查看: 3393|回复: 0
创客集结号:Arduino按键实验
本次实验要实现按键控制LED亮灭效果。按下点亮,再次按下熄灭。
1.原理图:
2.代码如下:
int ButtonState;
int ButtonLastState;
int ButtonCounter;
void setup() {
  // put your setup code here, to run once:
  pinMode(13,OUTPUT);
  pinMode(11,INPUT_PULLUP);
  Serial.begin(9600);
void loop() {
  // put your main code here, to run repeatedly:
  ButtonState = digitalRead(11);
  if(ButtonState != ButtonLastState)
    if(ButtonState)
        Serial.println("on");
        ButtonCounter++;
      Serial.println("off");
    delay(100);
  ButtonLastState = ButtonState;
  if(ButtonCounter%2)
    //Serial.println(ButtonCounter);
    digitalWrite(13,1);
    digitalWrite(13,0);
若想学习更多Arduino知识,可以搜查创客集结号
