专注电子技术学习与研究
Mega16按键与数码显示程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2012年04月11日   【字体:大 中 小】
#include <mega16.h>
#include <delay.h>
#define No_key 255
#define K1_11
#define K1_22
#define K1_33
#define K1_4    4
#define K2_15
#define K2_26
#define K2_37
#define K2_4    8
#define K3_19
#define K3_20
#define K3_310
#define K3_4    11
#define K4_112
#define K4_213
#define K4_314
#define K4_4    15
#define Key_mask0b00001111
#define data PORTB.0
#define clk PORTB.1
flash unsigned char led[16]={0x28,0xeb,0x19,0x89,0xca,0x8c,0x0c,0xe9,0x08,0x88,
                             0xdf,0x4a,0x1c,0x3e,0x7e,0x2a};
unsigned charkey_stime_counter;
unsigned char   key_temp;
bitkey_stime_ok;
//D0接键盘,低4位列线输入,高4位行线输出
unsigned char read_keyboard()
 static unsigned char key_state = 0, key_value, key_line;
 unsigned char key_return = No_key,i;
 switch (key_state)
  case 0:
  key_line = 0b00010000;
  for (i=1; i<=4; i++)// 扫描键盘
         PORTA = ~key_line;// 输出行线电平
 PORTA = ~key_line;// 必须送2次!!!
 key_value = Key_mask & PINA;// 读列电平
 if (key_value == Key_mask)
 key_line <<= 1;// 没有按键,继续扫描
  key_state++;// 有按键,停止扫描
  break;// 转消抖确认状态
break;
  case 1:
        if (key_value == (Key_mask & PINA))// 再次读列电平,
 switch (key_line | key_value)// 与状态0的相同,确认按键
 {// 键盘编码,返回编码值
  case 0b00011110:
       key_return = K1_1;
       break;
  case 0b00011101:
       key_return = K1_2;
       break;
          case 0b00011011:
       key_return = K1_3;
       break;
  case 0b00010111:
       key_return = K1_4;
       break;
  case 0b00101110:
       key_return = K2_1;
       break;
   case 0b00101101:
       key_return = K2_2;
       break;
  case 0b00101011:
       key_return = K2_3;
       break;
  case 0b00100111:
       key_return = K2_4;
       break;
   case 0b01001110:
       key_return = K3_1;
       break;
   case 0b01001101:
       key_return = K3_2;
       break;
  case 0b01001011:
       key_return = K3_3;
       break;
  case 0b01000111:
       key_return = K3_4;
       break;
   case 0b10001110:
       key_return = K4_1;
       break;
   case 0b10001101:
       key_return = K4_2;
       break;
  case 0b10001011:
       key_return = K4_3;
       break;
  case 0b10000111:
       key_return = K4_4;
       break;
key_state++;// 转入等待按键释放状态
  key_state--;
  delay_ms(5);
 }// 两次列电平不同返回状态0,(消抖处理)
 break;
  case 2:// 等待按键释放状态
      PORTA = 0b00001111;// 行线全部输出低电平
      PORTA = 0b00001111;// 重复送一次
      if ( (Key_mask & PINA) == Key_mask)
      key_state=0;// 列线全部为高电平返回状态0
      break;
 return key_return;
//向数码管送入数据
void sendbyte(unsigned char byte)
 unsigned char num,c;
 num=led[byte];
 for(c=0;c<8;c++)
  clk=0;
  data=num&0x01;
  clk=1;
  num>>=1;
void display(void)
 if (key_stime_ok)
   key_stime_ok = 0;// 10ms到
   key_temp = read_keyboard();// 调用键盘接口函数读键盘
   if (key_temp != No_key)
   {// 有按键按下
    sendbyte(key_temp);
    delay_ms(10);
void main(void)
 DDRB = 0xFF;
 //PORTC = 0xFF;// 键盘接口初始化
 DDRA = 0xF0;// PD2、PD1、PD0列线,输入方式,上拉有效
 // T/C0 初始化
 TCCR0=0x0B;// 内部时钟,64分频(4M/64=62.5KHz),CTC模式
 TCNT0=0x00;
 OCR0=0x7C;// OCR0 = 0x7C(124),(124+1)/62.5=2ms
 TIMSK=0x02;// 允许T/C0比较匹配中断
 #asm("sei")// 开放全局中断
 while (1)
  display();
// Timer 0 比较匹配中断服务,2ms定时
interrupt [TIM0_COMP] void timer0_comp_isr(void)
 //display();// 调用LED扫描显示
 if (++key_stime_counter >=5)
  key_stime_counter = 0;
  key_stime_ok = 1;// 10ms到
【关闭窗口】
相关文章
