楼主: 13142128573
用24C04与单片机设计电子密码锁 程序+Protues仿真 1602LCD显示
ID:84768 发表于 2015-7-4 17:44 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
进来请看
单片机程序与仿真文件下载: 用24C04与1602LCD设计电子密码锁.zip (26.03 KB, 下载次数: 180)
以下是源程序预览:
  1. //-----------------------------------------------------------------
  2. //原始程序中相邻两位密码不能相同.
  3. //本压缩包中的HEX由修改后的新程序编译生成,允许输入任意密码.
  4. //-----------------------------------------------------------------
  5. //实训100例中本例内的main函数可用以下代码替换.
  6. //改动的主要是main函数中while循环内的代码.
  7. //-----------------------------------------------------------------
  8. // 主程序
  9. //-----------------------------------------------------------------
  10. void main()
  11. {
  12.    uchar i = 0;
  13.    uchar IIC_Password[10];
  14.    uchar IS_Valid_User = 0;
  15.    P0 = 0xFF;
  16.    P1 = 0xFF;
  17.    P2 = 0xFF;
  18.    TMOD = 0x02;                     //T0设置为8位自动重装模式
  19.    TH0 = 175;
  20.    TL0 = 175;
  21.    TR0 = 1;                         //启动T0
  22.    DelayMS(10);
  23.    LCD_Init();                      //初始化LCD
  24.
  25.    IIC_24C04_Init();                //初始化24C04
  26.
  27.    Display_String(Title_Text,0x00); //在第1行显示标题
  28.
  29.    //24C04的内容已由初始化BIN文件导入
  30.    //将24C04中预先写入的密码读入pass
  31.    RecString(0xa0, 0 , IIC_Password, 6);
  32.    IIC_Password[6] = '\0';
  33.    while(1)
  34.    {
  35.       P1 = 0xF0;
  36.       if(P1 != 0xF0) KeyNo = Keys_Scan();  //扫描键盘获取键序号KeyNo
  37.       switch ( KeyNo )
  38.       {
  39.            case 0:  case 1: case 2: case 3: case 4:
  40.            case 5:  case 6: case 7: case 8: case 9:
  41.
  42.                    if ( i<= 5 )             //密码限制在6位以内
  43.                    {
  44.                         //如果i为0则执行一次清屏
  45.                         if (i ==0) Display_String("                ",0x40);
  46.
  47.                         UserPassword[i] = KeyNo + '0';
  48.                         UserPassword[i+1] = '\0';
  49.
  50.                         DSY_BUFFER[i] = '*';
  51.                         DSY_BUFFER[i+1] = '\0';
  52.
  53.                         Display_String(DSY_BUFFER,0x40);
  54.
  55.                         i++;
  56.                     }
  57.                     break;
  58.
  59.            case 10: //按A键开锁
  60.                     if (strcmp(UserPassword,IIC_Password) == 0)
  61.                     {
  62.                        LED_OPEN = 0;  //点亮LED
  63.                        Clear_Password();
  64.                        Display_String("Unlock OK!      ",0x40);
  65.                        IS_Valid_User = 1;
  66.                     }
  67.                     else
  68.                     {
  69.                        LED_OPEN =1;   //关闭LED
  70.                        Clear_Password();
  71.                        Display_String("ERROR !         ",0x40);
  72.                        IS_Valid_User = 0;
  73.                     }
  74.                     i = 0;
  75.                     break;
  76.
  77.            case 11: //按B键上锁
  78.                     LED_OPEN =1;
  79.                     Clear_Password();
  80.                     Display_String(Title_Text,0x00);
  81.                     Display_String("                ",0x40);
  82.                     i = 0;
  83.                     IS_Valid_User = 0;
  84.                     break;
  85.
  86.            case 12: //按C键设置新密码
  87.                     //如果是合法用户则提示输入新密码
  88.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  89.                     else
  90.                     {
  91.                        i = 0;
  92.                        Display_String("New Password:   ",0x00);
  93.                        Display_String("                ",0x40);
  94.                      }
  95.
  96.                     break;
  97.
  98.            case 13: //按D键保存新密码
  99.                     if ( !IS_Valid_User ) Display_String("No rights !",0x40);
  100.                     else
  101.                     {
  102.                        SendString(0xa0, 0 , UserPassword, 6);
  103.
  104.                        //重新读入刚写的密码
  105.                        RecString(0xa0, 0 , IIC_Password, 6);
  106.                        IIC_Password[6] = '\0';
  107.
  108.                        i = 0;
  109.                        Display_String(Title_Text,0x00);
  110.                        Display_String("Password Saved! ",0x40);
  111.                      }
  112.
  113.                     break;
  114.
  115.            case 14: //按E键消除所有输入
  116.                     i = 0;
  117.                     Clear_Password();
  118.                     Display_String("                ",0x40);
  119.        }
  120.        Beep();
  121.        DelayMS(100);
  122.        P1= 0xF0;
  123.        while (P1 != 0xF0);    //如果有键未释放则等待
  124.        while (P1 == 0xF0);    //如果没有再次按下按键则等待
  125.    }
  126. }
参与人数 2黑币 +55 收起 理由
tieq1952 + 5 赞一个!
admin + 50 共享资料的积分奖励!
收藏收藏2 分享淘帖 顶 踩
ID:84777 发表于 2015-7-4 21:27 | 只看该作者
厉害,,,51黑有你更精彩!!
ID:86064 发表于 2015-7-18 20:01 | 只看该作者
厉害,,,,太棒了
ID:86086 发表于 2015-7-18 22:01 | 只看该作者
看看思路希望能得到一些灵感,谢谢分享
ID:70839 发表于 2015-8-11 18:25 | 只看该作者
支持楼主,很不错,学习参考下
ID:76840 发表于 2015-8-12 12:28 | 只看该作者
怎么修改的密码是错误的,不能保存进去?
ID:84033 发表于 2015-8-27 22:18 | 只看该作者
电子密码锁在今后还是有更大 的发展空间的
ID:79615 发表于 2015-8-28 22:06 来自触屏版 | 只看该作者
很好的东西!!!!
ID:89999 发表于 2015-9-13 11:51 | 只看该作者
感谢分享
ID:44267 发表于 2015-9-18 11:12 | 只看该作者
太强了
ID:83138 发表于 2015-9-18 21:32 | 只看该作者
51Hei(51黑)论坛有你更精彩
ID:73691 发表于 2015-9-25 07:23 | 只看该作者
真的很不错
ID:44267 发表于 2015-9-25 08:09 | 只看该作者
强强强强强强强强强强强强强强强
ID:90789 发表于 2015-10-5 15:43 来自触屏版 | 只看该作者
ludaijin 发表于 2015-9-18 11:12
太强了
求两个按键输入的电子密码锁
ID:91448 发表于 2015-10-7 00:32 来自触屏版 | 只看该作者
太强啦,学习~
ID:97070 发表于 2015-11-25 18:11 | 只看该作者
值得来围观,请问有仿真和程序吗?
ID:97070 发表于 2015-11-25 18:24 | 只看该作者
居然不公开程序,有点失望
ID:98132 发表于 2015-12-5 17:22 | 只看该作者
这个程序有源代码吗
ID:98832 发表于 2015-12-10 15:10 | 只看该作者
有源代码吗?急需啊
ID:98832 发表于 2015-12-10 18:54 | 只看该作者
有没有源代码啊
ID:99459 发表于 2015-12-12 18:55 | 只看该作者
有没有不用24c04的?
ID:44267 发表于 2015-12-22 16:32 | 只看该作者
楼上有朋友做出来了嘛
ID:120850 发表于 2016-5-15 22:14 | 只看该作者
程序是不是有错》?除了头文件之外还缺点什么?
ID:157011 发表于 2016-12-23 16:17 | 只看该作者
有源代码吗?我编译的时候出现了错误
ID:89286 发表于 2016-12-25 09:24 | 只看该作者
thanks for sharing
ID:183867 发表于 2017-3-27 16:44 | 只看该作者
尤源代码吗
ID:159521 发表于 2017-3-27 17:39 | 只看该作者
很不错,正在学习
ID:244527 发表于 2017-10-31 13:23 | 只看该作者
楼主,不用总线怎么写啊
ID:245820 发表于 2017-11-3 21:33 | 只看该作者
非常不错
ID:144383 发表于 2017-12-6 17:30 来自触屏版 | 只看该作者
不错学习一下
ID:257027 发表于 2017-12-6 20:39 | 只看该作者
支持楼主,很不错,学习参考下
ID:259267 发表于 2017-12-11 15:40 | 只看该作者
厉害,,,51黑有你更精彩!!
ID:253767 发表于 2017-12-11 17:42 | 只看该作者
好东西,学习了
ID:287564 发表于 2018-3-13 10:46 | 只看该作者
厉害,,,51黑有你更精彩!!
ID:110278 发表于 2018-3-13 20:55 | 只看该作者
非常好,学习了。
ID:294933 发表于 2018-3-21 22:53 | 只看该作者
实训想做这个   谢谢大佬的分享  对于我这种小白很有用  拿走了  就是有点贵啊  这个  伤心
ID:236699 发表于 2018-3-22 08:09 | 只看该作者
感谢分享
ID:294933 发表于 2018-3-22 09:09 | 只看该作者
大佬这个编译了为什么会有错啊  解释下呗   小白一个不知道什么意思
ID:294933 发表于 2018-3-22 10:04 | 只看该作者
看不懂啊 大佬指点下  说明意思  头文件一直报错
