查看: 3764|回复: 1
串口调试工具vb源码
ID:142312 发表于 2016-10-11 13:40 | 显示全部楼层 |阅读模式
Private Sub ComMS_Click()
If ComMS.Caption = "打开串口" Then
ComMS.Caption = "关闭串口"
MSComm1.CommPort = Mid(Combo1.Text, 4)
    If MSComm1.PortOpen = False Then
        MSComm1.PortOpen = True
    Else
        MsgBox "串口已经打开!"
        Exit Sub
    End If
Else
    If MSComm1.PortOpen = True Then
    End If
End If
'If MSComm1.PortOpen = True Then
'    Me.Caption = "串口已经打开!"
'End If
End Sub
Private Sub ComTXA_Click()
'发送文本文件类
串口调试
串口调试
    '清空接收缓冲区
    MSComm1.InBufferCount = 0
    '发送数据帧
    MSComm1.Output = TextTXA.Text
End Sub
Private Sub ComTXN_Click()
'''''''''''''''''''''''''''发送多字节类
'定义变量
    Dim i As Byte
    Dim TXSum As Integer
    Dim TXBuff(0 To 8) As Byte
    Dim StrTX_Temp As String
    Dim StrData As String
TXSum = 0
For i = 0 To 7
    TXBuff(i) = Val("&H" & UCase(TextN(i))
     TXSum = TXSum + TXBuff(i)
Next i
    TXBuff(8) = TXSum Mod 256
'清空接收缓冲区
'发送数据帧
MSComm1.Output = TXBuff
End Sub
ID:298008 发表于 2020-5-4 07:47 | 显示全部楼层
谢谢楼主分享!!
