查看: 2717|回复: 0
数码管0~100秒程源
ID:3721 发表于 2015-1-5 21:20 | 显示全部楼层 |阅读模式
  1. #include<reg52.h>
  2. #define uint unsigned int
  4. uchar code q[10]={0x01,0x6d,0x22,0x82,0xc4,0x88,0x08,0xc3,0x00,0x80};
  5. sbit sda=P0^2;
  6. sbit scl=P0^3;
  7. sbit key=P1^0;
  8. uchar aa,a,b,c;
  9. void write_daty(uchar x)
  10. {
  11. uchar i;
  12. for(i=0;i<8;i++)
  13. {
  14.   scl=0;
  15.   x=x<<1;
  16.   sda=CY;
  17.   scl=1;
  18. }
  19. }
  20. void dalay(uchar z)
  21. {
  22. uchar x,y;
  23. for(x=z;x>0;x--)
  24.   for(y=100;y>0;y--);
  25. }
  26. void timer0() interrupt 1
  27. {
  28. TH0=(65536-5000)/256;
  29. TL0=(65536-5000)%256;
  30. aa++;
  31. if(aa==1)
  32. {
  33.    c=1;
  34.   b++;
  35.   if(b==10)
  36.   {
  37.    a++;
  38.    if(a==10)a=0;
  39.    b=0;
  40.   }
  41. }
  42. }
  43. void main()
  44. {
  45. uchar y;
  46. TMOD=0x01;
  47. TH0=(65536-50000)/256;
  48. TL0=(65536-50000)%256;
  49. EA=1;
  50. ET0=1;
  51. TR0=0;
  52. y=1;
  53. write_daty(q[0]);
  54. write_daty(q[0]);
  55. while(1)
  56. {
  57.   while(y==1)
  58.   {
  59.    if(key==0)
  60.    {
  61.     dalay(5);
  62.     while(key==0)
  63.      {
  64.      while(key==0);
  65.      y=2;
  66.      TR0=1;
  67.     }
  68.    }
  69.   }
  70.      while(y==2)
  71.   {
  72.    if(c==1)
  73.    {
  74.       write_daty(q[b]);
  75.     write_daty(q[a]);
  76.     c=2;
  77.    }
  78.    while(key==0)
  79.    {
  80.     dalay(5);
  81.     while(key==0)
  82.     {
  83.     while(key==0);
  84.     y=3;
  85.     TR0=0;
  86.     }
  87.    }
  88.    }
  89.    while(y==3)
  90.    {
  91.     while(key==0)
  92.    {
  93.     dalay(5);
  94.     while(key==0)
  95.     {
  96.     while(key==0);
  97.     y=1;
  98.     a=0;
  99.     b=0;
  100.     write_daty(q[0]);
  101.     write_daty(q[0]);
  102.     }
  103.    }
  104.    }
  105.   }
