TV2[Num1]);
         Num1++;
Position_Lcd(2,1);
unsigned char Key_Loosen[4][4]={{1,1,1,1},{1,1,1,1},{1,1,1,1},{1,1,1,1}};
Staret();
P2=0xff;
T0_Init();
        static unsigned char Num_Password2=0;
        unsigned char Num2,Num4,Num_Password3;
        static unsigned char Num_Password4=0;
        static unsigned char Num_Password1=0;
        static bit Num_Bit1=0;
        static bit Num_Bit2=0;
        unsigned char Num1;
        static unsigned char Num_Pa1=0;
        static unsigned char Num_Pa2=0;
        static unsigned char Num_Pa3=0;
        static unsigned char Num_Pa4=0;
        static unsigned char Num_Pa5=0;
        static unsigned char Num_Pa6=0;
        static unsigned char Num_Pa7=0;
        static unsigned char Num_Pa8=0;
        static unsigned char Num_Pa9=0;
        static unsigned char Num_Pa0=0;
        if(Num_Bit2==1)
                switch(Num_Password2)
                        case 1:if(Num_Password1==1){Num_Pa1++;}break;
                        case 2:if(Num_Password1==3){Num_Pa3++;}break;
                        case 3:if(Num_Password1==1){Num_Pa1++;}break;
                        case 4:if(Num_Password1==4){Num_Pa4++;}break;
                        case 5:if(Num_Password1==5){Num_Pa5++;}break;
                        case 6:if(Num_Password1==2){Num_Pa2++;}break;
                        case 7:if(Num_Password1==0){Num_Pa0++;}break;
                        default : break;
                Num_Bit2=0;
                while(Num_Pa1==2&Num_Pa2==1&Num_Pa3==1&Num_Pa4==1&Num_Pa5==1&Num_Pa0==1)
                unsigned char TV2[]={"    欢迎使用"};
                init_Lcd();
                 Num1=0;
                 Position_Lcd(2,0);
                         Num1++;
                while(1);
         if(Num_Password2==7)
                 unsigned char TV1[]={"              "};
                 unsigned char TV2[]={"密码错误 ^-^ "};
                 unsigned long ss;
                 Num1=0;
                 Position_Lcd(2,1);
                         Num1++;
                for(ss=50000;ss>0;ss--);
                 Num1=0;
                 Position_Lcd(2,1);
                         Num1++;
                 Num_Pa1=0;
                 Num_Pa2=0;
                 Num_Pa3=0;
                 Num_Pa4=0;
                 Num_Pa5=0;
                 Num_Pa6=0;
                 Num_Pa7=0;
                 Num_Pa8=0;
                 Num_Pa9=0;
                 Num_Pa0=0;
                 Num_Bit1=0;
                 Num_Password2=0;
        if(Num_Bit1==1)
                unsigned char TV1[]={"*"};
                Write_Instruction(0x0f);
                Num1=0;
                Position_Lcd(2,Num_Password2);
                         Num1++;
        for(Num4=0;Num4<4;Num4++)
                for(Num2=0;Num2<4;Num2++)
                        if(Key_Loosen[Num4][Num2]!=Key_Buff[Num4][Num2])
                                 if(Key_Loosen[Num4][Num2]==0)
                                         Num_Password1 = Num4*4+Num2;
                                         Num_Password2++;
                                         Num_Bit1=1;
                                         Num_Bit2=1;
                                Key_Loosen[Num4][Num2]=Key_Buff[Num4][Num2];
void InterruptTimer0() interrupt 1
unsigned char Num1;
static unsigned char Keys=0;
TH0 = 0xFC;
TL0 = 0x67;
Key_Buff[Keys][0]=(Key_Buff[Keys][0]<<1)|KEY_IN1;
Key_Buff[Keys][1]=(Key_Buff[Keys][1]<<1)|KEY_IN2;
Key_Buff[Keys][2]=(Key_Buff[Keys][2]<<1)|KEY_IN3;
Key_Buff[Keys][3]=(Key_Buff[Keys][3]<<1)|KEY_IN4;
        for(Num1=0;Num1<4;Num1++)
                 if((Key_Buff[Keys][Num1]&0x0f)==0x00)
                         Key_Buff[Keys][Num1]=0;
Keys++;
Keys=Keys&0x03;
switch(Keys)
        case 0:KEY_OUT4=1;KEY_OUT1=0;break;
        case 1:KEY_OUT1=1;KEY_OUT2=0;break;
        case 2:KEY_OUT2=1;KEY_OUT3=0;break;
        case 3:KEY_OUT3=1;KEY_OUT4=0;break;
ID:61484 发表于 2015-4-14 23:33 | 显示全部楼层
学习一下
ID:44267 发表于 2015-9-5 14:34 | 显示全部楼层
太强了,太强了,太强了,太强了,
ID:44267 发表于 2015-9-7 08:29 | 显示全部楼层
楼主有原理图嘛
ID:202591 发表于 2017-5-22 19:16 | 显示全部楼层
date是啥东西呀
