查看: 5777|回复: 3
求知,数码管程序编写时数组定义问题
ID:75319 发表于 2015-3-25 16:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include<reg51.h>
unsigned char  code table1[8] = {0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char  code table2[17]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
unsigned char  code data[8];
        unsigned char i;
        unsigned int j;
                for(i=0;i<8;i++)
                        data[i]=table2[i]
                        unsigned char a;
                        for(a=0;a<8;a++)
                                P1=table1[i];
                                P0=data[i];
                                j=10;
                                while(j--);
                                P0=0x00;
错误
compiling led1.c...
LED1.C(5): error C141: syntax error near 'data'
LED1.C(5): error C141: syntax error near '['
LED1.C(9): error C141: syntax error near 'data'
LED1.C(9): error C141: syntax error near '['
LED1.C(9): error C141: syntax error near ']'
LED1.C(10): error C141: syntax error near 'unsigned'
LED1.C(10): error C202: 'i': undefined identifier
LED1.C(11): error C141: syntax error near 'unsigned'
LED1.C(11): error C202: 'j': undefined identifier
LED1.C(12): error C202: 'i': undefined identifier
LED1.C(14): error C141: syntax error near '['
LED1.C(14): error C202: 'i': undefined identifier
LED1.C(15): error C141: syntax error near '}'
LED1.C(21): error C202: 'i': undefined identifier
LED1.C(22): error C141: syntax error near 'data'
LED1.C(22): error C202: 'i': undefined identifier
LED1.C(24): error C202: 'j': undefined identifier
Target not created
ID:58502 发表于 2015-3-26 00:29 | 只看该作者
这个不能用code,code是存在ROM里面的,不能改变值,而你这个是需要改变的,所以要去掉code
ID:75077 发表于 2015-3-26 14:17 | 只看该作者
楼上言之有理。。。
ID:78515 发表于 2015-5-23 14:54 | 只看该作者
楼上说的是呀,通常来说常量都是放在单片机ROM里的,为了区别常量变量,51单片机code及存放在单片机ROM里
