专注电子技术学习与研究
基于C8051F的金鹏LCD19264(带字库)程序
作者:文于鹰   来源:本站原创   点击数:…  更新时间:2013年12月06日   【字体:大 中 小】
//文件名:  LCD.h (LCD头文件)                                          *
#include "C8051F340.h"
#include <intrins.h>
#define uint  unsigned int
sbit rw = P2^1;           //H=read; L=write;
//sbit e1 = P2^2;           //up input enable;
sbit e2 = P2^2;           //down input enable;
sbit rs = P2^0;           //H=data; L=command;
//sbit rst= P3^0;           //Reset Signal 低电平有效
void init_lcd ();
void clrram ();
void string_disp (uchar up,uchar down,uchar addr,uchar length,uchar code *pp); //显示字符串
void number_disp (uchar up,uchar down,uchar addr,uchar length,uchar number1,uchar number2); //显示数字
//up:上半屏  down:下半屏
//up为1,控制上半屏,down为1,控制下半屏
uchar Math_Subwith(uchar dat)      //线序反转
      uchar i,temp;
      temp = 0x00;
      for(i=0;i<8;i++)
                temp >>= 1;
                if((dat<<i)&0x80)
                        temp |= 0x80;
                        temp &= 0x7F;
        return temp;
//判忙
void chk_busy (uchar up,uchar down)
  if(up==1)
 P1 = Math_Subwith(0xff);
    rs=0;
    rw=1;
    //e1=1;
 P4 = P4|0x01;
 while(P1 & 0x01);
    //e1=0;
 _nop_();_nop_();_nop_();_nop_();
 P4 = P4&0xfe;
  if(down==1)
 P1 =Math_Subwith(0xff);
    rs=0;
    rw=1;
    e2=1;
 while(P1& 0x01);
    e2=0;
//写命令
void send_c (uchar up,uchar down,uchar comm)
   chk_busy (up,down);
   rs=0;                //command
   rw=0;                //write
   if(up==1)
  P1 = Math_Subwith(comm);        //output comm
     //e1=1;
  P4 = P4|0x01;
     _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
     //e1=0;
  P4 = P4&0xfe;
   if(down==1)
     e2=1;
     e2=0;
//写数据
void send_d (uchar up,uchar down,uchar dat)
  chk_busy (up,down);
  rs=1;               //data
  rw=0;               //write
  if(up==1)
 P1 = Math_Subwith(dat);       //output data
    //e1=1;
 P4 = P4|0x01;
    //e1=0;
 P4 = P4&0xfe;
  if(down==1)
    e2=1;
    e2=0;
/*------------------初始化-----------------*/
void init_lcd (void)
   send_c (1,1,0x30);        /*30---基本指令动作*/
 send_c (1,1,0x01);        /*清屏,地址指针指向00H*/
 send_c (1,1,0x06);        /*光标的移动方向*/
 send_c (1,1,0x0c);        /*开显示,关游标*/
/*---------------显示汉字或字符----------------*/
/*void chn_disp (uchar code *chn)
  uchar i;
   send_c (1,1,0x30);       //第一行
 send_c (1,0,0x80);
    for (i=0;i<24;i++)
    send_d (1,0,chn[i]);
   send_c (1,0,0x90);       //第二行
    for (i=0;i<24;i++)
    send_d (1,0,chn[24+i]);
    send_c (0,1,0x80);       //第三行
    for (i=0;i<24;i++)
    send_d (0,1,chn[48+i]);
   send_c (0,1,0x90);       //第四行
    for (i=0;i<24;i++)
    send_d (0,1,chn[72+i]);
/*---------------任意位置显示汉字或字符----------------*/
void string_disp (uchar up,uchar down,uchar addr,uchar length,uchar code *pp)//地址,长度,数据
  uchar i;
   send_c (1,1,0x30);
 send_c (up,down,addr);       //第一行
    for (i=0;i<length;i++)
    send_d (up,down,pp[i]);
void number_disp (uchar up,uchar down,uchar addr,uchar length,uchar number1,uchar number2)//地址,长度,数据
  uchar i;
   send_c (1,1,0x30);
    send_d (up,down,number1);
 for(i=1;i<(length+1);i++)
 send_d (up,down,number2);
/*--------------清DDRAM------------------*/
void clrram (void)
   send_c (1,1,0x30);
   send_c (1,1,0x01);
【关闭窗口】
相关文章
