查看: 7665|回复: 1
具有语音功能的RCL电阻、电容、电感测试仪测试仪-电子设计
凌阳的一个项目给机器人或者小车、调试语音功能,可测电阻电容电感
资料目录:
电感测试电路:
语音电路:
程序流程图:
  1. //*****************************************************//
  2. //R/C/L测试:每次等测试稳定后语音播报1次,之后不再播报,
  3. //可以通过数码管显示观察测量结果。
  4. //*****************************************************//
  5. #include "s480.h"
  6. #define          P_IOA_Data                        (volatile int*)0x7000
  7. #define                 P_TimerB_Data              (volatile int*)0x700c
  8. #define                P_TimerB_Ctrl       (volatile int*)0x700D
  9. #define                 R_Test                                1
  10. #define                C_Test                                2
  11. #define                L_Test                                3
  12. float g_fRx=0.0;
  13. float g_fCx=0.0;
  14. float g_fLx=0.0;
  15. unsigned char         g_ucIntFlag=0;
  16. unsigned int         g_uiStatus;
  17. unsigned int          g_uiKey=0;
  18. unsigned int        g_uifx=0;
  19. unsigned int          g_uisum=0;
  20. unsigned int        j=0,i=0;
  21. unsigned int          g_uidisplay;
  22. unsigned int        Lxsum=0;
  23. unsigned char         LxFlag=0;
  24. unsigned int        g_speechID=0;
  25. unsigned int        g_speachIndex=0;
  26. unsigned int        g_Speechary[6]={0};
  27. unsigned int         g_array[4]={0};
  28. unsigned int         voicflag=0;
  29. //=========== 播放提示语音 ========================//
  30. //input:voice index
  31. //=================================================//
  32. void PlayTestValue()      //播放语音
  33. {
  34.    SACM_S480_Initial(1);
  35.    while(g_speachIndex<g_speechID)
  36.         {
  37.            SACM_S480_Play(g_Speechary[g_speachIndex],3,3);
  38.            while(SACM_S480_Status()&0x0001)
  39.             SACM_S480_ServiceLoop();
  40.             g_speachIndex++;
  41.         }
  42.         SACM_S480_Stop();
  43.         voicflag=1;
  44. }
  45. //*************************************************//
  46. main()
  47. {
  48.         g_uidisplay=0;
  49.         System_Initial();
  50.         while(1)
  51.         {
  52.            g_uiKey=SP_GetCh();
  53.            //g_uiKey=1;
  54.                   switch(g_uiKey)
  55.                           {
  56.                            case 0x0001:
  57.                                                 g_uiStatus = R_Test;
  58.                                                 RunTime2Hz();//开中断
  59.                                                    TmbCount();
  60.                                                    Rline_on();
  61.                                                    break;
  62.                            case 0x0002:
  63.                                                    g_uiStatus = C_Test;
  64.                                                    RunTime2Hz();//开中断
  65.                                                 TmbCount();
  66.                                             Cline_on();
  67.
  68.                                                 break;
  69.                            case 0x0004:
  70.                                                    g_uiStatus = L_Test;
  71.                                                 SP_INT_32Hz();
  72.                                                 TmbCount();
  73.                                                 Lline_on();
  74.
  75.                                                    break;
  76.                            default:
  77.                                                 break;
  78.
  79.
  80.                         }
  81.
  82. //************************状态判断处理*********************//
  83.
  84.                   switch(g_uiStatus)
  85.                 {
  86.                         case R_Test:
  87. //**********************R********************************//
  88.                         if(voicflag)
  89.                            RunTime2Hz();
  90.                          while(g_ucIntFlag)
  91.                         {
  92.                                 g_uifx=*(P_TimerB_Data);
  93.                                 g_ucIntFlag = 0;
  94.                                 *(P_TimerB_Data)=0;
  95.                                 if(g_uifx&&g_uifx<7500)
  96.                                          g_fRx=(3*2.7575*(1e+6))/g_uifx-100;  //计算
  97.                                 else
  98.                                 {
  99.                                         R_Above1K();
  100.                                         g_fRx =(3*69.3225*(1e+6))/g_uifx-(1e+4);
  101.                                 }
  102.                                         R_display(g_fRx);
  103.
  104.                         }
  105.                                 break;
  106.
  107.                         case C_Test:
  108. //************************C*******************//
  109.                      while(g_ucIntFlag)
  110.                         {
  111.                                 if(voicflag)
  112.                                    RunTime2Hz();
  113.                                 g_uifx=*(P_TimerB_Data);
  114.                                 g_ucIntFlag = 0;
  115.                                 *(P_TimerB_Data)=0;
  116.
  117.                                 if(g_uifx)
  118.                                  {
  119.                                         g_fCx=(3*4.81*(1e+6))/g_uifx;  //计算
  120.                         /*                if(g_fCx<1000)
  121.                                         {
  122.                                                 C_Below1K();
  123.                                                 g_fCx =(3*0.94*(1e+6))/g_uifx;
  124.
  125.                                         }  */
  126.                                         //PlayVoice(g_fRx);
  127.                                         C_display(g_fCx);
  128.                                 }
  129.                         }
  130.                                 break;
  131.
  132.                         case L_Test:
  133. //************************L*******************//
  134.                          while(LxFlag)
  135.                         {
  136.                                 if(voicflag)
  137.                                    RunTime2Hz();
  138.                                 g_uifx=*(P_TimerB_Data);
  139.                                 LxFlag = 0;
  140.                         //        *(P_IOA_Data)|=0x0008;
  141.                         //        Lline_on();
  142.                                 *(P_TimerB_Data)=0;
  143.                                 if(g_uifx)
  144.                                  {
  145.                                         g_fLx=(4*38*(1e+6))/(g_uifx*g_uifx); //计算
  146.
  147.                                         //PlayVoice(g_fRx);
  148.                                         L_display(g_fLx);
  149.
  150.                                 }
  151. ……………………
  152. …………限于本文篇幅 余下代码请从51黑下载附件…………
电子竞赛—具有语音功能的RCL测试仪.rar (1.92 MB, 下载次数: 113)
收藏收藏5 分享淘帖 顶顶 踩踩
ID:305388 发表于 2018-4-11 10:15 | 只看该作者
非常棒,下载学习一下。
