专注电子技术学习与研究
超声波测距51单片机12864液晶显示
作者:佚名   来源:不详   点击数:…  更新时间:2014年07月31日   【字体:大 中 小】
   超声波测距的模块,51单片机接上12864液晶,HC-SR04超声波模块,就可以了,具体程序没怎么看,超声波模块的硬件也不晓得,今天先贴个图,贴个程序吧(程序是淘宝买的模块附赠的)。
超声波测距51单片机12864液晶显示源程序:
 #include <reg52.h>
 #include<intrins.h>
//引脚定义
    sbit     RX    =  P1 ^ 1;
    sbit     TX    =  P1 ^ 2;
    sbit     CS    =  P3 ^ 3; //片选 高电平有效 单片LCD使用时可固定高电平
    sbit     SID   =  P3 ^ 4; //数据
    sbit     SCLK  =  P3 ^ 5; //时钟
//Function Definition 函数声明
void Delay(int num);
void Init_DS18B20(void);
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
unsigned int ReadTemperature(void);
void clock_out(unsigned char dd);
unsigned char clock_in(void);
unsigned char read_clock(unsigned char ord);
void write_clock(unsigned char ord, unsigned char dd);
void Disp(void);
void id_case1_key(void);
void id_case2_key(void);
void Set_time(unsigned char sel,bit sel_1);
void Timer0_Init(void);
void Init_1302(void);
void Set_Bell(unsigned char sel, bit sel_1);
void Bell(void);
//12864
void Write_char(bit start, unsigned char ddata);
void Send_byte(unsigned char bbyte);
void Delaynms(unsigned int di);
void Lcd_init(void);
void Disp_img(unsigned char *img);
void LCD_Write_string(unsigned char X,unsigned char Y,unsigned char *s);
void LCD_set_xy( unsigned char x, unsigned char y );
unsigned char code num[]={"0123456789 :.-"};
unsigned char code waves[]={"超声波测距系统"};
unsigned char code znwk[] ={"智能微控工作室"};
unsigned char code CM[] =  {"M"};
unsigned int  time=0;
         long S=0;
         bit  flag =0;
unsigned char disbuff[4]    ={ 0,0,0,0,};
unsigned char code logo[]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0xE0,0x00,0x00,0x0C,0x00,0x00,0x40,0x70,0x00,0x00,0x00,0x80,0x00,
0x00,0x00,0x00,0xE0,0x00,0x00,0x1E,0x00,0x00,0x60,0x70,0x00,0x00,0x0F,0xE0,0x00,
0x00,0x00,0x01,0xC0,0x00,0x60,0x3C,0x00,0x00,0xE0,0x60,0x00,0x1F,0xFF,0xE0,0x00,
0x00,0x00,0x03,0x80,0x00,0x70,0x70,0x40,0x00,0xE0,0x7E,0x00,0x1F,0xE0,0xC0,0x00,
0x00,0x00,0x03,0x00,0x00,0x73,0xC3,0xF0,0x01,0xC3,0xFC,0x00,0x38,0xE1,0xC0,0x00,
0x00,0x03,0xC6,0x3C,0x00,0x33,0x9F,0xF0,0x03,0x8F,0xC0,0x00,0x30,0xC1,0xC0,0x00,
0x00,0x3F,0xEF,0xFE,0x00,0x03,0x1C,0xE0,0x07,0x01,0xCC,0x00,0x31,0xF1,0x80,0x00,
0x00,0x79,0xDF,0xBC,0x00,0x06,0x18,0xC0,0x0E,0x01,0xFE,0x00,0x77,0xF9,0x80,0x00,
0x00,0x01,0xB0,0x30,0x01,0xC6,0x19,0xC0,0x1E,0x7F,0xDE,0x00,0x6F,0x83,0x80,0x00,
0x00,0x23,0xAC,0x60,0x0F,0xE6,0xF1,0x80,0x3E,0x7B,0x38,0x00,0x61,0x83,0x00,0x00,
0x00,0x37,0x0E,0x00,0x0F,0xC7,0xB7,0x80,0xEC,0x63,0x30,0x00,0xE3,0x03,0x00,0x00,
0x00,0x3E,0x0E,0x00,0x01,0x8F,0x37,0x01,0xCC,0x6F,0xF0,0x00,0xC7,0xF7,0x00,0x00,
0x00,0x1E,0x0C,0x00,0x03,0x1E,0x66,0x03,0x0C,0x7F,0x00,0x01,0xFF,0xE6,0x00,0x00,
0x00,0x1E,0x1C,0x00,0x03,0x1C,0x60,0x02,0x19,0xAC,0x00,0x01,0x96,0x06,0x00,0x00,
0x00,0x3E,0x3E,0x00,0x03,0x18,0x60,0x00,0x19,0xFC,0x00,0x03,0x86,0x0E,0x00,0x00,
0x00,0x7E,0x36,0x00,0x03,0x00,0xC0,0x00,0x38,0x78,0x00,0x03,0x06,0x0C,0x00,0x00,
0x00,0xE6,0x67,0x00,0x03,0x00,0xC0,0x00,0x30,0x78,0x00,0x06,0x0C,0x0C,0x00,0x00,
0x01,0xC6,0xC3,0x80,0x7F,0xF0,0xC0,0x00,0x30,0xFE,0x00,0x0E,0x0C,0x1C,0x00,0x00,
0x03,0x81,0x83,0xC0,0x78,0xFF,0x80,0x00,0x61,0xCF,0x80,0x1C,0x08,0x18,0x00,0x00,
0x06,0x07,0x03,0xE0,0x00,0x1F,0xFF,0xE0,0x67,0x07,0xE0,0x38,0x18,0xF8,0x00,0x00,
0x08,0x0E,0x01,0xF8,0x00,0x07,0xFF,0x80,0xCE,0x03,0xF8,0x60,0x00,0x70,0x00,0x00,
0x00,0x18,0x01,0xF8,0x00,0x01,0xFC,0x00,0xC0,0x01,0xFC,0xC0,0x00,0x70,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x07,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x06,0x00,0x00,0x00,0x0C,0xE0,0x00,0x01,0xE0,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x0E,0x00,0x00,0x00,0x3F,0xE0,0x00,0xFF,0xF0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x0C,0x00,0x00,0x0F,0xFF,0x80,0x00,0xF8,0xF0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x0C,0xF0,0x00,0x0F,0xC7,0x00,0x00,0x60,0xE0,0x00,0x38,0x00,0xE0,0x00,
0x00,0x00,0x1F,0xF0,0x00,0x01,0x8E,0x00,0x00,0x60,0xC0,0x00,0x70,0x01,0xC0,0x00,
0x00,0x07,0xFF,0x80,0x00,0x01,0x8C,0x00,0x00,0xE1,0x80,0x00,0x70,0x01,0xC0,0x00,
0x00,0x07,0xF8,0x00,0x00,0x01,0x98,0x00,0x00,0xDF,0xC0,0x00,0x70,0x01,0xC0,0x00,
0x00,0x00,0x78,0x00,0x00,0x01,0xBF,0xE0,0x00,0xFF,0x00,0x00,0x60,0x01,0x80,0x00,
0x00,0x00,0xFC,0x00,0x00,0x7F,0xFF,0xE0,0x00,0xC0,0x00,0x00,0xE0,0x03,0x80,0x00,
0x00,0x01,0xFE,0x00,0x00,0x7F,0xF8,0x00,0x00,0x00,0x00,0x00,0xC0,0x03,0x00,0x00,
0x00,0x03,0xB7,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x3C,0x00,0xC0,0x03,0x00,0x00,
0x00,0x07,0x67,0x00,0x00,0x60,0x00,0x00,0x03,0x9F,0xFE,0x00,0x80,0x02,0x00,0x00,
0x00,0x0E,0x63,0x80,0x00,0xE0,0x00,0x01,0xFF,0xCF,0x1E,0x01,0x80,0x06,0x00,0x00,
0x00,0x1C,0xE1,0xE0,0x00,0xC0,0x00,0x00,0xE3,0x9C,0x38,0x01,0x80,0x06,0x00,0x00,
0x00,0x38,0xC1,0xF8,0x01,0xC0,0x00,0x00,0xC3,0x18,0x30,0x00,0x00,0x00,0x00,0x00,
0x00,0xE0,0xFC,0xFE,0x03,0x80,0x00,0x01,0xC7,0x18,0x60,0x00,0x00,0x00,0x00,0x00,
0x01,0xDF,0xF8,0xFE,0x03,0x00,0x00,0x01,0x8E,0x1B,0xE0,0x07,0x00,0x1C,0x00,0x00,
0x07,0x07,0x80,0x00,0x07,0x00,0x00,0x01,0xFF,0x3F,0xE0,0x07,0x00,0x1C,0x00,0x00,
0x0C,0x03,0x80,0x00,0x0E,0x00,0x00,0x01,0xF0,0x38,0x00,0x0F,0x00,0x3C,0x00,0x00,
0x00,0x03,0x00,0x00,0x1C,0x00,0x00,0x01,0x00,0x20,0x00,0x06,0x00,0x18,0x00,0x00,
0x00,0x03,0x00,0x00,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x03,0x00,0x00,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x02,0x00,0x01,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
void Lcd_init(void) //初始化LCD
 Delaynms(10); //启动等待,等LCM讲入工作状态
   CS=1;
   Write_char(0,0x30);  //8 位介面,基本指令集
   Write_char(0,0x0c);  //显示打开,光标关,反白关
   Write_char(0,0x01);  //清屏,将DDRAM的地址计数器归零
void Write_char(bit start, unsigned char ddata) //写指令或数据
 unsigned char start_data,Hdata,Ldata;
   if(start==0)
  start_data=0xf8;  //写指令
     start_data=0xfa;  //写数据
   Hdata=ddata&0xf0;    //取高四位
   Ldata=(ddata<<4)&0xf0;  //取低四位
   Send_byte(start_data);   //发送起始信号
   Delaynms(5); //延时是必须的
   Send_byte(Hdata);       //发送高四位
   Delaynms(1);  //延时是必须的
   Send_byte(Ldata);    //发送低四位
void Send_byte(unsigned char bbyte) //发送一个字节
 unsigned char i;
  for(i=0;i<8;i++)
     SID=bbyte&0x80; //取出最高位
   SCLK=1;
     SCLK=0;
     bbyte<<=1; //左移
void Delaynms(unsigned int di) //延时
 unsigned int da,db;
  for(da=0;da
     for(db=0;db<10;db++);
void Disp_img(unsigned char  *img) //图形方式12864显示字模221 横向取膜
 unsigned char i,j;
 unsigned int k = 0;
 Write_char(0,0x36); //图形方式
 for(i=0;i<32;i++)
  Write_char(0,0x80+i);
  Write_char(0,0x80);
     for(j=0;j<16;j++)
   Write_char(1,img[k++]);
  for(i=0;i<32;i++)
  Write_char(0,0x88);
     for(j=0;j<16;j++)
void Clr_Scr(void)//清屏函数
 Write_char(0,0x01);
{ //设置LCD显示的起始位置,X为行,Y为列
    unsigned char address;
 switch(x)
  case 0: address = 0x80 + y; break;
     case 1: address = 0x80 + y; break;
  case 2: address = 0x90 + y; break;
      case 3: address = 0x88 + y; break;
  case 4: address = 0x98 + y; break;
  default:address = 0x80 + y; break;
    Write_char(0, address);
{ // 中英文字符串显示函数
 LCD_set_xy( X, Y );
    while (*s)
  Write_char( 1, *s );
     s ++;
  Delaynms(1);
void LCD_Write_number(unsigned char s)// 数字显示函数
 Write_char(1,num[s]);
 Delaynms(1);
void Lcd_Mark2(void)
 Clr_Scr();//清屏
 LCD_Write_string(1,0,znwk);//
 LCD_Write_string(2,0,waves);//
 LCD_Write_string(3,7,CM);//
    void Conut(void)
    time=TH0*256+TL0;
    TH0=0;
    TL0=0;
    S=time*1.87/100;       //算出来是CM   11。0592M晶振
    if(flag==1)        //超出测量
    flag=0;
    LCD_set_xy( 3, 4 );
    LCD_Write_number(13);
    LCD_Write_number(12);
    LCD_set_xy( 3, 5 );
    disbuff[1]=S00/100;
    disbuff[2]=S000/10;
    disbuff[3]=S00 ;
    LCD_set_xy( 3, 4 );
    LCD_Write_number(disbuff[1]);
    LCD_set_xy( 3, 5 );
    LCD_Write_number(disbuff[2]);
    LCD_Write_number(disbuff[3]);
void delayms(unsigned int ms)
 unsigned char i=100,j;
 for(;ms;ms--)
  while(--i)
   j=10;
   while(--j);
     void zd0() interrupt 1    //T0中断用来计数器溢出,超过测距范围
    flag=1;        //中断溢出标志
   void  StartModule()            //T1中断用来扫描数码管和计800MS启动模块
   TX=1;                    //800MS  启动一次模块
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   _nop_();
   TX=0;
void main(void)
    TMOD=0x01;     //设T0为方式1,GATE=1
 TH0=0;
 TL0=0;
 TR0=1;
 Lcd_init();       //设置液晶显示器
 Clr_Scr();        //清屏
 Disp_img(logo);   //显示欢迎使用本产品LOGO
 Delaynms(1000);
 Lcd_init();       //从图形显示状态下返回
    Lcd_Mark2();
  StartModule();
             //计算
  while(!RX);  //当RX为零时等待
  TR0=1;       //开启计数
  while(RX);   //当RX为1计数并等待
  TR0=0;    //关闭计数
  Conut();
  delayms(80);  //80MS
【关闭窗口】
