查看: 3932|回复: 0
STM32f103Rc,按键调节屏幕数值,不过按键老是无效,怎么解决
ID:194955 发表于 2017-4-30 11:32 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
if(KEY2==0)
     delay_ms(20);
                 OLED_Clear();
                 OLED_ShowCHinese(0,0,7);//ÎÂ
           OLED_ShowCHinese(18,0,9);//¶è
           OLED_ShowCHinese(36,0,12);//ÏT
           OLED_ShowCHinese(54,0,9);//¶è
                 OLED_ShowString(71,0,":");
                         while(j)
                                        OLED_showint(80,0,Temp0);
                                  delay_ms(200);
                                        OLED_showint1(80,0,Temp0);
                                        delay_ms(20);
          if(KEY0!=t1)
                                                        Temp0++;
                            if(KEY1!=t2)
                                                        Temp0--;
                      t1=KEY0;
                                        t2=KEY0;
                                        if(KEY2==1)
                                                j=0;
                          OLED_ShowCHinese(0,3,8);//êa
              OLED_ShowCHinese(18,3,9);//¶è
              OLED_ShowCHinese(36,3,12);//ÏT
              OLED_ShowCHinese(54,3,9);//¶è
                    OLED_ShowString(71,3,":");
                    OLED_showint(80,3,Rh0);
                         while(k)
                                  delay_ms(200);
                                        OLED_showint1(80,3,Rh0);
                                        delay_ms(20);
          if(KEY0!=t1)
                                                        Rh0++;
                            if(KEY1!=t2)
                                                        Rh0--;
                      t1=KEY0;
                                        t2=KEY1;
                                        if(KEY2==0)
                                                k=0;
                                OLED_Clear();
                OLED_ShowString(36,0,":");
                OLED_ShowString(36,3,":");
                OLED_ShowString(65,0,".");
                OLED_ShowString(65,3,".");
                OLED_ShowCHinese(73,0,10);
                OLED_ShowString(89,0,"C");
                OLED_ShowString(86,3,"%");
