查看: 17549|回复: 1
STM32编程输出可调的硬件PWM,频率范围1Hz-1MHz,占空比0-100%
ID:100029 发表于 2015-12-22 19:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
【原创】编程输出可调的硬件PWM,频率范围1Hz-1MHz,占空比0-100%
uint32_t TIM4_PWM_FQ = 50;             /* TIM4_CH1_PWM输出 频率设置值,1-1000000 */
uint32_t TIM4_PWM_FQ_Old  = 0;
uint16_t TIM4_PWM_Pulse = 50;          /* TIM4_CH1_PWM输出 占空比设置值,0-100 */
uint16_t TIM4_PWM_Pulse_Old = 0;
uint32_t SystemCoreClock = 168000000;
* 函数功能: 定时器4配置为硬件PWM模式(不开启TIM4的定时及DMA传输中断)
* TIM4_PWM_FQ:     TIM4_CH1_PWM 频率    1Hz至1000000Hz
* TIM4_PWM_Pulse:  TIM4_CH1_PWM 占空比  0-100%
void StdPeriph_TIM4_PWM_Config(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    uint32_t temp32;
    uint32_t uhTimerfrequency;
    uint16_t uhTimerPeriod;
    uint16_t uhTimerPulse;
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);
#ifdef USE_PB6_PWM
    // TIM4_CH1_PWM: PB6
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB, ENABLE);
    // GPIOB Configuration
    GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
    GPIO_InitStruct.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStruct.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStruct.GPIO_PuPd = GPIO_PuPd_DOWN;
    GPIO_InitStruct.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_Init(GPIOB, &GPIO_InitStruct);
    GPIO_PinAFConfig(GPIOB, GPIO_PinSource6, GPIO_AF_TIM4);
#else
    // TIM4_CH1_PWM: PD12
    RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOD, ENABLE);
    // GPIOD Configuration
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_12;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;
    GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;
    GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_DOWN;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;
    GPIO_Init(GPIOD, &GPIO_InitStructure);
    GPIO_PinAFConfig(GPIOD, GPIO_PinSource12, GPIO_AF_TIM4);
#endif
    uhTimerfrequency = 200000; /* 初始化 200KHz */
    temp32 = ((SystemCoreClock /2) / uhTimerfrequency);
    if(temp32 > 65535) temp32 = 65535;
    uhTimerPeriod = (uint16_t) temp32;
    uhTimerPulse  = uhTimerPeriod * 50 / 100; /* 占空比50% */
    // Time base configuration
    TIM_TimeBaseStructure.TIM_Period = uhTimerPeriod - 1; /* 0x0000 and 0xFFFF */
    TIM_TimeBaseStructure.TIM_Prescaler = 0; /* 0x0000 and 0xFFFF */
    TIM_TimeBaseStructure.TIM_ClockDivision = 0;
    TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
    // PWM1 Mode configuration: Channel1
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_Pulse = uhTimerPulse;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
    TIM_OC1Init(TIM4, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM4, TIM_OCPreload_Enable);
    TIM_ARRPreloadConfig(TIM4, ENABLE);
    TIM_GenerateEvent(TIM4, TIM_EventSource_Update);
    TIM_Cmd(TIM4, ENABLE);
* 函数功能: 刷新TIM4_CH1_PWM输出的频率和占空比
* 修改TIM4_PWM_FQ的值,调节PWM频率(1Hz至1MHz)
* 修改TIM4_PWM_Pulse的值,调节PWM的占空比(0-100)
void StdPeriph_TIM4_PWM_Update(void)
  uint32_t temp32;
  uint16_t uhTimerPrescaler;
  if ((TIM4_PWM_FQ_Old != TIM4_PWM_FQ) || (TIM4_PWM_Pulse_Old != TIM4_PWM_Pulse)){
    TIM4_PWM_FQ_Old = TIM4_PWM_FQ;
    TIM4_PWM_Pulse_Old = TIM4_PWM_Pulse;
    if(TIM4_PWM_FQ >= 4000){
      uhTimerfrequency = TIM4_PWM_FQ;  /* 定时器计时频率和PWM频率相等 */
      uhTimerPrescaler = 1;    /* 实际频率TIM4_PWM_FQ较大时,TIM4设置分频为1(不分频)   */
    }else{
      uhTimerfrequency = 4000; /* 实际频率TIM4_PWM_FQ较小时,和4000Hz的频率比较,看相差几倍 */
      uhTimerPrescaler = 4000 / TIM4_PWM_FQ;  /* 实际频率和4000相差的倍数作为TIM4的分频设置值 */
      uhTimerfrequency = uhTimerPrescaler * TIM4_PWM_FQ; /* TIM4分频后,计时周期变长,需要将uhTimerfrequency倍频  */
    /* TIM4的周期要通过倍频uhTimerfrequency来计算,uhTimerPeriod = 84MHz / uhTimerfrequency */
    if(TIM4_PWM_Pulse > 100) TIM4_PWM_Pulse = 100;
    uhTimerPulse = uhTimerPeriod * TIM4_PWM_Pulse/ 100;
    TIM4->ARR  = uhTimerPeriod - 1;
    TIM4->PSC  = uhTimerPrescaler - 1;
    TIM4->CCR1 = uhTimerPulse;
    TIM4->EGR  = TIM_PSCReloadMode_Update;
收藏收藏2 分享淘帖 顶顶 踩踩
ID:326374 发表于 2018-5-9 22:24 | 只看该作者
楼主你好,请问有工程代码打包吗?能给个下载链接不?
