查看: 19748|回复: 20
智能循迹小车电路图单片机程序与proteus仿真
ID:287566 发表于 2018-3-4 22:24 | 显示全部楼层 |阅读模式
发个智能循迹小车电路图和程序及仿真图,希望对大家有用
LM393比较器的作用:-端电平大于+端10mV,输出低电平,
相反,输出端导通,由上拉电阻R4(VCC)给输出端高电平
检测白线光电传器不导通,端口2电平为0,
检测到黑线光电传器导通,端口2电平由VCC经R6分压后得高电平
元件清单:
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar temp,signal,tt1;
  5. void delay_1ms(uint d)
  6. {
  7.         uint i;
  8.         while(d--)
  9.                 for(i=0;i<75;i++);
  10. }
  11. void motor_run()                   //电机起动
  12. {
  13.           P1=0x35;
  14.         delay_1ms(150);
  15.         P1=0x00;
  16.         delay_1ms(20);
  17. /*        ENA=1;
  18.         OUT1=0;
  19.         OUT2=1;
  20.         delay_1ms(800);
  21.         OUT2=0;
  22.         delay_1ms(200);
  23.
  24.         ENB=1;
  25.         OUT4=0;
  26.         OUT3=1;
  27.         delay_1ms(800);
  28.         OUT3=0;
  29.         delay_1ms(200);
  30. */
  31. }
  32. void motor_left()                         //左进
  33. {
  34.         P1=0x30;
  35.         delay_1ms(150);
  36.         P1=0x00;
  37.         delay_1ms(20);
  38. }
  39. void motor_right()                   //右进
  40. {
  41.         P1=0x05;
  42.         delay_1ms(150);
  43.         P1=0x00;
  44.         delay_1ms(20);
  45. }
  46. void motor_big_right()                         //粗右进
  47. {
  48.         P1=0x55;
  49.         delay_1ms(150);
  50.         P1=0x00;
  51.         delay_1ms(20);
  52. }
  53. void motor_big_left()
  54. {
  55.         P1=0x33;
  56.         delay_1ms(150);
  57.         P1=0x00;
  58.         delay_1ms(20);
  59. }
  60. void motor_stop()                                        //电机停止
  61. {
  62.          P1=0x00;
  63. }
  64. void motor_back()
  65. {
  66.         P1=0x53;
  67. }
  68. void main()
  69. {
  70.         tt1=0;
  71.         EA=1;
  72.         ET1=1;
  73.         TR1=1;
  74.         TMOD=0x01;
  75.         TH1=-(1000/256);
  76.         TL1=-(1000%256);
  77.         while(1)
  78.         {
  79.                  temp=P2;
  80.                 signal=temp&0xff;                   //得到红外反向信号
  81.                 switch(signal)
  82.                 {
  83.                         case 0xff:           //无偏差
  84.                                 motor_run();
  85.                                 break;
  86.                         case 0xfd:           //1轮右偏
  87.                                 motor_left();
  88.                                 break;
  89.                         case 0xef:            //4轮左偏
  90.                                 motor_right();
  91.                                 break;
  92.                         case 0xfb:     //2轮右偏出轨
  93.                         case 0xf9:           //1、2轮右偏
  94.                                  motor_big_left();
  95. //                                delay_1ms(10);
  96.                                 break;
  97.                         case 0xdf:           //5左偏出轨
  98.                         case 0xcf:      //4、5轮左偏
  99.                                  motor_big_right();
  100. //                                delay_1ms(10);
  101.                                 break;
  102.                         case 0xfe:           //0最右偏出轨
  103.                         case 0xfa:
  104.                                  motor_big_left();
  105. //                                delay_1ms(10);
  106.                                 break;
  107.                         case 0xbf:     //6最左偏出轨
  108.                          case 0x9f:
  109.                                 motor_big_right();
  110. //                                delay_1ms(10);
  111.                                 break;
  112.
  113.                         case 0xeb:         //前两传感器压在黑线上
  114.                         case 0xdb:         //后两传感器压在黑线上
  115.                         case 0xbe:         //中间两传感器压在黑线上
  116.                         case 0xac:                 //前四传感器压在黑线上
  117.                         case 0x9a:                //后四传感器压在黑线上
  118.                                 motor_back();
  119.                                 delay_1ms(200);
  120.                                 motor_stop();
  121.
  122. //                                delay_1ms(1000);
  123.                         default:
  124. ……………………
  125. …………限于本文篇幅 余下代码请从51黑下载附件…………
智能循迹小车电路图和程序及仿真图.rar (128.98 KB, 下载次数: 441)
参与人数 3黑币 +63 收起 理由
1234567890qwert + 5
明天26号 + 8 赞一个!
ID:79874 发表于 2018-6-26 07:17 | 显示全部楼层
谢谢分享
ID:359143 发表于 2018-6-26 12:43 | 显示全部楼层
有电路图吗?
ID:349520 发表于 2019-4-29 22:26 | 显示全部楼层
不错真厉害
ID:349520 发表于 2019-4-29 22:27 | 显示全部楼层
是三个轮子的吗
ID:526864 发表于 2019-5-4 11:45 | 显示全部楼层
感谢分享
ID:540727 发表于 2019-5-17 17:35 来自手机 | 显示全部楼层
楼主有实物么
ID:580160 发表于 2019-7-9 09:14 | 显示全部楼层
赞一个
ID:581439 发表于 2019-7-11 16:57 | 显示全部楼层
没有PCB。。。
ID:582476 发表于 2019-7-11 18:07 | 显示全部楼层
机械渣渣最近在做,需要电路仿真,大佬可以发一份,谢谢!
ID:583531 发表于 2019-7-13 16:23 | 显示全部楼层
这个不错
ID:440128 发表于 2019-7-22 11:19 | 显示全部楼层
双选爱 发表于 2018-4-25 23:19
可以发一份给我吗?
邮箱:
人家凭什么发给你,明明都有为什么不直接下载?
ID:616896 发表于 2019-11-17 22:16 | 显示全部楼层
谢谢分享
ID:673779 发表于 2019-12-25 18:12 | 显示全部楼层
为什么我用protues8.8打不开
ID:720325 发表于 2020-4-1 16:20 | 显示全部楼层
真好请问是怎么做的
ID:722299 发表于 2020-5-18 10:31 | 显示全部楼层
问一下这是几个轮子的,程序4,5轮完全不懂
ID:758501 发表于 2020-6-6 09:47 | 显示全部楼层
为什么我打不开仿真的那个文件?
ID:56932 发表于 2020-6-11 22:36 | 显示全部楼层
谢谢分享
ID:757948 发表于 2020-6-12 11:17 | 显示全部楼层
zhangaoxiang66 发表于 2020-6-6 09:47
为什么我打不开仿真的那个文件?
我也打不开
ID:1032785 发表于 2023-5-23 10:21 | 显示全部楼层
整的太好了
ID:1088383 发表于 2023-8-26 15:32 | 显示全部楼层
为什么都不用黑币下载,要发到你邮箱去
