查看: 4311|回复: 0
java命令行显示爱心形的源程序
ID:109770 发表于 2016-3-22 20:09 | 显示全部楼层 |阅读模式
public class Human
        public Human(String name, String sex, float height, float money, boolean handsome, boolean beautiful)
                this.name = name;
                this.sex = sex;
                this.height = height;
                this.money = money;
                this.handsome = handsome;
        public boolean ifTallRichHandsomeOrBeautiful()
                if (sex.equals("man"))
                        if (height >= 1.70f && money >= 10000f && handsome)
                                System.out.println("高富帅!!\n\n");
                                return true;
                                System.out.println("静下心来,好好想一下未来的路,相信你一定会成功!!\n\n");
                                return false;
                else if (sex.equals("woman"))
                        if (height >= 1.70f && money >= 10000f && beautiful)
                                System.out.println("白富美!!\n\n");
                                return true;
                                return false;
                        System.out.println("我是基的。。。\n\n");
                        return false;
        public String name;
        private String sex;
        private float height;
        private float money;
        private boolean beautiful;
        private boolean handsome;
public class Test
        public static void main(String args[])
                Human nanmei = new Human("楠妹", "woman", 1.70f, 5000f, true, false);
                System.out.println("我的名字是:" + nanmei.name + "\n" + ",哈!");
                nanmei.ifTallRichHandsomeOrBeautiful();
                int x = 0, y = 0;
                double result = 0, m = 0, n = 0, j = 0, k = 0;
                int[][] a = new int[80][30];
                for (y = 0; y < 30; ++y)
                        for (x = 0; x < 80; ++x)
                                if (y <= 7 & x <= 40)
                                        j = (7.0 - y) / 6.0;
                                        k = (40.0 - x) / 16.0 - 1;
                                        m = Math.pow(j, 2);
                                        n = Math.pow(k, 2);
                                        result = m + n;
                                        if (result > 1)
                                                a[x][y] = 1;
                                                a[x][y] = 0;
                                if (y <= 7 & x > 40)
                                        k = (x - 40.0) / 16.0 - 1;
                                        m = Math.pow(j, 2);
                                        n = Math.pow(k, 2);
                                        result = m + n;
                                        if (result > 1)
                                                a[x][y] = 1;
                                                a[x][y] = 0;
                                if (y > 7 & x <= 40)
                                        j = (7.0 - y) / 18.0;
                                        k = (40.0 - x) / 32.0;
                                        m = Math.pow(j, 2);
                                        n = Math.pow(k, 0.5);
                                        result = m + n;
                                        if (result > 1)
                                                a[x][y] = 1;
                                                a[x][y] = 0;
                                if (y > 7 & x > 40)
                                        k = (x - 40.0) / 32.0;
                                        m = Math.pow(j, 2);
                                        result = m + n;
                                        if (result > 1)
                                                a[x][y] = 1;
                                                a[x][y] = 0;
                for (y = 0; y < 25; ++y)
                                System.out.print(a[x][y]);
