查看: 2828|回复: 0
请教一下如何在时钟加一个可以定时的闹钟程序
file:///C:/Users/ADMINI~1/AppData/Local/Temp/snap_screen_20161214161252.png
#include <AT89X51.H>
unsigned char code dispcode[]={0x3f,0x06,0x5b,0x4f,
                               0x66,0x6d,0x7d,0x07,
                               0x7f,0x6f,0x77,0x7c,
                               0x39,0x5e,0x79,0x71,0x00};
unsigned char dispbitcode[]={0xfe,0xfd,0xfb,0xf7,
                             0xef,0xdf,0xbf,0x7f};
unsigned char dispbuf[8]={0,0,16,0,0,16,2,1};
unsigned char dispbitcnt;
unsigned char second;
unsigned char minite;
unsigned char hour;
unsigned int tcnt;
unsigned char mstcnt;
unsigned char i,j;
void main(void)
  TMOD=0x02;
  TH0=0x06;
  TL0=0x06;
  TR0=1;
  ET0=1;
  EA=1;
  hour=12;
      if(P0_0==0)
          for(i=5;i>0;i--)
          for(j=248;j>0;j--);
          if(P0_0==0)
              second++;
              if(second==60)
                  second=0;
              dispbuf[0]=second%10;
              dispbuf[1]=second/10;
              while(P0_0==0);
      if(P0_1==0)
          for(i=5;i>0;i--)
          for(j=248;j>0;j--);
          if(P0_1==0)
              minite++;
              if(minite==60)
                  minite=0;
              dispbuf[3]=minite%10;
              dispbuf[4]=minite/10;
              while(P0_1==0);
      if(P0_2==0)
          for(i=5;i>0;i--)
          for(j=248;j>0;j--);
          if(P0_2==0)
              hour++;
              if(hour==24)
                  hour=0;
              dispbuf[6]=hour%10;
              dispbuf[7]=hour/10;
              while(P0_2==0);
void t0(void) interrupt 1 using 0
  mstcnt++;
  if(mstcnt==8)
      mstcnt=0;
      P3=0xff;      //关闭所有显示
      P1=dispcode[dispbuf[dispbitcnt]];
      P3=dispbitcode[dispbitcnt];
      dispbitcnt++;
      if(dispbitcnt==8)
          dispbitcnt=0;
  tcnt++;
  if(tcnt==4000)
      tcnt=0;
      second++;
      if(second==60)
          second=0;
          minite++;
          if(minite==60)
              minite=0;
              hour++;
              if(hour==24)
                  hour=0;
      dispbuf[6]=hour%10;
      dispbuf[7]=hour/10;
