查看: 6962|回复: 2
AVR ATmega1280定时器PWM输出程序
ID:82628 发表于 2015-6-10 15:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "kernel.h"
//交流QQ:568434017.
unsigned int PWM_Buf[6];//6路PWM频率
unsigned long timer0_ticks;
unsigned long timer0_tickssec;
unsigned long timer1_ticks;
unsigned long timer1_ticksmin;
unsigned long timer2_ticks;
unsigned long timer2_tickssec;
unsigned long timer3_ticks;
unsigned long timer3_ticksmin;
unsigned long timer4_ticks;
unsigned long timer4_ticksmin;
unsigned long timer5_ticks;
unsigned long timer5_ticksmin;
void Timer0_Init(void)
    timer0_ticks = 0;
    timer0_tickssec = 0;
    TCCR0A = 0x00;
    TCCR0B = 0x00;
    TCNT0 = 0x00;
    OCR0A = F_CPU/(1024-1)/20;//频率F_PWM
    OCR0B = OCR0A/2;//占空比50%
    //TCCR0A = 0xA3;  //COM0A1 COM0A0 COM0B1 COM0B0 – – WGM01 WGM00
    TCCR0B = 0xCD;  //FOC0A FOC0B – – WGM02 CS02 CS01 CS00
    TCCR0A = 0x00;
    TCCR0B = 0x00;//stop
    TCNT0  = 0xE7;//25us
    OCR0A  = 0x18;
    OCR0B  = 0x18;
    TCCR0A = 0x03;
    TCCR0B = 0x02;//start,clkT0S/8
    TIMSK0|= 0x01;//enable 0verflow interrupt*/
void TC0_Set_PWM(unsigned int curF)
{//20~80为clkT0S/1024,80~300为clkT0S/256,300~2000为clkT0S/64
    if(curF==0)
        OCR0A = 0;
        OCR0B = 0;
        TCCR0A = 0;
    else if((curF>=20)&&(curF<80))
        OCR0A = F_CPU/(1024-1)/curF;
        OCR0B = OCR0A/2;
        TCCR0A = 0xA3;
        TCCR0B = 0xCD;
    else if((curF>=80)&&(curF<300))
        OCR0A = F_CPU/(256-1)/curF;
        OCR0B = OCR0A/2;
        TCCR0A = 0xA3;
        TCCR0B = 0xCC;
    else if((curF>=300)&&(curF<=2000))
        OCR0A = F_CPU/(64-1)/curF;
        OCR0B = OCR0A/2;
        TCCR0A = 0xA3;
        TCCR0B = 0xCB;
void Timer1_Init(void)
    unsigned int temp;
    timer1_ticks = 0;
    timer1_ticksmin = 0;
    TCCR1A = 0x00;
    TCCR1B = 0x00;
    TCCR1C = 0x00;
    TCNT1H = 0x00;
    TCNT1L = 0x00;
    temp = F_CPU/16/20;
    OCR1A=temp;
    //temp = temp/2;
    //OCR1B=temp;
    //OCR1C=temp;
    //TCCR1A=(0<<COM1A1)|(1<<COM1A0)|/*(1<<COM1B1)|(0<<COM1B0)|(1<<COM1C1)|(0<<COM1C0)|*/(1<<WGM11)|(1<<WGM10);
    TCCR1B=(1<<WGM13)|(1<<WGM12)|(0<<CS12)|(1<<CS11)/*|(1<<CS10)*/;
    TCCR1A = 0x00;//COM1A1 COM1A0 COM1B1 COM1B0 COM1C1 COM1C0 WGM11 WGM10
    TCCR1B = 0x00;//stop,ICNC1 ICES1 – WGM13 WGM12 CS12 CS11 CS10
    TCCR1C = 0x00;//FOC1A FOC1B FOC1C – – – – –
    TCNT1H = 0xE3;
    TCNT1L = 0xE0;
    OCR1AH = 0x1C;
    OCR1AL = 0x1F;
    OCR1BH = 0x1C;
    OCR1BL = 0x1F;
    OCR1CH = 0x1C;
    OCR1CL = 0x1F;
    ICR1H  = 0x00;
    ICR1L  = 0x00;
    TCCR1B = 0x05;
//    TIMSK |= 0x04;//enable 0verflow interrupt*/
void TC1_Set_PWM(unsigned int curF)
    unsigned int temp;
    if(curF==0)
        //OCR1A = 0;
        //OCR1B = 0;
        TCCR1A=0;
    else if((curF>=20)&&(curF<=2000))
        temp = F_CPU/16/curF;
        OCR1A=temp;
void Timer2_Init(void)
    timer2_ticks = 0;
    timer2_tickssec = 0;
    TCCR2A = 0x00;
    TCCR2B = 0x00;
    TCNT2 = 0x00;
    OCR2A = F_CPU/(1024-1)/20;//频率F_PWM
    OCR2B = OCR2A/2;//占空比50%
    //TCCR2A = 0xA3;  //COM2A1 COM2A0 COM2B1 COM2B0 – – WGM21 WGM20
    TCCR2B = 0xCF;  //FOC2A FOC2B – – WGM22 CS22 CS21 CS20
//    TCCR2 = 0x00;//stop,FOC2 WGM20 COM21 COM20 WGM21 CS22 CS21 CS20
//    TCNT2 = 0xB8;//set count 10ms
//    OCR2  = 0x47;
//    TCCR2 = 0x05;//start,clkT0S/1024
//    TIMSK|= 0x40;//enable 0verflow interrupt
void TC2_Set_PWM(unsigned int curF)
    if(curF==0)
        OCR2A = 0;
        OCR2B = 0;
        TCCR2A = 0;
        OCR2A = F_CPU/(1024-1)/curF;
        OCR2B = OCR2A/2;
        TCCR2A = 0xA3;
        TCCR2B = 0xCF;
        OCR2A = F_CPU/(256-1)/curF;
        OCR2B = OCR2A/2;
        TCCR2A = 0xA3;
        TCCR2B = 0xCE;
        OCR2A = F_CPU/(64-1)/curF;
        OCR2B = OCR2A/2;
        TCCR2A = 0xA3;
        TCCR2B = 0xCC;
void Timer3_Init(void)
    unsigned int temp;
    timer3_ticks = 0;
    timer3_ticksmin = 0;
    TCCR3A = 0x00;
    TCCR3B = 0x00;
    TCCR3C = 0x00;
    TCNT3H = 0x00;
    TCNT3L = 0x00;
    temp = F_CPU/16/20;
    OCR3A=temp;
    //temp = temp/2;
    //OCR3B=temp;
    //OCR3C=temp;
    //TCCR3A=(0<<COM3A1)|(1<<COM3A0)|/*(1<<COM3B1)|(0<<COM3B0)|(1<<COM3C1)|(0<<COM3C0)|*/(1<<WGM31)|(1<<WGM30);
    TCCR3B=(1<<WGM33)|(1<<WGM32)|(0<<CS32)|(1<<CS31)/*|(1<<CS30)*/;
    TCCR3A = 0x00;//COM3A1 COM3A0 COM3B1 COM3B0 COM3C1 COM3C0 WGM31 WGM30
    TCCR3B = 0x00;//stop,ICNC3 ICES3 – WGM33 WGM32 CS32 CS31 CS30
    TCCR3C = 0x00;//FOC3A FOC3B FOC3C – – – – –
    TCNT3H = 0xE3;
    TCNT3L = 0xE0;//set count 1s
    OCR3AH = 0x1C;
    OCR3AL = 0x1F;
    OCR3BH = 0x1C;
    OCR3BL = 0x1F;
    OCR3CH = 0x1C;
    OCR3CL = 0x1F;
    ICR3H  = 0x00;
    ICR3L  = 0x00;
    TCCR3B = 0x05;//start,clkT0S/1024
//    ETIMSK|= 0x04;//enable 0verflow interrupt*/
void TC3_Set_PWM(unsigned int curF)
    unsigned int temp;
    if(curF==0)
        //OCR3A = 0;
        //OCR3B = 0;
        TCCR3A=0;
        OCR3A=temp;
void Timer4_Init(void)
    unsigned int temp;
    timer4_ticks = 0;
    timer4_ticksmin = 0;
    TCCR4A = 0x00;
    TCCR4B = 0x00;
    TCCR4C = 0x00;
    TCNT4H = 0x00;
    TCNT4L = 0x00;
    temp = F_CPU/16/20;
    OCR4A=temp;
    //temp = temp/2;
    //OCR4B=temp;
    //OCR4C=temp;
    //TCCR4A=(0<<COM4A1)|(1<<COM4A0)|/*(1<<COM4B1)|(0<<COM4B0)|(1<<COM4C1)|(0<<COM4C0)|*/(1<<WGM41)|(1<<WGM40);
    TCCR4B=(1<<WGM43)|(1<<WGM42)|(0<<CS42)|(1<<CS41)/*|(1<<CS40)*/;
void TC4_Set_PWM(unsigned int curF)
    unsigned int temp;
    if(curF==0)
        //OCR4A = 0;
        //OCR4B = 0;
        TCCR4A=0;
        OCR4A=temp;
void Timer5_Init(void)
    unsigned int temp;
    timer5_ticks = 0;
    timer5_ticksmin = 0;
    TCCR5A = 0x00;
    TCCR5B = 0x00;
    TCCR5C = 0x00;
    TCNT5H = 0x00;
    TCNT5L = 0x00;
    temp = F_CPU/16/20;
    OCR5A=temp;
    //temp = temp/2;
    //OCR5B=temp;
    //OCR5C=temp;
    //TCCR5A=(0<<COM5A1)|(1<<COM5A0)|/*(1<<COM5B1)|(0<<COM5B0)|(1<<COM5C1)|(0<<COM5C0)|*/(1<<WGM51)|(1<<WGM50);
    TCCR5B=(1<<WGM53)|(1<<WGM52)|(0<<CS52)|(1<<CS51)/*|(1<<CS50)*/;
void TC5_Set_PWM(unsigned int curF)
    unsigned int temp;
    if(curF==0)
        //OCR5A = 0;
        //OCR5B = 0;
        TCCR5A=0;
        OCR5A=temp;
* Function Name  : TIMER0_OVF_vectFunc
* Description    : 定时器0溢出中断程序
* Input          : None
* Output         : None
* Return         : None
#pragma vector = TIMER0_OVF_vect
__interrupt void TIMER0_OVF_vectFunc(void)
* Function Name  : TIMER1_OVF_vectFunc
* Description    : 定时器1溢出中断程序
* Input          : None
* Output         : None
* Return         : None
#pragma vector = TIMER1_OVF_vect
__interrupt void TIMER1_OVF_vectFunc(void)
* Function Name  : TIMER2_OVF_vectFunc
* Description    : 定时器2溢出中断程序
* Input          : None
* Output         : None
* Return         : None
#pragma vector = TIMER2_OVF_vect
__interrupt void TIMER2_OVF_vectFunc(void)
* Function Name  : TIMER3_OVF_vectFunc
* Description    : 定时器3溢出中断程序
* Input          : None
* Output         : None
* Return         : None
#pragma vector = TIMER3_OVF_vect
__interrupt void TIMER3_OVF_vectFunc(void)
ATMEGA2560-PWM USART.zip
96.7 KB, 下载次数: 187, 下载积分: 黑币 -5
参与人数 1威望 +50 黑币 +50 收起 理由
admin + 50 + 50
ID:811474 发表于 2020-8-5 11:09 | 只看该作者
ATMEGA1280定时10毫秒如何初始化
ID:811474 发表于 2020-8-5 11:14 | 只看该作者
请教ATMEGA1280单片机定时器T3定时10毫秒,如何设置
