查看: 5532|回复: 2
发个16X16点阵+原理图+源程序
16X16点阵动态显示32个字,文字内容可以增加,修改,可以用论坛里面的字模提取软件,修改其他文字,显示效果:卷帘出,卷帘入,上滚屏,左跑马。大家一起学习,进步!
原理图:
单片机源程序:
  1. /*--------------------------------------
  2. 16×16点阵LED显示屏程序
  3. MCU AT89C51  XAL 24MHz        12MHZ/晶振频率不同、刷新率也不同、供参考。
  4. --------------------------------------*/
  5. #include <reg51.h>
  6. #define BLKN 2       //列锁存器数
  7. sbit G = 0x97;       //P1.7为显示允许控制信号端口
  8. sbit RCLK = 0x96;    //P1.6为输出锁存器时钟信号端
  9. sbit SCLR = 0x95;    //P1.5为移位寄存器清○端
  10. void delay(unsigned int);       //延时函数
  11. unsigned char data dispram[32]; //显示缓存
  12. /*--------------------------------------
  13.   主函数 void main(void)
  14. --------------------------------------*/
  15. void main(void)
  16. {
  17. unsigned char code Bmp[][32]={//字模表
  18. {0xFF,0xFF,0x80,0x01,0xFD,0xFF,0xFD,0xFF,0xFD,0xEF,0xFC,0x07,0xFD,0xEF,0xFB,0xEF,
  19. 0xFB,0xEF,0xFB,0xEF,0xF7,0xEF,0xF7,0xEF,0xEF,0xEF,0xDF,0x1F,0xBF,0xBF,0xFF,0xFF},/*"W",0*/
  20. {0xFF,0xBF,0x07,0xAF,0xF7,0x77,0xB6,0x03,0xB7,0xFB,0xB7,0x77,0xB6,0xFB,0x83,0x7F,
  21. 0xFB,0x03,0xEA,0x77,0xD9,0xAF,0x3B,0xDF,0xFB,0xAF,0xD6,0x71,0xE9,0xFB,0xFF,0xFF},/*"J",1*/
  22. {0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xC0,0x07,0xDE,0xF7,0xDE,0xF7,0xC0,0x07,0xDE,0xF7,
  23. 0xDE,0xF7,0xDE,0xF7,0xC0,0x07,0xDE,0xF7,0xFE,0xFD,0xFE,0xFD,0xFF,0x01,0xFF,0xFF},/*"?",2*/
  24. {0xFF,0xFF,0xC0,0x0F,0xFF,0xDF,0xFF,0xBF,0xFF,0x7F,0xFE,0xFF,0xFE,0xFF,0xFE,0xFB,
  25. 0x00,0x01,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFE,0xFF,0xFA,0xFF,0xFD,0xFF},/*"?",3*/
  26. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  27. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0xCF,0xFF,0xEF,0xFF,0xDF,0xFF,0xFF,0xFF},/*",",4*/
  28. {0xEF,0xBF,0xEB,0xAF,0xDD,0x87,0x80,0xBB,0xBE,0xBB,0xC1,0xC3,0xDD,0xFF,0xC1,0xB3,
  29. 0xDD,0x8F,0xC1,0xBB,0xDD,0xBB,0xD9,0xC3,0xD7,0x77,0xDB,0xBB,0xBB,0xBF,0xFF,0xFF},/*"?",5*/
  30. {0xDF,0xBF,0xEF,0xBF,0xEF,0xBF,0xF8,0x01,0x7B,0xBB,0xAB,0xBF,0xAB,0xBF,0xE8,0x07,
  31. 0xDA,0xF7,0xDB,0x6F,0x1B,0x6F,0xDB,0x9F,0xD7,0x9F,0xD7,0x68,0xCE,0xF1,0xD9,0xFB},/*"?",6*/
  32. {0xDB,0xFB,0xCB,0xFB,0xDB,0xDB,0xC0,0x5B,0xBB,0xDB,0xFB,0xDB,0x80,0x5B,0xFB,0xDB,
  33. 0xC0,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x5B,0xDB,0x7B,0xD8,0x7B,0xFA,0xEB,0xFB,0xF7},/*"制",7*/
  34. {0xF7,0x7F,0xF3,0x7F,0xF6,0xFF,0xEC,0x01,0xED,0x7F,0xCB,0x77,0xAF,0x03,0x6F,0x7F,
  35. 0xEF,0x7F,0xEF,0x7B,0xEF,0x01,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F,0xEF,0x7F},/*"作",8*/
  36. {0xFF,0xFF,0xFF,0xFF,0xFE,0x7F,0xF8,0x0F,0xE6,0x47,0xE6,0x47,0xE0,0x7F,0xF0,0x7F,
  37. 0xFC,0x1F,0xFE,0x07,0xE6,0x67,0xC2,0x63,0xE6,0x67,0xF0,0x1F,0xFE,0x7F,0xFF,0x7F},/*",",9*/
  38. {0xFF,0x7F,0xFF,0x7F,0x03,0x7F,0xFA,0x01,0x7A,0xFB,0xB5,0xB7,0xD7,0xBF,0xEF,0xBF,
  39. 0xE7,0xBF,0xE7,0x9F,0xDB,0x5F,0xDB,0x6F,0xBE,0xE7,0x79,0xF1,0xC7,0xFB,0xFF,0xFF},/*"欢",10*/
  40. {0xBF,0xFF,0xDE,0x7F,0xC9,0x83,0xDB,0xBB,0xFB,0xBB,0xFB,0xBB,0x1B,0xBB,0xDB,0xBB,
  41. 0xDA,0xBB,0xD9,0xAB,0xDB,0xB7,0xDF,0xBF,0xDF,0xBF,0xAF,0xFF,0x70,0x01,0xFF,0xFF},/*"迎",11*/
  42. {0xFF,0xFF,0xFE,0x03,0x82,0xFB,0xFA,0xDB,0xBA,0xDB,0xBA,0xDB,0xD6,0xDB,0xEE,0xDB,
  43. 0xD6,0xDB,0xDA,0xAB,0xB9,0xAF,0xBB,0x6F,0x7F,0x6D,0xFE,0xED,0xFD,0xF1,0xFB,0xFF},/*"观",12*/
  44. {0xFF,0x07,0xC0,0xFF,0xFE,0xFF,0xC0,0x07,0xFD,0xFF,0x00,0x01,0xFB,0xFF,0xF0,0x0F,
  45. 0xE7,0xEF,0x90,0x0F,0x77,0xEF,0xF0,0x0F,0xF7,0xEF,0xF7,0xEF,0xF0,0x0F,0xF7,0xEF},/*"看",13*/
  46. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xEF,0xF7,0xD9,0x9B,0xB9,0x9D,0xBF,0xFD,
  47. 0xBF,0xFD,0xBE,0x7D,0xBC,0x3D,0xDE,0x7B,0xEF,0xF7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},/*",",14*/
  48. {0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
  49. 0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF},/*"谢",15*/
  50. {0xFE,0xF7,0xBD,0xF7,0xC8,0x77,0xDB,0x77,0xF8,0x01,0xFB,0x77,0x18,0x37,0xDB,0x57,
  51. 0xD0,0x57,0xDE,0x77,0xDD,0x77,0xD5,0x77,0xCB,0x77,0xD7,0x77,0xED,0x57,0xFE,0xEF},/*"谢",16*/
  52. {0xFF,0xFF,0xFF,0xFF,0xFE,0xFF,0xFC,0x3F,0xFC,0x3F,0xFC,0x7F,0xFE,0x7F,0xFE,0x7F,
  53. 0xFE,0x7F,0xFE,0x7F,0xFF,0xFF,0xFF,0xFF,0xFC,0x3F,0xFC,0x3F,0xFF,0xFF,0xFF,0xFF},/*"!",17*/
  54. {0xFE,0xFF,0xFE,0xFF,0xFD,0x7F,0xFD,0x7F,0xFD,0x7F,0xFB,0xBF,0x03,0x81,0xBF,0xFB,
  55. 0xCF,0xE7,0xF7,0xDF,0xF7,0xDF,0xEE,0x6F,0xE9,0xAF,0xE7,0xCF,0xDF,0xF7,0xFF,0xFF},/*"☆",18*/
  56. {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xF3,0x8F,0xF1,0x8F,0xF1,
  57. 0x8F,0xF1,0x8F,0xF1,0x8C,0x71,0xC0,0x33,0xE3,0x87,0xF0,0x0F,0xFF,0xC3,0xFF,0xF7},  /*Q*/
  58.   {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xF3,0x8F,0xF1,0x8F,0xF1,
  59.   0x8F,0xF1,0x8F,0xF1,0x8C,0x71,0xC0,0x33,0xE3,0x87,0xF0,0x0F,0xFF,0xC3,0xFF,0xF7} , /*Q*/
  60.    {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xCF,0xFF,0x0F,0xFE,0x0F,0xFD,0x8F,0xF3,0x8F,
  61.   0xE7,0x8F,0xCF,0x8F,0xC0,0x01,0xFF,0x8F,0xFF,0x8F,0xFC,0x01,0xFF,0xFF,0xFF,0xFF}, /*4*/
  62.   {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xE3,0xC7,0xE3,0xFF,0xC7,
  63.    0xFF,0x8F,0xFE,0x3F,0xF8,0xFF,0xF3,0xFB,0xC0,0x03,0xC0,0x03,0xFF,0xFF,0xFF,0xFF},/*2*/
  64.    {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF8,0x0F,0xE3,0xC7,0xC7,0xE3,0xC7,0xE3,0x87,0xE1,
  65.     0x87,0xE1,0xC7,0xE3,0xC7,0xE3,0xC7,0xE3,0xE3,0xC7,0xF8,0x1F,0xFF,0xFF,0xFF,0xFF},/*0*/
  66.   {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xC7,0xE7,0xCF,0xE3,0x8F,0xE3,0x8F,0xE3,
  67.    0xC7,0xC3,0xE0,0x23,0xFF,0xE3,0xE7,0xC7,0xC3,0x8F,0xE0,0x1F,0xFF,0xFF,0xFF,0xFF}, /*9*/
  68.    {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x01,0xC7,0xF3,0xCF,0xEF,0xFF,0xCF,0xFF,0x9F,
  69.     0xFF,0x3F,0xFE,0x7F,0xFC,0x7F,0xFC,0x7F,0xFC,0x7F,0xFC,0x7F,0xFF,0xFF,0xFF,0xFF},/*7*/
  70.         {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xE7,0xE7,0xC7,0xE3,0xC7,0xE3,0xFF,0xC7,
  71.      0xFF,0x8F,0xFE,0x3F,0xF8,0xFF,0xF3,0xFB,0xC0,0x03,0xC0,0x03,0xFF,0xFF,0xFF,0xFF},  /*?*/
  72.         {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x03,0xE7,0xFF,0xE7,0xFF,0xE7,0x3F,0xE0,0x07,
  73.      0xE7,0xE3,0xFF,0xE3,0xEF,0xE3,0xC7,0xE3,0xC7,0xE7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},/*8*/
  74.          {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x0F,0xFE,0x0F,0xFD,0x8F,0xF3,0x8F,
  75.       0xE7,0x8F,0xCF,0x8F,0xC0,0x01,0xFF,0x8F,0xFF,0x8F,0xFC,0x01,0xFF,0xFF,0xFF,0xFF}, /*?*/
  76.          {0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x03,0xE7,0xFF,0xE7,0xFF,0xE7,0x3F,0xE0,0x07,
  77.       0xE7,0xE3,0xFF,0xE3,0xEF,0xE3,0xC7,0xE3,0xC7,0xE7,0xF0,0x0F,0xFF,0xFF,0xFF,0xFF},  /*5*/
  78.            {0xFF,0xFF,0xFF,0xFF,0xF0,0x0F,0xEF,0xF7,0xDF,0xFB,0xBF,0xFD,0x63,0xC6,0x63,0xC6,
  79.         0x7F,0xFE,0x7E,0x7E,0x7E,0x7E,0x7B,0xDE,0xBC,0x3D,0xDF,0xFB,0xE0,0x07,0xFF,0xFF}
  80. …………限于本文篇幅 余下代码请从51黑下载附件…………
下载:
16X16点阵 原理图.zip (120.72 KB, 下载次数: 31)
收藏收藏3 分享淘帖 顶顶 踩踩
ID:211119 发表于 2017-6-18 22:22 | 只看该作者
这个把芯片改成at89c51可以用吗
ID:649546 发表于 2019-11-25 23:31 | 只看该作者
这个文字取模是怎么取得,我的字取出来师傅不对
