专注电子技术学习与研究
单片机驱动1602液晶电路图及c51程序
作者:佚名   来源:本站原创   点击数:…  更新时间:2014年08月17日   【字体:大 中 小】
原理图:
    1602液晶电路图
51单片机驱动程序:
#include<reg51.h>
#include<intrins.h>
//这三个引脚参考资料
sbit E=P2^7; //1602使能引脚
sbit RW=P2^6; //1602读写引脚
sbit RS=P2^5; //1602数据/命令选择引脚
void init()
TMOD=0X00;
TH0=0X03;
TL0=0X32;
IE=0X82;
TR0=1;
* 名称 : Delay_1ms()
* 功能 : 延时子程序,延时时间为 1ms * x
* 输入 : x (延时一毫秒的个数)
* 输出 : 无
void Delay_1ms(uint i)//1ms延时
uchar x,j;
for(j=0;j<i;j++)
for(x=0;x<=148;x++);
void delay()
_nop_();
_nop_();
_nop_();
_nop_();
_nop_();
bit Busy(void)
bit busy_flag = 0;
RS = 0;
RW = 1;
E = 1;
delay();
busy_flag = (bit)(P0 & 0x80);
E = 0;
return busy_flag;
void wcmd(uchar del)
while(Busy());
RS = 0;
RW = 0;
E = 0;
delay();
P0 = del;
delay();
E = 1;
delay();
E = 0;
void wdata(uchar del)
while(Busy());
RS = 1;
RW = 0;
E = 0;
delay();
P0 = del;
    delay();
E = 1;
delay();
E = 0;
void L1602_init(void)
wcmd(0x38);
Delay_1ms(5);
wcmd(0x38);
Delay_1ms(5);
wcmd(0x38);
Delay_1ms(5);
wcmd(0x38);
wcmd(0x08);
wcmd(0x0c);
wcmd(0x06);
wcmd(0x01);
void L1602_char(uchar hang,uchar lie,char sign)
uchar a;
if(hang == 1) a = 0x80;
if(hang == 2) a = 0xc0;
a = a + lie - 1;
wcmd(a);
wdata(sign);
void L1602_string(uchar hang,uchar lie,uchar *p)
uchar a,b=0;
a = a + lie - 1;
wcmd(a++);
if((*p == '\0')||(b==16)) break;
b++;
wdata(*p);
p++;
uchar Keyscan(void)
uchar i,j, temp, Buffer[4] = {0xfe, 0xfd, 0xfb, 0xf7};
for(j=0; j<4; j++)
P1 = Buffer[j];
temp = 0x10;
for(i=0; i<4; i++)
if(!(P1 & temp))
return (i+j*4);
temp <<= 1;
void Main(void)
uchar Key_Value;  //读出的键值
L1602_init();
init();
L1602_string(1,16,"  4*4 KeyBoard  ");
L1602_string(2,16,"You Press The   ");
for(Key_Value=15;Key_Value>0;Key_Value--)
wcmd(0x18);
Delay_1ms(250);
Delay_1ms(250);
P1 = 0xf0;
if(P1 != 0xf0)
Delay_1ms(20); //按键消抖
if(P1 != 0xf0)
if(P1 != 0xf0)
Key_Value = Keyscan();
L1602_char(2,30,Key_Value / 10 + 48);
L1602_char(2,31,Key_Value % 10 + 48);
void timer0() interrupt 1
【关闭窗口】
