专注电子技术学习与研究
基于C8051F的AD UART0 KEY FLASH TIME3程序
作者:文于鹰   来源:本站原创   点击数:…  更新时间:2013年12月06日   【字体:大 中 小】
// Main.c
// Copyright (C) 2011 Shenyang 213.
//  Wbr
// Tool chain: KEIL Full  'c'
//#pragma CD OE DB SB                    // Compilation directives
// Includes
#include "C8051F340.h"
#include "1302.h"
#include "lcd.h"
#include <INTRINS.H>
#define SYSCLK          12000000       // SYSCLK frequency in Hz
// Global CONSTANTS
#define uint  unsigned int
#define T 1800                             //运算电量的时间单位1800是半个小时(1800秒)
#define N 11
sfr16 TMR2 = 0xCC;        //定义成16位地址
sfr16 ADC0 = 0xBD;
uint xdata ADCbuffer1[N];
uint count;
uint  sum = 0;
uchar ADcount = 0;
uchar ADsend;
uchar Page = 1,direction = 1;
uchar set = 0,ent = 0,Tset;
uchar TH,TL,TT1,TT2,TT3;     //用来拆分送显示的变量
uchar keybuffer[6];
uchar BGset=0;          //BGset背光关,开控制量,如果没有键按下超过1分钟,关闭背光!有键按下立刻开背光
bit Disptime,PDD;
sbit DI1  = P0^0 ;
sbit DI2  = P0^1 ;
sbit DE    = P0^6 ;
sbit BLK    = P0^7 ;        //LCD背光
sbit JC1   = P2^7 ;
sbit JC2   = P3^1 ;
sbit JC3   = P3^2 ;
sbit JC4  = P3^3 ;
sbit DI3   = P3^6 ;
sbit DI4  = P3^7 ;
uchar code  CPT_c[20] _at_ 0x8000;           //7k的地址左右//充电时间要存入的FLASH地址,保存3天的时间和功率
uchar xdata CPT_x[20] _at_ 0x8000;
uchar code  FPT_c[20] _at_ 0x8200;           //7k的地址左右//放电时间要存入的FLASH地址,保存3天的时间和功率
uchar xdata FPT_x[20] _at_ 0x8200;
uchar xdata Between[20];       //0~11时间12~19存功率
extern void Init_Device(void);
extern  uchar  time_buf1[8] ;
uchar  code tab1[]={
"实时电压:"
uchar  code tab2[]={
"实时电流:"
uchar  code tab3[]={
"实时功率:"
uchar  code tab4[]={
"运行状态:"
uchar  code tab5[]={
"历史充电记录"
uchar  code tab6[]={
"历史放电记录"
uchar  code tab7[]={
"当前时间"
uchar  code tab8[]={
"修改时间"
uchar  code tab9[]={
"暂无记录"
uchar  code run1[]={
"停机"
uchar  code run2[]={
"充电"
uchar  code run3[]={
"放电"
uchar  code run4[]={
"故障"
//uchar  code run5[]={
//"系统故障信息"
uchar  code run5[]={
"感谢您的使用"
uchar  code run6[]={
"本日累计充电"
uchar  code run7[]={
"本日累计放电"
uchar  code run8[]={
"版本号:V1.0"
uchar  xdata TAB[11]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x20};//数字0~9及显示空白0x20
// Function PROTOTYPES
void delayms(uint ms)
 uint Temp;
 while(ms--)
   Temp=1000;
   while(Temp--);
     //PCA0CPH2 = 1;
/*void Timer2_Init(int count2s)
 TMR2CN = 0x00;
  TMR2L = -count2s;
  TMR2 = 0xffff;
  ET2 = 1;
  TR2 = 1;
//中值滤波程序
void filter()
   static uchar count,i,j;
   uint value_buf[N];
   uint temp;
   sum=0;
   for(count=0;count<N;count++)
      value_buf[count] = ADCbuffer1[count];;
   for (j=0;j<N-1;j++)
      for (i=0;i<N-j;i++)
          if ( value_buf[i]>value_buf[i+1] )
              temp = value_buf[i];
              value_buf[i] = value_buf[i+1];
              value_buf[i+1] = temp;
  for(count=1;count<N-1;count++)
  sum += value_buf[count];
void Uart0_SendData(uchar dat0)
   SBUF0=dat0;          //写SBUF0,开始发送
   while(TI0==0);       //等待发送
   TI0=0;               //清发送标志位
void Flash_Erase_CTP()                //flash擦除充电时间和功率
 EA =0;
 VDM0CN = 0x80;                      // 使能VDD监视器
    RSTSRC = 0x02;                      // 上电复位VDD监视器复位标志
    FLSCL=0X80;                         // 使能FLASH单稳态定时器,FLASH读时间SYSCLK<=25MHz
  FLKEY  = 0xA5;                      // 写入关键字
    FLKEY  = 0xF1;                      // 写入关键字
 PSCTL |= 0x03;                      //允许擦,允许写
  CPT_x[0] = 0;
 PSCTL &= ~0x03;                     //禁止写,禁止擦
 //EA = 1;
void Flash_Program_CTP()              //flash写入充电时间时间和功率
 uchar j;
 EA =0;
  //Flash_Erase_CTP();
 VDM0CN = 0x80;                      //使能VDD监视器
    RSTSRC = 0x02;                      //上电复位/VDD监视器复位标志
    FLSCL=0X80;                         //使能FLASH单稳态定时器,FLASH读时间SYSCLK<=25MHz
  PSCTL |= 0x01;                    //write enable
  for(j =0;j<20;j++)
    FLKEY = 0xa5;
    FLKEY = 0xf1;
    CPT_x[j] = Between[j];
    //delayms(30);
   PSCTL &= ~0x01;                     //禁止写
   EA = 1;
void Flash_Erase_FTP()                //flash擦除放电时间和功率
 EA =0;
  FPT_x[0] = 0;
 //EA = 1;
void Flash_Program_FTP()              //flash写入放电时间和功率
 uchar j;
  //Flash_Erase_FTP();
 EA = 0;
  PSCTL|=0x01;                    //write enable
  for(j =0;j<20;j++)
    FLKEY = 0xa5;
    FLKEY = 0xf1;
    FPT_x[j] = Between[j];
   EA = 1;
/*void Flash_Read()
  static uchar j;
  for(j=0;j<3;j++)
    timer[j]=Ftime_c[j];
//按键处理程序
void key_scan()
    static uchar i,k;
 uchar Mkey=P4;
 if(BGset<2)
   if((Mkey&0xFE)!= 0XFE)      //有键按下先开启背光
     delayms(200);
       BGset++;
       if(BGset>1)
         BGset = 2;
 if(BGset ==2 )
 if(!(Mkey&0x80))         //SW1按下吗?ALM
   delayms(200);      //消抖
   if(!(Mkey&0x80))      //再判断
     BGset =2;     //开背光
     if(k<1) {Page = 0;}   //页面0:显示故障状态}
     k++;
     if(k>1) {k =0;Page = 1; } //再按后退出
     set = 0;
 if(!set)
   if(!(Mkey&0x40))        //SW2按下吗?下翻
     delayms(200);
     if(!(Mkey&0x40))
       if(Page !=0)
         Page++;
         BGset =2;
         if(Page>6)     //如果超过5界面回到1画面
           Page = 1;
   if(!(Mkey&0x20))        //SW3按下吗?上翻
     delayms(200);
     if(!(Mkey&0x20))
       if(Page !=0)
         Page--;
         BGset =2;
         if(Page<1)     //小于1画面后不显示0画面,显示6画面
           Page = 6;
 if(Page ==6)            //修改时间界面
   if(!(Mkey&0x04))          //SW6按下吗?设定SET只在6画面设置时间
     delayms(200);
     if(!(Mkey&0x04))
       BGset =2;
       set = 1;       //如果按下SET键表示开始设置时间,置设置标志位;
   if(set)
     if(!(Mkey&0x10))        //SW4按下吗?左移<- 只在6画面修改时间
       delayms(200);
       if(!(Mkey&0x10))
         BGset =2;
         direction--;
         if(direction < 1)
           direction = 6;
     if(!(Mkey&0x08))        //SW5按下吗?右移->只在6画面修改时间
       delayms(200);
       if(!(Mkey&0x08))
         BGset =2;
         direction++;
         if(direction > 6)
           direction = 1;
     switch(direction)
       case 1:
         if(!(P4&0x40))        //SW2按下吗?下翻
           delayms(200);
           if(!(P4&0x40))
             BGset =2;
             keybuffer[0]++;
             if(keybuffer[0]>99)   //年设置,不超过100年
               keybuffer[0] = 11;
         if(!(P4&0x20))        //SW3按下吗?上翻
           delayms(200);
           if(!(P4&0x20))
             BGset =2;
             keybuffer[0]--;
             if(keybuffer[0]<11)     //小于1画面后不显示0画面,显示6画面
               keybuffer[0] = 11;
         if(Tset < 4)
           TH = keybuffer[0]/10;
           TL = keybuffer[0]%10;
           number_disp (1,0,0x91,1,TAB[TH],TAB[TL]);
         if(Tset>4)
           number_disp (1,0,0x91,1,0x20,0x20);
        }break;
       case 2:
           delayms(200);
           if(!(P4&0x40))
             BGset =2;
             keybuffer[1]++;
             if(keybuffer[1]>12)   //月设置,不超过12月
               keybuffer[1] = 1;
           delayms(200);
           if(!(P4&0x20))
             BGset =2;
             keybuffer[1]--;
             if(keybuffer[1]<1)     //小于1 显示12月
               keybuffer[1] = 12;
         if(Tset < 4)
           TH = keybuffer[1]/10;
           TL = keybuffer[1]%10;
           number_disp (1,0,0x93,1,TAB[TH],TAB[TL]);
         if(Tset>4)
           number_disp (1,0,0x93,1,0x20,0x20);
        }break;
       case 3:
           delayms(200);
           if(!(P4&0x40))
             BGset =2;
             keybuffer[2]++;
             if(keybuffer[2]>31)     //日设置,不超过31日
               keybuffer[2] = 1;
           delayms(200);
           if(!(P4&0x20))
             BGset =2;
             keybuffer[2]--;
             if(keybuffer[2]<1)     //小于1,显示31日
               keybuffer[2] = 31;
         if(Tset<4)
           TH = keybuffer[2]/10;
           TL = keybuffer[2]%10;
           number_disp (1,0,0x95,1,TAB[TH],TAB[TL]);
         if(Tset>4)
           number_disp (1,0,0x95,1,0x20,0x20);
        }break;
       case 4:
           delayms(200);
           if(!(P4&0x40))
             BGset =2;
             keybuffer[3]++;
             if(keybuffer[3]>23)     //时设置,不超过24
               keybuffer[3] = 0;
           delayms(200);
           if(!(P4&0x20))
             BGset =2;
             keybuffer[3]--;
             if(keybuffer[3]<=0)     //小于1,显示23
               keybuffer[3] = 23;
         if(Tset < 4)
           TH = keybuffer[3]/10;
           TL = keybuffer[3]%10;
           number_disp (0,1,0x85,1,TAB[TH],TAB[TL]);
         if(Tset>4)
           number_disp (0,1,0x85,1,0x20,0x20);
        }break;
       case 5:
           delayms(200);
           if(!(P4&0x40))
             BGset =2;
             keybuffer[4]++;
             if(keybuffer[4]>59)     //分设置,不超过59
               keybuffer[4] = 0;
           delayms(200);
           if(!(P4&0x20))
             BGset =2;
             keybuffer[4]--;
             if(keybuffer[4]<=0)     //小于1,显示59
               keybuffer[4] = 59;
         if(Tset < 4)
           TH = keybuffer[4]/10;
           TL = keybuffer[4]%10;
           number_disp (0,1,0x87,1,TAB[TH],TAB[TL]);
         if(Tset>4)
           number_disp (0,1,0x87,1,0x20,0x20);
        }break;
       case 6:
           delayms(200);
           if(!(P4&0x40))
             BGset = 2;
             keybuffer[5]++;
             if(keybuffer[5]>59)     //时设置,不超过24
               keybuffer[5] = 0;
           delayms(200);
           if(!(P4&0x20))
             BGset = 2;
             keybuffer[5]--;
             if(keybuffer[5]<=0)     //小于1,显示23
               keybuffer[5] = 59;
         if(Tset < 4)
           TH = keybuffer[5]/10;
           TL = keybuffer[5]%10;
           number_disp (0,1,0x89,1,TAB[TH],TAB[TL]);
         if(Tset>4)
           number_disp (0,1,0x89,1,0x20,0x20);
        }break;
       default:break;
   if(!(Mkey&0x02))          //SW7按下吗?确认ENT 只在6画面设定时间
     delayms(200);
     if(!(Mkey&0x02))
       BGset =2;
       for(i=0;i<6;i++)
         time_buf1[i+1] = keybuffer[i];
       Ds1302_Write_Time();     //写DS1302
       set = 0;
       Page = 1;       //退出到1画面
void Pchange(uint PW)
 TH =   PW/10000;          //放电万位
 TL =  (PW-TH*10000)/1000;        //千位
 TT1 = (PW-TH*10000-TL*1000)/100;
 TT2 = (PW-TH*10000-TL*1000-TT1*100)/10;
 TT3 = (PW-TH*10000-TL*1000-TT1*100)%10;
 if(!TH)
   TH = 10;
   if(!TL)
     TL = 10;
     if(!TT1)
       TT1 = 10;
// Main  年:0xC4EA 月:0xD4C2 日:0xC8D5 时:0xCAB1: 分0xB7D6: 秒:0xC3EB 的汉字内码
void main(void)
 uchar Page1,j;
 uchar Runstate ;        //Runstate为运行状态指示:DI1=1;DI2=1停机;DI1=0;DI2=1充电;DI1=1;DI2=0放电;DI1=1;DI2=1故障
 uint VT,AT,PT,PC1,PF1,PDIS,PdownCount;   //电压电流功率功率计数变量
 uint ADC1,ADC2,ADC3,ADC4;      //四路AD通道变量
 long a,PT1,PT2;         //P1,P2充放电累计功率
 //P0 = 0;
 //P1 = 0;
 P4 =0xfe;
 P2 = 0;
 P3 = 0;
 Init_Device();
 PCA0MD &= ~0x40;
 EA = 0;
 //BLK = 1;
 delayms(1000);
 Ds1302_Init();
 init_lcd ();
 clrram ();
 ADC0CF = ((SYSCLK/3000000)-1)<<3;           // set SAR clock to 3MHz
 ADC0CN |=0x10;               //写ADC0BUSY位启动转换
    TMR3CN = 0x04;              //启动TM3
    //Timer2_Init(SYSCLK/12/50);             //20ms
 EA = 1;
 DE = 1;
 TR1 = 1;
 Ds1302_Read_Time();
  //PCA0CPH2 = 1;                      //喂狗
  key_scan();
  if(BGset)
    BLK = 1;
  if(!BGset)
    BLK = 0;
   }             //按键扫描
  if((DI1==1)&&(DI2==1))  Runstate = 0xa6;      //停机
  if((DI1==0)&&(DI2==1))  Runstate = 0xb7;      //充电
  if((DI1==1)&&(DI2==0))  Runstate = 0xc8;      //放电
  if((DI1==0)&&(DI2==0))  Runstate = 0xd9;      //故障
  //if(Runstate == 0xb7)           //充电的FLASH存储处理
  if(!set)
    if((time_buf1[2] != CPT_c[10])|| (time_buf1[3] != CPT_c[11])) //读取的当前时间与缓存不等的时候,所有内容依次前移
      Between[0]=CPT_c[3];       //依次前移
      Between[1]=CPT_c[4];
      Between[2]=CPT_c[5];
      Between[3]=CPT_c[6];//年
      Between[4]=CPT_c[7];//月
      Between[5]=CPT_c[8];//日
      Between[6]=CPT_c[9];
      Between[7]=CPT_c[10];
      Between[8]=CPT_c[11];
      Between[9]=time_buf1[1];
      Between[10]=time_buf1[2];
      Between[11]=time_buf1[3];
      Between[12]=CPT_c[14];
      Between[13]=CPT_c[15];
      Between[14]=CPT_c[16];
      Between[15]=CPT_c[17];
      Between[16]=CPT_c[18];
      Between[17]=CPT_c[19];
      Between[18] = PC1>>8;
                    Between[19] = PC1&255;
      Flash_Erase_CTP();
      Flash_Program_CTP();      //保存至FLASH
  //if(Runstate == 0xc8)           //放电时FLASH存储处理
  if(!set)
    if((time_buf1[2] != FPT_c[10])|| (time_buf1[3] != FPT_c[11]))
      Between[0]=FPT_c[3];       //依次前移
      Between[1]=FPT_c[4];
      Between[2]=FPT_c[5];
      Between[3]=FPT_c[6];//年
      Between[4]=FPT_c[7];//月
      Between[5]=FPT_c[8];//日
      Between[6]=FPT_c[9];
      Between[7]=FPT_c[10];
      Between[8]=FPT_c[11];
      Between[12]=FPT_c[14];
      Between[13]=FPT_c[15];
      Between[14]=FPT_c[16];
      Between[15]=FPT_c[17];
      Between[16]=FPT_c[18];
      Between[17]=FPT_c[19];
      Between[18] = PF1>>8;
                    Between[19] = PF1&255;
      Flash_Erase_FTP();
      Flash_Program_FTP();       //保存至FLASH
  if(PDD)
   PDD = 0;
   if(Runstate == 0xb7)                               //如果充电
                 PdownCount++;                               //秒累加
     PT1 = PT1+PT;           //秒累计的功率,
                 PC1 = PT1/3600;                                 //实际充电功率,按小时计算,注意此时累计电量为实际的10倍,为了送小数显示
                 if(PdownCount > T)                            //超过半个小时开始写入EEPROM
       PdownCount = 0;
       for(j=0;j<20;j++)       //先读出FLASH里的时间
           Between[j]=CPT_c[j];
                         if((time_buf1[2] == Between[10])&& (time_buf1[3] == Between[11]))     //当前时间等于缓存时间,继续写入缓存
         Flash_Program_CTP();       //写功率和时间到FLASH
   if(Runstate == 0xc8)                                 //如果放电
                 PdownCount++;                                 //秒累加
                 PT2 = PT2+PT;             //秒累计的功率
     PF1 = PT2/3600;                                   //实际放电功率,按小时计算,,注意此时累计电量为实际的10倍,为了送小数显示
       PdownCount = 0;
           Between[j]=FPT_c[j];
         Flash_Program_FTP();       //写功率和时间到FLASH
  if(Disptime)
    Disptime = 0;
    Ds1302_Read_Time();
    if(Page!=Page1)
      clrram ();          //如果页面变化,需要清屏;
    switch(Page)
      case 1: //画面1:显示当前电压电流
        string_disp (1,0,0x80,10,tab1);       //显示电压
        string_disp (1,0,0x90,10,tab2);       //显示电流
        string_disp (0,1,0x80,10,tab3);       //显示功率
        string_disp (0,1,0x90,10,tab4);
        if(Runstate == 0xa6)string_disp (0,1,0x96,4,run1);  //显示停机
        if(Runstate == 0xb7)string_disp (0,1,0x96,4,run2);  //显示充电
        if(Runstate == 0xc8)string_disp (0,1,0x96,4,run3);  //显示放电
        if(Runstate == 0xd9)string_disp (0,1,0x96,4,run4);  //显示故障
        TH= VT/1000;         //拆分送显示千位
        TL = (VT%1000)/100;        //拆分送显示百位
        TT1 = ((VT%1000)%100)/10;      //拆分送显示十位
        TT2 = ((VT%1000)%100)%10;      //拆分送显示个位
        if(!TH)
          TH = 10;
          if(!TL)
            TL = 10;
        number_disp (1,0,0x85,1,TAB[TH],TAB[TL]);    //电压送显示
        number_disp (1,0,0x86,1,TAB[TT1],0x2E);
        number_disp (1,0,0x87,1,TAB[TT2],0x20);
        number_disp (1,0,0x88,1,0x56,0x20);
        TH= AT/1000;         //拆分送显示千位
        TL = (AT%1000)/100;        //拆分送显示百位
        TT1 = ((AT%1000)%100)/10;      //拆分送显示十位
        TT2 = ((AT%1000)%100)%10;      //拆分送显示个位
        if(!TH)           //高位为零,灭零处理
          TH = 10;
          if(!TL)
            TL = 10;
        number_disp (1,0,0x95,1,TAB[TH],TAB[TL]);    //电流送显示
        number_disp (1,0,0x96,1,TAB[TT1],0x2E);
        number_disp (1,0,0x97,1,TAB[TT2],0x20);
        number_disp (1,0,0x98,1,0x41,0x20);
        TH= PT/1000;         //拆分送显示千位
        TL = (PT%1000)/100;        //拆分送显示百位
        TT1 = ((PT%1000)%100)/10;      //拆分送显示十位
        TT2 = ((PT%1000)%100)%10;      //拆分送显示个位
        if(!TH)           //高位为零,灭零处理
          TH = 10;
          if(!TL)
            TL = 10;
        number_disp (0,1,0x85,1,TAB[TH],TAB[TL]);    //功率送显示
        number_disp (0,1,0x86,1,TAB[TT1],0x2E);
        number_disp (0,1,0x87,1,TAB[TT2],0x4B);
        number_disp (0,1,0x88,1,0x57,0x20);
        Page1=Page;            //保存当前页面值
       }break;
      case 2:
        string_disp (1,0,0x80,12,run6);
        string_disp (0,1,0x80,12,run7);
        Pchange(PC1);
        number_disp (1,0,0x94,1,TAB[TH],TAB[TL]);
        number_disp (1,0,0x95,1,TAB[TT1],TAB[TT2]);
        number_disp (1,0,0x96,1,0x2e,TAB[TT3]);
        number_disp (1,0,0x97,1,0x4b,0x57);
        Pchange(PF1);
        number_disp (0,1,0x94,1,TAB[TH],TAB[TL]);
        number_disp (0,1,0x95,1,TAB[TT1],TAB[TT2]);
        number_disp (0,1,0x96,1,0x2e,TAB[TT3]);
        number_disp (0,1,0x97,1,0x4b,0x57);
        Page1=Page;
       }break;
      case 3: //显示历史充电记录
        string_disp (1,0,0x80,12,tab5);       //
        //第1条信息
        if((CPT_c[0]>99)||(CPT_c[1]>12)||(CPT_c[2]>31))
          string_disp (1,0,0x90,8,tab9);
         }     //如果读取时间不对,显示“暂无记录”
          number_disp (1,0,0x90,1,0x32,0x30);     //0送显示
          TH = CPT_c[0]/10;
          TL = CPT_c[0]%10;
          number_disp (1,0,0x92,1,0xc4,0xea);     //年
          TH = CPT_c[1]/10;
          TL = CPT_c[1]%10;
          number_disp (1,0,0x94,1,0xd4,0xc2);     //月
          TH = CPT_c[2]/10;
          TL = CPT_c[2]%10;
          number_disp (1,0,0x96,1,0xc8,0xd5);     //日
          PDIS = CPT_c[12];
          PDIS = PDIS<<8 + CPT_c[13];
          Pchange(PDIS);
          number_disp (1,0,0x98,1,TAB[TH],TAB[TL]);
          number_disp (1,0,0x99,1,TAB[TT1],TAB[TT2]);
          number_disp (1,0,0x9A,1,0x2e,TAB[TT3]);
          number_disp (1,0,0x9B,1,0x4b,0x57);
        //第2条信息
        if((CPT_c[3]>99)||(CPT_c[4]>12)||(CPT_c[5]>31))
          string_disp (0,1,0x80,8,tab9);
          number_disp (0,1,0x80,1,0x32,0x30);     //0送显示
          TH = CPT_c[3]/10;
          TL = CPT_c[3]%10;
          number_disp (0,1,0x81,1,TAB[TH],TAB[TL]);
          number_disp (0,1,0x82,1,0xc4,0xea);     //年
          TH = CPT_c[4]/10;
          TL = CPT_c[4]%10;
          number_disp (0,1,0x83,1,TAB[TH],TAB[TL]);
          number_disp (0,1,0x84,1,0xd4,0xc2);     //月
          TH = CPT_c[5]/10;
          TL = CPT_c[5]%10;
          number_disp (0,1,0x86,1,0xc8,0xd5);     //日
          PDIS = CPT_c[14];
          PDIS = PDIS<<8 + CPT_c[15];
          Pchange(PDIS);
          number_disp (0,1,0x88,1,TAB[TH],TAB[TL]);
          number_disp (0,1,0x89,1,TAB[TT1],TAB[TT2]);
          number_disp (0,1,0x8A,1,0x2e,TAB[TT3]);
          number_disp (0,1,0x8B,1,0x4b,0x57);
        //第3条信息
        if((CPT_c[6]>99)||(CPT_c[7]>12)||(CPT_c[8]>31))
          string_disp (0,1,0x90,8,tab9);  //如果读取时间不对,显示“暂无记录”
          number_disp (0,1,0x90,1,0x32,0x30);     //0送显示
          TH = CPT_c[6]/10;
          TL = CPT_c[6]%10;
          number_disp (0,1,0x91,1,TAB[TH],TAB[TL]);
          number_disp (0,1,0x92,1,0xc4,0xea);     //年
          TH = CPT_c[7]/10;
          TL = CPT_c[7]%10;
          number_disp (0,1,0x93,1,TAB[TH],TAB[TL]);
          number_disp (0,1,0x94,1,0xd4,0xc2);     //月
          TH = CPT_c[8]/10;
          TL = CPT_c[8]%10;
          number_disp (0,1,0x95,1,TAB[TH],TAB[TL]);
          number_disp (0,1,0x96,1,0xc8,0xd5);     //日
          PDIS = CPT_c[16];
          PDIS = PDIS<<8 + CPT_c[17];
          Pchange(PDIS);
          number_disp (0,1,0x98,1,TAB[TH],TAB[TL]);
          number_disp (0,1,0x99,1,TAB[TT1],TAB[TT2]);
          number_disp (0,1,0x9A,1,0x2e,TAB[TT3]);
          number_disp (0,1,0x9B,1,0x4b,0x57);
        Page1=Page;
       }break;
      case 4: //显示历史放电记录
        string_disp (1,0,0x80,12,tab6);       //
        //第1条信息
        if((FPT_c[0]>99)||(FPT_c[1]>12)||(FPT_c[2]>31)) //如果读取时间不对,显示“暂无记录”
          TH = FPT_c[0]/10;
          TL = FPT_c[0]%10;
          TH = FPT_c[1]/10;
          TL = FPT_c[1]%10;
          TH = FPT_c[2]/10;
          TL = FPT_c[2]%10;
          PDIS = FPT_c[12];
          PDIS = PDIS<<8 + FPT_c[13];
          Pchange(PDIS);
        //第2条信息
        if((FPT_c[3]>99)||(FPT_c[4]>12)||(FPT_c[5]>31))
          string_disp (0,1,0x80,8,tab9);   //如果读取时间不对,显示“暂无记录”
          TH = FPT_c[3]/10;
          TL = FPT_c[3]%10;
          TH = FPT_c[4]/10;
          TL = FPT_c[4]%10;
          TH = FPT_c[5]/10;
          TL = FPT_c[5]%10;
          PDIS = FPT_c[14];
          PDIS = PDIS<<8 + FPT_c[15];
          Pchange(PDIS);
        //第3条信息
        if((FPT_c[6]>99)||(FPT_c[7]>12)||(FPT_c[8]>31))
          TH = FPT_c[6]/10;
          TL = FPT_c[6]%10;
          TH = FPT_c[7]/10;
          TL = FPT_c[7]%10;
          TH = FPT_c[8]/10;
          TL = FPT_c[8]%10;
          PDIS = FPT_c[16];
          PDIS = PDIS<<8 + FPT_c[17];
          Pchange(PDIS);
        Page1=Page;
       }break;
      case 5: //显示当前时间
        string_disp (1,0,0x80,10,tab7);
        TH = time_buf1[1]/10;
        TL = time_buf1[1]%10;
        TH = time_buf1[2]/10;
        TL = time_buf1[2]%10;
        TH = time_buf1[3]/10;
        TL = time_buf1[3]%10;
        TH = time_buf1[4]/10;
        TL = time_buf1[4]%10;
        number_disp (0,1,0x86,1,0xca,0xb1);      //时
        TH = time_buf1[5]/10;
        TL = time_buf1[5]%10;
        number_disp (0,1,0x88,1,0xb7,0xd6);      //分
        TH = time_buf1[6]/10;
        TL = time_buf1[6]%10;
        number_disp (0,1,0x89,1,TAB[TH],TAB[TL]);    //
        number_disp (0,1,0x8a,1,0xc3,0xeb);      //秒
        Page1=Page;
       }break;
      case 6: //修改时间
        if(!set)              //没有按SET键
          string_disp (1,0,0x80,10,tab8);
          for (j = 0;j<6;j++)
            keybuffer[j] = time_buf1[j+1];
       }break;
      case 0:               //显示故障状态
        string_disp (1,0,0x90,12,run5);
        string_disp (0,1,0x85,12,run8);
       }break;
      default:break;
  if(ADsend)
    ADsend = 0;
    if(ADcount == 1)
      filter();
                 ADC1= (sum/(N-2));
      if(ADC1<5)
        ADC1 = 0;
                 a = (long)7500*ADC1/1021;                //放大10倍,为了送显示小数点
      VT = a;           //
      AMX0P = 0x06;         //下一个转换通道P30
      AD0EN = 1;
    if(ADcount == 2)
      filter();
                 ADC2= (sum/(N-2));
                 a = (long)4000*ADC2/1021;                //放大10倍,为了送显示
      AT = a;
      a =(long)VT*AT/10000;       //放大10倍的功率,单位KW
      PT = a;
      AMX0P = 0x08;         //下一个转换通道P26
      AD0EN = 1;
    if(ADcount == 3)
      filter();
                 ADC3= (sum/(N-2));
      AMX0P = 0x09;         //下一个转换通道P34
      AD0EN = 1;
    if(ADcount == 4)
      filter();
                 ADC4= (sum/(N-2));
      AMX0P = 0x05;         //下一个转换通道P35
      AD0EN = 1;
void UART0_ISR(void) interrupt 4
 static uchar Rcv;
    if(RI0)
   Rcv = SBUF0;
   RI0 =0;
 /*if(Rcv == 0x7E)                   //
   i = 1;
   buffer[0] = Rcv;
   if(i < 13)                  //12个字节
     buffer[i] = Rcv;
     i++;
/*void TIME2_ISR (void) interrupt 5
  TF2H = 0;                                //清标志位
  count1++;
  if(count1 ==5)
  count1 = 0;
void ADC0_ISR (void) interrupt 10
   static uchar count;                     // Loop counter
   AD0INT = 0;                            //清中断标志位
   switch( AMX0P )           //通道转换
     case 0x05:        //P2.6
  ADCbuffer1[count]=ADC0;
     count++;
     if (count > N-1){
       count = 0;
       AD0EN = 0;       //禁止转换
       ADcount = 1;
  break;
  case 0x06:        //P3.0
     count++;
     if (count > N-1){
       count = 0;
       AD0EN = 0;
       ADcount = 2;
  break;
  case 0x08:        //P3.4
     count++;
     if (count > N-1){
       count = 0;
       AD0EN = 0;
       ADcount = 3;
  break;
  case 0x09:        //P3.5
     count++;
     if (count > N-1){
       count = 0;
       AD0EN = 0;
       ADcount = 4;
  break;
  default:break;
//TIMER3中断
void Timer3_ISR(void) interrupt 14
    static uchar i,j,k;
 TMR3CN &=~(0x80);          //清标志位
    count++;
 i++;
 j++;
    if(count == 8)             //200ms
    count = 0;
   ADsend = 1;        //开始进行AD处理标志
   Tset++;
   if(Tset>5)
     Tset = 0;
 if(i==20)
   i = 0;
   Disptime = 1;
 if(j==39)       //1秒误差累积;正常是40
   j = 0;
   PDD = 1;     //一秒时间到,开始计算功率
   if(BGset)
     k++;
     if(k>240)   //4分钟关背光
       k=0;
       BGset = 0;
【关闭窗口】
相关文章
