专注电子技术学习与研究
用51单片机制作的简单计算器程序
作者:刘杰   来源:会员发布   点击数:…  更新时间:2014年06月25日   【字体:大 中 小】
一、硬件仿真图
件部分比较简单,当键盘按键按下时它的那一行、那一列的端口为低电平。因此,只要扫描行、列端口是否都为低电平就可以确定是哪个键被按下。
 二、主程序流程图
程序的主要思想是:将按键抽象为字符,然后就是对字符的处理。将操作数分别转化为字符串存储,操作符存储为字符形式。然后调用compute()函数进行计算并返回结果。具体程序及看注释还有流程图。
三、程序源代码
#include <</font>reg51.h>#include <</font>intrins.h>
#include <</font>ctype.h>
#include <</font>stdlib.h>
uchar operand1[9], operand2[9];
uchar operator;
void delay(uint);
uchar keyscan();
void disp(void);
void buf(uint value);
uint compute(uint va1,uint va2,uchar optor);
uchar code table[] = {0xc0,0xf9,0xa4,0xb0,0x99,
                0x92,0x82,0xf8,0x80,0x90,0xff};
uchar dbuf[8] = {10,10,10,10,10,10,10,10};
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
    for(y=110;y>0;y--);
uchar keyscan()
    uchar skey;
    P1 = 0xfe;
    while((P1 & 0xf0) != 0xf0)
        delay(3);
            switch(P1)
                case 0xee: skey = '7'; break;
                case 0xde: skey = '8'; break;
                case 0xbe: skey = '9'; break;
                case 0x7e: skey = '/'; break;
                default:   skey = '#';
    P1 = 0xfd;
        delay(3);
            switch(P1)
                case 0xed: skey = '4'; break;
                case 0xdd: skey = '5'; break;
                case 0xbd: skey = '6'; break;
                case 0x7d: skey = '*'; break;
    P1 = 0xfb;
        delay(3);
            switch(P1)
                case 0xeb: skey = '1'; break;
                case 0xdb: skey = '2'; break;
                case 0xbb: skey = '3'; break;
                case 0x7b: skey = '-'; break;
    P1 = 0xf7;
        delay(3);
            switch(P1)
                case 0xe7: skey = '$'; break;
                case 0xd7: skey = '0'; break;
                case 0xb7: skey = '='; break;
                case 0x77: skey = '+'; break;
    return skey;
    uint value1, value2, value;
    uchar ckey, cut1 = 0, cut2 = 0;
    uchar operator;
    uchar i, bool = 0;
init:
    buf(0);
    disp();
    value = 0;
    cut1 = cut2 = 0;
    bool = 0;
    for(i = 0;i <</font> 9;i++)
        operand1[i] = '\0';
        operand2[i] = '\0';
        ckey = keyscan();
        if(ckey != '#')
            if(isdigit(ckey))
                switch(bool)
                    case 0:
                            operand1[cut1] = ckey;
                            operand1[cut1+1] = '\0';
                            value1 = atoi(operand1);
                            cut1++;
                            buf(value1);
                            disp();
                            break;
                    case 1:
                            operand2[cut2] = ckey;
                            operand2[cut2+1] = '\0';
                            value2 = atoi(operand2);
                            cut2++;
                            buf(value2);
                            disp();
                            break;
                    default: break;
            else if(ckey=='+'||ckey=='-'||ckey=='*'||ckey=='/')
                bool = 1;
                operator = ckey;
                buf(0);
                dbuf[7] = 10;
                disp();
            else if(ckey == '=')
                value = compute(value1,value2,operator);
                buf(value);
                disp();
                    ckey = keyscan();
                    if(ckey == '$')
                        goto init;
                            buf(value);
                            disp();
            else if(ckey == '$')
            {    goto init;}
        disp();
    uint value;
    switch(optor)
        case '+' : value = va1+va2;    break;
        case '-' : value = va1-va2;    break;
        case '*' : value = va1*va2;    break;
        case '/' : value = va1/va2;    break;
        default :  break;
    return value;
void buf(uint val)
    uchar i;
    if(val == 0)
        dbuf[7] = 0;
        i = 6;
        for(i = 7; val > 0; i--)
            dbuf[i] = val % 10;
            val /= 10;
    for( ; i > 0; i--)
        dbuf[i] = 10;
void disp(void)
    uchar bsel, n;
    bsel=0x01;
    for(n=0;n<</font>8;n++)
        P2=bsel;
        P0=table[dbuf[n]];
        bsel=_crol_(bsel,1);
        delay(3);
        P0=0xff;
【关闭窗口】
相关文章
