查看: 2687|回复: 0
GPS数据处理
ID:210481 发表于 2017-6-12 15:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
int gps::set_opt(int fd,int nSpeed, int nBits, char nEvent, int nStop)
    struct termios newtio,oldtio;
    if  ( tcgetattr( fd,&oldtio)  !=  0)
        perror("SetupSerial 1");
        return -1;
    bzero( &newtio, sizeof( newtio ) );
    newtio.c_cflag  |=  CLOCAL | CREAD;
    newtio.c_cflag &= ~CSIZE;
    switch( nBits )
    case 7:
        newtio.c_cflag |= CS7;
        break;
    case 8:
        newtio.c_cflag |= CS8;
        break;
    switch( nEvent )
    case 'O':                     //奇校验
        newtio.c_cflag |= PARENB;
        newtio.c_cflag |= PARODD;
        newtio.c_iflag |= (INPCK | ISTRIP);
        break;
    case 'E':                     //偶校验
        newtio.c_cflag &= ~PARODD;
        break;
    case 'N':                    //无校验
        newtio.c_cflag &= ~PARENB;
        break;
switch( nSpeed )
    case 2400:
        cfsetispeed(&newtio, B2400);
        cfsetospeed(&newtio, B2400);
        break;
    case 4800:
        cfsetispeed(&newtio, B4800);
        cfsetospeed(&newtio, B4800);
        break;
    case 9600:
        cfsetispeed(&newtio, B9600);
        cfsetospeed(&newtio, B9600);
        break;
    case 115200:
        cfsetispeed(&newtio, B115200);
        cfsetospeed(&newtio, B115200);
        break;
    default:
        break;
    if( nStop == 1 )
        newtio.c_cflag &=  ~CSTOPB;
    else if ( nStop == 2 )
        newtio.c_cflag |=  CSTOPB;
    newtio.c_cc[VTIME]  = 0;
    newtio.c_cc[VMIN] = 0;
    tcflush(fd,TCIFLUSH);
    if((tcsetattr(fd,TCSANOW,&newtio))!=0)
        qDebug()<<"com set error"<<endl;
        return -1;
    qDebug()<<"set done!"<<endl;
    return 0;
