查看: 9883|回复: 13
蓝牙密码锁 单片机源代码
ID:189829 发表于 2017-4-15 15:02 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1.    //包含头文件
  2. #include <REG52.h>
  3. #include<intrins.h>
  4. //宏定义
  5. #define LCM_Data  P0                  //将P0口定义为LCM_Data
  6. #define uchar unsigned char
  7. #define uint  unsigned int
  8. #define w 6                                //定义密码位数
  9. //1602的控制脚
  10. sbit lcd1602_rs=P2^7;
  11. sbit lcd1602_rw=P2^6;
  12. sbit lcd1602_en=P2^5;
  13. sbit Scl=P3^4;                        //24C02串行时钟
  14. sbit Sda=P3^5;                        //24C02串行数据
  15. sbit ALAM = P2^1;                //报警
  16. sbit KEY = P3^6;                //开锁
  17. bit  operation=0;                //操作标志位
  18. bit  pass=0;                        //密码正确标志
  19. bit  ReInputEn=0;                //重置输入允许标志
  20. bit  s3_keydown=0;                //3秒按键标志位
  21. bit  key_disable=0;                //锁定键盘标志
  22. bit  flag_REC =0;       //串口接受标志位
  23. unsigned char buff[5]=0;
  24. unsigned char countt0,second;        //t0中断计数器,秒计数器
  25. void Delay5Ms(void);                //声明延时函数
  26. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};                                 //控盘扫描控制表
  27. //液晶显示数据数组
  28. unsigned char code start_line[]        = {"password:       "};
  29. unsigned char code name[]                  = { "===Coded Lock==="};        //显示名称
  30. unsigned char code Correct[]         = {"     correct    "};                //输入正确
  31. unsigned char code Error[]           = {"      error     "};          //输入错误
  32. unsigned char code codepass[]        = {"      pass      "};
  33. unsigned char code LockOpen[]        = {"      open      "};                //OPEN
  34. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  35. unsigned char code Input[]           = {"input:          "};                //INPUT
  36. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  37. unsigned char code initword[]        = {"Init password..."};
  38. unsigned char code Er_try[]                = {"error,try again!"};
  39. unsigned char code again[]                = {"input again     "};
  40. unsigned char InputData[16];        //输入密码暂存区
  41. unsigned char CurrentPassword[16]={1,3,1,4,2,0};                         //管理员密码(只可在程序中修改)
  42. unsigned char TempPassword[16];
  43. unsigned char N=0,M=0,flag=0;                                //密码输入位数记数
  44. unsigned char ErrorCont;                        //错误次数计数
  45. unsigned char CorrectCont;                        //正确输入计数
  46. unsigned char ReInputCont;                         //重新输入计数
  47. unsigned char code initpassword[16]={0,0,0,0,0,0};                        //输入管理员密码后将密码初始为000000
  48. unsigned char  MM[2]={0,0};
  49. //=====================5ms延时==============================
  50. void Delay5Ms(void)
  51. {
  52.         unsigned int TempCyc = 5552;
  53.         while(TempCyc--);
  54. }
  55. //===================400ms延时==============================
  56. void Delay400Ms(void)
  57. {
  58. unsigned char TempCycA = 5;
  59. unsigned int TempCycB;
  60. while(TempCycA--)
  61. {
  62.   TempCycB=7269;
  63.   while(TempCycB--);
  64. }
  65. }
  66. //=============================================================================================
  67. //================================24C02========================================================
  68. //=============================================================================================
  69. void mDelay(uint t) //延时
  70. {
  71.         uchar i;
  72.            while(t--)
  73.            {
  74.                    for(i=0;i<125;i++)
  75.                    {;}
  76.            }
  77. }
  78. void Nop(void)                  //空操作
  79. {
  80.          _nop_();                  //仅作延时用一条语句大约1us
  81.          _nop_();
  82.          _nop_();
  83.          _nop_();
  84. }
  85. /*****24c02程序参照24c02时序图*****/
  86. /*起始条件*/
  87. void Start(void)
  88. {
  89.          Sda=1;
  90.          Scl=1;
  91.          Nop();
  92.          Sda=0;
  93.          Nop();
  94. }
  95. /*停止条件*/
  96. void Stop(void)
  97. {
  98.          Sda=0;
  99.          Scl=1;
  100.          Nop();
  101.          Sda=1;
  102.          Nop();
  103. }
  104. /*应答位*/
  105. void Ack(void)
  106. {
  107.         Sda=0;
  108.         Nop();
  109.         Scl=1;
  110.         Nop();
  111.         Scl=0;
  112. }
  113. /*反向应答位*/
  114. void NoAck(void)
  115. {
  116.          Sda=1;
  117.          Nop();
  118.          Scl=1;
  119.          Nop();
  120.          Scl=0;
  121. }
  122. /*发送数据子程序,Data为要求发送的数据*/
  123. void Send(uchar Data)
  124. {
  125.            uchar BitCounter=8;
  126.            uchar temp;
  127.            do
  128.            {
  129.                    temp=Data;                                           //将待发送数据暂存temp
  130.                    Scl=0;
  131.                    Nop();
  132.                    if((temp&0x80)==0x80)                   //将读到的数据&0x80
  133.                    Sda=1;
  134.                    else
  135.                    Sda=0;
  136.                    Scl=1;
  137.                    temp=Data<<1;                                   //数据左移
  138.                    Data=temp;                                           //数据左移后重新赋值Data
  139.                    BitCounter--;                                   //该变量减到0时,数据也就传送完成了
  140.            }
  141.            while(BitCounter);                                   //判断是否传送完成
  142.            Scl=0;
  143. }
  144. /*读一字节的数据,并返回该字节值*/
  145. uchar Read(void)
  146. {
  147.     uchar temp=0;
  148.         uchar temp1=0;
  149.         uchar BitCounter=8;
  150.         Sda=1;
  151.         do
  152.         {
  153.                 Scl=0;
  154.                 Nop();
  155.                 Scl=1;
  156.                 Nop();
  157.                 if(Sda)                                   //数据位是否为1
  158.                         temp=temp|0x01;           //为1 temp的最低位为1(|0x01,就是将最低位变为1)
  159.                 else                                   //如果为0
  160.                         temp=temp&0xfe;           //temp最低位为0(&0xfe(11111110)最低位就是0)
  161.                 if(BitCounter-1)           //BitCounter减1后是否为真
  162.                 {
  163.                         temp1=temp<<1;           //temp左移
  164.                         temp=temp1;
  165.                 }
  166.                 BitCounter--;                   //BitCounter减到0时,数据就接收完了
  167.         }
  168.         while(BitCounter);                   //判断是否接收完成
  169.         return(temp);
  170. }
  171. void WrToROM(uchar Data[],uchar Address,uchar Num)
  172. {
  173.   uchar i;
  174.   uchar *PData;
  175.   PData=Data;
  176.   for(i=0;i<Num;i++)
  177.   {
  178.   Start();
  179.   Send(0xa0);
  180.   Ack();
  181.   Send(Address+i);
  182.   Ack();
  183.   Send(*(PData+i));
  184.   Ack();
  185.   Stop();
  186.   mDelay(20);
  187.   }
  188. }
  189. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  190. {
  191.   uchar i;
  192.   uchar *PData;
  193.   PData=Data;
  194.   for(i=0;i<Num;i++)
  195.   {
  196.   Start();
  197.   Send(0xa0);
  198.   Ack();
  199.   Send(Address+i);
  200.   Ack();
  201.   Start();
  202.   Send(0xa1);
  203.   Ack();
  204.   *(PData+i)=Read();
  205.   Scl=0;
  206.   NoAck();
  207.   Stop();
  208.   }
  209. }
  210. //==================================================================================================
  211. //=======================================LCD1602====================================================
  212. //==================================================================================================
  213. #define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
  214. #define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
  215. //----------------延时函数,后面经常调用----------------------
  216. void delay(uint xms)//延时函数,有参函数
  217. {
  218.         uint x,y;
  219.         for(x=xms;x>0;x--)
  220.          for(y=110;y>0;y--);
  221. }
  222. //--------------------------写指令---------------------------
  223. void write_1602com(uchar com)//****液晶写入指令函数****
  224. {
  225.         lcd1602_rs=0;//数据/指令选择置为指令
  226.         lcd1602_rw=0; //读写选择置为写
  227.         P0=com;//送入数据
  228.         delay(1);
  229.         lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
  230.         delay(1);
  231.         lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
  232. }
  233. //-------------------------写数据-----------------------------
  234. void write_1602dat(uchar dat)//***液晶写入数据函数****
  235. {
  236.         lcd1602_rs=1;//数据/指令选择置为数据
  237.         lcd1602_rw=0; //读写选择置为写
  238.         P0=dat;//送入数据
  239.         delay(1);
  240.         lcd1602_en=1; //en置高电平,为制造下降沿做准备
  241.         delay(1);
  242.         lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
  243. }
  244. //-------------------------初始化-------------------------
  245. void lcd_init(void)
  246. {
  247.         write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
  248.         write_1602com(0x0c);//开显示不显示光标
  249.         write_1602com(0x06);//整屏不移动,光标自动右移
  250.         write_1602com(0x01);//清显示
  251. }
  252. //========================================================================================
  253. //=========================================================================================
  254. //==============将按键值编码为数值=========================
  255. unsigned char coding(unsigned char m)
  256. {
  257.         unsigned char k;
  258.
  259.         switch(m)
  260.         {
  261.                 case (0x11): k=1;break;
  262.                 case (0x21): k=2;break;
  263.                 case (0x41): k=3;break;
  264.                 case (0x81): k='A';break;
  265.                 case (0x12): k=4;break;
  266.                 case (0x22): k=5;break;
  267.                 case (0x42): k=6;break;
  268.                 case (0x82): k='B';break;
  269.                 case (0x14): k=7;break;
  270.                 case (0x24): k=8;break;
  271.                 case (0x44): k=9;break;
  272.                 case (0x84): k='C';break;
  273.                 case (0x18): k='*';break;
  274.                 case (0x28): k=0;break;
  275.                 case (0x48): k='#';break;
  276.                 case (0x88): k='D';break;
  277.         }
  278.         return(k);
  279. }
  280. //=====================按键检测并返回按键值===============================
  281. unsigned char keynum(void)
  282. {
  283.          unsigned char row,col,i;
  284.          if(flag_REC==1)                                    //
  285.          {
  286.                  flag_REC=0;
  287.                 if(buff[0]=='O'&&buff[1]=='N')        //第一个字节为O,第二个字节为N,第三个字节为控制码
  288.                     switch(buff[2])
  289.                 {
  290.
  291.                       case '1' :
  292.                            return(0x11);
  293.                           break;
  294.                       case '2':
  295.                            return(0x21);
  296.                           break;
  297.                       case '3':
  298.                             return(0x41);
  299.                           break;
  300.                       case '4':
  301.                             return(0x12);
  302.                           break;
  303.                           case '5':
  304.                             return(0x22);
  305.                           break;
  306.                           case '6':
  307.                             return(0x42);
  308.                           break;
  309.                           case '7':
  310.                             return(0x14);
  311.                           break;
  312.                           case '8':
  313.                             return(0x24);
  314.                           break;
  315.                           case '9':
  316.                             return(0x44);
  317.                           break;
  318.                           case 'A':
  319.                             return(0x84);
  320.                           break;
  321.                           case 'B':
  322.                             return(0x18);
  323.                           break;
  324.                           case 'C':
  325.                             return(0x48);
  326.                           break;
  327.                           case 'D':
  328.                             return(0x88);
  329.                           break;
  330.                            case 'E':
  331.                             return(0x28);
  332.                           break;
  333.
  334.                   }
  335.           }
  336.                    P1=0xf0;
  337.          if((P1&0xf0)!=0xf0)
  338.          {
  339.                    Delay5Ms();
  340.         Delay5Ms();
  341.                    if((P1&0xf0)!=0xf0)
  342.                 {
  343.                     row=P1^0xf0;          //确定行线
  344.                         i=0;
  345.                         P1=a[i];                  //精确定位
  346.                         while(i<4)
  347.                         {
  348.                                  if((P1&0xf0)!=0xf0)
  349.                                   {
  350.                                            col=~(P1&0xff);          //确定列线
  351.                                            break;            //已定位后提前退出
  352.                                   }
  353.                                 else
  354.                                   {
  355.                                            i++;
  356.                                            P1=a[i];
  357.                                   }
  358.                         }
  359.                 }
  360.                 else
  361.                 {
  362.                         return 0;
  363.                 }
  364.
  365.                 while((P1&0xf0)!=0xf0);
  366.                 return (row|col);                         //行线与列线组合后返回
  367.          }
  368.          else return 0;                                 //无键按下时返回0
  369. }
  370. //=======================一声提示音,表示有效输入========================
  371. void OneAlam(void)
  372. {
  373.         ALAM=0;
  374.         Delay5Ms();
  375.     ALAM=1;
  376. }
  377. //========================二声提示音,表示操作成功========================
  378. void TwoAlam(void)
  379. {
  380.         ALAM=0;
  381.         Delay5Ms();
  382.     ALAM=1;
  383.     Delay5Ms();
  384.         ALAM=0;
  385.         Delay5Ms();
  386.     ALAM=1;
  387. }
  388. //========================三声提示音,表示错误========================
  389. void ThreeAlam(void)
  390. {
  391.         ALAM=0;
  392.         Delay5Ms();
  393.     ALAM=1;
  394.     Delay5Ms();
  395.         ALAM=0;
  396.         Delay5Ms();
  397.     ALAM=1;
  398.     Delay5Ms();
  399.         ALAM=0;
  400.         Delay5Ms();
  401.     ALAM=1;
  402. }
  403. //=====================显示输入的N个数字,用H代替以便隐藏============================
  404. //=======================显示提示输入=========================
  405. void DisplayChar(void)
  406. {
  407.         unsigned char i;
  408.         if(pass==1)
  409.         {
  410.                 //DisplayListChar(0,1,LockOpen);
  411.                 write_1602com(er);                                   //在二行开始显示
  412.                 for(i=0;i<16;i++)
  413.                 {
  414.                         write_1602dat(LockOpen[i]);           //显示open 开锁成功
  415.                 }
  416.         }
  417.         else
  418.         {
  419.                 if(N==0)
  420.                 {
  421.                         //DisplayListChar(0,1,Error);
  422.                         write_1602com(er);
  423.                         for(i=0;i<16;i++)
  424.                         {
  425.                                 write_1602dat(Error[i]);        //显示错误
  426.                         }
  427.                 }
  428.                 else
  429.                 {
  430.                         //DisplayListChar(0,1,start_line);
  431.                         write_1602com(er);
  432.                         for(i=0;i<16;i++)
  433.                         {
  434.                                 write_1602dat(start_line[i]);//显示开始输入
  435.                         }
  436.                 }
  437.         }
  438. }
  439. //========================重置密码==================================================
  440. //==================================================================================
  441. void ResetPassword(void)
  442. {
  443.         unsigned char i;
  444.         unsigned char j;
  445.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  446.         for(i=0;i<16;i++)
  447.         {
  448.                 write_1602dat(name[i]);//向液晶屏写开机画面
  449.         }
  450.         if(pass==0)
  451.         {
  452.                 pass=0;
  453.                 DisplayChar();           //显示错误
  454.                 ThreeAlam();           //没开锁时按下重置密码报警3声
  455.         }
  456.         else                                   //开锁状态下才能进行密码重置程序
  457.         {
  458.             if(ReInputEn==1)   //开锁状态下,ReInputEn置1,重置密码允许
  459.                 {
  460.                         if(N==M)           //输入6位密码
  461.                         {
  462.                                 ReInputCont++;                        //密码次数计数
  463.                                 if(ReInputCont==2)                //输入两次密码
  464.                                 {
  465.                                         for(i=0;i<M;)
  466.                                         {
  467.                                                 if(TempPassword[i]==InputData[i])        //将两次输入的新密码作对比
  468.                                                         i++;
  469.                                                 else        //如果两次的密码不同
  470.                                                 {
  471.                                                         //DisplayListChar(0,1,Error);
  472.                                                         write_1602com(er);
  473.                                                         for(j=0;j<16;j++)
  474.                                                         {
  475.        write_1602dat(Error[j]);        //显示错误Error
  476.                                                         }
  477.                                                         ThreeAlam();                        //错误提示
  478.                                                         pass=0;                                        //关锁
  479.                                                         ReInputEn=0;                        //关闭重置功能,
  480.                                                         ReInputCont=0;
  481.                                                         DisplayChar();
  482.                                                         break;
  483.                                                 }
  484.                                         }
  485.                                         if(i==M)
  486.                                         {
  487.                                                 //DisplayListChar(0,1,ResetOK);
  488.                                                 write_1602com(er);
  489.                                                 for(j=0;j<16;j++)
  490.                                                 {
  491.                                                         write_1602dat(ResetOK[j]);          //密码修改成功,显示
  492.                                                 }
  493.                                                 TwoAlam();                                //操作成功提示
  494.                                                 MM[0]=M;
  495.                                                  WrToROM(TempPassword,0,M);                //将新密码写入24C02存储
  496.                                                 WrToROM(MM,17,1);
  497.                                                 ReInputEn=0;
  498.                                         }
  499.                                         ReInputCont=0;
  500.                                         CorrectCont=0;
  501.                                 }
  502.                                 else                                          //输入一次密码时
  503.                                 {
  504.                                         OneAlam();
  505.                                         //DisplayListChar(0, 1, again);                 //显示再次输入一次
  506.                                         write_1602com(er);
  507.                                         for(j=0;j<16;j++)
  508.                                         {
  509.                                                 write_1602dat(again[j]);                        //显示再输入一次
  510.                                         }
  511.                                         for(i=0;i<M;i++)
  512.                                         {
  513.                                                 TempPassword[i]=InputData[i];                //将第一次输入的数据暂存起来
  514.                                         }
  515.                                 }
  516.                         N=0;                                                //输入数据位数计数器清零
  517.                    }
  518.             }
  519.         }
  520. }
  521. //=======================输入密码错误超过三过,报警并锁死键盘======================
  522. void Alam_KeyUnable(void)
  523. {
  524.         P1=0x00;
  525.         {
  526.                 ALAM=~ALAM;                                 //蜂鸣器一直闪烁鸣响
  527.                 Delay5Ms();
  528.         }
  529. }
  530. //=======================取消所有操作============================================
  531. void Cancel(void)
  532. {
  533.         unsigned char i;
  534.         unsigned char j;
  535.         //DisplayListChar(0, 1, start_line);
  536.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  537.         for(i=0;i<16;i++)
  538.         {
  539.                 write_1602dat(name[i]);//向液晶屏写开机画面
  540.         }
  541.         write_1602com(er);
  542.         for(j=0;j<16;j++)
  543.         {
  544.                 write_1602dat(start_line[j]);          //显示开机输入密码界面
  545.         }
  546.         TwoAlam();                                //提示音
  547.         for(i=0;i<6;i++)
  548.         {
  549.                 InputData[i]=0;                //将输入密码清零
  550.         }
  551.         KEY=1;                                        //关闭锁
  552.         ALAM=1;                                        //报警关
  553.         operation=0;                        //操作标志位清零
  554.         pass=0;                                        //密码正确标志清零
  555.         ReInputEn=0;                        //重置输入充许标志清零
  556.         ErrorCont=0;                        //密码错误输入次数清零
  557.         CorrectCont=0;                        //密码正确输入次数清零
  558.         ReInputCont=0;                        //重置密码输入次数清零
  559.         s3_keydown=0;
  560.         key_disable=0;                        //锁定键盘标志清零
  561.         N=0;                                        //输入位数计数器清零
  562. }
  563. //==========================确认键,并通过相应标志位执行相应功能===============================
  564. void Ensure(void)
  565. {
  566.         unsigned char i,j,k;
  567.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  568.         for(i=0;i<16;i++)
  569.         {
  570.                 write_1602dat(name[i]);//向液晶屏写开机画面
  571.         }
  572.         RdFromROM(MM,17,1);
  573.         M=MM[0];
  574.         if(M==0)
  575.         M=6;
  576.         RdFromROM(CurrentPassword,0,M);                                         //从24C02里读出存储密码
  577.         if(N==6)
  578.         {
  579.                     if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
  580.                                    {
  581.                                      flag=1;
  582.                                     MM[0]=6;
  583.                                     WrToROM(MM,17,1);
  584.                                         WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
  585.                                         //DisplayListChar(0,1,initword);                        //显示初始化密码
  586.                                         write_1602com(er);
  587.                                         for(j=0;j<16;j++)
  588.                                         {
  589.                                                 write_1602dat(initword[j]);                                //显示初始化密码
  590.                                         }
  591.                                         TwoAlam();        //成功提示音
  592.                                         Delay400Ms();        //延时400ms
  593.                                         TwoAlam();        //成功提示音
  594.                                         N=0;        //输入位数计数器清零
  595.                                 }
  596.                          else
  597.                             flag=0;
  598.
  599.         }
  600.                 if(N>M&&flag!=1)
  601.         {
  602.
  603.                 for(i=0;i<16;i++)
  604.                 {
  605.                    for(j=0;j<M;j++)
  606.                  {  if(InputData[i+j]==CurrentPassword[j])
  607.                     k=1;
  608.
  609.                     else
  610.
  611.                         k=0;
  612.                 if(k==0)
  613.                 break;
  614.
  615.                 }
  616.                 if(k==1)
  617.                 break;
  618.                 }
  619.                 if(k==1)
  620.                 {
  621.                         CorrectCont++;                                        //输入正确变量++
  622.
  623.                                 if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁
  624.                                 {
  625.                                         //DisplayListChar(0,1,LockOpen);
  626.                                         write_1602com(er);
  627.                                         for(j=0;j<16;j++)
  628.                                         {
  629.                                                 write_1602dat(LockOpen[j]);                  //显示open开锁画面
  630.                                         }
  631.                                         TwoAlam();                        //操作成功提示音
  632.                                         KEY=0;        //开锁
  633.                                         pass=1;        //置正确标志位
  634.                                         TR0=1;        //开启定时
  635.
  636.                                         for(j=0;j<16;j++)        //将输入清除
  637.                                         {
  638.                                                 InputData[j]=j;        //开锁后将输入位清零
  639.                                         }
  640.                                 }
  641.                                 else        //当两次正确输入时,开启重置密码功能
  642.                                 {
  643.                                         //DisplayListChar(0,1,SetNew);
  644.                                         write_1602com(er);
  645.                                         for(j=0;j<16;j++)
  646.                                         {
  647.                                                 write_1602dat(SetNew[j]);                                        //显示重置密码界面
  648.                                         }
  649.                                         TwoAlam();        //操作成功提示
  650.                                         ReInputEn=1;        //允许重置密码输入
  651.                                         CorrectCont=0;        //正确计数器清零
  652.                                 }
  653.                 }
  654.
  655.             if(k==0)
  656.                  {
  657.                                         ErrorCont++;                                                //错误次数++
  658.                                                 write_1602com(er);
  659.                                                 for(i=0;i<16;i++)
  660.                                                 {
  661.                                                         write_1602dat(Error[i]);
  662.                                                 }
  663.                                         if(ErrorCont==3)                        //错误输入计数达三次时,报警并锁定键盘
  664.                                         {
  665.                                                 write_1602com(er);
  666.                                                 for(i=0;i<16;i++)
  667.                                                 {
  668.                                                         write_1602dat(Error[i]);
  669.                                                 }
  670.                                                 do
  671.                                                 Alam_KeyUnable();
  672.                                                 while(1);
  673.                                         }
  674.                                         else                                         //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
  675.                                         {
  676.                                                 TR0=1;                                //开启定时
  677.                                                 key_disable=1;                        //锁定键盘
  678.                                                 pass=0;                                        //pass位清零
  679.
  680.                                         }
  681.               }
  682.                   k=0;N=0;
  683.         }
  684.     if(N==M&&N!=0)
  685.         {
  686.             if(ReInputEn==0)                                                        //重置密码功能未开启
  687.                 {
  688.                         for(i=0;i<M;)
  689.                            {
  690.                                 if(CurrentPassword[i]==InputData[i])        //判断输入密码和24c02中的密码是否相同
  691.                                 {
  692.                                         i++;        //相同一位 i就+1
  693.                                 }
  694.                                 else        //如果有密码不同
  695.                                 {
  696.                                         ErrorCont++;                                                //错误次数++
  697.                                         if(ErrorCont==3)                        //错误输入计数达三次时,报警并锁定键盘
  698.                                         {
  699.                                                 write_1602com(er);
  700.                                                 for(i=0;i<16;i++)
  701.                                                 {
  702.                                                         write_1602dat(Error[i]);
  703.                                                 }
  704.                                                 do
  705.                                                 Alam_KeyUnable();
  706.                                                 while(1);
  707.                                         }
  708.                                         else                                         //错误次数小于3次时,锁死键盘3秒,然后重新可以输入
  709.                                         {
  710.                                                 write_1602com(er);
  711.                                                 for(i=0;i<16;i++)
  712.                                                 {
  713.                                                         write_1602dat(Error[i]);
  714.                                                 }
  715.                                                 TR0=1;                                //开启定时
  716.                                                 key_disable=1;                        //锁定键盘
  717.                                                 pass=0;                                        //pass位清零
  718.                                                 break;                                        //跳出
  719.                                         }
  720.                                 }
  721.                         }
  722.                         if(i==M)                                         //密码输入对时
  723.                         {
  724.                                 CorrectCont++;                                        //输入正确变量++
  725.                                 if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁
  726.                                 {
  727.                                         //DisplayListChar(0,1,LockOpen);
  728.                                         write_1602com(er);
  729.                                         for(j=0;j<16;j++)
  730.                                         {
  731.                                                 write_1602dat(LockOpen[j]);                  //显示open开锁画面
  732.                                         }
  733.                                         TwoAlam();                        //操作成功提示音
  734.                                         KEY=0;        //开锁
  735.                                         pass=1;        //置正确标志位
  736.                                         TR0=1;        //开启定时
  737.
  738.                                         for(j=0;j<M;j++)        //将输入清除
  739.                                         {
  740.                                                 InputData[i]=0;        //开锁后将输入位清零
  741.                                         }
  742.                                 }
  743.                                 else        //当两次正确输入时,开启重置密码功能
  744.                                 {
  745.                                         //DisplayListChar(0,1,SetNew);
  746.                                         write_1602com(er);
  747.                                         for(j=0;j<16;j++)
  748.                                         {
  749.                                                 write_1602dat(SetNew[j]);                                        //显示重置密码界面
  750.                                         }
  751.                                         TwoAlam();        //操作成功提示
  752.                                         ReInputEn=1;        //允许重置密码输入
  753.                                         CorrectCont=0;        //正确计数器清零
  754.                                 }
  755.                           }
  756.
  757.                         else                        //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
  758.                         {
  759.
  760.                         }
  761.                 }
  762.                 else        //当已经开启重置密码功能时,而按下开锁键,
  763.                 {
  764.                         //DisplayListChar(0,1,Er_try);
  765.                         write_1602com(er);
  766.                         for(j=0;j<16;j++)
  767.                         {
  768.                                 write_1602dat(Er_try[j]);                          //错误,请重新输入
  769.                         }
  770.                         ThreeAlam();                                                          //错误提示音
  771.                 }
  772.         }
  773.         if(N<M&&flag!=1&&N!=0)
  774.         {
  775.                 //DisplayListChar(0,1,Error);
  776.                 write_1602com(er);
  777.                 for(j=0;j<16;j++)
  778.                 {
  779.                         write_1602dat(Error[j]);                 //显示错误
  780.                 }
  781.                  ThreeAlam();        //错误提示音
  782.                 pass=0;
  783.         }
  784.
  785.         N=0;        //将输入数据计数器清零,为下一次输入作准备
  786.         operation=1;
  787. }
  788. //==============================主函数===============================
  789. void main(void)
  790. {
  791.          unsigned char KEY,NUM;
  792.         unsigned char i,j;
  793.          P1=0xFF;                                    //P1口复位
  794.         TMOD=0x21;                                   //定义工作方式
  795.          TL0=0xB0;
  796.          TH0=0x3C;                                   //定时器赋初值
  797.          EA=1;                                           //打开中断总开关
  798.          ET0=1;                                           //打开中断允许开关
  799.          TR0=0;                                           //打开定时器开关
  800.         TH1=0Xfd;
  801.         TL1=0Xfd;            //9600
  802.         TR1=1;                     // 定时器1启动
  803.         SM0=0;            // 设置串口的工作模式
  804.         SM1=1;             //方式1
  805.         REN=1;                  // 允许串口接收数据
  806.         ES=1;              // 串口中断应许
  807.
  808.          Delay400Ms();         //启动等待,等LCM讲入工作状态
  809.          lcd_init();         //LCD初始化
  810.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  811.         for(i=0;i<16;i++)
  812.         {
  813.                 write_1602dat(name[i]);//向液晶屏写开机画面
  814.         }
  815.         write_1602com(er);
  816.         for(i=0;i<16;i++)
  817.         {
  818.                 write_1602dat(start_line[i]);//写输入密码等待界面
  819.         }
  820.         write_1602com(er+9);        //设置光标位置
  821.         write_1602com(0x0f);        //设置光标为闪烁
  822.          Delay5Ms(); //延时片刻(可不要)
  823.          N=0;        //初始化数据输入位数
  824.         RdFromROM(MM,17,1);
  825.         M=MM[0];
  826.                 if(M==0||M>16)
  827.         {
  828.          M=6;
  829.          MM[0]=6;
  830.          WrToROM(MM,17,1);
  831.         }
  832.          while(1)                 //进入循环
  833.          {
  834.                 if(key_disable==1)                                                //锁定键盘标志为1时
  835.                         Alam_KeyUnable();                                        //报警键盘锁
  836.                 else
  837.                         ALAM=1;        //关报警
  838.                 KEY=keynum();                                                        //读按键的位置码
  839.                 if(KEY!=0)        //当有按键按下时
  840.                 {
  841.                         if(key_disable==1)                                        //锁定键盘标志为1时
  842.                         {
  843.                                 second=0;                                                //秒清零
  844.                         }
  845.                         else        //没有锁定键盘时
  846.                         {
  847.                                 NUM=coding(KEY);                                //根据按键的位置将其编码,编码值赋值给NUM
  848.                                 {
  849.                                         switch(NUM)                                        //判断按键值
  850.                                         {
  851.                                                 case ('A'):         ;                                         break;
  852.                                                 case ('B'):                ;                                     break;
  853.                                                 case ('C'):
  854.        write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  855.        for(i=0;i<16;i++)
  856.        {
  857.        write_1602dat(name[i]);//向液晶屏写开机画面
  858.        }
  859.                                                        if(N>=1) N--;        OneAlam();        //按键提示音
  860.        //DisplayOneChar(6+N,1,'*');
  861.                                                            for(j=N;j<16;j++)
  862.                                                           {
  863.                                                           write_1602com(er+j);
  864.        write_1602dat(' ');
  865.                                                           }
  866.                                                            for(j=0;j<N;j++)
  867.                                                           {
  868.        write_1602com(er+j);                                //显示位数随输入增加而增加
  869.        write_1602dat('*');                                        //但不显示实际数字,用*代替
  870.        }
  871.        InputData[N]=N+4;
  872.        break;                //ABC是无定义按键
  873.                                                 case ('D'): ResetPassword();                break;      //重新设置密码
  874.                                                 case ('*'): Cancel();                                break;      //取消当前输入
  875.                                                 case ('#'): Ensure();                                 break;           //确认键,
  876.                                                 default:        //如果不是功能键按下时,就是数字键按下
  877.                                                 {
  878.                                                         //DisplayListChar(0,1,Input);
  879.                                                         write_1602com(yi);
  880.                                                         for(i=0;i<16;i++)
  881.                                                         {
  882.        write_1602dat(Input[i]);                                //显示输入画面
  883.                                                         }
  884.                                                     operation=0;        //操作标志清零
  885.                                                         if(N<16)                                                           //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
  886.                                                         {
  887.        OneAlam();        //按键提示音
  888.        //DisplayOneChar(6+N,1,'*');
  889.        for(j=0;j<16;j++)
  890.        {
  891.        if(j>N)
  892.        {
  893.        write_1602com(er+j);
  894.        write_1602dat(' ');
  895.        }
  896.        if(j<=N)
  897.        {
  898.        write_1602com(er+j);                                //显示位数随输入增加而增加
  899.        write_1602dat('*');                                        //但不显示实际数字,用*代替
  900.        }
  901.        }
  902.        InputData[N]=NUM;                                                //将数字键的码赋值给InputData[]数组暂存
  903.        N++;        //密码位数加
  904.                                                         }
  905.                                                         else        //输入数据位数大于6后,忽略输入
  906.                                                         {
  907.        N=16;        //密码输入大于6位时,不接受输入
  908.        break;
  909.                                                         }
  910.                                                         write_1602com(er+N);
  911.                                                         if(ReInputEn==1&&ReInputCont==0)
  912.                                                         M=N;
  913.                                                 }
  914.                                         }
  915.                                 }
  916.                         }
  917.                  }
  918.         }
  919. }
  920. //*********************************中断服务函数**************************************
  921. void  time0_int(void) interrupt 1                    //定时器T0
  922. {
  923.          TL0=0xB0;
  924.          TH0=0x3C;                  //定时器重新赋初值
  925.          //TR0=1;
  926.          countt0++;                           //计时变量加,加1次时50ms
  927.           if(countt0==20)                   //加到20次就是1s
  928.            {
  929.                 countt0=0;                   //变量清零
  930.                 second++;                   //秒加
  931.                 if(pass==1)                   //开锁状态时
  932.                 {
  933.                         if(second==1)                        //秒加到1s时
  934.                         {
  935.
  936.                                 TR0=0;                                //关定时器
  937.                                 TL0=0xB0;
  938.                                  TH0=0x3C;                        //再次赋初值
  939.                                 second=0;                        //秒清零
  940.                         }
  941.                 }
  942.                 else                                                //不在开锁状态时
  943.                 {
  944.                         if(second==3)                        //秒加到3时
  945.                         {
  946.                                 TR0=0;                                //关闭定时器
  947.                                 second=0;                        //秒清零
  948.                                 key_disable=0;                //锁定键盘清零
  949.                                 s3_keydown=0;
  950.                                 TL0=0xB0;
  951.                                 TH0=0x3C;                        //重新赋初值
  952.                         }
  953.                         else
  954.                             TR0=1;                                //打开定时器
  955.                 }
  956.
  957.            }
  958. }
  959. //  通讯中断接收程序   中断函数无返回值
  960.   void uart_rx(void)  interrupt 4        using 3          //放在这里 和放在main()里面是一样的
  961. {
  962.            unsigned char i;
  963.         unsigned char flag;
  964.         unsigned char dat;
  965.     if(RI)                         //是否接收中断
  966.     {
  967.        RI=0;
  968.        dat=SBUF;
  969.        if(dat=='O'&&(i==0)) //接收数据第一帧
  970.        {
  971.             buff[i]=dat;
  972.             flag=1;        //开始接收数据
  973.        }
  974.        else
  975.               if(flag==1)
  976.               {
  977.                       i++;
  978.                       buff[i]=dat;
  979.                       if(i>=2)
  980.                   {
  981.                            i=0;
  982.                            flag=0;
  983.                            flag_REC=1 ;
  984.                       }  // 停止接收
  985.               }
  986.          }
  987. }
收藏收藏3 分享淘帖 顶顶 踩踩
ID:189829 发表于 2017-4-15 15:04 | 只看该作者
程序非常清楚
ID:192867 发表于 2017-4-23 21:49 | 只看该作者
但是好像,程序有错,我用Kil3通不过编译
ID:189829 发表于 2017-5-18 13:52 | 只看该作者
用keil4试试
ID:192867 发表于 2017-5-23 18:42 | 只看该作者
楼主,这个程序和原理图是不是配套的?
ID:186936 发表于 2017-6-9 22:42 | 只看该作者
有没有app
app给一下可以吗:QQ1306501801
ID:195403 发表于 2017-6-13 16:39 | 只看该作者
蓝牙连接上去以后无法使用蓝牙的功能
ID:195403 发表于 2017-6-13 16:45 | 只看该作者
蓝牙部分如何操作?
ID:210319 发表于 2017-6-15 07:13 | 只看该作者
楼主APP用超级串口么
ID:210319 发表于 2017-6-15 08:08 | 只看该作者
楼主 蓝牙部分怎么操作啊
ID:192867 发表于 2017-6-15 16:43 | 只看该作者
楼主按键,部分不怎么能对上号
ID:418215 发表于 2018-12-10 20:42 | 只看该作者
怎么用蓝牙串口输入密码
ID:660034 发表于 2019-12-9 21:20 | 只看该作者
蓝牙模块没有程序吧,连接蓝牙用不了,大佬可以发一下吗?
