查看: 2971|回复: 0
stm32启动文件选择
ID:91350 发表于 2015-10-29 17:26 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
                        小容量产品是指闪存存储器容量在16K至32K字节之间的STM32F101xx、STM32F102xx和STM32F103xx微控制器。
中容量产品是指闪存存储器容量在64K至128K字节之间的STM32F101xx、STM32F102xx和STM32F103xx微控制器。
大容量产品是指闪存存储器容量在256K至512K字节之间的STM32F101xx和STM32F103xx微控制器。
互联型产品是指STM32F105xx和STM32F107xx微控制器。
- startup_stm32f10x_ld_vl.s: for STM32 Low density Valueline devices
- startup_stm32f10x_ld.s: for STM32 Low densitydevices
- startup_stm32f10x_md_vl.s: for STM32 Medium density Valueline devices
- startup_stm32f10x_md.s: for STM32 Medium densitydevices
- startup_stm32f10x_hd.s: for STM32 High densitydevices
- startup_stm32f10x_xl.s: for STM32 XL densitydevices
- startup_stm32f10x_cl.s: for STM32 Connectivity linedevices
cl:互联型产品,stm32f105/107系列
vl:超值型产品,stm32f100系列
xl:超高密度产品,stm32f101/103系列
ld:低密度产品,FLASH小于64K
md:中等密度产品,FLASH=64 or 128
hd:高密度产品,FLASH大于128
● Low-density devices: STM32F101xx, STM32F102xx andSTM32F103xx
  microcontrollers where the Flash memory densityranges between 16 and 32 Kbytes.
● Medium-density devices: STM32F101xx, STM32F102xx andSTM32F103xx
  microcontrollers where the Flash memory densityranges between 64 and 128 Kbytes.
● High-density devices: STM32F101xx and STM32F103xxmicrocontrollers where the
  Flash memory density ranges between 256 and 512Kbytes.
● XL-density devices: STM32F101xx and STM32F103xx microcontrollerswhere the
  Flash memory density ranges between 512 and 1024Kbytes.
● Medium-density Low-Power devices: STM32L15xx microcontrollerswhere the Flash
  memory density ranges between 64 and 128Kbytes.
● Low Power Medium-density Plus devices:STM32L15xx andSTM32L162xx
  microcontrollers where the Flash memory densityis 256 Kbytes.
● Low Power High-density devices: STM32L15xx and STM32L162xxmicrocontrollers
  where the Flash memory density is 384Kbytes.
