查看: 3327|回复: 0
编写了一个pic单片机的程序,显示没有问题,但是无法编译到开发板上,求大神指教一...
ID:212878 发表于 2017-6-20 11:03 | 显示全部楼层 |阅读模式
#include<pic.h>
__CONFIG(0x20d2);
__CONFIG(0xffff);
const uchar table[]=
0x3f,0x06,0x5b,0x4f,0x66,
0x6d,0x7d,0x07,0x7f,0x6f
const uchar chair[]=
0xbf,0x86,0xdb,0xcf,0xe6,
0xed,0xfd,0x87,0xff,0xef
uchar aa,shim,miao,haom;
uint b;
void delay(uint);
void init()
b=0;
TRISA=0x00;
TRISB=0x00;
TRISC=0x00;
TRISE=0x00;
INTCON=0b10100000;
TMR0=217;
        init();
                if(RB0==0)
                INTCON=0b00000000;
                if(RB1==0)
                INTCON=0b10100000;
                if(RB2==0)
                b=0;
                if(aa==50)
                        aa=0;
            b++;
                        if(b==1000)
                                b=0;
                    shim=b/100;
                    miao=b%100/10;
                        haom=b%10;
                RE2=1;
                PORTC=table[shim];
                delay(1);
               RE1=1;
                PORTC=chair[miao];
                delay(1);
            RE0=1;
                PORTC=table[haom];
                delay(1);
void delay(uint x)
        uint i,j;
  for(i=0;i<x;i++)
          for(j=125;j>0;j--);
void interrupt ISR(void)
if(T0IF==1)
T0IF=0;
TMR0=248;//TMR0赋初值,定时2ms
aa++;
