查看: 5752|回复: 0
TFT点阵上的七段数码管表
ID:72008 发表于 2015-1-12 19:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
想让TFT显示数字,可以直接调用ASCII码表即可,但是要想显示的数字有7段数码管的效果,那就要自己动手了,在zimo221.exe中新建想要大小的数字,如下是16*32大小的数字代码和32*64大小的数字代码。太耗费时间和眼力了,留着备用吧。
制作是还是有点窍门的,不要0-9按顺序制作,看看他们的形态,想想应按照那种顺序制作会比较快捷再动手。
0
/*--  调入了一幅图像:  --*/
/*--  宽度x高度=16x32  --*/
0x00,0x00,0x00,0x00,0x07,0xF0,0x0F,0xF8,0x17,0xF0,0x38,0x08,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x10,0x08,
0x00,0x00,0x10,0x08,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x17,0xE8,0x0F,0xF0,0x07,0xE0,0x00,0x00
1
/*--  调入了一幅图像:这是您新建的图像  --*/
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x00,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,
0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x01,0x00,0x00,0x00,
0x01,0x00,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,
0x03,0x80,0x03,0x80,0x03,0x80,0x03,0x80,0x01,0x00,0x00,0x00,0x00,0x00,0x00,0x00
2
/*--  调入了一幅图像:*/
0x00,0x00,0x00,0x00,0x07,0xF0,0x0F,0xF8,0x07,0xF0,0x00,0x08,0x00,0x1C,0x00,0x1C,
0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x07,0xE8,
0x0F,0xF0,0x17,0xE0,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,
0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x17,0xE0,0x0F,0xF0,0x07,0xE0,0x00,0x00
3
/*--  调入了一幅图像:*/
0x0F,0xF0,0x07,0xE8,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,
0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x07,0xE8,0x0F,0xF0,0x07,0xE0,0x00,0x00
4
/*--  调入了一幅图像:*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x10,0x08,0x38,0x1C,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x17,0xE8,
0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x08,0x00,0x00,0x00,0x00,0x00,0x00
5
/*--  调入了一幅图像: --*/
0x00,0x00,0x00,0x00,0x07,0xF0,0x0F,0xF8,0x17,0xF0,0x38,0x00,0x38,0x00,0x38,0x00,
0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x38,0x00,0x17,0xE0,
6
/*--  调入了一幅图像: --*/
0x0F,0xF0,0x17,0xE8,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,
7
/*--  调入了一幅图像: --*/
0x00,0x00,0x00,0x00,0x07,0xE0,0x0F,0xF0,0x17,0xE8,0x38,0x1C,0x38,0x1C,0x38,0x1C,
0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x38,0x1C,0x18,0x08,
0x00,0x00,0x00,0x08,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,0x00,0x1C,
8
/*--  调入了一幅图像:  --*/
9
/*--  调入了一幅图像:  --*/
以下是32*64的代码:
0
/*--  宽度x高度=32x64  --*/
0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xC0,0x07,0xFF,0xFF,0xE0,0x0F,0xFF,0xFF,0xF0,
0x17,0xFF,0xFF,0xE8,0x3B,0xFF,0xFF,0xDC,0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x38,0x00,0x00,0x1C,0x10,0x00,0x00,0x08,
0x00,0x00,0x00,0x00,0x10,0x00,0x00,0x08,0x38,0x00,0x00,0x1C,0x7C,0x00,0x00,0x3E,
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x3B,0xFF,0xFF,0xDC,0x17,0xFF,0xFF,0xE8,
0x0F,0xFF,0xFF,0xF0,0x07,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x00,
1
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x08,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x08,0x00,0x00,0x00,0x00,
2
0x07,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xC8,0x00,0x00,0x00,0x1C,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x01,0xFF,0xFF,0x9C,0x03,0xFF,0xFF,0xC8,
0x07,0xFF,0xFF,0xE0,0x13,0xFF,0xFF,0xC0,0x39,0xFF,0xFF,0x80,0x7C,0x00,0x00,0x00,
0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,
0x7C,0x00,0x00,0x00,0x78,0x00,0x00,0x00,0x3B,0xFF,0xFF,0xC0,0x17,0xFF,0xFF,0xE0,
3
0x07,0xFF,0xFF,0xE0,0x03,0xFF,0xFF,0xC8,0x01,0xFF,0xFF,0x9C,0x00,0x00,0x00,0x3E,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x1C,0x03,0xFF,0xFF,0xC8,0x07,0xFF,0xFF,0xE0,
4
0x7C,0x00,0x00,0x3E,0x7C,0x00,0x00,0x3E,0x39,0xFF,0xFF,0x9C,0x13,0xFF,0xFF,0xC8,
5
0x17,0xFF,0xFF,0xE0,0x3B,0xFF,0xFF,0xC0,0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,
0x7C,0x00,0x00,0x00,0x7C,0x00,0x00,0x00,0x39,0xFF,0xFF,0x80,0x13,0xFF,0xFF,0xC0,
0x00,0x00,0x00,0x3E,0x00,0x00,0x00,0x3E,0x03,0xFF,0xFF,0xDC,0x07,0xFF,0xFF,0xE8,
6
0x07,0xFF,0xFF,0xE0,0x13,0xFF,0xFF,0xC8,0x39,0xFF,0xFF,0x9C,0x7C,0x00,0x00,0x3E,
7
0x00,0x00,0x00,0x00,0x03,0xFF,0xFF,0xE0,0x07,0xFF,0xFF,0xF0,0x0F,0xFF,0xFF,0xF8,
0x07,0xFF,0xFF,0xF0,0x13,0xFF,0xFF,0xE8,0x38,0x00,0x00,0x1C,0x7C,0x00,0x00,0x3E,
8
9
0x17,0xFF,0xFF,0xE0,0x3B,0xFF,0xFF,0xC8,0x7C,0x00,0x00,0x1C,0x7C,0x00,0x00,0x3E,
