查看: 11003|回复: 7
用DS1302与1602LCD设计的可调式电子日历与时钟 屏幕不显示字符 求指导
ID:137190 发表于 2016-9-9 01:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include<reg51.h>
  2. #include<string.h>
  3. #include<intrins.h>
  5. #define uint unsigned int
  6. sbit SDA=P1^0;                    //1302的IO口
  7. sbit CLK=P1^1;                   //1302的时钟线
  8. sbit RST=P1^2;                   //1302的复位线
  9. sbit RS=P2^0;                   //1602寄存器选择
  10. sbit RW=P2^1;                   //1602读写控制
  11. sbit E=P2^2;                        //1602的启动
  12. sbit K1=P3^4;                        //调时选择
  13. sbit K2=P3^5;                         //加
  14. sbit K3=P3^6;                          //减
  15. sbit K4=P3^7;                          //确定
  16. uchar tcount=0;
  17. uchar monthsdays[]={0,31,0,31,30,31,30,31,31,30,31,30,31};
  18. uchar*week[]={"SUN","MON","TUS","WEN","THU","FRI","SAT"};
  19. uchar LCD_buffer1[]={"DATE 00-00-00   "};
  20. uchar LCD_buffer2[]={"TIME 00-00-00   "};
  21. uchar datetime[7];
  22. char adjust_index=-1;
  23. uchar change_flag[]="-MHDM-Y";
  24. void delay(uint z);
  25. void set_ds1302();
  26. void gettime();
  27. uchar read_date(uchar addr);
  28. void write_ds1302(uchar addr,uchar dat);
  29. void write_a_byte_to_ds1302(uchar x);
  30. uchar get_a_byte_from_ds1302();
  31. uchar read1602state();
  32. void busy_wait();
  33. void write_date(uchar dat);
  34. void write_com(uchar cmd);
  35. void init_lcd1602();
  36. void set_weizhi(uchar p);
  37. void display_string(uchar p,uchar*s);
  38. void format_datetime(uchar d,uchar*a);
  39. uchar runnian(uint y);
  40. void refresh_week_day();
  41. void datetime_adjust(char x);
  42. /////////主程序
  43. void main()
  44. {
  45. init_lcd1602();
  46. IE=0x83;
  47. IP=0x01;
  48. IT0=1;
  49. TMOD=0X01;
  50. TH0=5000/256;
  51. TL0=5000%256;
  52. TR0=1;
  53. while(1)
  54. {
  55. if(adjust_index==-1)
  56. gettime();
  57. }
  58. }
  59. /////////////////延时
  60. void delay(uint z)
  61. {
  62. uchar i;
  63. while(z--)
  64. for(i=0;i<120;i++);
  65. }
  66. ////////////设置时间
  67. void set_ds1302()
  68. {
  69. uchar i;
  70. write_ds1302(0x8e,0x00);
  71. for(i=1;i<7;i++)
  72. {
  73. write_ds1302(0x80+2*i,(datetime[i]/10<<4)|(datetime[i]%10));
  74. }
  75. write_ds1302(0x8e,0x80);
  76. }
  77. /////////////读取当前日期时间
  78. void gettime()
  79. {
  80. uchar i;
  81. for(i=0;i<7;i++)
  82. {
  83. datetime[i]=read_date(0x81+2*i);
  84. }
  85. }
  86. /////////////从1302指定位置读数
  87. uchar read_date(uchar addr)
  88. {
  89. uchar dat;
  90. RST=0;
  91. CLK=0;
  92. RST=1;
  93. write_a_byte_to_ds1302(addr);
  94. dat=get_a_byte_from_ds1302();
  95. CLK=1;
  96. RST=0;
  97. return dat;
  98. }
  99. //////////////向1302某地址写数据
  100. void write_ds1302(uchar addr,uchar dat)
  101. {
  102. CLK=0;
  103. RST=1;
  104. write_a_byte_to_ds1302(addr);
  105. write_a_byte_to_ds1302(dat);
  106. CLK=0;
  107. RST=0;
  108. }
  109. /////////////向1302写入一个字节
  110. void write_a_byte_to_ds1302(uchar x)
  111. {
  112. uchar i;
  113. for(i=0;i<8;i++)
  114. {
  115. SDA=x&0X01;
  116. CLK=1;
  117. CLK=0;
  118. x>>=1;
  119. }
  120. }
  121. /////////从1302中读取一个字节
  122. uchar get_a_byte_from_ds1302()
  123. {
  124. uchar i,b=0x00;
  125. for(i=0;i<8;i++)
  126. {
  127. b=_crol_((uchar)SDA,i);
  128. CLK=1;
  129. CLK=0;
  130. }
  131. return b/16*10+b%16;
  132. }
  133. /////////读1602状态
  134. uchar read1602state()
  135. {
  136. uchar state;
  137. RS=0;
  138. RW=1;
  139. E=1;
  140. delay(1);
  141. state=P0;
  142. E=0;
  143. delay(1);
  144. return state;
  145. }
  146. //1602忙等待
  147. void busy_wait()
  148. {
  149. while((read1602state()&0x80)==0x80);
  150. delay(5);
  151. }
  152.   //向1602写数据
  153.   void write_date(uchar dat)
  154.   {
  155.   busy_wait();
  156.   RS=1;
  157.   RW=0;
  158.   E=0;
  159.   P0=dat;
  160.   E=1;
  161.   delay(1);
  162.   E=0;
  163.   }
  164.   //////向1602写指令
  165.   void write_com(uchar cmd)
  166.   {
  167.   busy_wait();
  168.   RS=0;
  169.   RW=0;
  170.   E=0;
  171.   P0=cmd;
  172.   delay(1);
  173.   E=0;
  174.   }
  175.   ///1602初始化
  176.   void init_lcd1602()
  177.   {
  178.   write_com(0x38);
  179.   delay(1);
  180.   write_com(0x01);
  181.   delay(1);
  182.   write_com(0x06);
  183.   delay(1);
  184.   write_com(0x0c);
  185.   delay(1);
  186.   }
  187.   //设置1602显示位置
  188.   void set_weizhi(uchar p)
  189.   {
  190.   write_com(p|0x80);
  191.   }
  192.   void display_string(uchar p,uchar*s)
  193.   {
  194.   uchar i;
  195.   set_weizhi(p);
  196.   for(i=0;i<16;i++)
  197.   {
  198.   write_date(s[i]);
  199.   delay(1);
  200.   }
  201.   }
  202.   //日期 时间值转化为数字字符
  203.   void format_datetime(uchar d,uchar*a)
  204.   {
  205.   a[0]=d/10+'0';
  206.   a[1]=d%10+'0';
  207.   }
  208.   ///判断闰年
  209.   uchar runnian(uint y)
  210.   {
  211.   return(y%4==0&&y%100!=0||(y%400==0));
  212.   }
  213.   ///////求2000 1.1开始任何一天是星期几
  214.   //////////求总天数后 再求星期几
  215.   void refresh_week_day()
  216.   {
  217.   uint i,d,w=5;
  218.   for(i=2000;i<2000+datetime[6];i++)
  219.   {
  220.   d=runnian(i)?366:365;
  221.   w=(w+d)%7;
  222.   }
  223.   d=0;
  224.   for(i=1;i<datetime[4];i++)
  225.   d+=monthsdays[i];
  226.   d+=datetime[3];
  227.   datetime[5]=(w+d)%7+1;
  228.   }
  229.   ///调整处理
  230.   void EX_INT0() interrupt 0
  231.   {
  232.   if(K1==0)
  233.   {
  234.   while(K1==0);
  235.   if(adjust_index==-1||adjust_index==1)
  236.   adjust_index=7;
  237.   adjust_index--;
  238.   if(adjust_index==5)adjust_index=4;
  239.   LCD_buffer2[13]='[';
  240.   LCD_buffer2[14]=change_flag[adjust_index];
  241.   LCD_buffer2[15]=']';
  242.   }
  243.   else
  244.   if(K2==0)
  245.   {
  246.   while(K2==0);
  247.   datetime_adjust(1);
  248.   }
  249.   else
  250.   if(K3==0)
  251.   {
  252.   while(K3==0);
  253.   datetime_adjust(-1);
  254.   }
  255.   else
  256.   if(K4==0)
  257.   {
  258.   while(K4==0);
  259.   set_ds1302();
  260.   LCD_buffer2[13]=' ';
  261.   LCD_buffer2[14]=' ';
  262.   LCD_buffer2[15]=' ';
  263.   adjust_index=-1;
  264.   }
  265.   }
  266. //分时日月年 加减
  267. void datetime_adjust(char x)
  268. {
  269. switch(adjust_index)
  270. {
  271. case 6:
  272. if(x==1&&datetime[6]<99)datetime[6]++;
  273. if(x==-1&&datetime[6]>0)datetime[6]--;
  274. monthsdays[2]=runnian(2000+datetime[6]?29:28);
  275. if(datetime[3]>monthsdays[datetime[4]])
  276. datetime[3]=monthsdays[datetime[4]];
  277. refresh_week_day();
  278. break;
  279. case 4:
  280. if(x==1&&datetime[4]<12)
  281. datetime[4]++;
  282. if(x==-1&&datetime[4]>1)
  283. datetime[4]--;
  284. monthsdays[2]=runnian(2000+datetime[6])?29:28;
  285. if(datetime[3]>monthsdays[datetime[4]])
  286. datetime[3]=monthsdays[datetime[4]];
  287. refresh_week_day();
  288. break;
  289. case 3:
  290. monthsdays[2]=runnian(2000+datetime[6])?29:28;
  291.   if(x==1&&datetime[3]<monthsdays[datetime[4]])
  292.   datetime[3]++;
  293.   if(x==-1&&datetime[3]>0)
  294.   datetime[3]--;
  295.   refresh_week_day();
  296.   break;
  297.   case 2:
  298.   if(x==1&&datetime[2]<23)
  299.   datetime[2]++;
  300.   if(x==-1&&datetime[2]>0)
  301.    datetime[2]--;
  302.    break;
  303.    case 1:
  304.   if(x==1&&datetime[1]<59)
  305.    datetime[1]++;
  306.   if(x==-1&&datetime[1]>0)
  307.    datetime[1]--;
  308.    break;
  309.    }
  310.    }
  311.    void T0_INT() interrupt 1
  312.    {
  313.    TH0=5000/256;
  314.    TL0=5000%256;
  315.    if(++tcount!=2)return;
  316.    tcount=0;
  317.    format_datetime(datetime[6],LCD_buffer1+5);
  318.    format_datetime(datetime[4],LCD_buffer1+8);
  319.    format_datetime(datetime[3],LCD_buffer1+11);
  320.    strcpy(LCD_buffer1+13,week[datetime[5]-1]);
  321.    format_datetime(datetime[2],LCD_buffer2+5);
  322.    format_datetime(datetime[1],LCD_buffer2+8);
  323.    format_datetime(datetime[0],LCD_buffer2+11);
  324.    display_string(0x00,LCD_buffer1);
  325.    display_string(0x40,LCD_buffer2);
  326.    }
程序无法编译,仿真也不显示字符怎么办?如何找错误,求大神帮助
下载:
程序.zip
31.8 KB, 下载次数: 249
用DS1302与1602LCD设计的可调式电子日历与时钟.zip
10.35 KB, 下载次数: 209
参与人数 3黑币 +9 收起 理由
是的发生 + 3 很给力!
29qq + 1 共享资料的黑币奖励!
zzdzhf + 5 很给力!
收藏收藏3 分享淘帖 顶 踩
ID:157576 发表于 2016-12-27 21:10 | 只看该作者
LCD感觉像一个摆设啊
ID:167465 发表于 2017-3-2 22:28 | 只看该作者
为什么仿真不成功
ID:270105 发表于 2018-1-5 13:06 | 只看该作者
为什么LCD1602不显示出时间啊?
ID:275761 发表于 2018-1-14 15:38 | 只看该作者
程序可以参考,但有些问题
ID:574538 发表于 2019-6-29 13:53 | 只看该作者
显示器显示不出来?
ID:763892 发表于 2020-6-2 14:37 来自触屏版 | 只看该作者
416659851 发表于 2019-6-29 13:53
显示器显示不出来?
有修改好的程序和Proteus文件么
ID:490561 发表于 2026-1-9 12:53 | 只看该作者
#include<reg51.h>
#include<string.h>
#include<intrins.h>
#include "LCD1602.H"
uchar code mychar[8][8]={
        0x08,0x0F,0x12,0x0F,0x0A,0x1F,0x02,0x02,        //年        0x00
        0x0F,0x09,0x0F,0x09,0x0F,0x09,0x13,0x00,        //月        0x01
        0x1F,0x11,0x11,0x1F,0x11,0x11,0x1F,0x00,        //日        0x02
        0x10,0x06,0x09,0x08,0x08,0x08,0x09,0x06,        // ℃                0x03
        0x01,0x03,0x1D,0x11,0x1D,0x03,0x01,0x00,  //小喇叭标记        0x04
        0x1F,0x0A,0x0A,0x1F,0x0A,0x0A,0x1A,0x00,  // 开  0x05
        0x11,0x0A,0x1F,0x04,0x1F,0x0A,0x11,0x00,         // 关  0x06
        0x04,0x0E,0x0E,0x0E,0x1F,0x1F,0x04,0x00,  // 闹钟标记 0x07
///****************延时函数************************/
//void delay(uint i)
//  while(--i);  //自减 当i为1时,跳出循环
/****************侧忙函数************************/
bit  ReadStatusLCD()
        bit result;
        LCD_RS = 0;
        LCD_RW = 1;
        LCD_E = 1;
  delay(50);
        result = (bit)(LCD_Data&0x80);  //当LCD_DATA&0x80不为0时result=1,否则result=0
        LCD_E = 0;
        return result;
/****************LCD1602写指令函数************************/
/*写指令数据到LCD
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。
void WriteCommandLCM(uchar WDLCD)
        while(ReadStatusLCD());
  LCD_RS = 0; //表示向LCM写入指令
  LCD_RW = 0; //表示向LCM写入指令
  /****在高脉冲下命令输入*****/
  LCD_E = 0;
        delay(50);
  LCD_Data = WDLCD; //指令代码
  delay(50);;
  LCD_E = 1;
  delay(50);
  LCD_E = 0;
/****************LCD1602写数据函数************************/
/*写显示数据到LCD
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。
void WriteDataLCM(uchar WDLCD)
        LCD_RS = 1;//写数据使能
  LCD_RW = 0;
  /****在高脉冲下数据输入*****/
  LCD_E = 0;
  LCD_Data = WDLCD;  //数据内容
  delay(50);
  LCD_E = 1;
  delay(50);
  LCD_E = 0;
/****************CGRAM区写入自定义的字符************************/
void WriteCGRAM(void)
        uchar x,y;
        WriteCommandLCM(0x40);
        for(y = 0; y < 8; y++)
  for(x = 0; x < 8; x++)
          WriteDataLCM(mychar[y][x]);   //写入自定义汉字字模,作为临时字库。掉电会清除。
extern uchar code time0[];       //显示日期字符串
extern uchar code time1[];       //显示时间字符串
/****************初始化LCD1602函数************************/
void LCMInit(void)
  uchar i;
        P2&=~0x10;
        delay(50);
  WriteCommandLCM(0x38);//显示模式设置
  delay(50);
  delay(50);
  WriteCommandLCM(0x08);//显示关闭
  delay(50);
  WriteCommandLCM(0x01);//清除DDRAM的所有单元,光标被移动到屏幕左上角,也就是清除屏幕内容
  WriteCommandLCM(0x06);//光标移动设置整屏不移动
  WriteCommandLCM(0x0c);//屏幕开、光标不闪(0)不显示(0)
  delay(50);
  WriteCommandLCM(0x80);   //指定第一行
  for(i = 0;i < 16;i++)
    WriteDataLCM(time0[i]);   //显示字符 日期
                delay(5);
                switch(i)
                  case 4 : WriteDataLCM(0x00);break;   //显示自定义汉字 年
                        case 6 : WriteDataLCM(0x01);break;   //显示自定义汉字 月
                        case 8 : WriteDataLCM(0x02);break;   //显示自定义汉字 日
  WriteCommandLCM(0x80+0x40);  //指定第二行
  for(i = 0;i < 12;i++)
    WriteDataLCM(time1[i]);    //显示字符 时间
    delay(5);
