查看: 4499|回复: 0
51单片机1602温度显示程序
ID:200649 发表于 2017-5-14 16:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.H>
#include <intrins.H>
#include <math.H>
sbit dula=P2^6;
sbit wela=P2^7;
sbit lcdrs=P3^5;
sbit lcden=P3^4;
void delayUs()
    _nop_();
void delayMs(uint a)
    uint i,j;
    for(i=a;i>0;i--)
        for(j=100;j>0;j--);
void writeComm(uchar comm)
    lcdrs=0;
    P0=comm;
    lcden = 1;
    delayUs();
    lcden = 0;
    delayMs(1);
//写数据:RS=1, RW=0;
void writeData(uchar dat)
    lcdrs=1;
    P0=dat;
    lcden=1;
    delayUs();
    lcden=0;
    delayMs(1);
void init()
    dula=wela=0;
    writeComm(0x38);
    writeComm(0x0c);
    writeComm(0x06);
    writeComm(0x01);
void writeString(uchar*str, uchar length)
     uchar i;
    for(i=0;i<length;i++)
         writeData(str[i]);
/**//*****************************DS18B20*******************************/
sbit ds = P2^2;
void dsInit()
    unsigned int i;
    ds=0;
    i=100;
    while(i>0) i--;
    ds=1;
    i=4;
    while(i>0) i--;
void dsWait()
      unsigned int i;
      while(ds);
      while(~ds);
      i=4;
      while(i>0) i--;
bit readBit()
    unsigned int i;
    bit b;
    ds=0;
    i++;
    ds=1;
   i++; i++;
    b=ds;
    i=8;
    while(i>0) i--;
    return b;
unsigned char readByte()
    unsigned int i;
    unsigned char j, dat;
   dat = 0;
    for(i=0; i<8; i++)
        j = readBit();
        dat = (j<<7) | (dat>>1);
    return dat;
void writeByte(unsigned char dat)
    unsigned int i;
    unsigned char j;
    bit b;
    for(j=0; j<8; j++)
        b = dat & 0x01;
        dat >>= 1;
        if(b)
           ds=0;          i++; i++;
            ds=1;
            i=8; while(i>0) i--;
            ds=0;
            ds=1;
           i++; i++;
void sendChangeCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0x44);
void sendReadCmd()
    dsInit();
    dsWait();
    delayMs(1);
    writeByte(0xcc);
    writeByte(0xbe);
int getTmpValue()
    unsigned int tmpvalue;
    int value;
    float t;
    unsigned char low, high;
    sendReadCmd();
    low=readByte();
    high=readByte();
    tmpvalue=high;
    tmpvalue<<=8;
    tmpvalue |=low;
    value=tmpvalue;
    t = value * 0.0625;
    value = t * 100 + (value > 0 ? 0.5 : -0.5); //大于0加0.5, 小于0减0.5
    return value;
void display(int v)
    unsigned char count;
    unsigned char datas[] = {0, 0, 0, 0, 0};
    unsigned int tmp = abs(v);
    datas[0] = tmp / 10000;
    datas[1] = tmp % 10000 / 1000;
    datas[2] = tmp % 1000 / 100;
    datas[3] = tmp % 100 / 10;
    datas[4] = tmp % 10;
    writeComm(0xc0+3);
    if(v < 0)
        writeString("- ", 2);
       writeString("+ ", 2);
    if(datas[0] != 0)
        writeData('0'+datas[0]);
    for(count = 1; count != 5; count++)
        writeData('0'+datas[count]);
        if(count == 2)
            writeData('.');
    uchar table[] = "  temperature:  ";
    sendChangeCmd();
    init();
    writeComm(0x80);
    writeString(table, 16);
        delayMs(1000); //温度转换时间需要750ms以上
        writeComm(0xc0);
        display(getTmpValue());
        sendChangeCmd();
