查看: 5999|回复: 1
velilog波形发生器,成功版带仿真文件,深大,期末作业
刘春平老师的,你懂的,velilog做的波形发生器源程序,带仿真文件,深大的期末作业,
源程序:
  1. module wave_producer(data,p,f_clk,choose);
  2. output [7:0] data;
  3. input f_clk;
  4. input [1:0] choose;
  5. input [27:0] p;
  6. reg f_out;
  7. reg [7:0] data;
  8. reg [3:0] Q=4'd0;
  9. reg [27:0] count;
  10. wire f_clk;
  11. initial
  12.    begin
  13.        count<=0;
  14.        Q<=4'd0;
  15.        f_out<=0;
  16.    end
  17.
  18. always @(f_clk)         //利用计数器count变量实现分频
  19. begin
  20.          if(count==p)                   //设置频率控制字
  21.            begin
  22.             count=0;
  23.                   f_out=~f_out;
  24.            end
  25.          else
  26.                 count=count+1;
  27. end
  28. always @ (posedge f_out)
  29. begin
  30. if(Q==15) Q<=4'd0;
  31. else Q<=Q+4'd1;
  32. end
  33. always @(Q or choose)
  34. begin
  35. case (choose)
  36. 0: data=romout({choose,Q});
  37. 1: data=romout({choose,Q});
  38. 2: data=romout({choose,Q});
  39. 3: data=romout({choose,Q});
  40. endcase
  41. end
  42. function [7:0] romout;
  43. input [5:0] address;
  44. case(address)
  45. //??????????//
  46. 0 : romout =0;
  47. 1 : romout =41;
  48. 2 : romout =74;
  49. 3 : romout =95;
  50. 4 : romout =99;
  51. 5 : romout =87;
  52. 6 : romout =58;
  53. 7 : romout =21;
  54. 8 : romout =-21;
  55. 9 : romout =-58;
  56. 10: romout =-87;
  57. 11: romout =-99;
  58. 12: romout =-95;
  59. 13: romout =-74;
  60. 14: romout =-41;
  61. 15: romout =0;
  62. //?????????//
  63. 16: romout =200;
  64. 17: romout =200;
  65. 18: romout =200;
  66. 19: romout =200;
  67. 20: romout =200;
  68. 21: romout =200;
  69. 22: romout =200;
  70. 23: romout =200;
  71. 24: romout =0;
  72. 25: romout =0;
  73. 26: romout =0;
  74. 27: romout =0;
  75. 28: romout =0;
  76. 29: romout =0;
  77. 30: romout =0;
  78. 31: romout =0;
  79. //???????????//
  80. 32: romout =0;
  81. 33: romout =5;
  82. 34: romout =10;
  83. 35: romout =15;
  84. 36: romout =20;
  85. 37: romout =25;
  86. 38: romout =30;
  87. 39: romout =35;
  88. 40: romout =40;
  89. 41: romout =45;
  90. 42: romout =50;
  91. 43: romout =55;
  92. 44: romout =60;
  93. 45: romout =65;
  94. 46: romout =70;
  95. 47: romout =75;
  96. //???????????//
  97. 48: romout =75;
  98. 49: romout =70;
  99. 50: romout =65;
  100. 51: romout =60;
  101. 52: romout =55;
  102. 53: romout =50;
  103. 54: romout =45;
  104. 55: romout =40;
  105. 56: romout =35;
  106. 57: romout =30;
  107. 58: romout =25;
  108. 59: romout =20;
  109. 60: romout =15;
  110. 61: romout =10;
  111. 62: romout =5;
  112. 63: romout =0;
  113. default : romout = 8'hxx;
  114. endcase
  115. endfunction
  116. endmodule
仿真结果:
# Compile of wave_producer.v was successful.
# Compile of wave_producer_tp.v was successful.
# 2 compiles, 0 failed with no errors.
vsim work.wave_producer_tp
# vsim work.wave_producer_tp
# Loading work.wave_producer_tp
# ** Warning: (vsim-3009) [TSCALE] - Module 'wave_producer' does not have a `timescale directive in effect, but previous modules do.
#         Region: /wave_producer_tp/A
add wave sim:/wave_producer_tp/*
run -all
#                    0  f_clk=0 p=        0 choose=0 data=  0
#                   50  f_clk=1 p=        0 choose=0 data= 41
#                  100  f_clk=0 p=        0 choose=0 data= 41
#                  150  f_clk=1 p=        0 choose=0 data= 74
#                  200  f_clk=0 p=        0 choose=0 data= 74
#                  250  f_clk=1 p=        0 choose=0 data= 95
#                  300  f_clk=0 p=        0 choose=0 data= 95
#                  350  f_clk=1 p=        0 choose=0 data= 99
#                  400  f_clk=0 p=        0 choose=0 data= 99
#                  450  f_clk=1 p=        0 choose=0 data= 87
#                  500  f_clk=0 p=        0 choose=0 data= 87
#                  550  f_clk=1 p=        0 choose=0 data= 58
#                  600  f_clk=0 p=        0 choose=0 data= 58
#                  650  f_clk=1 p=        0 choose=0 data= 21
#                  700  f_clk=0 p=        0 choose=0 data= 21
#                  750  f_clk=1 p=        0 choose=0 data=235
#                  800  f_clk=0 p=        0 choose=0 data=235
#                  850  f_clk=1 p=        0 choose=0 data=198
#                  900  f_clk=0 p=        0 choose=0 data=198
#                  950  f_clk=1 p=        0 choose=0 data=169
#                 1000  f_clk=0 p=        0 choose=0 data=169
#                 1050  f_clk=1 p=        0 choose=0 data=157
#                 1100  f_clk=0 p=        0 choose=0 data=157
#                 1150  f_clk=1 p=        0 choose=0 data=161
#                 1200  f_clk=0 p=        0 choose=0 data=161
#                 1250  f_clk=1 p=        0 choose=0 data=182
#                 1300  f_clk=0 p=        0 choose=0 data=182
#                 1350  f_clk=1 p=        0 choose=0 data=215
#                 1400  f_clk=0 p=        0 choose=0 data=215
#                 1450  f_clk=1 p=        0 choose=0 data=  0
#                 1500  f_clk=0 p=        0 choose=0 data=  0
#                 1550  f_clk=1 p=        0 choose=0 data=  0
#                 1600  f_clk=0 p=        0 choose=0 data=  0
#                 1650  f_clk=1 p=        0 choose=0 data= 41
#                 1700  f_clk=0 p=        0 choose=0 data= 41
#                 1750  f_clk=1 p=        0 choose=0 data= 74
#                 1800  f_clk=0 p=        0 choose=0 data= 74
#                 1850  f_clk=1 p=        0 choose=0 data= 95
#                 1900  f_clk=0 p=        0 choose=0 data= 95
#                 1950  f_clk=1 p=        0 choose=0 data= 99
#                 2000  f_clk=0 p=        0 choose=0 data= 99
#                 2050  f_clk=1 p=        0 choose=0 data= 87
#                 2100  f_clk=0 p=        0 choose=0 data= 87
#                 2150  f_clk=1 p=        0 choose=0 data= 58
#                 2200  f_clk=0 p=        0 choose=0 data= 58
#                 2250  f_clk=1 p=        0 choose=0 data= 21
#                 2300  f_clk=0 p=        0 choose=0 data= 21
#                 2350  f_clk=1 p=        0 choose=0 data=235
#                 2400  f_clk=0 p=        0 choose=0 data=235
#                 2450  f_clk=1 p=        0 choose=0 data=198
#                 2500  f_clk=0 p=        0 choose=0 data=198
#                 2550  f_clk=1 p=        0 choose=0 data=169
#                 2600  f_clk=0 p=        0 choose=0 data=169
#                 2650  f_clk=1 p=        0 choose=0 data=157
#                 2700  f_clk=0 p=        0 choose=0 data=157
#                 2750  f_clk=1 p=        0 choose=0 data=161
#                 2800  f_clk=0 p=        0 choose=0 data=161
#                 2850  f_clk=1 p=        0 choose=0 data=182
#                 2900  f_clk=0 p=        0 choose=0 data=182
#                 2950  f_clk=1 p=        0 choose=0 data=215
#                 3000  f_clk=0 p=        0 choose=0 data=215
#                 3050  f_clk=1 p=        0 choose=0 data=  0
#                 3100  f_clk=0 p=        0 choose=0 data=  0
#                 3150  f_clk=1 p=        0 choose=0 data=  0
#                 3200  f_clk=0 p=        0 choose=0 data=  0
#                 3250  f_clk=1 p=        0 choose=0 data= 41
#                 3300  f_clk=0 p=        0 choose=0 data= 41
#                 3350  f_clk=1 p=        0 choose=0 data= 74
#                 3400  f_clk=0 p=        0 choose=0 data= 74
#                 3450  f_clk=1 p=        0 choose=0 data= 95
#                 3500  f_clk=0 p=        0 choose=0 data= 95
#                 3550  f_clk=1 p=        0 choose=0 data= 99
#                 3600  f_clk=0 p=        0 choose=0 data= 99
#                 3650  f_clk=1 p=        0 choose=0 data= 87
#                 3700  f_clk=0 p=        0 choose=0 data= 87
#                 3750  f_clk=1 p=        0 choose=0 data= 58
#                 3800  f_clk=0 p=        0 choose=0 data= 58
#                 3850  f_clk=1 p=        0 choose=0 data= 21
#                 3900  f_clk=0 p=        0 choose=0 data= 21
#                 3950  f_clk=1 p=        0 choose=0 data=235
#                 4000  f_clk=0 p=        0 choose=0 data=235
#                 4050  f_clk=1 p=        0 choose=0 data=198
#                 4100  f_clk=0 p=        0 choose=0 data=198
#                 4150  f_clk=1 p=        0 choose=0 data=169
#                 4200  f_clk=0 p=        0 choose=0 data=169
#                 4250  f_clk=1 p=        0 choose=0 data=157
#                 4300  f_clk=0 p=        0 choose=0 data=157
#                 4350  f_clk=1 p=        0 choose=0 data=161
#                 4400  f_clk=0 p=        0 choose=0 data=161
#                 4450  f_clk=1 p=        0 choose=0 data=182
#                 4500  f_clk=0 p=        0 choose=0 data=182
#                 4550  f_clk=1 p=        0 choose=0 data=215
#                 4600  f_clk=0 p=        0 choose=0 data=215
#                 4650  f_clk=1 p=        0 choose=0 data=  0
#                 4700  f_clk=0 p=        0 choose=0 data=  0
#                 4750  f_clk=1 p=        0 choose=0 data=  0
#                 4800  f_clk=0 p=        0 choose=0 data=  0
#                 4850  f_clk=1 p=        0 choose=0 data= 41
#                 4900  f_clk=0 p=        0 choose=0 data= 41
#                 4950  f_clk=1 p=        0 choose=0 data= 74
#                 5000  f_clk=0 p=        0 choose=0 data= 74
#                 5050  f_clk=1 p=        0 choose=0 data= 95
#                 5100  f_clk=0 p=        0 choose=0 data= 95
#                 5150  f_clk=1 p=        0 choose=0 data= 99
#                 5200  f_clk=0 p=        0 choose=0 data= 99
#                 5250  f_clk=1 p=        0 choose=0 data= 87
#                 5300  f_clk=0 p=        0 choose=0 data= 87
#                 5350  f_clk=1 p=        0 choose=0 data= 58
#                 5400  f_clk=0 p=        0 choose=0 data= 58
#                 5450  f_clk=1 p=        0 choose=0 data= 21
#                 5500  f_clk=0 p=        0 choose=0 data= 21
#                 5550  f_clk=1 p=        0 choose=0 data=235
#                 5600  f_clk=0 p=        0 choose=0 data=235
#                 5650  f_clk=1 p=        0 choose=0 data=198
#                 5700  f_clk=0 p=        0 choose=0 data=198
#                 5750  f_clk=1 p=        0 choose=0 data=169
#                 5800  f_clk=0 p=        0 choose=0 data=169
#                 5850  f_clk=1 p=        0 choose=0 data=157
#                 5900  f_clk=0 p=        0 choose=0 data=157
#                 5950  f_clk=1 p=        0 choose=0 data=161
#                 6000  f_clk=0 p=        0 choose=0 data=161
#                 6050  f_clk=1 p=        0 choose=0 data=182
#                 6100  f_clk=0 p=        0 choose=0 data=182
#                 6150  f_clk=1 p=        0 choose=0 data=215
#                 6200  f_clk=0 p=        0 choose=0 data=215
#                 6250  f_clk=1 p=        0 choose=0 data=  0
#                 6300  f_clk=0 p=        0 choose=0 data=  0
#                 6350  f_clk=1 p=        0 choose=0 data=  0
#                 6400  f_clk=0 p=        0 choose=0 data=  0
#                 6450  f_clk=1 p=        0 choose=0 data= 41
#                 6500  f_clk=0 p=        0 choose=0 data= 41
#                 6550  f_clk=1 p=        0 choose=0 data= 74
#                 6600  f_clk=0 p=        0 choose=0 data= 74
#                 6650  f_clk=1 p=        0 choose=0 data= 95
#                 6700  f_clk=0 p=        0 choose=0 data= 95
#                 6750  f_clk=1 p=        0 choose=0 data= 99
#                 6800  f_clk=0 p=        0 choose=0 data= 99
#                 6850  f_clk=1 p=        0 choose=0 data= 87
#                 6900  f_clk=0 p=        0 choose=0 data= 87
#                 6950  f_clk=1 p=        0 choose=0 data= 58
#                 7000  f_clk=0 p=        0 choose=0 data= 58
#                 7050  f_clk=1 p=        0 choose=0 data= 21
#                 7100  f_clk=0 p=        0 choose=0 data= 21
#                 7150  f_clk=1 p=        0 choose=0 data=235
#                 7200  f_clk=0 p=        0 choose=0 data=235
#                 7250  f_clk=1 p=        0 choose=0 data=198
#                 7300  f_clk=0 p=        0 choose=0 data=198
#                 7350  f_clk=1 p=        0 choose=0 data=169
#                 7400  f_clk=0 p=        0 choose=0 data=169
#                 7450  f_clk=1 p=        0 choose=0 data=157
#                 7500  f_clk=0 p=        0 choose=0 data=157
#                 7550  f_clk=1 p=        0 choose=0 data=161
#                 7600  f_clk=0 p=        0 choose=0 data=161
#                 7650  f_clk=1 p=        0 choose=0 data=182
#                 7700  f_clk=0 p=        0 choose=0 data=182
#                 7750  f_clk=1 p=        0 choose=0 data=215
#                 7800  f_clk=0 p=        0 choose=0 data=215
#                 7850  f_clk=1 p=        0 choose=0 data=  0
#                 7900  f_clk=0 p=        0 choose=0 data=  0
#                 7950  f_clk=1 p=        0 choose=0 data=  0
#                 8000  f_clk=0 p=        0 choose=0 data=  0
#                 8050  f_clk=1 p=        0 choose=0 data= 41
#                 8100  f_clk=0 p=        0 choose=0 data= 41
#                 8150  f_clk=1 p=        0 choose=0 data= 74
#                 8200  f_clk=0 p=        0 choose=0 data= 74
#                 8250  f_clk=1 p=        0 choose=0 data= 95
#                 8300  f_clk=0 p=        0 choose=0 data= 95
#                 8350  f_clk=1 p=        0 choose=0 data= 99
#                 8400  f_clk=0 p=        0 choose=0 data= 99
#                 8450  f_clk=1 p=        0 choose=0 data= 87
#                 8500  f_clk=0 p=        0 choose=0 data= 87
#                 8550  f_clk=1 p=        0 choose=0 data= 58
#                 8600  f_clk=0 p=        0 choose=0 data= 58
#                 8650  f_clk=1 p=        0 choose=0 data= 21
#                 8700  f_clk=0 p=        0 choose=0 data= 21
#                 8750  f_clk=1 p=        0 choose=0 data=235
#                 8800  f_clk=0 p=        0 choose=0 data=235
#                 8850  f_clk=1 p=        0 choose=0 data=198
#                 8900  f_clk=0 p=        0 choose=0 data=198
#                 8950  f_clk=1 p=        0 choose=0 data=169
#                 9000  f_clk=0 p=        0 choose=0 data=169
#                 9050  f_clk=1 p=        0 choose=0 data=157
#                 9100  f_clk=0 p=        0 choose=0 data=157
#                 9150  f_clk=1 p=        0 choose=0 data=161
#                 9200  f_clk=0 p=        0 choose=0 data=161
#                 9250  f_clk=1 p=        0 choose=0 data=182
#                 9300  f_clk=0 p=        0 choose=0 data=182
#                 9350  f_clk=1 p=        0 choose=0 data=215
#                 9400  f_clk=0 p=        0 choose=0 data=215
#                 9450  f_clk=1 p=        0 choose=0 data=  0
#                 9500  f_clk=0 p=        0 choose=0 data=  0
#                 9550  f_clk=1 p=        0 choose=0 data=  0
#                 9600  f_clk=0 p=        0 choose=0 data=  0
#                 9650  f_clk=1 p=        0 choose=0 data= 41
#                 9700  f_clk=0 p=        0 choose=0 data= 41
#                 9750  f_clk=1 p=        0 choose=0 data= 74
#                 9800  f_clk=0 p=        0 choose=0 data= 74
#                 9850  f_clk=1 p=        0 choose=0 data= 95
#                 9900  f_clk=0 p=        0 choose=0 data= 95
#                 9950  f_clk=1 p=        0 choose=0 data= 99
#                10000  f_clk=0 p=        0 choose=0 data= 99
#                10050  f_clk=1 p=        0 choose=0 data= 87
#                10100  f_clk=0 p=        0 choose=0 data= 87
#                10150  f_clk=1 p=        0 choose=0 data= 58
#                10200  f_clk=0 p=        0 choose=0 data= 58
#                10250  f_clk=1 p=        0 choose=0 data= 21
#                10300  f_clk=0 p=        0 choose=0 data= 21
#                10350  f_clk=1 p=        0 choose=0 data=235
#                10400  f_clk=0 p=        0 choose=0 data=235
#                10450  f_clk=1 p=        0 choose=0 data=198
#                10500  f_clk=0 p=        0 choose=0 data=198
#                10550  f_clk=1 p=        0 choose=0 data=169
#                10600  f_clk=0 p=        0 choose=0 data=169
#                10650  f_clk=1 p=        0 choose=0 data=157
#                10700  f_clk=0 p=        0 choose=0 data=157
#                10750  f_clk=1 p=        0 choose=0 data=161
#                10800  f_clk=0 p=        0 choose=0 data=161
#                10850  f_clk=1 p=        0 choose=0 data=182
#                10900  f_clk=0 p=        0 choose=0 data=182
#                10950  f_clk=1 p=        0 choose=0 data=215
#                11000  f_clk=0 p=        0 choose=0 data=215
#                11050  f_clk=1 p=        0 choose=0 data=  0
#                11100  f_clk=0 p=        0 choose=0 data=  0
#                11150  f_clk=1 p=        0 choose=0 data=  0
#                11200  f_clk=0 p=        0 choose=0 data=  0
#                11250  f_clk=1 p=        0 choose=0 data= 41
#                11300  f_clk=0 p=        0 choose=0 data= 41
#                11350  f_clk=1 p=        0 choose=0 data= 74
#                11400  f_clk=0 p=        0 choose=0 data= 74
#                11450  f_clk=1 p=        0 choose=0 data= 95
#                11500  f_clk=0 p=        0 choose=0 data= 95
#                11550  f_clk=1 p=        0 choose=0 data= 99
#                11600  f_clk=0 p=        0 choose=0 data= 99
#                11650  f_clk=1 p=        0 choose=0 data= 87
#                11700  f_clk=0 p=        0 choose=0 data= 87
#                11750  f_clk=1 p=        0 choose=0 data= 58
#                11800  f_clk=0 p=        0 choose=0 data= 58
#                11850  f_clk=1 p=        0 choose=0 data= 21
#                11900  f_clk=0 p=        0 choose=0 data= 21
#                11950  f_clk=1 p=        0 choose=0 data=235
#                12000  f_clk=0 p=        0 choose=0 data=235
#                12050  f_clk=1 p=        0 choose=0 data=198
#                12100  f_clk=0 p=        0 choose=0 data=198
#                12150  f_clk=1 p=        0 choose=0 data=169
#                12200  f_clk=0 p=        0 choose=0 data=169
#                12250  f_clk=1 p=        0 choose=0 data=157
#                12300  f_clk=0 p=        0 choose=0 data=157
#                12350  f_clk=1 p=        0 choose=0 data=161
#                12400  f_clk=0 p=        0 choose=0 data=161
#                12450  f_clk=1 p=        0 choose=0 data=182
#                12500  f_clk=0 p=        0 choose=0 data=182
#                12550  f_clk=1 p=        0 choose=0 data=215
#                12600  f_clk=0 p=        0 choose=0 data=215
#                12650  f_clk=1 p=        0 choose=0 data=  0
#                12700  f_clk=0 p=        0 choose=0 data=  0
#                12750  f_clk=1 p=        0 choose=0 data=  0
#                12800  f_clk=0 p=        0 choose=0 data=  0
#                12850  f_clk=1 p=        0 choose=0 data= 41
#                12900  f_clk=0 p=        0 choose=0 data= 41
#                12950  f_clk=1 p=        0 choose=0 data= 74
#                13000  f_clk=0 p=        0 choose=0 data= 74
#                13050  f_clk=1 p=        0 choose=0 data= 95
#                13100  f_clk=0 p=        0 choose=0 data= 95
#                13150  f_clk=1 p=        0 choose=0 data= 99
#                13200  f_clk=0 p=        0 choose=0 data= 99
#                13250  f_clk=1 p=        0 choose=0 data= 87
#                13300  f_clk=0 p=        0 choose=0 data= 87
#                13350  f_clk=1 p=        0 choose=0 data= 58
#                13400  f_clk=0 p=        0 choose=0 data= 58
#                13450  f_clk=1 p=        0 choose=0 data= 21
#                13500  f_clk=0 p=        0 choose=0 data= 21
#                13550  f_clk=1 p=        0 choose=0 data=235
#                13600  f_clk=0 p=        0 choose=0 data=235
#                13650  f_clk=1 p=        0 choose=0 data=198
#                13700  f_clk=0 p=        0 choose=0 data=198
#                13750  f_clk=1 p=        0 choose=0 data=169
#                13800  f_clk=0 p=        0 choose=0 data=169
#                13850  f_clk=1 p=        0 choose=0 data=157
#                13900  f_clk=0 p=        0 choose=0 data=157
#                13950  f_clk=1 p=        0 choose=0 data=161
#                14000  f_clk=0 p=        0 choose=0 data=161
#                14050  f_clk=1 p=        0 choose=0 data=182
#                14100  f_clk=0 p=        0 choose=0 data=182
#                14150  f_clk=1 p=        0 choose=0 data=215
#                14200  f_clk=0 p=        0 choose=0 data=215
#                14250  f_clk=1 p=        0 choose=0 data=  0
#                14300  f_clk=0 p=        0 choose=0 data=  0
#                14350  f_clk=1 p=        0 choose=0 data=  0
#                14400  f_clk=0 p=        0 choose=0 data=  0
#                14450  f_clk=1 p=        0 choose=0 data= 41
#                14500  f_clk=0 p=        0 choose=0 data= 41
#                14550  f_clk=1 p=        0 choose=0 data= 74
#                14600  f_clk=0 p=        0 choose=0 data= 74
#                14650  f_clk=1 p=        0 choose=0 data= 95
#                14700  f_clk=0 p=        0 choose=0 data= 95
#                14750  f_clk=1 p=        0 choose=0 data= 99
#                14800  f_clk=0 p=        0 choose=0 data= 99
#                14850  f_clk=1 p=        0 choose=0 data= 87
#                14900  f_clk=0 p=        0 choose=0 data= 87
#                14950  f_clk=1 p=        0 choose=0 data= 58
#                15000  f_clk=0 p=        0 choose=0 data= 58
#                15050  f_clk=1 p=        0 choose=0 data= 21
#                15100  f_clk=0 p=        0 choose=0 data= 21
#                15150  f_clk=1 p=        0 choose=0 data=235
#                15200  f_clk=0 p=        0 choose=0 data=235
#                15250  f_clk=1 p=        0 choose=0 data=198
#                15300  f_clk=0 p=        0 choose=0 data=198
#                15350  f_clk=1 p=        0 choose=0 data=169
#                15400  f_clk=0 p=        0 choose=0 data=169
#                15450  f_clk=1 p=        0 choose=0 data=157
#                15500  f_clk=0 p=        0 choose=0 data=157
#                15550  f_clk=1 p=        0 choose=0 data=161
#                15600  f_clk=0 p=        0 choose=0 data=161
#                15650  f_clk=1 p=        0 choose=0 data=182
#                15700  f_clk=0 p=        0 choose=0 data=182
#                15750  f_clk=1 p=        0 choose=0 data=215
#                15800  f_clk=0 p=        0 choose=0 data=215
#                15850  f_clk=1 p=        0 choose=0 data=  0
#                15900  f_clk=0 p=        0 choose=0 data=  0
#                15950  f_clk=1 p=        0 choose=0 data=  0
#                16000  f_clk=0 p=        0 choose=0 data=  0
#                16050  f_clk=1 p=        0 choose=0 data= 41
#                16100  f_clk=0 p=        0 choose=0 data= 41
#                16150  f_clk=1 p=        0 choose=0 data= 74
#                16200  f_clk=0 p=        0 choose=0 data= 74
#                16250  f_clk=1 p=        0 choose=0 data= 95
#                16300  f_clk=0 p=        0 choose=0 data= 95
#                16350  f_clk=1 p=        0 choose=0 data= 99
#                16400  f_clk=0 p=        0 choose=0 data= 99
#                16450  f_clk=1 p=        0 choose=0 data= 87
#                16500  f_clk=0 p=        0 choose=0 data= 87
#                16550  f_clk=1 p=        0 choose=0 data= 58
#                16600  f_clk=0 p=        0 choose=0 data= 58
#                16650  f_clk=1 p=        0 choose=0 data= 21
#                16700  f_clk=0 p=        0 choose=0 data= 21
#                16750  f_clk=1 p=        0 choose=0 data=235
#                16800  f_clk=0 p=        0 choose=0 data=235
#                16850  f_clk=1 p=        0 choose=0 data=198
#                16900  f_clk=0 p=        0 choose=0 data=198
#                16950  f_clk=1 p=        0 choose=0 data=169
#                17000  f_clk=0 p=        0 choose=0 data=169
#                17050  f_clk=1 p=        0 choose=0 data=157
#                17100  f_clk=0 p=        0 choose=0 data=157
#                17150  f_clk=1 p=        0 choose=0 data=161
#                17200  f_clk=0 p=        0 choose=0 data=161
#                17250  f_clk=1 p=        0 choose=0 data=182
#                17300  f_clk=0 p=        0 choose=0 data=182
#                17350  f_clk=1 p=        0 choose=0 data=215
#                17400  f_clk=0 p=        0 choose=0 data=215
#                17450  f_clk=1 p=        0 choose=0 data=  0
#                17500  f_clk=0 p=        0 choose=0 data=  0
#                17550  f_clk=1 p=        0 choose=0 data=  0
#                17600  f_clk=0 p=        0 choose=0 data=  0
#                17650  f_clk=1 p=        0 choose=0 data= 41
#                17700  f_clk=0 p=        0 choose=0 data= 41
#                17750  f_clk=1 p=        0 choose=0 data= 74
#                17800  f_clk=0 p=        0 choose=0 data= 74
#                17850  f_clk=1 p=        0 choose=0 data= 95
#                17900  f_clk=0 p=        0 choose=0 data= 95
#                17950  f_clk=1 p=        0 choose=0 data= 99
#                18000  f_clk=0 p=        0 choose=0 data= 99
#                18050  f_clk=1 p=        0 choose=0 data= 87
#                18100  f_clk=0 p=        0 choose=0 data= 87
#                18150  f_clk=1 p=        0 choose=0 data= 58
#                18200  f_clk=0 p=        0 choose=0 data= 58
#                18250  f_clk=1 p=        0 choose=0 data= 21
#                18300  f_clk=0 p=        0 choose=0 data= 21
#                18350  f_clk=1 p=        0 choose=0 data=235
#                18400  f_clk=0 p=        0 choose=0 data=235
#                18450  f_clk=1 p=        0 choose=0 data=198
#                18500  f_clk=0 p=        0 choose=0 data=198
#                18550  f_clk=1 p=        0 choose=0 data=169
#                18600  f_clk=0 p=        0 choose=0 data=169
#                18650  f_clk=1 p=        0 choose=0 data=157
#                18700  f_clk=0 p=        0 choose=0 data=157
#                18750  f_clk=1 p=        0 choose=0 data=161
#                18800  f_clk=0 p=        0 choose=0 data=161
#                18850  f_clk=1 p=        0 choose=0 data=182
#                18900  f_clk=0 p=        0 choose=0 data=182
#                18950  f_clk=1 p=        0 choose=0 data=215
#                19000  f_clk=0 p=        0 choose=0 data=215
#                19050  f_clk=1 p=        0 choose=0 data=  0
#                19100  f_clk=0 p=        0 choose=0 data=  0
#                19150  f_clk=1 p=        0 choose=0 data=  0
#                19200  f_clk=0 p=        0 choose=0 data=  0
#                19250  f_clk=1 p=        0 choose=0 data= 41
#                19300  f_clk=0 p=        0 choose=0 data= 41
#                19350  f_clk=1 p=        0 choose=0 data= 74
#                19400  f_clk=0 p=        0 choose=0 data= 74
#                19450  f_clk=1 p=        0 choose=0 data= 95
#                19500  f_clk=0 p=        0 choose=0 data= 95
#                19550  f_clk=1 p=        0 choose=0 data= 99
#                19600  f_clk=0 p=        0 choose=0 data= 99
#                19650  f_clk=1 p=        0 choose=0 data= 87
#                19700  f_clk=0 p=        0 choose=0 data= 87
#                19750  f_clk=1 p=        0 choose=0 data= 58
#                19800  f_clk=0 p=        0 choose=0 data= 58
#                19850  f_clk=1 p=        0 choose=0 data= 21
#                19900  f_clk=0 p=        0 choose=0 data= 21
#                19950  f_clk=1 p=        0 choose=0 data=235
#                20000  f_clk=0 p=        0 choose=1 data=  0
#                20050  f_clk=1 p=        0 choose=1 data=  0
#                20100  f_clk=0 p=        0 choose=1 data=  0
#                20150  f_clk=1 p=        0 choose=1 data=  0
#                20200  f_clk=0 p=        0 choose=1 data=  0
#                20250  f_clk=1 p=        0 choose=1 data=  0
#                20300  f_clk=0 p=        0 choose=1 data=  0
#                20350  f_clk=1 p=        0 choose=1 data=  0
#                20400  f_clk=0 p=        0 choose=1 data=  0
#                20450  f_clk=1 p=        0 choose=1 data=  0
#                20500  f_clk=0 p=        0 choose=1 data=  0
#                20550  f_clk=1 p=        0 choose=1 data=  0
#                20600  f_clk=0 p=        0 choose=1 data=  0
#                20650  f_clk=1 p=        0 choose=1 data=  0
#                20700  f_clk=0 p=        0 choose=1 data=  0
#                20750  f_clk=1 p=        0 choose=1 data=200
#                20800  f_clk=0 p=        0 choose=1 data=200
#                20850  f_clk=1 p=        0 choose=1 data=200
#                20900  f_clk=0 p=        0 choose=1 data=200
#                20950  f_clk=1 p=        0 choose=1 data=200
#                21000  f_clk=0 p=        0 choose=1 data=200
#                21050  f_clk=1 p=        0 choose=1 data=200
#                21100  f_clk=0 p=        0 choose=1 data=200
#                21150  f_clk=1 p=        0 choose=1 data=200
#                21200  f_clk=0 p=        0 choose=1 data=200
#                21250  f_clk=1 p=        0 choose=1 data=200
#                21300  f_clk=0 p=        0 choose=1 data=200
#                21350  f_clk=1 p=        0 choose=1 data=200
#                21400  f_clk=0 p=        0 choose=1 data=200
#                21450  f_clk=1 p=        0 choose=1 data=200
#                21500  f_clk=0 p=        0 choose=1 data=200
#                21550  f_clk=1 p=        0 choose=1 data=  0
#                21600  f_clk=0 p=        0 choose=1 data=  0
#                21650  f_clk=1 p=        0 choose=1 data=  0
#                21700  f_clk=0 p=        0 choose=1 data=  0
#                21750  f_clk=1 p=        0 choose=1 data=  0
#                21800  f_clk=0 p=        0 choose=1 data=  0
#                21850  f_clk=1 p=        0 choose=1 data=  0
#                21900  f_clk=0 p=        0 choose=1 data=  0
#                21950  f_clk=1 p=        0 choose=1 data=  0
#                22000  f_clk=0 p=        0 choose=1 data=  0
#                22050  f_clk=1 p=        0 choose=1 data=  0
#                22100  f_clk=0 p=        0 choose=1 data=  0
#                22150  f_clk=1 p=        0 choose=1 data=  0
#                22200  f_clk=0 p=        0 choose=1 data=  0
#                22250  f_clk=1 p=        0 choose=1 data=  0
#                22300  f_clk=0 p=        0 choose=1 data=  0
#                22350  f_clk=1 p=        0 choose=1 data=200
#                22400  f_clk=0 p=        0 choose=1 data=200
#                22450  f_clk=1 p=        0 choose=1 data=200
#                22500  f_clk=0 p=        0 choose=1 data=200
#                22550  f_clk=1 p=        0 choose=1 data=200
#                22600  f_clk=0 p=        0 choose=1 data=200
#                22650  f_clk=1 p=        0 choose=1 data=200
#                22700  f_clk=0 p=        0 choose=1 data=200
#                22750  f_clk=1 p=        0 choose=1 data=200
#                22800  f_clk=0 p=        0 choose=1 data=200
#                22850  f_clk=1 p=        0 choose=1 data=200
#                22900  f_clk=0 p=        0 choose=1 data=200
#                22950  f_clk=1 p=        0 choose=1 data=200
#                23000  f_clk=0 p=        0 choose=1 data=200
#                23050  f_clk=1 p=        0 choose=1 data=200
#                23100  f_clk=0 p=        0 choose=1 data=200
#                23150  f_clk=1 p=        0 choose=1 data=  0
#                23200  f_clk=0 p=        0 choose=1 data=  0
#                23250  f_clk=1 p=        0 choose=1 data=  0
#                23300  f_clk=0 p=        0 choose=1 data=  0
#                23350  f_clk=1 p=        0 choose=1 data=  0
#                23400  f_clk=0 p=        0 choose=1 data=  0
#                23450  f_clk=1 p=        0 choose=1 data=  0
#                23500  f_clk=0 p=        0 choose=1 data=  0
#                23550  f_clk=1 p=        0 choose=1 data=  0
#                23600  f_clk=0 p=        0 choose=1 data=  0
#                23650  f_clk=1 p=        0 choose=1 data=  0
#                23700  f_clk=0 p=        0 choose=1 data=  0
#                23750  f_clk=1 p=        0 choose=1 data=  0
#                23800  f_clk=0 p=        0 choose=1 data=  0
#                23850  f_clk=1 p=        0 choose=1 data=  0
#                23900  f_clk=0 p=        0 choose=1 data=  0
#                23950  f_clk=1 p=        0 choose=1 data=200
#                24000  f_clk=0 p=        0 choose=1 data=200
#                24050  f_clk=1 p=        0 choose=1 data=200
#                24100  f_clk=0 p=        0 choose=1 data=200
#                24150  f_clk=1 p=        0 choose=1 data=200
#                24200  f_clk=0 p=        0 choose=1 data=200
#                24250  f_clk=1 p=        0 choose=1 data=200
#                24300  f_clk=0 p=        0 choose=1 data=200
#                24350  f_clk=1 p=        0 choose=1 data=200
#                24400  f_clk=0 p=        0 choose=1 data=200
#                24450  f_clk=1 p=        0 choose=1 data=200
#                24500  f_clk=0 p=        0 choose=1 data=200
#                24550  f_clk=1 p=        0 choose=1 data=200
#                24600  f_clk=0 p=        0 choose=1 data=200
#                24650  f_clk=1 p=        0 choose=1 data=200
#                24700  f_clk=0 p=        0 choose=1 data=200
#                24750  f_clk=1 p=        0 choose=1 data=  0
#                24800  f_clk=0 p=        0 choose=1 data=  0
#                24850  f_clk=1 p=        0 choose=1 data=  0
#                24900  f_clk=0 p=        0 choose=1 data=  0
#                24950  f_clk=1 p=        0 choose=1 data=  0
#                25000  f_clk=0 p=        0 choose=1 data=  0
#                25050  f_clk=1 p=        0 choose=1 data=  0
#                25100  f_clk=0 p=        0 choose=1 data=  0
#                25150  f_clk=1 p=        0 choose=1 data=  0
#                25200  f_clk=0 p=        0 choose=1 data=  0
#                25250  f_clk=1 p=        0 choose=1 data=  0
#                25300  f_clk=0 p=        0 choose=1 data=  0
#                25350  f_clk=1 p=        0 choose=1 data=  0
#                25400  f_clk=0 p=        0 choose=1 data=  0
#                25450  f_clk=1 p=        0 choose=1 data=  0
#                25500  f_clk=0 p=        0 choose=1 data=  0
#                25550  f_clk=1 p=        0 choose=1 data=200
#                25600  f_clk=0 p=        0 choose=1 data=200
#                25650  f_clk=1 p=        0 choose=1 data=200
#                25700  f_clk=0 p=        0 choose=1 data=200
#                25750  f_clk=1 p=        0 choose=1 data=200
#                25800  f_clk=0 p=        0 choose=1 data=200
#                25850  f_clk=1 p=        0 choose=1 data=200
#                25900  f_clk=0 p=        0 choose=1 data=200
#                25950  f_clk=1 p=        0 choose=1 data=200
#                26000  f_clk=0 p=        0 choose=1 data=200
#                26050  f_clk=1 p=        0 choose=1 data=200
#                26100  f_clk=0 p=        0 choose=1 data=200
#                26150  f_clk=1 p=        0 choose=1 data=200
#                26200  f_clk=0 p=        0 choose=1 data=200
#                26250  f_clk=1 p=        0 choose=1 data=200
#                26300  f_clk=0 p=        0 choose=1 data=200
#                26350  f_clk=1 p=        0 choose=1 data=  0
#                26400  f_clk=0 p=        0 choose=1 data=  0
#                26450  f_clk=1 p=        0 choose=1 data=  0
#                26500  f_clk=0 p=        0 choose=1 data=  0
#                26550  f_clk=1 p=        0 choose=1 data=  0
#                26600  f_clk=0 p=        0 choose=1 data=  0
#                26650  f_clk=1 p=        0 choose=1 data=  0
#                26700  f_clk=0 p=        0 choose=1 data=  0
#                26750  f_clk=1 p=        0 choose=1 data=  0
#                26800  f_clk=0 p=        0 choose=1 data=  0
#                26850  f_clk=1 p=        0 choose=1 data=  0
#                26900  f_clk=0 p=        0 choose=1 data=  0
#                26950  f_clk=1 p=        0 choose=1 data=  0
#                27000  f_clk=0 p=        0 choose=1 data=  0
#                27050  f_clk=1 p=        0 choose=1 data=  0
#                27100  f_clk=0 p=        0 choose=1 data=  0
#                27150  f_clk=1 p=        0 choose=1 data=200
#                27200  f_clk=0 p=        0 choose=1 data=200
#                27250  f_clk=1 p=        0 choose=1 data=200
#                27300  f_clk=0 p=        0 choose=1 data=200
#                27350  f_clk=1 p=        0 choose=1 data=200
#                27400  f_clk=0 p=        0 choose=1 data=200
#                27450  f_clk=1 p=        0 choose=1 data=200
#                27500  f_clk=0 p=        0 choose=1 data=200
#                27550  f_clk=1 p=        0 choose=1 data=200
#                27600  f_clk=0 p=        0 choose=1 data=200
#                27650  f_clk=1 p=        0 choose=1 data=200
#                27700  f_clk=0 p=        0 choose=1 data=200
#                27750  f_clk=1 p=        0 choose=1 data=200
#                27800  f_clk=0 p=        0 choose=1 data=200
#                27850  f_clk=1 p=        0 choose=1 data=200
#                27900  f_clk=0 p=        0 choose=1 data=200
#                27950  f_clk=1 p=        0 choose=1 data=  0
#                28000  f_clk=0 p=        0 choose=1 data=  0
#                28050  f_clk=1 p=        0 choose=1 data=  0
#                28100  f_clk=0 p=        0 choose=1 data=  0
#                28150  f_clk=1 p=        0 choose=1 data=  0
#                28200  f_clk=0 p=        0 choose=1 data=  0
#                28250  f_clk=1 p=        0 choose=1 data=  0
#                28300  f_clk=0 p=        0 choose=1 data=  0
#                28350  f_clk=1 p=        0 choose=1 data=  0
#                28400  f_clk=0 p=        0 choose=1 data=  0
#                28450  f_clk=1 p=        0 choose=1 data=  0
#                28500  f_clk=0 p=        0 choose=1 data=  0
#                28550  f_clk=1 p=        0 choose=1 data=  0
#                28600  f_clk=0 p=        0 choose=1 data=  0
#                28650  f_clk=1 p=        0 choose=1 data=  0
#                28700  f_clk=0 p=        0 choose=1 data=  0
#                28750  f_clk=1 p=        0 choose=1 data=200
#                28800  f_clk=0 p=        0 choose=1 data=200
#                28850  f_clk=1 p=        0 choose=1 data=200
#                28900  f_clk=0 p=        0 choose=1 data=200
#                28950  f_clk=1 p=        0 choose=1 data=200
#                29000  f_clk=0 p=        0 choose=1 data=200
#                29050  f_clk=1 p=        0 choose=1 data=200
#                29100  f_clk=0 p=        0 choose=1 data=200
#                29150  f_clk=1 p=        0 choose=1 data=200
#                29200  f_clk=0 p=        0 choose=1 data=200
#                29250  f_clk=1 p=        0 choose=1 data=200
#                29300  f_clk=0 p=        0 choose=1 data=200
#                29350  f_clk=1 p=        0 choose=1 data=200
#                29400  f_clk=0 p=        0 choose=1 data=200
#                29450  f_clk=1 p=        0 choose=1 data=200
#                29500  f_clk=0 p=        0 choose=1 data=200
#                29550  f_clk=1 p=        0 choose=1 data=  0
#                29600  f_clk=0 p=        0 choose=1 data=  0
#                29650  f_clk=1 p=        0 choose=1 data=  0
#                29700  f_clk=0 p=        0 choose=1 data=  0
#                29750  f_clk=1 p=        0 choose=1 data=  0
#                29800  f_clk=0 p=        0 choose=1 data=  0
#                29850  f_clk=1 p=        0 choose=1 data=  0
#                29900  f_clk=0 p=        0 choose=1 data=  0
#                29950  f_clk=1 p=        0 choose=1 data=  0
#                30000  f_clk=0 p=        0 choose=1 data=  0
#                30050  f_clk=1 p=        0 choose=1 data=  0
#                30100  f_clk=0 p=        0 choose=1 data=  0
#                30150  f_clk=1 p=        0 choose=1 data=  0
#                30200  f_clk=0 p=        0 choose=1 data=  0
#                30250  f_clk=1 p=        0 choose=1 data=  0
#                30300  f_clk=0 p=        0 choose=1 data=  0
#                30350  f_clk=1 p=        0 choose=1 data=200
#                30400  f_clk=0 p=        0 choose=1 data=200
#                30450  f_clk=1 p=        0 choose=1 data=200
#                30500  f_clk=0 p=        0 choose=1 data=200
#                30550  f_clk=1 p=        0 choose=1 data=200
#                30600  f_clk=0 p=        0 choose=1 data=200
#                30650  f_clk=1 p=        0 choose=1 data=200
#                30700  f_clk=0 p=        0 choose=1 data=200
#                30750  f_clk=1 p=        0 choose=1 data=200
#                30800  f_clk=0 p=        0 choose=1 data=200
#                30850  f_clk=1 p=        0 choose=1 data=200
#                30900  f_clk=0 p=        0 choose=1 data=200
#                30950  f_clk=1 p=        0 choose=1 data=200
#                31000  f_clk=0 p=        0 choose=1 data=200
#                31050  f_clk=1 p=        0 choose=1 data=200
#                31100  f_clk=0 p=        0 choose=1 data=200
#                31150  f_clk=1 p=        0 choose=1 data=  0
#                31200  f_clk=0 p=        0 choose=1 data=  0
#                31250  f_clk=1 p=        0 choose=1 data=  0
#                31300  f_clk=0 p=        0 choose=1 data=  0
#                31350  f_clk=1 p=        0 choose=1 data=  0
#                31400  f_clk=0 p=        0 choose=1 data=  0
#                31450  f_clk=1 p=        0 choose=1 data=  0
#                31500  f_clk=0 p=        0 choose=1 data=  0
#                31550  f_clk=1 p=        0 choose=1 data=  0
#                31600  f_clk=0 p=        0 choose=1 data=  0
#                31650  f_clk=1 p=        0 choose=1 data=  0
#                31700  f_clk=0 p=        0 choose=1 data=  0
#                31750  f_clk=1 p=        0 choose=1 data=  0
#                31800  f_clk=0 p=        0 choose=1 data=  0
#                31850  f_clk=1 p=        0 choose=1 data=  0
#                31900  f_clk=0 p=        0 choose=1 data=  0
#                31950  f_clk=1 p=        0 choose=1 data=200
#                32000  f_clk=0 p=        0 choose=1 data=200
#                32050  f_clk=1 p=        0 choose=1 data=200
#                32100  f_clk=0 p=        0 choose=1 data=200
#                32150  f_clk=1 p=        0 choose=1 data=200
#                32200  f_clk=0 p=        0 choose=1 data=200
#                32250  f_clk=1 p=        0 choose=1 data=200
#                32300  f_clk=0 p=        0 choose=1 data=200
#                32350  f_clk=1 p=        0 choose=1 data=200
#                32400  f_clk=0 p=        0 choose=1 data=200
#                32450  f_clk=1 p=        0 choose=1 data=200
#                32500  f_clk=0 p=        0 choose=1 data=200
#                32550  f_clk=1 p=        0 choose=1 data=200
#                32600  f_clk=0 p=        0 choose=1 data=200
#                32650  f_clk=1 p=        0 choose=1 data=200
#                32700  f_clk=0 p=        0 choose=1 data=200
#                32750  f_clk=1 p=        0 choose=1 data=  0
#                32800  f_clk=0 p=        0 choose=1 data=  0
#                32850  f_clk=1 p=        0 choose=1 data=  0
#                32900  f_clk=0 p=        0 choose=1 data=  0
#                32950  f_clk=1 p=        0 choose=1 data=  0
#                33000  f_clk=0 p=        0 choose=1 data=  0
#                33050  f_clk=1 p=        0 choose=1 data=  0
#                33100  f_clk=0 p=        0 choose=1 data=  0
#                33150  f_clk=1 p=        0 choose=1 data=  0
#                33200  f_clk=0 p=        0 choose=1 data=  0
#                33250  f_clk=1 p=        0 choose=1 data=  0
#                33300  f_clk=0 p=        0 choose=1 data=  0
#                33350  f_clk=1 p=        0 choose=1 data=  0
#                33400  f_clk=0 p=        0 choose=1 data=  0
#                33450  f_clk=1 p=        0 choose=1 data=  0
#                33500  f_clk=0 p=        0 choose=1 data=  0
#                33550  f_clk=1 p=        0 choose=1 data=200
#                33600  f_clk=0 p=        0 choose=1 data=200
#                33650  f_clk=1 p=        0 choose=1 data=200
#                33700  f_clk=0 p=        0 choose=1 data=200
#                33750  f_clk=1 p=        0 choose=1 data=200
#                33800  f_clk=0 p=        0 choose=1 data=200
#                33850  f_clk=1 p=        0 choose=1 data=200
#                33900  f_clk=0 p=        0 choose=1 data=200
#                33950  f_clk=1 p=        0 choose=1 data=200
#                34000  f_clk=0 p=        0 choose=1 data=200
#                34050  f_clk=1 p=        0 choose=1 data=200
#                34100  f_clk=0 p=        0 choose=1 data=200
#                34150  f_clk=1 p=        0 choose=1 data=200
#                34200  f_clk=0 p=        0 choose=1 data=200
#                34250  f_clk=1 p=        0 choose=1 data=200
#                34300  f_clk=0 p=        0 choose=1 data=200
#                34350  f_clk=1 p=        0 choose=1 data=  0
#                34400  f_clk=0 p=        0 choose=1 data=  0
#                34450  f_clk=1 p=        0 choose=1 data=  0
#                34500  f_clk=0 p=        0 choose=1 data=  0
#                34550  f_clk=1 p=        0 choose=1 data=  0
#                34600  f_clk=0 p=        0 choose=1 data=  0
#                34650  f_clk=1 p=        0 choose=1 data=  0
#                34700  f_clk=0 p=        0 choose=1 data=  0
#                34750  f_clk=1 p=        0 choose=1 data=  0
#                34800  f_clk=0 p=        0 choose=1 data=  0
#                34850  f_clk=1 p=        0 choose=1 data=  0
#                34900  f_clk=0 p=        0 choose=1 data=  0
#                34950  f_clk=1 p=        0 choose=1 data=  0
#                35000  f_clk=0 p=        0 choose=1 data=  0
#                35050  f_clk=1 p=        0 choose=1 data=  0
#                35100  f_clk=0 p=        0 choose=1 data=  0
#                35150  f_clk=1 p=        0 choose=1 data=200
#                35200  f_clk=0 p=        0 choose=1 data=200
#                35250  f_clk=1 p=        0 choose=1 data=200
#                35300  f_clk=0 p=        0 choose=1 data=200
#                35350  f_clk=1 p=        0 choose=1 data=200
#                35400  f_clk=0 p=        0 choose=1 data=200
#                35450  f_clk=1 p=        0 choose=1 data=200
#                35500  f_clk=0 p=        0 choose=1 data=200
#                35550  f_clk=1 p=        0 choose=1 data=200
#                35600  f_clk=0 p=        0 choose=1 data=200
#                35650  f_clk=1 p=        0 choose=1 data=200
#                35700  f_clk=0 p=        0 choose=1 data=200
#                35750  f_clk=1 p=        0 choose=1 data=200
#                35800  f_clk=0 p=        0 choose=1 data=200
#                35850  f_clk=1 p=        0 choose=1 data=200
#                35900  f_clk=0 p=        0 choose=1 data=200
#                35950  f_clk=1 p=        0 choose=1 data=  0
#                36000  f_clk=0 p=        0 choose=1 data=  0
#                36050  f_clk=1 p=        0 choose=1 data=  0
#                36100  f_clk=0 p=        0 choose=1 data=  0
#                36150  f_clk=1 p=        0 choose=1 data=  0
#                36200  f_clk=0 p=        0 choose=1 data=  0
#                36250  f_clk=1 p=        0 choose=1 data=  0
#                36300  f_clk=0 p=        0 choose=1 data=  0
#                36350  f_clk=1 p=        0 choose=1 data=  0
#                36400  f_clk=0 p=        0 choose=1 data=  0
#                36450  f_clk=1 p=        0 choose=1 data=  0
#                36500  f_clk=0 p=        0 choose=1 data=  0
#                36550  f_clk=1 p=        0 choose=1 data=  0
#                36600  f_clk=0 p=        0 choose=1 data=  0
#                36650  f_clk=1 p=        0 choose=1 data=  0
#                36700  f_clk=0 p=        0 choose=1 data=  0
#                36750  f_clk=1 p=        0 choose=1 data=200
#                36800  f_clk=0 p=        0 choose=1 data=200
#                36850  f_clk=1 p=        0 choose=1 data=200
#                36900  f_clk=0 p=        0 choose=1 data=200
#                36950  f_clk=1 p=        0 choose=1 data=200
#                37000  f_clk=0 p=        0 choose=1 data=200
#                37050  f_clk=1 p=        0 choose=1 data=200
#                37100  f_clk=0 p=        0 choose=1 data=200
#                37150  f_clk=1 p=        0 choose=1 data=200
#                37200  f_clk=0 p=        0 choose=1 data=200
#                37250  f_clk=1 p=        0 choose=1 data=200
#                37300  f_clk=0 p=        0 choose=1 data=200
#                37350  f_clk=1 p=        0 choose=1 data=200
#                37400  f_clk=0 p=        0 choose=1 data=200
#                37450  f_clk=1 p=        0 choose=1 data=200
#                37500  f_clk=0 p=        0 choose=1 data=200
#                37550  f_clk=1 p=        0 choose=1 data=  0
#                37600  f_clk=0 p=        0 choose=1 data=  0
#                37650  f_clk=1 p=        0 choose=1 data=  0
#                37700  f_clk=0 p=        0 choose=1 data=  0
#                37750  f_clk=1 p=        0 choose=1 data=  0
#                37800  f_clk=0 p=        0 choose=1 data=  0
#                37850  f_clk=1 p=        0 choose=1 data=  0
#                37900  f_clk=0 p=        0 choose=1 data=  0
#                37950  f_clk=1 p=        0 choose=1 data=  0
#                38000  f_clk=0 p=        0 choose=1 data=  0
#                38050  f_clk=1 p=        0 choose=1 data=  0
#                38100  f_clk=0 p=        0 choose=1 data=  0
#                38150  f_clk=1 p=        0 choose=1 data=  0
#                38200  f_clk=0 p=        0 choose=1 data=  0
#                38250  f_clk=1 p=        0 choose=1 data=  0
#                38300  f_clk=0 p=        0 choose=1 data=  0
#                38350  f_clk=1 p=        0 choose=1 data=200
#                38400  f_clk=0 p=        0 choose=1 data=200
#                38450  f_clk=1 p=        0 choose=1 data=200
#                38500  f_clk=0 p=        0 choose=1 data=200
#                38550  f_clk=1 p=        0 choose=1 data=200
#                38600  f_clk=0 p=        0 choose=1 data=200
#                38650  f_clk=1 p=        0 choose=1 data=200
#                38700  f_clk=0 p=        0 choose=1 data=200
#                38750  f_clk=1 p=        0 choose=1 data=200
#                38800  f_clk=0 p=        0 choose=1 data=200
#                38850  f_clk=1 p=        0 choose=1 data=200
#                38900  f_clk=0 p=        0 choose=1 data=200
#                38950  f_clk=1 p=        0 choose=1 data=200
#                39000  f_clk=0 p=        0 choose=1 data=200
#                39050  f_clk=1 p=        0 choose=1 data=200
#                39100  f_clk=0 p=        0 choose=1 data=200
#                39150  f_clk=1 p=        0 choose=1 data=  0
#                39200  f_clk=0 p=        0 choose=1 data=  0
#                39250  f_clk=1 p=        0 choose=1 data=  0
#                39300  f_clk=0 p=        0 choose=1 data=  0
#                39350  f_clk=1 p=        0 choose=1 data=  0
#                39400  f_clk=0 p=        0 choose=1 data=  0
#                39450  f_clk=1 p=        0 choose=1 data=  0
#                39500  f_clk=0 p=        0 choose=1 data=  0
#                39550  f_clk=1 p=        0 choose=1 data=  0
#                39600  f_clk=0 p=        0 choose=1 data=  0
#                39650  f_clk=1 p=        0 choose=1 data=  0
#                39700  f_clk=0 p=        0 choose=1 data=  0
#                39750  f_clk=1 p=        0 choose=1 data=  0
#                39800  f_clk=0 p=        0 choose=1 data=  0
#                39850  f_clk=1 p=        0 choose=1 data=  0
#                39900  f_clk=0 p=        0 choose=1 data=  0
#                39950  f_clk=1 p=        0 choose=1 data=200
#                40000  f_clk=0 p=        0 choose=2 data=  0
#                40050  f_clk=1 p=        0 choose=2 data=  5
#                40100  f_clk=0 p=        0 choose=2 data=  5
#                40150  f_clk=1 p=        0 choose=2 data= 10
#                40200  f_clk=0 p=        0 choose=2 data= 10
#                40250  f_clk=1 p=        0 choose=2 data= 15
#                40300  f_clk=0 p=        0 choose=2 data= 15
#                40350  f_clk=1 p=        0 choose=2 data= 20
#                40400  f_clk=0 p=        0 choose=2 data= 20
#                40450  f_clk=1 p=        0 choose=2 data= 25
#                40500  f_clk=0 p=        0 choose=2 data= 25
#                40550  f_clk=1 p=        0 choose=2 data= 30
#                40600  f_clk=0 p=        0 choose=2 data= 30
#                40650  f_clk=1 p=        0 choose=2 data= 35
#                40700  f_clk=0 p=        0 choose=2 data= 35
#                40750  f_clk=1 p=        0 choose=2 data= 40
#                40800  f_clk=0 p=        0 choose=2 data= 40
#                40850  f_clk=1 p=        0 choose=2 data= 45
#                40900  f_clk=0 p=        0 choose=2 data= 45
#                40950  f_clk=1 p=        0 choose=2 data= 50
#                41000  f_clk=0 p=        0 choose=2 data= 50
#                41050  f_clk=1 p=        0 choose=2 data= 55
#                41100  f_clk=0 p=        0 choose=2 data= 55
#                41150  f_clk=1 p=        0 choose=2 data= 60
#                41200  f_clk=0 p=        0 choose=2 data= 60
#                41250  f_clk=1 p=        0 choose=2 data= 65
#                41300  f_clk=0 p=        0 choose=2 data= 65
#                41350  f_clk=1 p=        0 choose=2 data= 70
#                41400  f_clk=0 p=        0 choose=2 data= 70
#                41450  f_clk=1 p=        0 choose=2 data= 75
#                41500  f_clk=0 p=        0 choose=2 data= 75
#                41550  f_clk=1 p=        0 choose=2 data=  0
#                41600  f_clk=0 p=        0 choose=2 data=  0
#                41650  f_clk=1 p=        0 choose=2 data=  5
#                41700  f_clk=0 p=        0 choose=2 data=  5
#                41750  f_clk=1 p=        0 choose=2 data= 10
#                41800  f_clk=0 p=        0 choose=2 data= 10
#                41850  f_clk=1 p=        0 choose=2 data= 15
#                41900  f_clk=0 p=        0 choose=2 data= 15
#                41950  f_clk=1 p=        0 choose=2 data= 20
#                42000  f_clk=0 p=        0 choose=2 data= 20
#                42050  f_clk=1 p=        0 choose=2 data= 25
#                42100  f_clk=0 p=        0 choose=2 data= 25
#                42150  f_clk=1 p=        0 choose=2 data= 30
#                42200  f_clk=0 p=        0 choose=2 data= 30
#                42250  f_clk=1 p=        0 choose=2 data= 35
#                42300  f_clk=0 p=        0 choose=2 data= 35
#                42350  f_clk=1 p=        0 choose=2 data= 40
#                42400  f_clk=0 p=        0 choose=2 data= 40
#                42450  f_clk=1 p=        0 choose=2 data= 45
#                42500  f_clk=0 p=        0 choose=2 data= 45
#                42550  f_clk=1 p=        0 choose=2 data= 50
#                42600  f_clk=0 p=        0 choose=2 data= 50
#                42650  f_clk=1 p=        0 choose=2 data= 55
#                42700  f_clk=0 p=        0 choose=2 data= 55
#                42750  f_clk=1 p=        0 choose=2 data= 60
#                42800  f_clk=0 p=        0 choose=2 data= 60
#                42850  f_clk=1 p=        0 choose=2 data= 65
#                42900  f_clk=0 p=        0 choose=2 data= 65
#                42950  f_clk=1 p=        0 choose=2 data= 70
#                43000  f_clk=0 p=        0 choose=2 data= 70
#                43050  f_clk=1 p=        0 choose=2 data= 75
#                43100  f_clk=0 p=        0 choose=2 data= 75
#                43150  f_clk=1 p=        0 choose=2 data=  0
#                43200  f_clk=0 p=        0 choose=2 data=  0
#                43250  f_clk=1 p=        0 choose=2 data=  5
#                43300  f_clk=0 p=        0 choose=2 data=  5
#                43350  f_clk=1 p=        0 choose=2 data= 10
#                43400  f_clk=0 p=        0 choose=2 data= 10
#                43450  f_clk=1 p=        0 choose=2 data= 15
#                43500  f_clk=0 p=        0 choose=2 data= 15
#                43550  f_clk=1 p=        0 choose=2 data= 20
#                43600  f_clk=0 p=        0 choose=2 data= 20
#                43650  f_clk=1 p=        0 choose=2 data= 25
#                43700  f_clk=0 p=        0 choose=2 data= 25
#                43750  f_clk=1 p=        0 choose=2 data= 30
#                43800  f_clk=0 p=        0 choose=2 data= 30
#                43850  f_clk=1 p=        0 choose=2 data= 35
#                43900  f_clk=0 p=        0 choose=2 data= 35
#                43950  f_clk=1 p=        0 choose=2 data= 40
#                44000  f_clk=0 p=        0 choose=2 data= 40
#                44050  f_clk=1 p=        0 choose=2 data= 45
#                44100  f_clk=0 p=        0 choose=2 data= 45
#                44150  f_clk=1 p=        0 choose=2 data= 50
#                44200  f_clk=0 p=        0 choose=2 data= 50
#                44250  f_clk=1 p=        0 choose=2 data= 55
#                44300  f_clk=0 p=        0 choose=2 data= 55
#                44350  f_clk=1 p=        0 choose=2 data= 60
#                44400  f_clk=0 p=        0 choose=2 data= 60
#                44450  f_clk=1 p=        0 choose=2 data= 65
#                44500  f_clk=0 p=        0 choose=2 data= 65
#                44550  f_clk=1 p=        0 choose=2 data= 70
#                44600  f_clk=0 p=        0 choose=2 data= 70
#                44650  f_clk=1 p=        0 choose=2 data= 75
#                44700  f_clk=0 p=        0 choose=2 data= 75
#                44750  f_clk=1 p=        0 choose=2 data=  0
#                44800  f_clk=0 p=        0 choose=2 data=  0
#                44850  f_clk=1 p=        0 choose=2 data=  5
#                44900  f_clk=0 p=        0 choose=2 data=  5
#                44950  f_clk=1 p=        0 choose=2 data= 10
#                45000  f_clk=0 p=        0 choose=2 data= 10
#                45050  f_clk=1 p=        0 choose=2 data= 15
#                45100  f_clk=0 p=        0 choose=2 data= 15
#                45150  f_clk=1 p=        0 choose=2 data= 20
#                45200  f_clk=0 p=        0 choose=2 data= 20
#                45250  f_clk=1 p=        0 choose=2 data= 25
#                45300  f_clk=0 p=        0 choose=2 data= 25
#                45350  f_clk=1 p=        0 choose=2 data= 30
#                45400  f_clk=0 p=        0 choose=2 data= 30
#                45450  f_clk=1 p=        0 choose=2 data= 35
#                45500  f_clk=0 p=        0 choose=2 data= 35
#                45550  f_clk=1 p=        0 choose=2 data= 40
#                45600  f_clk=0 p=        0 choose=2 data= 40
#                45650  f_clk=1 p=        0 choose=2 data= 45
#                45700  f_clk=0 p=        0 choose=2 data= 45
#                45750  f_clk=1 p=        0 choose=2 data= 50
#                45800  f_clk=0 p=        0 choose=2 data= 50
#                45850  f_clk=1 p=        0 choose=2 data= 55
#                45900  f_clk=0 p=        0 choose=2 data= 55
#                45950  f_clk=1 p=        0 choose=2 data= 60
#                46000  f_clk=0 p=        0 choose=2 data= 60
#                46050  f_clk=1 p=        0 choose=2 data= 65
#                46100  f_clk=0 p=        0 choose=2 data= 65
#                46150  f_clk=1 p=        0 choose=2 data= 70
#                46200  f_clk=0 p=        0 choose=2 data= 70
#                46250  f_clk=1 p=        0 choose=2 data= 75
#                46300  f_clk=0 p=        0 choose=2 data= 75
#                46350  f_clk=1 p=        0 choose=2 data=  0
#                46400  f_clk=0 p=        0 choose=2 data=  0
#                46450  f_clk=1 p=        0 choose=2 data=  5
#                46500  f_clk=0 p=        0 choose=2 data=  5
#                46550  f_clk=1 p=        0 choose=2 data= 10
#                46600  f_clk=0 p=        0 choose=2 data= 10
#                46650  f_clk=1 p=        0 choose=2 data= 15
#                46700  f_clk=0 p=        0 choose=2 data= 15
#                46750  f_clk=1 p=        0 choose=2 data= 20
#                46800  f_clk=0 p=        0 choose=2 data= 20
#                46850  f_clk=1 p=        0 choose=2 data= 25
#                46900  f_clk=0 p=        0 choose=2 data= 25
#                46950  f_clk=1 p=        0 choose=2 data= 30
#                47000  f_clk=0 p=        0 choose=2 data= 30
#                47050  f_clk=1 p=        0 choose=2 data= 35
#                47100  f_clk=0 p=        0 choose=2 data= 35
#                47150  f_clk=1 p=        0 choose=2 data= 40
#                47200  f_clk=0 p=        0 choose=2 data= 40
#                47250  f_clk=1 p=        0 choose=2 data= 45
#                47300  f_clk=0 p=        0 choose=2 data= 45
#                47350  f_clk=1 p=        0 choose=2 data= 50
#                47400  f_clk=0 p=        0 choose=2 data= 50
#                47450  f_clk=1 p=        0 choose=2 data= 55
#                47500  f_clk=0 p=        0 choose=2 data= 55
#                47550  f_clk=1 p=        0 choose=2 data= 60
#                47600  f_clk=0 p=        0 choose=2 data= 60
#                47650  f_clk=1 p=        0 choose=2 data= 65
#                47700  f_clk=0 p=        0 choose=2 data= 65
#                47750  f_clk=1 p=        0 choose=2 data= 70
#                47800  f_clk=0 p=        0 choose=2 data= 70
#                47850  f_clk=1 p=        0 choose=2 data= 75
#                47900  f_clk=0 p=        0 choose=2 data= 75
#                47950  f_clk=1 p=        0 choose=2 data=  0
#                48000  f_clk=0 p=        0 choose=2 data=  0
#                48050  f_clk=1 p=        0 choose=2 data=  5
#                48100  f_clk=0 p=        0 choose=2 data=  5
#                48150  f_clk=1 p=        0 choose=2 data= 10
#                48200  f_clk=0 p=        0 choose=2 data= 10
#                48250  f_clk=1 p=        0 choose=2 data= 15
#                48300  f_clk=0 p=        0 choose=2 data= 15
#                48350  f_clk=1 p=        0 choose=2 data= 20
#                48400  f_clk=0 p=        0 choose=2 data= 20
#                48450  f_clk=1 p=        0 choose=2 data= 25
#                48500  f_clk=0 p=        0 choose=2 data= 25
#                48550  f_clk=1 p=        0 choose=2 data= 30
#                48600  f_clk=0 p=        0 choose=2 data= 30
#                48650  f_clk=1 p=        0 choose=2 data= 35
#                48700  f_clk=0 p=        0 choose=2 data= 35
#                48750  f_clk=1 p=        0 choose=2 data= 40
#                48800  f_clk=0 p=        0 choose=2 data= 40
#                48850  f_clk=1 p=        0 choose=2 data= 45
#                48900  f_clk=0 p=        0 choose=2 data= 45
#                48950  f_clk=1 p=        0 choose=2 data= 50
#                49000  f_clk=0 p=        0 choose=2 data= 50
#                49050  f_clk=1 p=        0 choose=2 data= 55
#                49100  f_clk=0 p=        0 choose=2 data= 55
#                49150  f_clk=1 p=        0 choose=2 data= 60
#                49200  f_clk=0 p=        0 choose=2 data= 60
#                49250  f_clk=1 p=        0 choose=2 data= 65
#                49300  f_clk=0 p=        0 choose=2 data= 65
#                49350  f_clk=1 p=        0 choose=2 data= 70
#                49400  f_clk=0 p=        0 choose=2 data= 70
#                49450  f_clk=1 p=        0 choose=2 data= 75
#                49500  f_clk=0 p=        0 choose=2 data= 75
#                49550  f_clk=1 p=        0 choose=2 data=  0
#                49600  f_clk=0 p=        0 choose=2 data=  0
#                49650  f_clk=1 p=        0 choose=2 data=  5
#                49700  f_clk=0 p=        0 choose=2 data=  5
#                49750  f_clk=1 p=        0 choose=2 data= 10
#                49800  f_clk=0 p=        0 choose=2 data= 10
#                49850  f_clk=1 p=        0 choose=2 data= 15
#                49900  f_clk=0 p=        0 choose=2 data= 15
#                49950  f_clk=1 p=        0 choose=2 data= 20
#                50000  f_clk=0 p=        0 choose=2 data= 20
#                50050  f_clk=1 p=        0 choose=2 data= 25
#                50100  f_clk=0 p=        0 choose=2 data= 25
#                50150  f_clk=1 p=        0 choose=2 data= 30
#                50200  f_clk=0 p=        0 choose=2 data= 30
#                50250  f_clk=1 p=        0 choose=2 data= 35
#                50300  f_clk=0 p=        0 choose=2 data= 35
#                50350  f_clk=1 p=        0 choose=2 data= 40
#                50400  f_clk=0 p=        0 choose=2 data= 40
#                50450  f_clk=1 p=        0 choose=2 data= 45
#                50500  f_clk=0 p=        0 choose=2 data= 45
#                50550  f_clk=1 p=        0 choose=2 data= 50
#                50600  f_clk=0 p=        0 choose=2 data= 50
#                50650  f_clk=1 p=        0 choose=2 data= 55
#                50700  f_clk=0 p=        0 choose=2 data= 55
#                50750  f_clk=1 p=        0 choose=2 data= 60
#                50800  f_clk=0 p=        0 choose=2 data= 60
#                50850  f_clk=1 p=        0 choose=2 data= 65
#                50900  f_clk=0 p=        0 choose=2 data= 65
#                50950  f_clk=1 p=        0 choose=2 data= 70
#                51000  f_clk=0 p=        0 choose=2 data= 70
#                51050  f_clk=1 p=        0 choose=2 data= 75
#                51100  f_clk=0 p=        0 choose=2 data= 75
#                51150  f_clk=1 p=        0 choose=2 data=  0
#                51200  f_clk=0 p=        0 choose=2 data=  0
#                51250  f_clk=1 p=        0 choose=2 data=  5
#                51300  f_clk=0 p=        0 choose=2 data=  5
#                51350  f_clk=1 p=        0 choose=2 data= 10
#                51400  f_clk=0 p=        0 choose=2 data= 10
#                51450  f_clk=1 p=        0 choose=2 data= 15
#                51500  f_clk=0 p=        0 choose=2 data= 15
#                51550  f_clk=1 p=        0 choose=2 data= 20
#                51600  f_clk=0 p=        0 choose=2 data= 20
#                51650  f_clk=1 p=        0 choose=2 data= 25
#                51700  f_clk=0 p=        0 choose=2 data= 25
#                51750  f_clk=1 p=        0 choose=2 data= 30
#                51800  f_clk=0 p=        0 choose=2 data= 30
#                51850  f_clk=1 p=        0 choose=2 data= 35
#                51900  f_clk=0 p=        0 choose=2 data= 35
#                51950  f_clk=1 p=        0 choose=2 data= 40
#                52000  f_clk=0 p=        0 choose=2 data= 40
#                52050  f_clk=1 p=        0 choose=2 data= 45
#                52100  f_clk=0 p=        0 choose=2 data= 45
#                52150  f_clk=1 p=        0 choose=2 data= 50
#                52200  f_clk=0 p=        0 choose=2 data= 50
#                52250  f_clk=1 p=        0 choose=2 data= 55
#                52300  f_clk=0 p=        0 choose=2 data= 55
#                52350  f_clk=1 p=        0 choose=2 data= 60
#                52400  f_clk=0 p=        0 choose=2 data= 60
#                52450  f_clk=1 p=        0 choose=2 data= 65
#                52500  f_clk=0 p=        0 choose=2 data= 65
#                52550  f_clk=1 p=        0 choose=2 data= 70
#                52600  f_clk=0 p=        0 choose=2 data= 70
#                52650  f_clk=1 p=        0 choose=2 data= 75
#                52700  f_clk=0 p=        0 choose=2 data= 75
#                52750  f_clk=1 p=        0 choose=2 data=  0
#                52800  f_clk=0 p=        0 choose=2 data=  0
#                52850  f_clk=1 p=        0 choose=2 data=  5
#                52900  f_clk=0 p=        0 choose=2 data=  5
#                52950  f_clk=1 p=        0 choose=2 data= 10
#                53000  f_clk=0 p=        0 choose=2 data= 10
#                53050  f_clk=1 p=        0 choose=2 data= 15
#                53100  f_clk=0 p=        0 choose=2 data= 15
#                53150  f_clk=1 p=        0 choose=2 data= 20
#                53200  f_clk=0 p=        0 choose=2 data= 20
#                53250  f_clk=1 p=        0 choose=2 data= 25
#                53300  f_clk=0 p=        0 choose=2 data= 25
#                53350  f_clk=1 p=        0 choose=2 data= 30
#                53400  f_clk=0 p=        0 choose=2 data= 30
#                53450  f_clk=1 p=        0 choose=2 data= 35
#                53500  f_clk=0 p=        0 choose=2 data= 35
#                53550  f_clk=1 p=        0 choose=2 data= 40
#                53600  f_clk=0 p=        0 choose=2 data= 40
#                53650  f_clk=1 p=        0 choose=2 data= 45
#                53700  f_clk=0 p=        0 choose=2 data= 45
#                53750  f_clk=1 p=        0 choose=2 data= 50
#                53800  f_clk=0 p=        0 choose=2 data= 50
#                53850  f_clk=1 p=        0 choose=2 data= 55
#                53900  f_clk=0 p=        0 choose=2 data= 55
#                53950  f_clk=1 p=        0 choose=2 data= 60
#                54000  f_clk=0 p=        0 choose=2 data= 60
#                54050  f_clk=1 p=        0 choose=2 data= 65
#                54100  f_clk=0 p=        0 choose=2 data= 65
#                54150  f_clk=1 p=        0 choose=2 data= 70
#                54200  f_clk=0 p=        0 choose=2 data= 70
#                54250  f_clk=1 p=        0 choose=2 data= 75
#                54300  f_clk=0 p=        0 choose=2 data= 75
#                54350  f_clk=1 p=        0 choose=2 data=  0
#                54400  f_clk=0 p=        0 choose=2 data=  0
#                54450  f_clk=1 p=        0 choose=2 data=  5
#                54500  f_clk=0 p=        0 choose=2 data=  5
#                54550  f_clk=1 p=        0 choose=2 data= 10
#                54600  f_clk=0 p=        0 choose=2 data= 10
#                54650  f_clk=1 p=        0 choose=2 data= 15
#                54700  f_clk=0 p=        0 choose=2 data= 15
#                54750  f_clk=1 p=        0 choose=2 data= 20
#                54800  f_clk=0 p=        0 choose=2 data= 20
#                54850  f_clk=1 p=        0 choose=2 data= 25
#                54900  f_clk=0 p=        0 choose=2 data= 25
#                54950  f_clk=1 p=        0 choose=2 data= 30
#                55000  f_clk=0 p=        0 choose=2 data= 30
#                55050  f_clk=1 p=        0 choose=2 data= 35
#                55100  f_clk=0 p=        0 choose=2 data= 35
#                55150  f_clk=1 p=        0 choose=2 data= 40
#                55200  f_clk=0 p=        0 choose=2 data= 40
#                55250  f_clk=1 p=        0 choose=2 data= 45
#                55300  f_clk=0 p=        0 choose=2 data= 45
#                55350  f_clk=1 p=        0 choose=2 data= 50
#                55400  f_clk=0 p=        0 choose=2 data= 50
#                55450  f_clk=1 p=        0 choose=2 data= 55
#                55500  f_clk=0 p=        0 choose=2 data= 55
#                55550  f_clk=1 p=        0 choose=2 data= 60
#                55600  f_clk=0 p=        0 choose=2 data= 60
#                55650  f_clk=1 p=        0 choose=2 data= 65
#                55700  f_clk=0 p=        0 choose=2 data= 65
#                55750  f_clk=1 p=        0 choose=2 data= 70
#                55800  f_clk=0 p=        0 choose=2 data= 70
#                55850  f_clk=1 p=        0 choose=2 data= 75
#                55900  f_clk=0 p=        0 choose=2 data= 75
#                55950  f_clk=1 p=        0 choose=2 data=  0
#                56000  f_clk=0 p=        0 choose=2 data=  0
#                56050  f_clk=1 p=        0 choose=2 data=  5
#                56100  f_clk=0 p=        0 choose=2 data=  5
#                56150  f_clk=1 p=        0 choose=2 data= 10
#                56200  f_clk=0 p=        0 choose=2 data= 10
#                56250  f_clk=1 p=        0 choose=2 data= 15
#                56300  f_clk=0 p=        0 choose=2 data= 15
#                56350  f_clk=1 p=        0 choose=2 data= 20
#                56400  f_clk=0 p=        0 choose=2 data= 20
#                56450  f_clk=1 p=        0 choose=2 data= 25
#                56500  f_clk=0 p=        0 choose=2 data= 25
#                56550  f_clk=1 p=        0 choose=2 data= 30
#                56600  f_clk=0 p=        0 choose=2 data= 30
#                56650  f_clk=1 p=        0 choose=2 data= 35
#                56700  f_clk=0 p=        0 choose=2 data= 35
#                56750  f_clk=1 p=        0 choose=2 data= 40
#                56800  f_clk=0 p=        0 choose=2 data= 40
#                56850  f_clk=1 p=        0 choose=2 data= 45
#                56900  f_clk=0 p=        0 choose=2 data= 45
#                56950  f_clk=1 p=        0 choose=2 data= 50
#                57000  f_clk=0 p=        0 choose=2 data= 50
#                57050  f_clk=1 p=        0 choose=2 data= 55
#                57100  f_clk=0 p=        0 choose=2 data= 55
#                57150  f_clk=1 p=        0 choose=2 data= 60
#                57200  f_clk=0 p=        0 choose=2 data= 60
#                57250  f_clk=1 p=        0 choose=2 data= 65
#                57300  f_clk=0 p=        0 choose=2 data= 65
#                57350  f_clk=1 p=        0 choose=2 data= 70
#                57400  f_clk=0 p=        0 choose=2 data= 70
#                57450  f_clk=1 p=        0 choose=2 data= 75
#                57500  f_clk=0 p=        0 choose=2 data= 75
#                57550  f_clk=1 p=        0 choose=2 data=  0
#                57600  f_clk=0 p=        0 choose=2 data=  0
#                57650  f_clk=1 p=        0 choose=2 data=  5
#                57700  f_clk=0 p=        0 choose=2 data=  5
#                57750  f_clk=1 p=        0 choose=2 data= 10
#                57800  f_clk=0 p=        0 choose=2 data= 10
#                57850  f_clk=1 p=        0 choose=2 data= 15
#                57900  f_clk=0 p=        0 choose=2 data= 15
#                57950  f_clk=1 p=        0 choose=2 data= 20
#                58000  f_clk=0 p=        0 choose=2 data= 20
#                58050  f_clk=1 p=        0 choose=2 data= 25
#                58100  f_clk=0 p=        0 choose=2 data= 25
#                58150  f_clk=1 p=        0 choose=2 data= 30
#                58200  f_clk=0 p=        0 choose=2 data= 30
#                58250  f_clk=1 p=        0 choose=2 data= 35
#                58300  f_clk=0 p=        0 choose=2 data= 35
#                58350  f_clk=1 p=        0 choose=2 data= 40
#                58400  f_clk=0 p=        0 choose=2 data= 40
#                58450  f_clk=1 p=        0 choose=2 data= 45
#                58500  f_clk=0 p=        0 choose=2 data= 45
#                58550  f_clk=1 p=        0 choose=2 data= 50
#                58600  f_clk=0 p=        0 choose=2 data= 50
#                58650  f_clk=1 p=        0 choose=2 data= 55
#                58700  f_clk=0 p=        0 choose=2 data= 55
#                58750  f_clk=1 p=        0 choose=2 data= 60
#                58800  f_clk=0 p=        0 choose=2 data= 60
#                58850  f_clk=1 p=        0 choose=2 data= 65
#                58900  f_clk=0 p=        0 choose=2 data= 65
#                58950  f_clk=1 p=        0 choose=2 data= 70
#                59000  f_clk=0 p=        0 choose=2 data= 70
#                59050  f_clk=1 p=        0 choose=2 data= 75
#                59100  f_clk=0 p=        0 choose=2 data= 75
#                59150  f_clk=1 p=        0 choose=2 data=  0
#                59200  f_clk=0 p=        0 choose=2 data=  0
#                59250  f_clk=1 p=        0 choose=2 data=  5
#                59300  f_clk=0 p=        0 choose=2 data=  5
#                59350  f_clk=1 p=        0 choose=2 data= 10
#                59400  f_clk=0 p=        0 choose=2 data= 10
#                59450  f_clk=1 p=        0 choose=2 data= 15
#                59500  f_clk=0 p=        0 choose=2 data= 15
#                59550  f_clk=1 p=        0 choose=2 data= 20
#                59600  f_clk=0 p=        0 choose=2 data= 20
#                59650  f_clk=1 p=        0 choose=2 data= 25
#                59700  f_clk=0 p=        0 choose=2 data= 25
#                59750  f_clk=1 p=        0 choose=2 data= 30
#                59800  f_clk=0 p=        0 choose=2 data= 30
#                59850  f_clk=1 p=        0 choose=2 data= 35
#                59900  f_clk=0 p=        0 choose=2 data= 35
#                59950  f_clk=1 p=        0 choose=2 data= 40
#                60000  f_clk=0 p=        0 choose=3 data= 35
#                60050  f_clk=1 p=        0 choose=3 data= 30
#                60100  f_clk=0 p=        0 choose=3 data= 30
#                60150  f_clk=1 p=        0 choose=3 data= 25
#                60200  f_clk=0 p=        0 choose=3 data= 25
#                60250  f_clk=1 p=        0 choose=3 data= 20
#                60300  f_clk=0 p=        0 choose=3 data= 20
#                60350  f_clk=1 p=        0 choose=3 data= 15
#                60400  f_clk=0 p=        0 choose=3 data= 15
#                60450  f_clk=1 p=        0 choose=3 data= 10
#                60500  f_clk=0 p=        0 choose=3 data= 10
#                60550  f_clk=1 p=        0 choose=3 data=  5
#                60600  f_clk=0 p=        0 choose=3 data=  5
#                60650  f_clk=1 p=        0 choose=3 data=  0
#                60700  f_clk=0 p=        0 choose=3 data=  0
#                60750  f_clk=1 p=        0 choose=3 data= 75
#                60800  f_clk=0 p=        0 choose=3 data= 75
#                60850  f_clk=1 p=        0 choose=3 data= 70
#                60900  f_clk=0 p=        0 choose=3 data= 70
#                60950  f_clk=1 p=        0 choose=3 data= 65
#                61000  f_clk=0 p=        0 choose=3 data= 65
#                61050  f_clk=1 p=        0 choose=3 data= 60
#                61100  f_clk=0 p=        0 choose=3 data= 60
#                61150  f_clk=1 p=        0 choose=3 data= 55
#                61200  f_clk=0 p=        0 choose=3 data= 55
#                61250  f_clk=1 p=        0 choose=3 data= 50
#                61300  f_clk=0 p=        0 choose=3 data= 50
#                61350  f_clk=1 p=        0 choose=3 data= 45
#                61400  f_clk=0 p=        0 choose=3 data= 45
#                61450  f_clk=1 p=        0 choose=3 data= 40
#                61500  f_clk=0 p=        0 choose=3 data= 40
#                61550  f_clk=1 p=        0 choose=3 data= 35
#                61600  f_clk=0 p=        0 choose=3 data= 35
#                61650  f_clk=1 p=        0 choose=3 data= 30
#                61700  f_clk=0 p=        0 choose=3 data= 30
#                61750  f_clk=1 p=        0 choose=3 data= 25
#                61800  f_clk=0 p=        0 choose=3 data= 25
#                61850  f_clk=1 p=        0 choose=3 data= 20
#                61900  f_clk=0 p=        0 choose=3 data= 20
#                61950  f_clk=1 p=        0 choose=3 data= 15
#                62000  f_clk=0 p=        0 choose=3 data= 15
#                62050  f_clk=1 p=        0 choose=3 data= 10
#                62100  f_clk=0 p=        0 choose=3 data= 10
#                62150  f_clk=1 p=        0 choose=3 data=  5
#                62200  f_clk=0 p=        0 choose=3 data=  5
#                62250  f_clk=1 p=        0 choose=3 data=  0
#                62300  f_clk=0 p=        0 choose=3 data=  0
#                62350  f_clk=1 p=        0 choose=3 data= 75
#                62400  f_clk=0 p=        0 choose=3 data= 75
#                62450  f_clk=1 p=        0 choose=3 data= 70
#                62500  f_clk=0 p=        0 choose=3 data= 70
#                62550  f_clk=1 p=        0 choose=3 data= 65
#                62600  f_clk=0 p=        0 choose=3 data= 65
#                62650  f_clk=1 p=        0 choose=3 data= 60
#                62700  f_clk=0 p=        0 choose=3 data= 60
#                62750  f_clk=1 p=        0 choose=3 data= 55
#                62800  f_clk=0 p=        0 choose=3 data= 55
#                62850  f_clk=1 p=        0 choose=3 data= 50
#                62900  f_clk=0 p=        0 choose=3 data= 50
#                62950  f_clk=1 p=        0 choose=3 data= 45
#                63000  f_clk=0 p=        0 choose=3 data= 45
#                63050  f_clk=1 p=        0 choose=3 data= 40
#                63100  f_clk=0 p=        0 choose=3 data= 40
#                63150  f_clk=1 p=        0 choose=3 data= 35
#                63200  f_clk=0 p=        0 choose=3 data= 35
#                63250  f_clk=1 p=        0 choose=3 data= 30
#                63300  f_clk=0 p=        0 choose=3 data= 30
#                63350  f_clk=1 p=        0 choose=3 data= 25
#                63400  f_clk=0 p=        0 choose=3 data= 25
#                63450  f_clk=1 p=        0 choose=3 data= 20
#                63500  f_clk=0 p=        0 choose=3 data= 20
#                63550  f_clk=1 p=        0 choose=3 data= 15
#                63600  f_clk=0 p=        0 choose=3 data= 15
#                63650  f_clk=1 p=        0 choose=3 data= 10
#                63700  f_clk=0 p=        0 choose=3 data= 10
#                63750  f_clk=1 p=        0 choose=3 data=  5
#                63800  f_clk=0 p=        0 choose=3 data=  5
#                63850  f_clk=1 p=        0 choose=3 data=  0
#                63900  f_clk=0 p=        0 choose=3 data=  0
#                63950  f_clk=1 p=        0 choose=3 data= 75
#                64000  f_clk=0 p=        0 choose=3 data= 75
#                64050  f_clk=1 p=        0 choose=3 data= 70
#                64100  f_clk=0 p=        0 choose=3 data= 70
#                64150  f_clk=1 p=        0 choose=3 data= 65
#                64200  f_clk=0 p=        0 choose=3 data= 65
#                64250  f_clk=1 p=        0 choose=3 data= 60
#                64300  f_clk=0 p=        0 choose=3 data= 60
#                64350  f_clk=1 p=        0 choose=3 data= 55
#                64400  f_clk=0 p=        0 choose=3 data= 55
#                64450  f_clk=1 p=        0 choose=3 data= 50
#                64500  f_clk=0 p=        0 choose=3 data= 50
#                64550  f_clk=1 p=        0 choose=3 data= 45
#                64600  f_clk=0 p=        0 choose=3 data= 45
#                64650  f_clk=1 p=        0 choose=3 data= 40
#                64700  f_clk=0 p=        0 choose=3 data= 40
#                64750  f_clk=1 p=        0 choose=3 data= 35
#                64800  f_clk=0 p=        0 choose=3 data= 35
#                64850  f_clk=1 p=        0 choose=3 data= 30
#                64900  f_clk=0 p=        0 choose=3 data= 30
#                64950  f_clk=1 p=        0 choose=3 data= 25
#                65000  f_clk=0 p=        0 choose=3 data= 25
#                65050  f_clk=1 p=        0 choose=3 data= 20
#                65100  f_clk=0 p=        0 choose=3 data= 20
#                65150  f_clk=1 p=        0 choose=3 data= 15
#                65200  f_clk=0 p=        0 choose=3 data= 15
#                65250  f_clk=1 p=        0 choose=3 data= 10
#                65300  f_clk=0 p=        0 choose=3 data= 10
#                65350  f_clk=1 p=        0 choose=3 data=  5
#                65400  f_clk=0 p=        0 choose=3 data=  5
#                65450  f_clk=1 p=        0 choose=3 data=  0
#                65500  f_clk=0 p=        0 choose=3 data=  0
#                65550  f_clk=1 p=        0 choose=3 data= 75
#                65600  f_clk=0 p=        0 choose=3 data= 75
#                65650  f_clk=1 p=        0 choose=3 data= 70
#                65700  f_clk=0 p=        0 choose=3 data= 70
#                65750  f_clk=1 p=        0 choose=3 data= 65
#                65800  f_clk=0 p=        0 choose=3 data= 65
#                65850  f_clk=1 p=        0 choose=3 data= 60
#                65900  f_clk=0 p=        0 choose=3 data= 60
#                65950  f_clk=1 p=        0 choose=3 data= 55
#                66000  f_clk=0 p=        0 choose=3 data= 55
#                66050  f_clk=1 p=        0 choose=3 data= 50
#                66100  f_clk=0 p=        0 choose=3 data= 50
#                66150  f_clk=1 p=        0 choose=3 data= 45
#                66200  f_clk=0 p=        0 choose=3 data= 45
#                66250  f_clk=1 p=        0 choose=3 data= 40
#                66300  f_clk=0 p=        0 choose=3 data= 40
#                66350  f_clk=1 p=        0 choose=3 data= 35
#                66400  f_clk=0 p=        0 choose=3 data= 35
#                66450  f_clk=1 p=        0 choose=3 data= 30
#                66500  f_clk=0 p=        0 choose=3 data= 30
#                66550  f_clk=1 p=        0 choose=3 data= 25
#                66600  f_clk=0 p=        0 choose=3 data= 25
#                66650  f_clk=1 p=        0 choose=3 data= 20
#                66700  f_clk=0 p=        0 choose=3 data= 20
#                66750  f_clk=1 p=        0 choose=3 data= 15
#                66800  f_clk=0 p=        0 choose=3 data= 15
#                66850  f_clk=1 p=        0 choose=3 data= 10
#                66900  f_clk=0 p=        0 choose=3 data= 10
#                66950  f_clk=1 p=        0 choose=3 data=  5
#                67000  f_clk=0 p=        0 choose=3 data=  5
#                67050  f_clk=1 p=        0 choose=3 data=  0
#                67100  f_clk=0 p=        0 choose=3 data=  0
#                67150  f_clk=1 p=        0 choose=3 data= 75
#                67200  f_clk=0 p=        0 choose=3 data= 75
#                67250  f_clk=1 p=        0 choose=3 data= 70
#                67300  f_clk=0 p=        0 choose=3 data= 70
#                67350  f_clk=1 p=        0 choose=3 data= 65
#                67400  f_clk=0 p=        0 choose=3 data= 65
#                67450  f_clk=1 p=        0 choose=3 data= 60
#                67500  f_clk=0 p=        0 choose=3 data= 60
#                67550  f_clk=1 p=        0 choose=3 data= 55
#                67600  f_clk=0 p=        0 choose=3 data= 55
#                67650  f_clk=1 p=        0 choose=3 data= 50
#                67700  f_clk=0 p=        0 choose=3 data= 50
#                67750  f_clk=1 p=        0 choose=3 data= 45
#                67800  f_clk=0 p=        0 choose=3 data= 45
#                67850  f_clk=1 p=        0 choose=3 data= 40
#                67900  f_clk=0 p=        0 choose=3 data= 40
#                67950  f_clk=1 p=        0 choose=3 data= 35
#                68000  f_clk=0 p=        0 choose=3 data= 35
#                68050  f_clk=1 p=        0 choose=3 data= 30
#                68100  f_clk=0 p=        0 choose=3 data= 30
#                68150  f_clk=1 p=        0 choose=3 data= 25
#                68200  f_clk=0 p=        0 choose=3 data= 25
#                68250  f_clk=1 p=        0 choose=3 data= 20
#                68300  f_clk=0 p=        0 choose=3 data= 20
#                68350  f_clk=1 p=        0 choose=3 data= 15
#                68400  f_clk=0 p=        0 choose=3 data= 15
#                68450  f_clk=1 p=        0 choose=3 data= 10
#                68500  f_clk=0 p=        0 choose=3 data= 10
#                68550  f_clk=1 p=        0 choose=3 data=  5
#                68600  f_clk=0 p=        0 choose=3 data=  5
#                68650  f_clk=1 p=        0 choose=3 data=  0
#                68700  f_clk=0 p=        0 choose=3 data=  0
#                68750  f_clk=1 p=        0 choose=3 data= 75
#                68800  f_clk=0 p=        0 choose=3 data= 75
#                68850  f_clk=1 p=        0 choose=3 data= 70
#                68900  f_clk=0 p=        0 choose=3 data= 70
#                68950  f_clk=1 p=        0 choose=3 data= 65
#                69000  f_clk=0 p=        0 choose=3 data= 65
#                69050  f_clk=1 p=        0 choose=3 data= 60
#                69100  f_clk=0 p=        0 choose=3 data= 60
#                69150  f_clk=1 p=        0 choose=3 data= 55
#                69200  f_clk=0 p=        0 choose=3 data= 55
#                69250  f_clk=1 p=        0 choose=3 data= 50
#                69300  f_clk=0 p=        0 choose=3 data= 50
#                69350  f_clk=1 p=        0 choose=3 data= 45
#                69400  f_clk=0 p=        0 choose=3 data= 45
#                69450  f_clk=1 p=        0 choose=3 data= 40
#                69500  f_clk=0 p=        0 choose=3 data= 40
#                69550  f_clk=1 p=        0 choose=3 data= 35
#                69600  f_clk=0 p=        0 choose=3 data= 35
#                69650  f_clk=1 p=        0 choose=3 data= 30
#                69700  f_clk=0 p=        0 choose=3 data= 30
#                69750  f_clk=1 p=        0 choose=3 data= 25
#                69800  f_clk=0 p=        0 choose=3 data= 25
#                69850  f_clk=1 p=        0 choose=3 data= 20
#                69900  f_clk=0 p=        0 choose=3 data= 20
#                69950  f_clk=1 p=        0 choose=3 data= 15
#                70000  f_clk=0 p=        0 choose=3 data= 15
#                70050  f_clk=1 p=        0 choose=3 data= 10
#                70100  f_clk=0 p=        0 choose=3 data= 10
#                70150  f_clk=1 p=        0 choose=3 data=  5
#                70200  f_clk=0 p=        0 choose=3 data=  5
#                70250  f_clk=1 p=        0 choose=3 data=  0
#                70300  f_clk=0 p=        0 choose=3 data=  0
#                70350  f_clk=1 p=        0 choose=3 data= 75
#                70400  f_clk=0 p=        0 choose=3 data= 75
#                70450  f_clk=1 p=        0 choose=3 data= 70
#                70500  f_clk=0 p=        0 choose=3 data= 70
#                70550  f_clk=1 p=        0 choose=3 data= 65
#                70600  f_clk=0 p=        0 choose=3 data= 65
#                70650  f_clk=1 p=        0 choose=3 data= 60
#                70700  f_clk=0 p=        0 choose=3 data= 60
#                70750  f_clk=1 p=        0 choose=3 data= 55
#                70800  f_clk=0 p=        0 choose=3 data= 55
#                70850  f_clk=1 p=        0 choose=3 data= 50
#                70900  f_clk=0 p=        0 choose=3 data= 50
#                70950  f_clk=1 p=        0 choose=3 data= 45
#                71000  f_clk=0 p=        0 choose=3 data= 45
#                71050  f_clk=1 p=        0 choose=3 data= 40
#                71100  f_clk=0 p=        0 choose=3 data= 40
#                71150  f_clk=1 p=        0 choose=3 data= 35
#                71200  f_clk=0 p=        0 choose=3 data= 35
#                71250  f_clk=1 p=        0 choose=3 data= 30
#                71300  f_clk=0 p=        0 choose=3 data= 30
#                71350  f_clk=1 p=        0 choose=3 data= 25
#                71400  f_clk=0 p=        0 choose=3 data= 25
#                71450  f_clk=1 p=        0 choose=3 data= 20
#                71500  f_clk=0 p=        0 choose=3 data= 20
#                71550  f_clk=1 p=        0 choose=3 data= 15
#                71600  f_clk=0 p=        0 choose=3 data= 15
#                71650  f_clk=1 p=        0 choose=3 data= 10
#                71700  f_clk=0 p=        0 choose=3 data= 10
#                71750  f_clk=1 p=        0 choose=3 data=  5
#                71800  f_clk=0 p=        0 choose=3 data=  5
#                71850  f_clk=1 p=        0 choose=3 data=  0
#                71900  f_clk=0 p=        0 choose=3 data=  0
#                71950  f_clk=1 p=        0 choose=3 data= 75
#                72000  f_clk=0 p=        0 choose=3 data= 75
#                72050  f_clk=1 p=        0 choose=3 data= 70
#                72100  f_clk=0 p=        0 choose=3 data= 70
#                72150  f_clk=1 p=        0 choose=3 data= 65
#                72200  f_clk=0 p=        0 choose=3 data= 65
#                72250  f_clk=1 p=        0 choose=3 data= 60
#                72300  f_clk=0 p=        0 choose=3 data= 60
#                72350  f_clk=1 p=        0 choose=3 data= 55
#                72400  f_clk=0 p=        0 choose=3 data= 55
#                72450  f_clk=1 p=        0 choose=3 data= 50
#                72500  f_clk=0 p=        0 choose=3 data= 50
#                72550  f_clk=1 p=        0 choose=3 data= 45
#                72600  f_clk=0 p=        0 choose=3 data= 45
#                72650  f_clk=1 p=        0 choose=3 data= 40
#                72700  f_clk=0 p=        0 choose=3 data= 40
#                72750  f_clk=1 p=        0 choose=3 data= 35
#                72800  f_clk=0 p=        0 choose=3 data= 35
#                72850  f_clk=1 p=        0 choose=3 data= 30
#                72900  f_clk=0 p=        0 choose=3 data= 30
#                72950  f_clk=1 p=        0 choose=3 data= 25
#                73000  f_clk=0 p=        0 choose=3 data= 25
#                73050  f_clk=1 p=        0 choose=3 data= 20
#                73100  f_clk=0 p=        0 choose=3 data= 20
#                73150  f_clk=1 p=        0 choose=3 data= 15
#                73200  f_clk=0 p=        0 choose=3 data= 15
#                73250  f_clk=1 p=        0 choose=3 data= 10
#                73300  f_clk=0 p=        0 choose=3 data= 10
#                73350  f_clk=1 p=        0 choose=3 data=  5
#                73400  f_clk=0 p=        0 choose=3 data=  5
#                73450  f_clk=1 p=        0 choose=3 data=  0
#                73500  f_clk=0 p=        0 choose=3 data=  0
#                73550  f_clk=1 p=        0 choose=3 data= 75
#                73600  f_clk=0 p=        0 choose=3 data= 75
#                73650  f_clk=1 p=        0 choose=3 data= 70
#                73700  f_clk=0 p=        0 choose=3 data= 70
#                73750  f_clk=1 p=        0 choose=3 data= 65
#                73800  f_clk=0 p=        0 choose=3 data= 65
#                73850  f_clk=1 p=        0 choose=3 data= 60
#                73900  f_clk=0 p=        0 choose=3 data= 60
#                73950  f_clk=1 p=        0 choose=3 data= 55
#                74000  f_clk=0 p=        0 choose=3 data= 55
#                74050  f_clk=1 p=        0 choose=3 data= 50
#                74100  f_clk=0 p=        0 choose=3 data= 50
#                74150  f_clk=1 p=        0 choose=3 data= 45
#                74200  f_clk=0 p=        0 choose=3 data= 45
#                74250  f_clk=1 p=        0 choose=3 data= 40
#                74300  f_clk=0 p=        0 choose=3 data= 40
#                74350  f_clk=1 p=        0 choose=3 data= 35
#                74400  f_clk=0 p=        0 choose=3 data= 35
#                74450  f_clk=1 p=        0 choose=3 data= 30
#                74500  f_clk=0 p=        0 choose=3 data= 30
#                74550  f_clk=1 p=        0 choose=3 data= 25
#                74600  f_clk=0 p=        0 choose=3 data= 25
#                74650  f_clk=1 p=        0 choose=3 data= 20
#                74700  f_clk=0 p=        0 choose=3 data= 20
#                74750  f_clk=1 p=        0 choose=3 data= 15
#                74800  f_clk=0 p=        0 choose=3 data= 15
#                74850  f_clk=1 p=        0 choose=3 data= 10
#                74900  f_clk=0 p=        0 choose=3 data= 10
#                74950  f_clk=1 p=        0 choose=3 data=  5
#                75000  f_clk=0 p=        0 choose=3 data=  5
#                75050  f_clk=1 p=        0 choose=3 data=  0
#                75100  f_clk=0 p=        0 choose=3 data=  0
#                75150  f_clk=1 p=        0 choose=3 data= 75
#                75200  f_clk=0 p=        0 choose=3 data= 75
#                75250  f_clk=1 p=        0 choose=3 data= 70
#                75300  f_clk=0 p=        0 choose=3 data= 70
#                75350  f_clk=1 p=        0 choose=3 data= 65
#                75400  f_clk=0 p=        0 choose=3 data= 65
#                75450  f_clk=1 p=        0 choose=3 data= 60
#                75500  f_clk=0 p=        0 choose=3 data= 60
#                75550  f_clk=1 p=        0 choose=3 data= 55
#                75600  f_clk=0 p=        0 choose=3 data= 55
#                75650  f_clk=1 p=        0 choose=3 data= 50
#                75700  f_clk=0 p=        0 choose=3 data= 50
#                75750  f_clk=1 p=        0 choose=3 data= 45
#                75800  f_clk=0 p=        0 choose=3 data= 45
#                75850  f_clk=1 p=        0 choose=3 data= 40
#                75900  f_clk=0 p=        0 choose=3 data= 40
#                75950  f_clk=1 p=        0 choose=3 data= 35
#                76000  f_clk=0 p=        0 choose=3 data= 35
#                76050  f_clk=1 p=        0 choose=3 data= 30
#                76100  f_clk=0 p=        0 choose=3 data= 30
#                76150  f_clk=1 p=        0 choose=3 data= 25
#                76200  f_clk=0 p=        0 choose=3 data= 25
#                76250  f_clk=1 p=        0 choose=3 data= 20
#                76300  f_clk=0 p=        0 choose=3 data= 20
#                76350  f_clk=1 p=        0 choose=3 data= 15
#                76400  f_clk=0 p=        0 choose=3 data= 15
#                76450  f_clk=1 p=        0 choose=3 data= 10
#                76500  f_clk=0 p=        0 choose=3 data= 10
#                76550  f_clk=1 p=        0 choose=3 data=  5
#                76600  f_clk=0 p=        0 choose=3 data=  5
#                76650  f_clk=1 p=        0 choose=3 data=  0
#                76700  f_clk=0 p=        0 choose=3 data=  0
#                76750  f_clk=1 p=        0 choose=3 data= 75
#                76800  f_clk=0 p=        0 choose=3 data= 75
#                76850  f_clk=1 p=        0 choose=3 data= 70
#                76900  f_clk=0 p=        0 choose=3 data= 70
#                76950  f_clk=1 p=        0 choose=3 data= 65
#                77000  f_clk=0 p=        0 choose=3 data= 65
#                77050  f_clk=1 p=        0 choose=3 data= 60
#                77100  f_clk=0 p=        0 choose=3 data= 60
#                77150  f_clk=1 p=        0 choose=3 data= 55
#                77200  f_clk=0 p=        0 choose=3 data= 55
#                77250  f_clk=1 p=        0 choose=3 data= 50
#                77300  f_clk=0 p=        0 choose=3 data= 50
#                77350  f_clk=1 p=        0 choose=3 data= 45
#                77400  f_clk=0 p=        0 choose=3 data= 45
#                77450  f_clk=1 p=        0 choose=3 data= 40
#                77500  f_clk=0 p=        0 choose=3 data= 40
#                77550  f_clk=1 p=        0 choose=3 data= 35
#                77600  f_clk=0 p=        0 choose=3 data= 35
#                77650  f_clk=1 p=        0 choose=3 data= 30
#                77700  f_clk=0 p=        0 choose=3 data= 30
#                77750  f_clk=1 p=        0 choose=3 data= 25
#                77800  f_clk=0 p=        0 choose=3 data= 25
#                77850  f_clk=1 p=        0 choose=3 data= 20
#                77900  f_clk=0 p=        0 choose=3 data= 20
#                77950  f_clk=1 p=        0 choose=3 data= 15
#                78000  f_clk=0 p=        0 choose=3 data= 15
#                78050  f_clk=1 p=        0 choose=3 data= 10
#                78100  f_clk=0 p=        0 choose=3 data= 10
#                78150  f_clk=1 p=        0 choose=3 data=  5
#                78200  f_clk=0 p=        0 choose=3 data=  5
#                78250  f_clk=1 p=        0 choose=3 data=  0
#                78300  f_clk=0 p=        0 choose=3 data=  0
#                78350  f_clk=1 p=        0 choose=3 data= 75
#                78400  f_clk=0 p=        0 choose=3 data= 75
#                78450  f_clk=1 p=        0 choose=3 data= 70
#                78500  f_clk=0 p=        0 choose=3 data= 70
#                78550  f_clk=1 p=        0 choose=3 data= 65
#                78600  f_clk=0 p=        0 choose=3 data= 65
#                78650  f_clk=1 p=        0 choose=3 data= 60
#                78700  f_clk=0 p=        0 choose=3 data= 60
#                78750  f_clk=1 p=        0 choose=3 data= 55
#                78800  f_clk=0 p=        0 choose=3 data= 55
#                78850  f_clk=1 p=        0 choose=3 data= 50
#                78900  f_clk=0 p=        0 choose=3 data= 50
#                78950  f_clk=1 p=        0 choose=3 data= 45
#                79000  f_clk=0 p=        0 choose=3 data= 45
#                79050  f_clk=1 p=        0 choose=3 data= 40
#                79100  f_clk=0 p=        0 choose=3 data= 40
#                79150  f_clk=1 p=        0 choose=3 data= 35
#                79200  f_clk=0 p=        0 choose=3 data= 35
#                79250  f_clk=1 p=        0 choose=3 data= 30
#                79300  f_clk=0 p=        0 choose=3 data= 30
#                79350  f_clk=1 p=        0 choose=3 data= 25
#                79400  f_clk=0 p=        0 choose=3 data= 25
#                79450  f_clk=1 p=        0 choose=3 data= 20
#                79500  f_clk=0 p=        0 choose=3 data= 20
#                79550  f_clk=1 p=        0 choose=3 data= 15
#                79600  f_clk=0 p=        0 choose=3 data= 15
#                79650  f_clk=1 p=        0 choose=3 data= 10
#                79700  f_clk=0 p=        0 choose=3 data= 10
#                79750  f_clk=1 p=        0 choose=3 data=  5
#                79800  f_clk=0 p=        0 choose=3 data=  5
#                79850  f_clk=1 p=        0 choose=3 data=  0
#                79900  f_clk=0 p=        0 choose=3 data=  0
#                79950  f_clk=1 p=        0 choose=3 data= 75
#                80000  f_clk=0 p=        1 choose=0 data=  0
#                80050  f_clk=1 p=        1 choose=0 data=  0
#                80100  f_clk=0 p=        1 choose=0 data=  0
#                80150  f_clk=1 p=        1 choose=0 data= 41
#                80200  f_clk=0 p=        1 choose=0 data= 41
#                80250  f_clk=1 p=        1 choose=0 data= 41
#                80300  f_clk=0 p=        1 choose=0 data= 41
#                80350  f_clk=1 p=        1 choose=0 data= 74
#                80400  f_clk=0 p=        1 choose=0 data= 74
#                80450  f_clk=1 p=        1 choose=0 data= 74
#                80500  f_clk=0 p=        1 choose=0 data= 74
#                80550  f_clk=1 p=        1 choose=0 data= 95
#                80600  f_clk=0 p=        1 choose=0 data= 95
#                80650  f_clk=1 p=        1 choose=0 data= 95
#                80700  f_clk=0 p=        1 choose=0 data= 95
#                80750  f_clk=1 p=        1 choose=0 data= 99
#                80800  f_clk=0 p=        1 choose=0 data= 99
#                80850  f_clk=1 p=        1 choose=0 data= 99
#                80900  f_clk=0 p=        1 choose=0 data= 99
#                80950  f_clk=1 p=        1 choose=0 data= 87
#                81000  f_clk=0 p=        1 choose=0 data= 87
#                81050  f_clk=1 p=        1 choose=0 data= 87
#                81100  f_clk=0 p=        1 choose=0 data= 87
#                81150  f_clk=1 p=        1 choose=0 data= 58
#                81200  f_clk=0 p=        1 choose=0 data= 58
#                81250  f_clk=1 p=        1 choose=0 data= 58
#                81300  f_clk=0 p=        1 choose=0 data= 58
#                81350  f_clk=1 p=        1 choose=0 data= 21
#                81400  f_clk=0 p=        1 choose=0 data= 21
#                81450  f_clk=1 p=        1 choose=0 data= 21
#                81500  f_clk=0 p=        1 choose=0 data= 21
#                81550  f_clk=1 p=        1 choose=0 data=235
#                81600  f_clk=0 p=        1 choose=0 data=235
#                81650  f_clk=1 p=        1 choose=0 data=235
#                81700  f_clk=0 p=        1 choose=0 data=235
#                81750  f_clk=1 p=        1 choose=0 data=198
#                81800  f_clk=0 p=        1 choose=0 data=198
#                81850  f_clk=1 p=        1 choose=0 data=198
#                81900  f_clk=0 p=        1 choose=0 data=198
#                81950  f_clk=1 p=        1 choose=0 data=169
#                82000  f_clk=0 p=        1 choose=0 data=169
#                82050  f_clk=1 p=        1 choose=0 data=169
#                82100  f_clk=0 p=        1 choose=0 data=169
#                82150  f_clk=1 p=        1 choose=0 data=157
#                82200  f_clk=0 p=        1 choose=0 data=157
#                82250  f_clk=1 p=        1 choose=0 data=157
#                82300  f_clk=0 p=        1 choose=0 data=157
#                82350  f_clk=1 p=        1 choose=0 data=161
#                82400  f_clk=0 p=        1 choose=0 data=161
#                82450  f_clk=1 p=        1 choose=0 data=161
#                82500  f_clk=0 p=        1 choose=0 data=161
#                82550  f_clk=1 p=        1 choose=0 data=182
#                82600  f_clk=0 p=        1 choose=0 data=182
#                82650  f_clk=1 p=        1 choose=0 data=182
#                82700  f_clk=0 p=        1 choose=0 data=182
#                82750  f_clk=1 p=        1 choose=0 data=215
#                82800  f_clk=0 p=        1 choose=0 data=215
#                82850  f_clk=1 p=        1 choose=0 data=215
#                82900  f_clk=0 p=        1 choose=0 data=215
#                82950  f_clk=1 p=        1 choose=0 data=  0
#                83000  f_clk=0 p=        1 choose=0 data=  0
#                83050  f_clk=1 p=        1 choose=0 data=  0
#                83100  f_clk=0 p=        1 choose=0 data=  0
#                83150  f_clk=1 p=        1 choose=0 data=  0
#                83200  f_clk=0 p=        1 choose=0 data=  0
#                83250  f_clk=1 p=        1 choose=0 data=  0
#                83300  f_clk=0 p=        1 choose=0 data=  0
#                83350  f_clk=1 p=        1 choose=0 data= 41
#                83400  f_clk=0 p=        1 choose=0 data= 41
#                83450  f_clk=1 p=        1 choose=0 data= 41
#                83500  f_clk=0 p=        1 choose=0 data= 41
#                83550  f_clk=1 p=        1 choose=0 data= 74
#                83600  f_clk=0 p=        1 choose=0 data= 74
#                83650  f_clk=1 p=        1 choose=0 data= 74
#                83700  f_clk=0 p=        1 choose=0 data= 74
#                83750  f_clk=1 p=        1 choose=0 data= 95
#                83800  f_clk=0 p=        1 choose=0 data= 95
#                83850  f_clk=1 p=        1 choose=0 data= 95
#                83900  f_clk=0 p=        1 choose=0 data= 95
#                83950  f_clk=1 p=        1 choose=0 data= 99
#                84000  f_clk=0 p=        1 choose=0 data= 99
#                84050  f_clk=1 p=        1 choose=0 data= 99
#                84100  f_clk=0 p=        1 choose=0 data= 99
#                84150  f_clk=1 p=        1 choose=0 data= 87
#                84200  f_clk=0 p=        1 choose=0 data= 87
#                84250  f_clk=1 p=        1 choose=0 data= 87
#                84300  f_clk=0 p=        1 choose=0 data= 87
#                84350  f_clk=1 p=        1 choose=0 data= 58
#                84400  f_clk=0 p=        1 choose=0 data= 58
#                84450  f_clk=1 p=        1 choose=0 data= 58
#                84500  f_clk=0 p=        1 choose=0 data= 58
#                84550  f_clk=1 p=        1 choose=0 data= 21
#                84600  f_clk=0 p=        1 choose=0 data= 21
#                84650  f_clk=1 p=        1 choose=0 data= 21
#                84700  f_clk=0 p=        1 choose=0 data= 21
#                84750  f_clk=1 p=        1 choose=0 data=235
#                84800  f_clk=0 p=        1 choose=0 data=235
#                84850  f_clk=1 p=        1 choose=0 data=235
#                84900  f_clk=0 p=        1 choose=0 data=235
#                84950  f_clk=1 p=        1 choose=0 data=198
#                85000  f_clk=0 p=        1 choose=0 data=198
#                85050  f_clk=1 p=        1 choose=0 data=198
#                85100  f_clk=0 p=        1 choose=0 data=198
#                85150  f_clk=1 p=        1 choose=0 data=169
#                85200  f_clk=0 p=        1 choose=0 data=169
#                85250  f_clk=1 p=        1 choose=0 data=169
#                85300  f_clk=0 p=        1 choose=0 data=169
#                85350  f_clk=1 p=        1 choose=0 data=157
#                85400  f_clk=0 p=        1 choose=0 data=157
#                85450  f_clk=1 p=        1 choose=0 data=157
#                85500  f_clk=0 p=        1 choose=0 data=157
#                85550  f_clk=1 p=        1 choose=0 data=161
#                85600  f_clk=0 p=        1 choose=0 data=161
#                85650  f_clk=1 p=        1 choose=0 data=161
#                85700  f_clk=0 p=        1 choose=0 data=161
#                85750  f_clk=1 p=        1 choose=0 data=182
#                85800  f_clk=0 p=        1 choose=0 data=182
#                85850  f_clk=1 p=        1 choose=0 data=182
#                85900  f_clk=0 p=        1 choose=0 data=182
#                85950  f_clk=1 p=        1 choose=0 data=215
#                86000  f_clk=0 p=        1 choose=0 data=215
#                86050  f_clk=1 p=        1 choose=0 data=215
#                86100  f_clk=0 p=        1 choose=0 data=215
#                86150  f_clk=1 p=        1 choose=0 data=  0
#                86200  f_clk=0 p=        1 choose=0 data=  0
#                86250  f_clk=1 p=        1 choose=0 data=  0
#                86300  f_clk=0 p=        1 choose=0 data=  0
#                86350  f_clk=1 p=        1 choose=0 data=  0
#                86400  f_clk=0 p=        1 choose=0 data=  0
#                86450  f_clk=1 p=        1 choose=0 data=  0
#                86500  f_clk=0 p=        1 choose=0 data=  0
#                86550  f_clk=1 p=        1 choose=0 data= 41
#                86600  f_clk=0 p=        1 choose=0 data= 41
#                86650  f_clk=1 p=        1 choose=0 data= 41
#                86700  f_clk=0 p=        1 choose=0 data= 41
#                86750  f_clk=1 p=        1 choose=0 data= 74
#                86800  f_clk=0 p=        1 choose=0 data= 74
#                86850  f_clk=1 p=        1 choose=0 data= 74
#                86900  f_clk=0 p=        1 choose=0 data= 74
#                86950  f_clk=1 p=        1 choose=0 data= 95
#                87000  f_clk=0 p=        1 choose=0 data= 95
#                87050  f_clk=1 p=        1 choose=0 data= 95
#                87100  f_clk=0 p=        1 choose=0 data= 95
#                87150  f_clk=1 p=        1 choose=0 data= 99
#                87200  f_clk=0 p=        1 choose=0 data= 99
#                87250  f_clk=1 p=        1 choose=0 data= 99
#                87300  f_clk=0 p=        1 choose=0 data= 99
#                87350  f_clk=1 p=        1 choose=0 data= 87
#                87400  f_clk=0 p=        1 choose=0 data= 87
#                87450  f_clk=1 p=        1 choose=0 data= 87
#                87500  f_clk=0 p=        1 choose=0 data= 87
#                87550  f_clk=1 p=        1 choose=0 data= 58
#                87600  f_clk=0 p=        1 choose=0 data= 58
#                87650  f_clk=1 p=        1 choose=0 data= 58
#                87700  f_clk=0 p=        1 choose=0 data= 58
#                87750  f_clk=1 p=        1 choose=0 data= 21
#                87800  f_clk=0 p=        1 choose=0 data= 21
#                87850  f_clk=1 p=        1 choose=0 data= 21
#                87900  f_clk=0 p=        1 choose=0 data= 21
#                87950  f_clk=1 p=        1 choose=0 data=235
#                88000  f_clk=0 p=        1 choose=0 data=235
#                88050  f_clk=1 p=        1 choose=0 data=235
#                88100  f_clk=0 p=        1 choose=0 data=235
#                88150  f_clk=1 p=        1 choose=0 data=198
#                88200  f_clk=0 p=        1 choose=0 data=198
#                88250  f_clk=1 p=        1 choose=0 data=198
#                88300  f_clk=0 p=        1 choose=0 data=198
#                88350  f_clk=1 p=        1 choose=0 data=169
#                88400  f_clk=0 p=        1 choose=0 data=169
#                88450  f_clk=1 p=        1 choose=0 data=169
#                88500  f_clk=0 p=        1 choose=0 data=169
#                88550  f_clk=1 p=        1 choose=0 data=157
#                88600  f_clk=0 p=        1 choose=0 data=157
#                88650  f_clk=1 p=        1 choose=0 data=157
#                88700  f_clk=0 p=        1 choose=0 data=157
#                88750  f_clk=1 p=        1 choose=0 data=161
#                88800  f_clk=0 p=        1 choose=0 data=161
#                88850  f_clk=1 p=        1 choose=0 data=161
#                88900  f_clk=0 p=        1 choose=0 data=161
#                88950  f_clk=1 p=        1 choose=0 data=182
#                89000  f_clk=0 p=        1 choose=0 data=182
#                89050  f_clk=1 p=        1 choose=0 data=182
#                89100  f_clk=0 p=        1 choose=0 data=182
#                89150  f_clk=1 p=        1 choose=0 data=215
#                89200  f_clk=0 p=        1 choose=0 data=215
#                89250  f_clk=1 p=        1 choose=0 data=215
#                89300  f_clk=0 p=        1 choose=0 data=215
#                89350  f_clk=1 p=        1 choose=0 data=  0
#                89400  f_clk=0 p=        1 choose=0 data=  0
#                89450  f_clk=1 p=        1 choose=0 data=  0
#                89500  f_clk=0 p=        1 choose=0 data=  0
#                89550  f_clk=1 p=        1 choose=0 data=  0
#                89600  f_clk=0 p=        1 choose=0 data=  0
#                89650  f_clk=1 p=        1 choose=0 data=  0
#                89700  f_clk=0 p=        1 choose=0 data=  0
#                89750  f_clk=1 p=        1 choose=0 data= 41
#                89800  f_clk=0 p=        1 choose=0 data= 41
#                89850  f_clk=1 p=        1 choose=0 data= 41
#                89900  f_clk=0 p=        1 choose=0 data= 41
#                89950  f_clk=1 p=        1 choose=0 data= 74
#                90000  f_clk=0 p=        1 choose=0 data= 74
#                90050  f_clk=1 p=        1 choose=0 data= 74
#                90100  f_clk=0 p=        1 choose=0 data= 74
#                90150  f_clk=1 p=        1 choose=0 data= 95
#                90200  f_clk=0 p=        1 choose=0 data= 95
#                90250  f_clk=1 p=        1 choose=0 data= 95
#                90300  f_clk=0 p=        1 choose=0 data= 95
#                90350  f_clk=1 p=        1 choose=0 data= 99
#                90400  f_clk=0 p=        1 choose=0 data= 99
#                90450  f_clk=1 p=        1 choose=0 data= 99
#                90500  f_clk=0 p=        1 choose=0 data= 99
#                90550  f_clk=1 p=        1 choose=0 data= 87
#                90600  f_clk=0 p=        1 choose=0 data= 87
#                90650  f_clk=1 p=        1 choose=0 data= 87
#                90700  f_clk=0 p=        1 choose=0 data= 87
#                90750  f_clk=1 p=        1 choose=0 data= 58
#                90800  f_clk=0 p=        1 choose=0 data= 58
#                90850  f_clk=1 p=        1 choose=0 data= 58
#                90900  f_clk=0 p=        1 choose=0 data= 58
#                90950  f_clk=1 p=        1 choose=0 data= 21
#                91000  f_clk=0 p=        1 choose=0 data= 21
#                91050  f_clk=1 p=        1 choose=0 data= 21
#                91100  f_clk=0 p=        1 choose=0 data= 21
#                91150  f_clk=1 p=        1 choose=0 data=235
#                91200  f_clk=0 p=        1 choose=0 data=235
#                91250  f_clk=1 p=        1 choose=0 data=235
#                91300  f_clk=0 p=        1 choose=0 data=235
#                91350  f_clk=1 p=        1 choose=0 data=198
#                91400  f_clk=0 p=        1 choose=0 data=198
#                91450  f_clk=1 p=        1 choose=0 data=198
#                91500  f_clk=0 p=        1 choose=0 data=198
#                91550  f_clk=1 p=        1 choose=0 data=169
#                91600  f_clk=0 p=        1 choose=0 data=169
#                91650  f_clk=1 p=        1 choose=0 data=169
#                91700  f_clk=0 p=        1 choose=0 data=169
#                91750  f_clk=1 p=        1 choose=0 data=157
#                91800  f_clk=0 p=        1 choose=0 data=157
#                91850  f_clk=1 p=        1 choose=0 data=157
#                91900  f_clk=0 p=        1 choose=0 data=157
#                91950  f_clk=1 p=        1 choose=0 data=161
#                92000  f_clk=0 p=        1 choose=0 data=161
#                92050  f_clk=1 p=        1 choose=0 data=161
#                92100  f_clk=0 p=        1 choose=0 data=161
#                92150  f_clk=1 p=        1 choose=0 data=182
#                92200  f_clk=0 p=        1 choose=0 data=182
#                92250  f_clk=1 p=        1 choose=0 data=182
#                92300  f_clk=0 p=        1 choose=0 data=182
#                92350  f_clk=1 p=        1 choose=0 data=215
#                92400  f_clk=0 p=        1 choose=0 data=215
#                92450  f_clk=1 p=        1 choose=0 data=215
#                92500  f_clk=0 p=        1 choose=0 data=215
#                92550  f_clk=1 p=        1 choose=0 data=  0
#                92600  f_clk=0 p=        1 choose=0 data=  0
#                92650  f_clk=1 p=        1 choose=0 data=  0
#                92700  f_clk=0 p=        1 choose=0 data=  0
#                92750  f_clk=1 p=        1 choose=0 data=  0
#                92800  f_clk=0 p=        1 choose=0 data=  0
#                92850  f_clk=1 p=        1 choose=0 data=  0
#                92900  f_clk=0 p=        1 choose=0 data=  0
#                92950  f_clk=1 p=        1 choose=0 data= 41
#                93000  f_clk=0 p=        1 choose=0 data= 41
#                93050  f_clk=1 p=        1 choose=0 data= 41
#                93100  f_clk=0 p=        1 choose=0 data= 41
#                93150  f_clk=1 p=        1 choose=0 data= 74
#                93200  f_clk=0 p=        1 choose=0 data= 74
#                93250  f_clk=1 p=        1 choose=0 data= 74
#                93300  f_clk=0 p=        1 choose=0 data= 74
#                93350  f_clk=1 p=        1 choose=0 data= 95
#                93400  f_clk=0 p=        1 choose=0 data= 95
#                93450  f_clk=1 p=        1 choose=0 data= 95
#                93500  f_clk=0 p=        1 choose=0 data= 95
#                93550  f_clk=1 p=        1 choose=0 data= 99
#                93600  f_clk=0 p=        1 choose=0 data= 99
#                93650  f_clk=1 p=        1 choose=0 data= 99
#                93700  f_clk=0 p=        1 choose=0 data= 99
#                93750  f_clk=1 p=        1 choose=0 data= 87
#                93800  f_clk=0 p=        1 choose=0 data= 87
#                93850  f_clk=1 p=        1 choose=0 data= 87
#                93900  f_clk=0 p=        1 choose=0 data= 87
#                93950  f_clk=1 p=        1 choose=0 data= 58
#                94000  f_clk=0 p=        1 choose=0 data= 58
#                94050  f_clk=1 p=        1 choose=0 data= 58
#                94100  f_clk=0 p=        1 choose=0 data= 58
#                94150  f_clk=1 p=        1 choose=0 data= 21
#                94200  f_clk=0 p=        1 choose=0 data= 21
#                94250  f_clk=1 p=        1 choose=0 data= 21
#                94300  f_clk=0 p=        1 choose=0 data= 21
#                94350  f_clk=1 p=        1 choose=0 data=235
#                94400  f_clk=0 p=        1 choose=0 data=235
#                94450  f_clk=1 p=        1 choose=0 data=235
#                94500  f_clk=0 p=        1 choose=0 data=235
#                94550  f_clk=1 p=        1 choose=0 data=198
#                94600  f_clk=0 p=        1 choose=0 data=198
#                94650  f_clk=1 p=        1 choose=0 data=198
#                94700  f_clk=0 p=        1 choose=0 data=198
#                94750  f_clk=1 p=        1 choose=0 data=169
#                94800  f_clk=0 p=        1 choose=0 data=169
#                94850  f_clk=1 p=        1 choose=0 data=169
#                94900  f_clk=0 p=        1 choose=0 data=169
#                94950  f_clk=1 p=        1 choose=0 data=157
#                95000  f_clk=0 p=        1 choose=0 data=157
#                95050  f_clk=1 p=        1 choose=0 data=157
#                95100  f_clk=0 p=        1 choose=0 data=157
#                95150  f_clk=1 p=        1 choose=0 data=161
#                95200  f_clk=0 p=        1 choose=0 data=161
#                95250  f_clk=1 p=        1 choose=0 data=161
#                95300  f_clk=0 p=        1 choose=0 data=161
#                95350  f_clk=1 p=        1 choose=0 data=182
#                95400  f_clk=0 p=        1 choose=0 data=182
#                95450  f_clk=1 p=        1 choose=0 data=182
#                95500  f_clk=0 p=        1 choose=0 data=182
#                95550  f_clk=1 p=        1 choose=0 data=215
#                95600  f_clk=0 p=        1 choose=0 data=215
#                95650  f_clk=1 p=        1 choose=0 data=215
#                95700  f_clk=0 p=        1 choose=0 data=215
#                95750  f_clk=1 p=        1 choose=0 data=  0
#                95800  f_clk=0 p=        1 choose=0 data=  0
#                95850  f_clk=1 p=        1 choose=0 data=  0
#                95900  f_clk=0 p=        1 choose=0 data=  0
#                95950  f_clk=1 p=        1 choose=0 data=  0
#                96000  f_clk=0 p=        1 choose=0 data=  0
#                96050  f_clk=1 p=        1 choose=0 data=  0
#                96100  f_clk=0 p=        1 choose=0 data=  0
#                96150  f_clk=1 p=        1 choose=0 data= 41
#                96200  f_clk=0 p=        1 choose=0 data= 41
#                96250  f_clk=1 p=        1 choose=0 data= 41
#                96300  f_clk=0 p=        1 choose=0 data= 41
#                96350  f_clk=1 p=        1 choose=0 data= 74
#                96400  f_clk=0 p=        1 choose=0 data= 74
#                96450  f_clk=1 p=        1 choose=0 data= 74
#                96500  f_clk=0 p=        1 choose=0 data= 74
#                96550  f_clk=1 p=        1 choose=0 data= 95
#                96600  f_clk=0 p=        1 choose=0 data= 95
#                96650  f_clk=1 p=        1 choose=0 data= 95
#                96700  f_clk=0 p=        1 choose=0 data= 95
#                96750  f_clk=1 p=        1 choose=0 data= 99
#                96800  f_clk=0 p=        1 choose=0 data= 99
#                96850  f_clk=1 p=        1 choose=0 data= 99
#                96900  f_clk=0 p=        1 choose=0 data= 99
#                96950  f_clk=1 p=        1 choose=0 data= 87
#                97000  f_clk=0 p=        1 choose=0 data= 87
#                97050  f_clk=1 p=        1 choose=0 data= 87
#                97100  f_clk=0 p=        1 choose=0 data= 87
#                97150  f_clk=1 p=        1 choose=0 data= 58
#                97200  f_clk=0 p=        1 choose=0 data= 58
#                97250  f_clk=1 p=        1 choose=0 data= 58
#                97300  f_clk=0 p=        1 choose=0 data= 58
#                97350  f_clk=1 p=        1 choose=0 data= 21
#                97400  f_clk=0 p=        1 choose=0 data= 21
#                97450  f_clk=1 p=        1 choose=0 data= 21
#                97500  f_clk=0 p=        1 choose=0 data= 21
#                97550  f_clk=1 p=        1 choose=0 data=235
#                97600  f_clk=0 p=        1 choose=0 data=235
#                97650  f_clk=1 p=        1 choose=0 data=235
#                97700  f_clk=0 p=        1 choose=0 data=235
#                97750  f_clk=1 p=        1 choose=0 data=198
#                97800  f_clk=0 p=        1 choose=0 data=198
#                97850  f_clk=1 p=        1 choose=0 data=198
#                97900  f_clk=0 p=        1 choose=0 data=198
#                97950  f_clk=1 p=        1 choose=0 data=169
#                98000  f_clk=0 p=        1 choose=0 data=169
#                98050  f_clk=1 p=        1 choose=0 data=169
#                98100  f_clk=0 p=        1 choose=0 data=169
#                98150  f_clk=1 p=        1 choose=0 data=157
#                98200  f_clk=0 p=        1 choose=0 data=157
#                98250  f_clk=1 p=        1 choose=0 data=157
#                98300  f_clk=0 p=        1 choose=0 data=157
#                98350  f_clk=1 p=        1 choose=0 data=161
#                98400  f_clk=0 p=        1 choose=0 data=161
#                98450  f_clk=1 p=        1 choose=0 data=161
#                98500  f_clk=0 p=        1 choose=0 data=161
#                98550  f_clk=1 p=        1 choose=0 data=182
#                98600  f_clk=0 p=        1 choose=0 data=182
#                98650  f_clk=1 p=        1 choose=0 data=182
#                98700  f_clk=0 p=        1 choose=0 data=182
#                98750  f_clk=1 p=        1 choose=0 data=215
#                98800  f_clk=0 p=        1 choose=0 data=215
#                98850  f_clk=1 p=        1 choose=0 data=215
#                98900  f_clk=0 p=        1 choose=0 data=215
#                98950  f_clk=1 p=        1 choose=0 data=  0
#                99000  f_clk=0 p=        1 choose=0 data=  0
#                99050  f_clk=1 p=        1 choose=0 data=  0
#                99100  f_clk=0 p=        1 choose=0 data=  0
#                99150  f_clk=1 p=        1 choose=0 data=  0
#                99200  f_clk=0 p=        1 choose=0 data=  0
#                99250  f_clk=1 p=        1 choose=0 data=  0
#                99300  f_clk=0 p=        1 choose=0 data=  0
#                99350  f_clk=1 p=        1 choose=0 data= 41
#                99400  f_clk=0 p=        1 choose=0 data= 41
#                99450  f_clk=1 p=        1 choose=0 data= 41
#                99500  f_clk=0 p=        1 choose=0 data= 41
#                99550  f_clk=1 p=        1 choose=0 data= 74
#                99600  f_clk=0 p=        1 choose=0 data= 74
#                99650  f_clk=1 p=        1 choose=0 data= 74
#                99700  f_clk=0 p=        1 choose=0 data= 74
#                99750  f_clk=1 p=        1 choose=0 data= 95
#                99800  f_clk=0 p=        1 choose=0 data= 95
#                99850  f_clk=1 p=        1 choose=0 data= 95
#                99900  f_clk=0 p=        1 choose=0 data= 95
#                99950  f_clk=1 p=        1 choose=0 data= 99
#               100000  f_clk=0 p=        1 choose=1 data=200
#               100050  f_clk=1 p=        1 choose=1 data=200
#               100100  f_clk=0 p=        1 choose=1 data=200
#               100150  f_clk=1 p=        1 choose=1 data=200
#               100200  f_clk=0 p=        1 choose=1 data=200
#               100250  f_clk=1 p=        1 choose=1 data=200
#               100300  f_clk=0 p=        1 choose=1 data=200
#               100350  f_clk=1 p=        1 choose=1 data=200
#               100400  f_clk=0 p=        1 choose=1 data=200
#               100450  f_clk=1 p=        1 choose=1 data=200
#               100500  f_clk=0 p=        1 choose=1 data=200
#               100550  f_clk=1 p=        1 choose=1 data=200
#               100600  f_clk=0 p=        1 choose=1 data=200
#               100650  f_clk=1 p=        1 choose=1 data=200
#               100700  f_clk=0 p=        1 choose=1 data=200
#               100750  f_clk=1 p=        1 choose=1 data=  0
#               100800  f_clk=0 p=        1 choose=1 data=  0
#               100850  f_clk=1 p=        1 choose=1 data=  0
#               100900  f_clk=0 p=        1 choose=1 data=  0
#               100950  f_clk=1 p=        1 choose=1 data=  0
#               101000  f_clk=0 p=        1 choose=1 data=  0
#               101050  f_clk=1 p=        1 choose=1 data=  0
#               101100  f_clk=0 p=        1 choose=1 data=  0
#               101150  f_clk=1 p=        1 choose=1 data=  0
#               101200  f_clk=0 p=        1 choose=1 data=  0
#               101250  f_clk=1 p=        1 choose=1 data=  0
#               101300  f_clk=0 p=        1 choose=1 data=  0
#               101350  f_clk=1 p=        1 choose=1 data=  0
#               101400  f_clk=0 p=        1 choose=1 data=  0
#               101450  f_clk=1 p=        1 choose=1 data=  0
#               101500  f_clk=0 p=        1 choose=1 data=  0
#               101550  f_clk=1 p=        1 choose=1 data=  0
#               101600  f_clk=0 p=        1 choose=1 data=  0
#               101650  f_clk=1 p=        1 choose=1 data=  0
#               101700  f_clk=0 p=        1 choose=1 data=  0
#               101750  f_clk=1 p=        1 choose=1 data=  0
#               101800  f_clk=0 p=        1 choose=1 data=  0
#               101850  f_clk=1 p=        1 choose=1 data=  0
#               101900  f_clk=0 p=        1 choose=1 data=  0
#               101950  f_clk=1 p=        1 choose=1 data=  0
#               102000  f_clk=0 p=        1 choose=1 data=  0
#               102050  f_clk=1 p=        1 choose=1 data=  0
#               102100  f_clk=0 p=        1 choose=1 data=  0
#               102150  f_clk=1 p=        1 choose=1 data=  0
#               102200  f_clk=0 p=        1 choose=1 data=  0
#               102250  f_clk=1 p=        1 choose=1 data=  0
#               102300  f_clk=0 p=        1 choose=1 data=  0
#               102350  f_clk=1 p=        1 choose=1 data=200
#               102400  f_clk=0 p=        1 choose=1 data=200
#               102450  f_clk=1 p=        1 choose=1 data=200
#               102500  f_clk=0 p=        1 choose=1 data=200
#               102550  f_clk=1 p=        1 choose=1 data=200
#               102600  f_clk=0 p=        1 choose=1 data=200
#               102650  f_clk=1 p=        1 choose=1 data=200
#               102700  f_clk=0 p=        1 choose=1 data=200
#               102750  f_clk=1 p=        1 choose=1 data=200
#               102800  f_clk=0 p=        1 choose=1 data=200
#               102850  f_clk=1 p=        1 choose=1 data=200
#               102900  f_clk=0 p=        1 choose=1 data=200
#               102950  f_clk=1 p=        1 choose=1 data=200
#               103000  f_clk=0 p=        1 choose=1 data=200
#               103050  f_clk=1 p=        1 choose=1 data=200
#               103100  f_clk=0 p=        1 choose=1 data=200
#               103150  f_clk=1 p=        1 choose=1 data=200
#               103200  f_clk=0 p=        1 choose=1 data=200
#               103250  f_clk=1 p=        1 choose=1 data=200
#               103300  f_clk=0 p=        1 choose=1 data=200
#               103350  f_clk=1 p=        1 choose=1 data=200
#               103400  f_clk=0 p=        1 choose=1 data=200
#               103450  f_clk=1 p=        1 choose=1 data=200
#               103500  f_clk=0 p=        1 choose=1 data=200
#               103550  f_clk=1 p=        1 choose=1 data=200
#               103600  f_clk=0 p=        1 choose=1 data=200
#               103650  f_clk=1 p=        1 choose=1 data=200
#               103700  f_clk=0 p=        1 choose=1 data=200
#               103750  f_clk=1 p=        1 choose=1 data=200
#               103800  f_clk=0 p=        1 choose=1 data=200
#               103850  f_clk=1 p=        1 choose=1 data=200
#               103900  f_clk=0 p=        1 choose=1 data=200
#               103950  f_clk=1 p=        1 choose=1 data=  0
#               104000  f_clk=0 p=        1 choose=1 data=  0
#               104050  f_clk=1 p=        1 choose=1 data=  0
#               104100  f_clk=0 p=        1 choose=1 data=  0
#               104150  f_clk=1 p=        1 choose=1 data=  0
#               104200  f_clk=0 p=        1 choose=1 data=  0
#               104250  f_clk=1 p=        1 choose=1 data=  0
#               104300  f_clk=0 p=        1 choose=1 data=  0
#               104350  f_clk=1 p=        1 choose=1 data=  0
#               104400  f_clk=0 p=        1 choose=1 data=  0
#               104450  f_clk=1 p=        1 choose=1 data=  0
#               104500  f_clk=0 p=        1 choose=1 data=  0
#               104550  f_clk=1 p=        1 choose=1 data=  0
#               104600  f_clk=0 p=        1 choose=1 data=  0
#               104650  f_clk=1 p=        1 choose=1 data=  0
#               104700  f_clk=0 p=        1 choose=1 data=  0
#               104750  f_clk=1 p=        1 choose=1 data=  0
#               104800  f_clk=0 p=        1 choose=1 data=  0
#               104850  f_clk=1 p=        1 choose=1 data=  0
#               104900  f_clk=0 p=        1 choose=1 data=  0
#               104950  f_clk=1 p=        1 choose=1 data=  0
#               105000  f_clk=0 p=        1 choose=1 data=  0
#               105050  f_clk=1 p=        1 choose=1 data=  0
#               105100  f_clk=0 p=        1 choose=1 data=  0
#               105150  f_clk=1 p=        1 choose=1 data=  0
#               105200  f_clk=0 p=        1 choose=1 data=  0
#               105250  f_clk=1 p=        1 choose=1 data=  0
#               105300  f_clk=0 p=        1 choose=1 data=  0
#               105350  f_clk=1 p=        1 choose=1 data=  0
#               105400  f_clk=0 p=        1 choose=1 data=  0
#               105450  f_clk=1 p=        1 choose=1 data=  0
#               105500  f_clk=0 p=        1 choose=1 data=  0
#               105550  f_clk=1 p=        1 choose=1 data=200
#               105600  f_clk=0 p=        1 choose=1 data=200
#               105650  f_clk=1 p=        1 choose=1 data=200
#               105700  f_clk=0 p=        1 choose=1 data=200
#               105750  f_clk=1 p=        1 choose=1 data=200
#               105800  f_clk=0 p=        1 choose=1 data=200
#               105850  f_clk=1 p=        1 choose=1 data=200
#               105900  f_clk=0 p=        1 choose=1 data=200
#               105950  f_clk=1 p=        1 choose=1 data=200
#               106000  f_clk=0 p=        1 choose=1 data=200
#               106050  f_clk=1 p=        1 choose=1 data=200
#               106100  f_clk=0 p=        1 choose=1 data=200
#               106150  f_clk=1 p=        1 choose=1 data=200
#               106200  f_clk=0 p=        1 choose=1 data=200
#               106250  f_clk=1 p=        1 choose=1 data=200
#               106300  f_clk=0 p=        1 choose=1 data=200
#               106350  f_clk=1 p=        1 choose=1 data=200
#               106400  f_clk=0 p=        1 choose=1 data=200
#               106450  f_clk=1 p=        1 choose=1 data=200
#               106500  f_clk=0 p=        1 choose=1 data=200
#               106550  f_clk=1 p=        1 choose=1 data=200
#               106600  f_clk=0 p=        1 choose=1 data=200
#               106650  f_clk=1 p=        1 choose=1 data=200
#               106700  f_clk=0 p=        1 choose=1 data=200
#               106750  f_clk=1 p=        1 choose=1 data=200
#               106800  f_clk=0 p=        1 choose=1 data=200
#               106850  f_clk=1 p=        1 choose=1 data=200
#               106900  f_clk=0 p=        1 choose=1 data=200
#               106950  f_clk=1 p=        1 choose=1 data=200
#               107000  f_clk=0 p=        1 choose=1 data=200
#               107050  f_clk=1 p=        1 choose=1 data=200
#               107100  f_clk=0 p=        1 choose=1 data=200
#               107150  f_clk=1 p=        1 choose=1 data=  0
#               107200  f_clk=0 p=        1 choose=1 data=  0
#               107250  f_clk=1 p=        1 choose=1 data=  0
#               107300  f_clk=0 p=        1 choose=1 data=  0
#               107350  f_clk=1 p=        1 choose=1 data=  0
#               107400  f_clk=0 p=        1 choose=1 data=  0
#               107450  f_clk=1 p=        1 choose=1 data=  0
#               107500  f_clk=0 p=        1 choose=1 data=  0
#               107550  f_clk=1 p=        1 choose=1 data=  0
#               107600  f_clk=0 p=        1 choose=1 data=  0
#               107650  f_clk=1 p=        1 choose=1 data=  0
#               107700  f_clk=0 p=        1 choose=1 data=  0
#               107750  f_clk=1 p=        1 choose=1 data=  0
#               107800  f_clk=0 p=        1 choose=1 data=  0
#               107850  f_clk=1 p=        1 choose=1 data=  0
#               107900  f_clk=0 p=        1 choose=1 data=  0
#               107950  f_clk=1 p=        1 choose=1 data=  0
#               108000  f_clk=0 p=        1 choose=1 data=  0
#               108050  f_clk=1 p=        1 choose=1 data=  0
#               108100  f_clk=0 p=        1 choose=1 data=  0
#               108150  f_clk=1 p=        1 choose=1 data=  0
#               108200  f_clk=0 p=        1 choose=1 data=  0
#               108250  f_clk=1 p=        1 choose=1 data=  0
#               108300  f_clk=0 p=        1 choose=1 data=  0
#               108350  f_clk=1 p=        1 choose=1 data=  0
#               108400  f_clk=0 p=        1 choose=1 data=  0
#               108450  f_clk=1 p=        1 choose=1 data=  0
#               108500  f_clk=0 p=        1 choose=1 data=  0
#               108550  f_clk=1 p=        1 choose=1 data=  0
#               108600  f_clk=0 p=        1 choose=1 data=  0
#               108650  f_clk=1 p=        1 choose=1 data=  0
#               108700  f_clk=0 p=        1 choose=1 data=  0
#               108750  f_clk=1 p=        1 choose=1 data=200
#               108800  f_clk=0 p=        1 choose=1 data=200
#               108850  f_clk=1 p=        1 choose=1 data=200
#               108900  f_clk=0 p=        1 choose=1 data=200
#               108950  f_clk=1 p=        1 choose=1 data=200
#               109000  f_clk=0 p=        1 choose=1 data=200
#               109050  f_clk=1 p=        1 choose=1 data=200
#               109100  f_clk=0 p=        1 choose=1 data=200
#               109150  f_clk=1 p=        1 choose=1 data=200
#               109200  f_clk=0 p=        1 choose=1 data=200
#               109250  f_clk=1 p=        1 choose=1 data=200
#               109300  f_clk=0 p=        1 choose=1 data=200
#               109350  f_clk=1 p=        1 choose=1 data=200
#               109400  f_clk=0 p=        1 choose=1 data=200
#               109450  f_clk=1 p=        1 choose=1 data=200
#               109500  f_clk=0 p=        1 choose=1 data=200
#               109550  f_clk=1 p=        1 choose=1 data=200
#               109600  f_clk=0 p=        1 choose=1 data=200
#               109650  f_clk=1 p=        1 choose=1 data=200
#               109700  f_clk=0 p=        1 choose=1 data=200
#               109750  f_clk=1 p=        1 choose=1 data=200
#               109800  f_clk=0 p=        1 choose=1 data=200
#               109850  f_clk=1 p=        1 choose=1 data=200
#               109900  f_clk=0 p=        1 choose=1 data=200
#               109950  f_clk=1 p=        1 choose=1 data=200
#               110000  f_clk=0 p=        1 choose=1 data=200
#               110050  f_clk=1 p=        1 choose=1 data=200
#               110100  f_clk=0 p=        1 choose=1 data=200
#               110150  f_clk=1 p=        1 choose=1 data=200
#               110200  f_clk=0 p=        1 choose=1 data=200
#               110250  f_clk=1 p=        1 choose=1 data=200
#               110300  f_clk=0 p=        1 choose=1 data=200
#               110350  f_clk=1 p=        1 choose=1 data=  0
#               110400  f_clk=0 p=        1 choose=1 data=  0
#               110450  f_clk=1 p=        1 choose=1 data=  0
#               110500  f_clk=0 p=        1 choose=1 data=  0
#               110550  f_clk=1 p=        1 choose=1 data=  0
#               110600  f_clk=0 p=        1 choose=1 data=  0
#               110650  f_clk=1 p=        1 choose=1 data=  0
#               110700  f_clk=0 p=        1 choose=1 data=  0
#               110750  f_clk=1 p=        1 choose=1 data=  0
#               110800  f_clk=0 p=        1 choose=1 data=  0
#               110850  f_clk=1 p=        1 choose=1 data=  0
#               110900  f_clk=0 p=        1 choose=1 data=  0
#               110950  f_clk=1 p=        1 choose=1 data=  0
#               111000  f_clk=0 p=        1 choose=1 data=  0
#               111050  f_clk=1 p=        1 choose=1 data=  0
#               111100  f_clk=0 p=        1 choose=1 data=  0
#               111150  f_clk=1 p=        1 choose=1 data=  0
#               111200  f_clk=0 p=        1 choose=1 data=  0
#               111250  f_clk=1 p=        1 choose=1 data=  0
#               111300  f_clk=0 p=        1 choose=1 data=  0
#               111350  f_clk=1 p=        1 choose=1 data=  0
#               111400  f_clk=0 p=        1 choose=1 data=  0
#               111450  f_clk=1 p=        1 choose=1 data=  0
#               111500  f_clk=0 p=        1 choose=1 data=  0
#               111550  f_clk=1 p=        1 choose=1 data=  0
#               111600  f_clk=0 p=        1 choose=1 data=  0
#               111650  f_clk=1 p=        1 choose=1 data=  0
#               111700  f_clk=0 p=        1 choose=1 data=  0
#               111750  f_clk=1 p=        1 choose=1 data=  0
#               111800  f_clk=0 p=        1 choose=1 data=  0
#               111850  f_clk=1 p=        1 choose=1 data=  0
#               111900  f_clk=0 p=        1 choose=1 data=  0
#               111950  f_clk=1 p=        1 choose=1 data=200
#               112000  f_clk=0 p=        1 choose=1 data=200
#               112050  f_clk=1 p=        1 choose=1 data=200
#               112100  f_clk=0 p=        1 choose=1 data=200
#               112150  f_clk=1 p=        1 choose=1 data=200
#               112200  f_clk=0 p=        1 choose=1 data=200
#               112250  f_clk=1 p=        1 choose=1 data=200
#               112300  f_clk=0 p=        1 choose=1 data=200
#               112350  f_clk=1 p=        1 choose=1 data=200
#               112400  f_clk=0 p=        1 choose=1 data=200
#               112450  f_clk=1 p=        1 choose=1 data=200
#               112500  f_clk=0 p=        1 choose=1 data=200
#               112550  f_clk=1 p=        1 choose=1 data=200
#               112600  f_clk=0 p=        1 choose=1 data=200
#               112650  f_clk=1 p=        1 choose=1 data=200
#               112700  f_clk=0 p=        1 choose=1 data=200
#               112750  f_clk=1 p=        1 choose=1 data=200
#               112800  f_clk=0 p=        1 choose=1 data=200
#               112850  f_clk=1 p=        1 choose=1 data=200
#               112900  f_clk=0 p=        1 choose=1 data=200
#               112950  f_clk=1 p=        1 choose=1 data=200
#               113000  f_clk=0 p=        1 choose=1 data=200
#               113050  f_clk=1 p=        1 choose=1 data=200
#               113100  f_clk=0 p=        1 choose=1 data=200
#               113150  f_clk=1 p=        1 choose=1 data=200
#               113200  f_clk=0 p=        1 choose=1 data=200
#               113250  f_clk=1 p=        1 choose=1 data=200
#               113300  f_clk=0 p=        1 choose=1 data=200
#               113350  f_clk=1 p=        1 choose=1 data=200
#               113400  f_clk=0 p=        1 choose=1 data=200
#               113450  f_clk=1 p=        1 choose=1 data=200
#               113500  f_clk=0 p=        1 choose=1 data=200
#               113550  f_clk=1 p=        1 choose=1 data=  0
#               113600  f_clk=0 p=        1 choose=1 data=  0
#               113650  f_clk=1 p=        1 choose=1 data=  0
#               113700  f_clk=0 p=        1 choose=1 data=  0
#               113750  f_clk=1 p=        1 choose=1 data=  0
#               113800  f_clk=0 p=        1 choose=1 data=  0
#               113850  f_clk=1 p=        1 choose=1 data=  0
#               113900  f_clk=0 p=        1 choose=1 data=  0
#               113950  f_clk=1 p=        1 choose=1 data=  0
#               114000  f_clk=0 p=        1 choose=1 data=  0
#               114050  f_clk=1 p=        1 choose=1 data=  0
#               114100  f_clk=0 p=        1 choose=1 data=  0
#               114150  f_clk=1 p=        1 choose=1 data=  0
#               114200  f_clk=0 p=        1 choose=1 data=  0
#               114250  f_clk=1 p=        1 choose=1 data=  0
#               114300  f_clk=0 p=        1 choose=1 data=  0
#               114350  f_clk=1 p=        1 choose=1 data=  0
#               114400  f_clk=0 p=        1 choose=1 data=  0
#               114450  f_clk=1 p=        1 choose=1 data=  0
#               114500  f_clk=0 p=        1 choose=1 data=  0
#               114550  f_clk=1 p=        1 choose=1 data=  0
#               114600  f_clk=0 p=        1 choose=1 data=  0
#               114650  f_clk=1 p=        1 choose=1 data=  0
#               114700  f_clk=0 p=        1 choose=1 data=  0
#               114750  f_clk=1 p=        1 choose=1 data=  0
#               114800  f_clk=0 p=        1 choose=1 data=  0
#               114850  f_clk=1 p=        1 choose=1 data=  0
#               114900  f_clk=0 p=        1 choose=1 data=  0
#               114950  f_clk=1 p=        1 choose=1 data=  0
#               115000  f_clk=0 p=        1 choose=1 data=  0
#               115050  f_clk=1 p=        1 choose=1 data=  0
#               115100  f_clk=0 p=        1 choose=1 data=  0
#               115150  f_clk=1 p=        1 choose=1 data=200
#               115200  f_clk=0 p=        1 choose=1 data=200
#               115250  f_clk=1 p=        1 choose=1 data=200
#               115300  f_clk=0 p=        1 choose=1 data=200
#               115350  f_clk=1 p=        1 choose=1 data=200
#               115400  f_clk=0 p=        1 choose=1 data=200
#               115450  f_clk=1 p=        1 choose=1 data=200
#               115500  f_clk=0 p=        1 choose=1 data=200
#               115550  f_clk=1 p=        1 choose=1 data=200
#               115600  f_clk=0 p=        1 choose=1 data=200
#               115650  f_clk=1 p=        1 choose=1 data=200
#               115700  f_clk=0 p=        1 choose=1 data=200
#               115750  f_clk=1 p=        1 choose=1 data=200
#               115800  f_clk=0 p=        1 choose=1 data=200
#               115850  f_clk=1 p=        1 choose=1 data=200
#               115900  f_clk=0 p=        1 choose=1 data=200
#               115950  f_clk=1 p=        1 choose=1 data=200
#               116000  f_clk=0 p=        1 choose=1 data=200
#               116050  f_clk=1 p=        1 choose=1 data=200
#               116100  f_clk=0 p=        1 choose=1 data=200
#               116150  f_clk=1 p=        1 choose=1 data=200
#               116200  f_clk=0 p=        1 choose=1 data=200
#               116250  f_clk=1 p=        1 choose=1 data=200
#               116300  f_clk=0 p=        1 choose=1 data=200
#               116350  f_clk=1 p=        1 choose=1 data=200
#               116400  f_clk=0 p=        1 choose=1 data=200
#               116450  f_clk=1 p=        1 choose=1 data=200
#               116500  f_clk=0 p=        1 choose=1 data=200
#               116550  f_clk=1 p=        1 choose=1 data=200
#               116600  f_clk=0 p=        1 choose=1 data=200
#               116650  f_clk=1 p=        1 choose=1 data=200
#               116700  f_clk=0 p=        1 choose=1 data=200
#               116750  f_clk=1 p=        1 choose=1 data=  0
#               116800  f_clk=0 p=        1 choose=1 data=  0
#               116850  f_clk=1 p=        1 choose=1 data=  0
#               116900  f_clk=0 p=        1 choose=1 data=  0
#               116950  f_clk=1 p=        1 choose=1 data=  0
#               117000  f_clk=0 p=        1 choose=1 data=  0
#               117050  f_clk=1 p=        1 choose=1 data=  0
#               117100  f_clk=0 p=        1 choose=1 data=  0
#               117150  f_clk=1 p=        1 choose=1 data=  0
#               117200  f_clk=0 p=        1 choose=1 data=  0
#               117250  f_clk=1 p=        1 choose=1 data=  0
#               117300  f_clk=0 p=        1 choose=1 data=  0
#               117350  f_clk=1 p=        1 choose=1 data=  0
#               117400  f_clk=0 p=        1 choose=1 data=  0
#               117450  f_clk=1 p=        1 choose=1 data=  0
#               117500  f_clk=0 p=        1 choose=1 data=  0
#               117550  f_clk=1 p=        1 choose=1 data=  0
#               117600  f_clk=0 p=        1 choose=1 data=  0
#               117650  f_clk=1 p=        1 choose=1 data=  0
#               117700  f_clk=0 p=        1 choose=1 data=  0
#               117750  f_clk=1 p=        1 choose=1 data=  0
#               117800  f_clk=0 p=        1 choose=1 data=  0
#               117850  f_clk=1 p=        1 choose=1 data=  0
#               117900  f_clk=0 p=        1 choose=1 data=  0
#               117950  f_clk=1 p=        1 choose=1 data=  0
#               118000  f_clk=0 p=        1 choose=1 data=  0
#               118050  f_clk=1 p=        1 choose=1 data=  0
#               118100  f_clk=0 p=        1 choose=1 data=  0
#               118150  f_clk=1 p=        1 choose=1 data=  0
#               118200  f_clk=0 p=        1 choose=1 data=  0
#               118250  f_clk=1 p=        1 choose=1 data=  0
#               118300  f_clk=0 p=        1 choose=1 data=  0
#               118350  f_clk=1 p=        1 choose=1 data=200
#               118400  f_clk=0 p=        1 choose=1 data=200
#               118450  f_clk=1 p=        1 choose=1 data=200
#               118500  f_clk=0 p=        1 choose=1 data=200
#               118550  f_clk=1 p=        1 choose=1 data=200
#               118600  f_clk=0 p=        1 choose=1 data=200
#               118650  f_clk=1 p=        1 choose=1 data=200
#               118700  f_clk=0 p=        1 choose=1 data=200
#               118750  f_clk=1 p=        1 choose=1 data=200
#               118800  f_clk=0 p=        1 choose=1 data=200
#               118850  f_clk=1 p=        1 choose=1 data=200
#               118900  f_clk=0 p=        1 choose=1 data=200
#               118950  f_clk=1 p=        1 choose=1 data=200
#               119000  f_clk=0 p=        1 choose=1 data=200
#               119050  f_clk=1 p=        1 choose=1 data=200
#               119100  f_clk=0 p=        1 choose=1 data=200
#               119150  f_clk=1 p=        1 choose=1 data=200
#               119200  f_clk=0 p=        1 choose=1 data=200
#               119250  f_clk=1 p=        1 choose=1 data=200
#               119300  f_clk=0 p=        1 choose=1 data=200
#               119350  f_clk=1 p=        1 choose=1 data=200
#               119400  f_clk=0 p=        1 choose=1 data=200
#               119450  f_clk=1 p=        1 choose=1 data=200
#               119500  f_clk=0 p=        1 choose=1 data=200
#               119550  f_clk=1 p=        1 choose=1 data=200
#               119600  f_clk=0 p=        1 choose=1 data=200
#               119650  f_clk=1 p=        1 choose=1 data=200
#               119700  f_clk=0 p=        1 choose=1 data=200
#               119750  f_clk=1 p=        1 choose=1 data=200
#               119800  f_clk=0 p=        1 choose=1 data=200
#               119850  f_clk=1 p=        1 choose=1 data=200
#               119900  f_clk=0 p=        1 choose=1 data=200
#               119950  f_clk=1 p=        1 choose=1 data=  0
#               120000  f_clk=0 p=        1 choose=2 data= 40
#               120050  f_clk=1 p=        1 choose=2 data= 40
#               120100  f_clk=0 p=        1 choose=2 data= 40
#               120150  f_clk=1 p=        1 choose=2 data= 45
#               120200  f_clk=0 p=        1 choose=2 data= 45
#               120250  f_clk=1 p=        1 choose=2 data= 45
#               120300  f_clk=0 p=        1 choose=2 data= 45
#               120350  f_clk=1 p=        1 choose=2 data= 50
#               120400  f_clk=0 p=        1 choose=2 data= 50
#               120450  f_clk=1 p=        1 choose=2 data= 50
#               120500  f_clk=0 p=        1 choose=2 data= 50
#               120550  f_clk=1 p=        1 choose=2 data= 55
#               120600  f_clk=0 p=        1 choose=2 data= 55
#               120650  f_clk=1 p=        1 choose=2 data= 55
#               120700  f_clk=0 p=        1 choose=2 data= 55
#               120750  f_clk=1 p=        1 choose=2 data= 60
#               120800  f_clk=0 p=        1 choose=2 data= 60
#               120850  f_clk=1 p=        1 choose=2 data= 60
#               120900  f_clk=0 p=        1 choose=2 data= 60
#               120950  f_clk=1 p=        1 choose=2 data= 65
#               121000  f_clk=0 p=        1 choose=2 data= 65
#               121050  f_clk=1 p=        1 choose=2 data= 65
#               121100  f_clk=0 p=        1 choose=2 data= 65
#               121150  f_clk=1 p=        1 choose=2 data= 70
#               121200  f_clk=0 p=        1 choose=2 data= 70
#               121250  f_clk=1 p=        1 choose=2 data= 70
#               121300  f_clk=0 p=        1 choose=2 data= 70
#               121350  f_clk=1 p=        1 choose=2 data= 75
#               121400  f_clk=0 p=        1 choose=2 data= 75
#               121450  f_clk=1 p=        1 choose=2 data= 75
#               121500  f_clk=0 p=        1 choose=2 data= 75
#               121550  f_clk=1 p=        1 choose=2 data=  0
#               121600  f_clk=0 p=        1 choose=2 data=  0
#               121650  f_clk=1 p=        1 choose=2 data=  0
#               121700  f_clk=0 p=        1 choose=2 data=  0
#               121750  f_clk=1 p=        1 choose=2 data=  5
#               121800  f_clk=0 p=        1 choose=2 data=  5
#               121850  f_clk=1 p=        1 choose=2 data=  5
#               121900  f_clk=0 p=        1 choose=2 data=  5
#               121950  f_clk=1 p=        1 choose=2 data= 10
#               122000  f_clk=0 p=        1 choose=2 data= 10
#               122050  f_clk=1 p=        1 choose=2 data= 10
#               122100  f_clk=0 p=        1 choose=2 data= 10
#               122150  f_clk=1 p=        1 choose=2 data= 15
#               122200  f_clk=0 p=        1 choose=2 data= 15
#               122250  f_clk=1 p=        1 choose=2 data= 15
#               122300  f_clk=0 p=        1 choose=2 data= 15
#               122350  f_clk=1 p=        1 choose=2 data= 20
#               122400  f_clk=0 p=        1 choose=2 data= 20
#               122450  f_clk=1 p=        1 choose=2 data= 20
#               122500  f_clk=0 p=        1 choose=2 data= 20
#               122550  f_clk=1 p=        1 choose=2 data= 25
#               122600  f_clk=0 p=        1 choose=2 data= 25
#               122650  f_clk=1 p=        1 choose=2 data= 25
#               122700  f_clk=0 p=        1 choose=2 data= 25
#               122750  f_clk=1 p=        1 choose=2 data= 30
#               122800  f_clk=0 p=        1 choose=2 data= 30
#               122850  f_clk=1 p=        1 choose=2 data= 30
#               122900  f_clk=0 p=        1 choose=2 data= 30
#               122950  f_clk=1 p=        1 choose=2 data= 35
#               123000  f_clk=0 p=        1 choose=2 data= 35
#               123050  f_clk=1 p=        1 choose=2 data= 35
#               123100  f_clk=0 p=        1 choose=2 data= 35
#               123150  f_clk=1 p=        1 choose=2 data= 40
#               123200  f_clk=0 p=        1 choose=2 data= 40
#               123250  f_clk=1 p=        1 choose=2 data= 40
#               123300  f_clk=0 p=        1 choose=2 data= 40
#               123350  f_clk=1 p=        1 choose=2 data= 45
#               123400  f_clk=0 p=        1 choose=2 data= 45
#               123450  f_clk=1 p=        1 choose=2 data= 45
#               123500  f_clk=0 p=        1 choose=2 data= 45
#               123550  f_clk=1 p=        1 choose=2 data= 50
#               123600  f_clk=0 p=        1 choose=2 data= 50
#               123650  f_clk=1 p=        1 choose=2 data= 50
#               123700  f_clk=0 p=        1 choose=2 data= 50
#               123750  f_clk=1 p=        1 choose=2 data= 55
#               123800  f_clk=0 p=        1 choose=2 data= 55
#               123850  f_clk=1 p=        1 choose=2 data= 55
#               123900  f_clk=0 p=        1 choose=2 data= 55
#               123950  f_clk=1 p=        1 choose=2 data= 60
#               124000  f_clk=0 p=        1 choose=2 data= 60
#               124050  f_clk=1 p=        1 choose=2 data= 60
#               124100  f_clk=0 p=        1 choose=2 data= 60
#               124150  f_clk=1 p=        1 choose=2 data= 65
#               124200  f_clk=0 p=        1 choose=2 data= 65
#               124250  f_clk=1 p=        1 choose=2 data= 65
#               124300  f_clk=0 p=        1 choose=2 data= 65
#               124350  f_clk=1 p=        1 choose=2 data= 70
#               124400  f_clk=0 p=        1 choose=2 data= 70
#               124450  f_clk=1 p=        1 choose=2 data= 70
#               124500  f_clk=0 p=        1 choose=2 data= 70
#               124550  f_clk=1 p=        1 choose=2 data= 75
#               124600  f_clk=0 p=        1 choose=2 data= 75
#               124650  f_clk=1 p=        1 choose=2 data= 75
#               124700  f_clk=0 p=        1 choose=2 data= 75
#               124750  f_clk=1 p=        1 choose=2 data=  0
#               124800  f_clk=0 p=        1 choose=2 data=  0
#               124850  f_clk=1 p=        1 choose=2 data=  0
#               124900  f_clk=0 p=        1 choose=2 data=  0
#               124950  f_clk=1 p=        1 choose=2 data=  5
#               125000  f_clk=0 p=        1 choose=2 data=  5
#               125050  f_clk=1 p=        1 choose=2 data=  5
#               125100  f_clk=0 p=        1 choose=2 data=  5
#               125150  f_clk=1 p=        1 choose=2 data= 10
#               125200  f_clk=0 p=        1 choose=2 data= 10
#               125250  f_clk=1 p=        1 choose=2 data= 10
#               125300  f_clk=0 p=        1 choose=2 data= 10
#               125350  f_clk=1 p=        1 choose=2 data= 15
#               125400  f_clk=0 p=        1 choose=2 data= 15
#               125450  f_clk=1 p=        1 choose=2 data= 15
#               125500  f_clk=0 p=        1 choose=2 data= 15
#               125550  f_clk=1 p=        1 choose=2 data= 20
#               125600  f_clk=0 p=        1 choose=2 data= 20
#               125650  f_clk=1 p=        1 choose=2 data= 20
#               125700  f_clk=0 p=        1 choose=2 data= 20
#               125750  f_clk=1 p=        1 choose=2 data= 25
#               125800  f_clk=0 p=        1 choose=2 data= 25
#               125850  f_clk=1 p=        1 choose=2 data= 25
#               125900  f_clk=0 p=        1 choose=2 data= 25
#               125950  f_clk=1 p=        1 choose=2 data= 30
#               126000  f_clk=0 p=        1 choose=2 data= 30
#               126050  f_clk=1 p=        1 choose=2 data= 30
#               126100  f_clk=0 p=        1 choose=2 data= 30
#               126150  f_clk=1 p=        1 choose=2 data= 35
#               126200  f_clk=0 p=        1 choose=2 data= 35
#               126250  f_clk=1 p=        1 choose=2 data= 35
#               126300  f_clk=0 p=        1 choose=2 data= 35
#               126350  f_clk=1 p=        1 choose=2 data= 40
#               126400  f_clk=0 p=        1 choose=2 data= 40
#               126450  f_clk=1 p=        1 choose=2 data= 40
#               126500  f_clk=0 p=        1 choose=2 data= 40
#               126550  f_clk=1 p=        1 choose=2 data= 45
#               126600  f_clk=0 p=        1 choose=2 data= 45
#               126650  f_clk=1 p=        1 choose=2 data= 45
#               126700  f_clk=0 p=        1 choose=2 data= 45
#               126750  f_clk=1 p=        1 choose=2 data= 50
#               126800  f_clk=0 p=        1 choose=2 data= 50
#               126850  f_clk=1 p=        1 choose=2 data= 50
#               126900  f_clk=0 p=        1 choose=2 data= 50
#               126950  f_clk=1 p=        1 choose=2 data= 55
#               127000  f_clk=0 p=        1 choose=2 data= 55
#               127050  f_clk=1 p=        1 choose=2 data= 55
#               127100  f_clk=0 p=        1 choose=2 data= 55
#               127150  f_clk=1 p=        1 choose=2 data= 60
#               127200  f_clk=0 p=        1 choose=2 data= 60
#               127250  f_clk=1 p=        1 choose=2 data= 60
#               127300  f_clk=0 p=        1 choose=2 data= 60
#               127350  f_clk=1 p=        1 choose=2 data= 65
#               127400  f_clk=0 p=        1 choose=2 data= 65
#               127450  f_clk=1 p=        1 choose=2 data= 65
#               127500  f_clk=0 p=        1 choose=2 data= 65
#               127550  f_clk=1 p=        1 choose=2 data= 70
#               127600  f_clk=0 p=        1 choose=2 data= 70
#               127650  f_clk=1 p=        1 choose=2 data= 70
#               127700  f_clk=0 p=        1 choose=2 data= 70
#               127750  f_clk=1 p=        1 choose=2 data= 75
#               127800  f_clk=0 p=        1 choose=2 data= 75
#               127850  f_clk=1 p=        1 choose=2 data= 75
#               127900  f_clk=0 p=        1 choose=2 data= 75
#               127950  f_clk=1 p=        1 choose=2 data=  0
#               128000  f_clk=0 p=        1 choose=2 data=  0
#               128050  f_clk=1 p=        1 choose=2 data=  0
#               128100  f_clk=0 p=        1 choose=2 data=  0
#               128150  f_clk=1 p=        1 choose=2 data=  5
#               128200  f_clk=0 p=        1 choose=2 data=  5
#               128250  f_clk=1 p=        1 choose=2 data=  5
#               128300  f_clk=0 p=        1 choose=2 data=  5
#               128350  f_clk=1 p=        1 choose=2 data= 10
#               128400  f_clk=0 p=        1 choose=2 data= 10
#               128450  f_clk=1 p=        1 choose=2 data= 10
#               128500  f_clk=0 p=        1 choose=2 data= 10
#               128550  f_clk=1 p=        1 choose=2 data= 15
#               128600  f_clk=0 p=        1 choose=2 data= 15
#               128650  f_clk=1 p=        1 choose=2 data= 15
#               128700  f_clk=0 p=        1 choose=2 data= 15
#               128750  f_clk=1 p=        1 choose=2 data= 20
#               128800  f_clk=0 p=        1 choose=2 data= 20
#               128850  f_clk=1 p=        1 choose=2 data= 20
#               128900  f_clk=0 p=        1 choose=2 data= 20
#               128950  f_clk=1 p=        1 choose=2 data= 25
#               129000  f_clk=0 p=        1 choose=2 data= 25
#               129050  f_clk=1 p=        1 choose=2 data= 25
#               129100  f_clk=0 p=        1 choose=2 data= 25
#               129150  f_clk=1 p=        1 choose=2 data= 30
#               129200  f_clk=0 p=        1 choose=2 data= 30
#               129250  f_clk=1 p=        1 choose=2 data= 30
#               129300  f_clk=0 p=        1 choose=2 data= 30
#               129350  f_clk=1 p=        1 choose=2 data= 35
#               129400  f_clk=0 p=        1 choose=2 data= 35
#               129450  f_clk=1 p=        1 choose=2 data= 35
#               129500  f_clk=0 p=        1 choose=2 data= 35
#               129550  f_clk=1 p=        1 choose=2 data= 40
#               129600  f_clk=0 p=        1 choose=2 data= 40
#               129650  f_clk=1 p=        1 choose=2 data= 40
#               129700  f_clk=0 p=        1 choose=2 data= 40
#               129750  f_clk=1 p=        1 choose=2 data= 45
#               129800  f_clk=0 p=        1 choose=2 data= 45
#               129850  f_clk=1 p=        1 choose=2 data= 45
#               129900  f_clk=0 p=        1 choose=2 data= 45
#               129950  f_clk=1 p=        1 choose=2 data= 50
#               130000  f_clk=0 p=        1 choose=2 data= 50
#               130050  f_clk=1 p=        1 choose=2 data= 50
#               130100  f_clk=0 p=        1 choose=2 data= 50
#               130150  f_clk=1 p=        1 choose=2 data= 55
#               130200  f_clk=0 p=        1 choose=2 data= 55
#               130250  f_clk=1 p=        1 choose=2 data= 55
#               130300  f_clk=0 p=        1 choose=2 data= 55
#               130350  f_clk=1 p=        1 choose=2 data= 60
#               130400  f_clk=0 p=        1 choose=2 data= 60
#               130450  f_clk=1 p=        1 choose=2 data= 60
#               130500  f_clk=0 p=        1 choose=2 data= 60
#               130550  f_clk=1 p=        1 choose=2 data= 65
#               130600  f_clk=0 p=        1 choose=2 data= 65
#               130650  f_clk=1 p=        1 choose=2 data= 65
#               130700  f_clk=0 p=        1 choose=2 data= 65
#               130750  f_clk=1 p=        1 choose=2 data= 70
#               130800  f_clk=0 p=        1 choose=2 data= 70
#               130850  f_clk=1 p=        1 choose=2 data= 70
#               130900  f_clk=0 p=        1 choose=2 data= 70
#               130950  f_clk=1 p=        1 choose=2 data= 75
#               131000  f_clk=0 p=        1 choose=2 data= 75
#               131050  f_clk=1 p=        1 choose=2 data= 75
#               131100  f_clk=0 p=        1 choose=2 data= 75
#               131150  f_clk=1 p=        1 choose=2 data=  0
#               131200  f_clk=0 p=        1 choose=2 data=  0
#               131250  f_clk=1 p=        1 choose=2 data=  0
#               131300  f_clk=0 p=        1 choose=2 data=  0
#               131350  f_clk=1 p=        1 choose=2 data=  5
#               131400  f_clk=0 p=        1 choose=2 data=  5
#               131450  f_clk=1 p=        1 choose=2 data=  5
#               131500  f_clk=0 p=        1 choose=2 data=  5
#               131550  f_clk=1 p=        1 choose=2 data= 10
#               131600  f_clk=0 p=        1 choose=2 data= 10
#               131650  f_clk=1 p=        1 choose=2 data= 10
#               131700  f_clk=0 p=        1 choose=2 data= 10
#               131750  f_clk=1 p=        1 choose=2 data= 15
#               131800  f_clk=0 p=        1 choose=2 data= 15
#               131850  f_clk=1 p=        1 choose=2 data= 15
#               131900  f_clk=0 p=        1 choose=2 data= 15
#               131950  f_clk=1 p=        1 choose=2 data= 20
#               132000  f_clk=0 p=        1 choose=2 data= 20
#               132050  f_clk=1 p=        1 choose=2 data= 20
#               132100  f_clk=0 p=        1 choose=2 data= 20
#               132150  f_clk=1 p=        1 choose=2 data= 25
#               132200  f_clk=0 p=        1 choose=2 data= 25
#               132250  f_clk=1 p=        1 choose=2 data= 25
#               132300  f_clk=0 p=        1 choose=2 data= 25
#               132350  f_clk=1 p=        1 choose=2 data= 30
#               132400  f_clk=0 p=        1 choose=2 data= 30
#               132450  f_clk=1 p=        1 choose=2 data= 30
#               132500  f_clk=0 p=        1 choose=2 data= 30
#               132550  f_clk=1 p=        1 choose=2 data= 35
#               132600  f_clk=0 p=        1 choose=2 data= 35
#               132650  f_clk=1 p=        1 choose=2 data= 35
#               132700  f_clk=0 p=        1 choose=2 data= 35
#               132750  f_clk=1 p=        1 choose=2 data= 40
#               132800  f_clk=0 p=        1 choose=2 data= 40
#               132850  f_clk=1 p=        1 choose=2 data= 40
#               132900  f_clk=0 p=        1 choose=2 data= 40
#               132950  f_clk=1 p=        1 choose=2 data= 45
#               133000  f_clk=0 p=        1 choose=2 data= 45
#               133050  f_clk=1 p=        1 choose=2 data= 45
#               133100  f_clk=0 p=        1 choose=2 data= 45
#               133150  f_clk=1 p=        1 choose=2 data= 50
#               133200  f_clk=0 p=        1 choose=2 data= 50
#               133250  f_clk=1 p=        1 choose=2 data= 50
#               133300  f_clk=0 p=        1 choose=2 data= 50
#               133350  f_clk=1 p=        1 choose=2 data= 55
#               133400  f_clk=0 p=        1 choose=2 data= 55
#               133450  f_clk=1 p=        1 choose=2 data= 55
#               133500  f_clk=0 p=        1 choose=2 data= 55
#               133550  f_clk=1 p=        1 choose=2 data= 60
#               133600  f_clk=0 p=        1 choose=2 data= 60
#               133650  f_clk=1 p=        1 choose=2 data= 60
#               133700  f_clk=0 p=        1 choose=2 data= 60
#               133750  f_clk=1 p=        1 choose=2 data= 65
#               133800  f_clk=0 p=        1 choose=2 data= 65
#               133850  f_clk=1 p=        1 choose=2 data= 65
#               133900  f_clk=0 p=        1 choose=2 data= 65
#               133950  f_clk=1 p=        1 choose=2 data= 70
#               134000  f_clk=0 p=        1 choose=2 data= 70
#               134050  f_clk=1 p=        1 choose=2 data= 70
#               134100  f_clk=0 p=        1 choose=2 data= 70
#               134150  f_clk=1 p=        1 choose=2 data= 75
#               134200  f_clk=0 p=        1 choose=2 data= 75
#               134250  f_clk=1 p=        1 choose=2 data= 75
#               134300  f_clk=0 p=        1 choose=2 data= 75
#               134350  f_clk=1 p=        1 choose=2 data=  0
#               134400  f_clk=0 p=        1 choose=2 data=  0
#               134450  f_clk=1 p=        1 choose=2 data=  0
#               134500  f_clk=0 p=        1 choose=2 data=  0
#               134550  f_clk=1 p=        1 choose=2 data=  5
#               134600  f_clk=0 p=        1 choose=2 data=  5
#               134650  f_clk=1 p=        1 choose=2 data=  5
#               134700  f_clk=0 p=        1 choose=2 data=  5
#               134750  f_clk=1 p=        1 choose=2 data= 10
#               134800  f_clk=0 p=        1 choose=2 data= 10
#               134850  f_clk=1 p=        1 choose=2 data= 10
#               134900  f_clk=0 p=        1 choose=2 data= 10
#               134950  f_clk=1 p=        1 choose=2 data= 15
#               135000  f_clk=0 p=        1 choose=2 data= 15
#               135050  f_clk=1 p=        1 choose=2 data= 15
#               135100  f_clk=0 p=        1 choose=2 data= 15
#               135150  f_clk=1 p=        1 choose=2 data= 20
#               135200  f_clk=0 p=        1 choose=2 data= 20
#               135250  f_clk=1 p=        1 choose=2 data= 20
#               135300  f_clk=0 p=        1 choose=2 data= 20
#               135350  f_clk=1 p=        1 choose=2 data= 25
#               135400  f_clk=0 p=        1 choose=2 data= 25
#               135450  f_clk=1 p=        1 choose=2 data= 25
#               135500  f_clk=0 p=        1 choose=2 data= 25
#               135550  f_clk=1 p=        1 choose=2 data= 30
#               135600  f_clk=0 p=        1 choose=2 data= 30
#               135650  f_clk=1 p=        1 choose=2 data= 30
#               135700  f_clk=0 p=        1 choose=2 data= 30
#               135750  f_clk=1 p=        1 choose=2 data= 35
#               135800  f_clk=0 p=        1 choose=2 data= 35
#               135850  f_clk=1 p=        1 choose=2 data= 35
#               135900  f_clk=0 p=        1 choose=2 data= 35
#               135950  f_clk=1 p=        1 choose=2 data= 40
#               136000  f_clk=0 p=        1 choose=2 data= 40
#               136050  f_clk=1 p=        1 choose=2 data= 40
#               136100  f_clk=0 p=        1 choose=2 data= 40
#               136150  f_clk=1 p=        1 choose=2 data= 45
#               136200  f_clk=0 p=        1 choose=2 data= 45
#               136250  f_clk=1 p=        1 choose=2 data= 45
#               136300  f_clk=0 p=        1 choose=2 data= 45
#               136350  f_clk=1 p=        1 choose=2 data= 50
#               136400  f_clk=0 p=        1 choose=2 data= 50
#               136450  f_clk=1 p=        1 choose=2 data= 50
#               136500  f_clk=0 p=        1 choose=2 data= 50
#               136550  f_clk=1 p=        1 choose=2 data= 55
#               136600  f_clk=0 p=        1 choose=2 data= 55
#               136650  f_clk=1 p=        1 choose=2 data= 55
#               136700  f_clk=0 p=        1 choose=2 data= 55
#               136750  f_clk=1 p=        1 choose=2 data= 60
#               136800  f_clk=0 p=        1 choose=2 data= 60
#               136850  f_clk=1 p=        1 choose=2 data= 60
#               136900  f_clk=0 p=        1 choose=2 data= 60
#               136950  f_clk=1 p=        1 choose=2 data= 65
#               137000  f_clk=0 p=        1 choose=2 data= 65
#               137050  f_clk=1 p=        1 choose=2 data= 65
#               137100  f_clk=0 p=        1 choose=2 data= 65
#               137150  f_clk=1 p=        1 choose=2 data= 70
#               137200  f_clk=0 p=        1 choose=2 data= 70
#               137250  f_clk=1 p=        1 choose=2 data= 70
#               137300  f_clk=0 p=        1 choose=2 data= 70
#               137350  f_clk=1 p=        1 choose=2 data= 75
#               137400  f_clk=0 p=        1 choose=2 data= 75
#               137450  f_clk=1 p=        1 choose=2 data= 75
#               137500  f_clk=0 p=        1 choose=2 data= 75
#               137550  f_clk=1 p=        1 choose=2 data=  0
#               137600  f_clk=0 p=        1 choose=2 data=  0
#               137650  f_clk=1 p=        1 choose=2 data=  0
#               137700  f_clk=0 p=        1 choose=2 data=  0
#               137750  f_clk=1 p=        1 choose=2 data=  5
#               137800  f_clk=0 p=        1 choose=2 data=  5
#               137850  f_clk=1 p=        1 choose=2 data=  5
#               137900  f_clk=0 p=        1 choose=2 data=  5
#               137950  f_clk=1 p=        1 choose=2 data= 10
#               138000  f_clk=0 p=        1 choose=2 data= 10
#               138050  f_clk=1 p=        1 choose=2 data= 10
#               138100  f_clk=0 p=        1 choose=2 data= 10
#               138150  f_clk=1 p=        1 choose=2 data= 15
#               138200  f_clk=0 p=        1 choose=2 data= 15
#               138250  f_clk=1 p=        1 choose=2 data= 15
#               138300  f_clk=0 p=        1 choose=2 data= 15
#               138350  f_clk=1 p=        1 choose=2 data= 20
#               138400  f_clk=0 p=        1 choose=2 data= 20
#               138450  f_clk=1 p=        1 choose=2 data= 20
#               138500  f_clk=0 p=        1 choose=2 data= 20
#               138550  f_clk=1 p=        1 choose=2 data= 25
#               138600  f_clk=0 p=        1 choose=2 data= 25
#               138650  f_clk=1 p=        1 choose=2 data= 25
#               138700  f_clk=0 p=        1 choose=2 data= 25
#               138750  f_clk=1 p=        1 choose=2 data= 30
#               138800  f_clk=0 p=        1 choose=2 data= 30
#               138850  f_clk=1 p=        1 choose=2 data= 30
#               138900  f_clk=0 p=        1 choose=2 data= 30
#               138950  f_clk=1 p=        1 choose=2 data= 35
#               139000  f_clk=0 p=        1 choose=2 data= 35
#               139050  f_clk=1 p=        1 choose=2 data= 35
#               139100  f_clk=0 p=        1 choose=2 data= 35
#               139150  f_clk=1 p=        1 choose=2 data= 40
#               139200  f_clk=0 p=        1 choose=2 data= 40
#               139250  f_clk=1 p=        1 choose=2 data= 40
#               139300  f_clk=0 p=        1 choose=2 data= 40
#               139350  f_clk=1 p=        1 choose=2 data= 45
#               139400  f_clk=0 p=        1 choose=2 data= 45
#               139450  f_clk=1 p=        1 choose=2 data= 45
#               139500  f_clk=0 p=        1 choose=2 data= 45
#               139550  f_clk=1 p=        1 choose=2 data= 50
#               139600  f_clk=0 p=        1 choose=2 data= 50
#               139650  f_clk=1 p=        1 choose=2 data= 50
#               139700  f_clk=0 p=        1 choose=2 data= 50
#               139750  f_clk=1 p=        1 choose=2 data= 55
#               139800  f_clk=0 p=        1 choose=2 data= 55
#               139850  f_clk=1 p=        1 choose=2 data= 55
#               139900  f_clk=0 p=        1 choose=2 data= 55
#               139950  f_clk=1 p=        1 choose=2 data= 60
#               140000  f_clk=0 p=        1 choose=3 data= 15
#               140050  f_clk=1 p=        1 choose=3 data= 15
#               140100  f_clk=0 p=        1 choose=3 data= 15
#               140150  f_clk=1 p=        1 choose=3 data= 10
#               140200  f_clk=0 p=        1 choose=3 data= 10
#               140250  f_clk=1 p=        1 choose=3 data= 10
#               140300  f_clk=0 p=        1 choose=3 data= 10
#               140350  f_clk=1 p=        1 choose=3 data=  5
#               140400  f_clk=0 p=        1 choose=3 data=  5
#               140450  f_clk=1 p=        1 choose=3 data=  5
#               140500  f_clk=0 p=        1 choose=3 data=  5
#               140550  f_clk=1 p=        1 choose=3 data=  0
#               140600  f_clk=0 p=        1 choose=3 data=  0
#               140650  f_clk=1 p=        1 choose=3 data=  0
#               140700  f_clk=0 p=        1 choose=3 data=  0
#               140750  f_clk=1 p=        1 choose=3 data= 75
#               140800  f_clk=0 p=        1 choose=3 data= 75
#               140850  f_clk=1 p=        1 choose=3 data= 75
#               140900  f_clk=0 p=        1 choose=3 data= 75
#               140950  f_clk=1 p=        1 choose=3 data= 70
#               141000  f_clk=0 p=        1 choose=3 data= 70
#               141050  f_clk=1 p=        1 choose=3 data= 70
#               141100  f_clk=0 p=        1 choose=3 data= 70
#               141150  f_clk=1 p=        1 choose=3 data= 65
#               141200  f_clk=0 p=        1 choose=3 data= 65
#               141250  f_clk=1 p=        1 choose=3 data= 65
#               141300  f_clk=0 p=        1 choose=3 data= 65
#               141350  f_clk=1 p=        1 choose=3 data= 60
#               141400  f_clk=0 p=        1 choose=3 data= 60
#               141450  f_clk=1 p=        1 choose=3 data= 60
#               141500  f_clk=0 p=        1 choose=3 data= 60
#               141550  f_clk=1 p=        1 choose=3 data= 55
#               141600  f_clk=0 p=        1 choose=3 data= 55
#               141650  f_clk=1 p=        1 choose=3 data= 55
#               141700  f_clk=0 p=        1 choose=3 data= 55
#               141750  f_clk=1 p=        1 choose=3 data= 50
#               141800  f_clk=0 p=        1 choose=3 data= 50
#               141850  f_clk=1 p=        1 choose=3 data= 50
#               141900  f_clk=0 p=        1 choose=3 data= 50
#               141950  f_clk=1 p=        1 choose=3 data= 45
#               142000  f_clk=0 p=        1 choose=3 data= 45
#               142050  f_clk=1 p=        1 choose=3 data= 45
#               142100  f_clk=0 p=        1 choose=3 data= 45
#               142150  f_clk=1 p=        1 choose=3 data= 40
#               142200  f_clk=0 p=        1 choose=3 data= 40
#               142250  f_clk=1 p=        1 choose=3 data= 40
#               142300  f_clk=0 p=        1 choose=3 data= 40
#               142350  f_clk=1 p=        1 choose=3 data= 35
#               142400  f_clk=0 p=        1 choose=3 data= 35
#               142450  f_clk=1 p=        1 choose=3 data= 35
#               142500  f_clk=0 p=        1 choose=3 data= 35
#               142550  f_clk=1 p=        1 choose=3 data= 30
#               142600  f_clk=0 p=        1 choose=3 data= 30
#               142650  f_clk=1 p=        1 choose=3 data= 30
#               142700  f_clk=0 p=        1 choose=3 data= 30
#               142750  f_clk=1 p=        1 choose=3 data= 25
#               142800  f_clk=0 p=        1 choose=3 data= 25
#               142850  f_clk=1 p=        1 choose=3 data= 25
#               142900  f_clk=0 p=        1 choose=3 data= 25
#               142950  f_clk=1 p=        1 choose=3 data= 20
#               143000  f_clk=0 p=        1 choose=3 data= 20
#               143050  f_clk=1 p=        1 choose=3 data= 20
#               143100  f_clk=0 p=        1 choose=3 data= 20
#               143150  f_clk=1 p=        1 choose=3 data= 15
#               143200  f_clk=0 p=        1 choose=3 data= 15
#               143250  f_clk=1 p=        1 choose=3 data= 15
#               143300  f_clk=0 p=        1 choose=3 data= 15
#               143350  f_clk=1 p=        1 choose=3 data= 10
#               143400  f_clk=0 p=        1 choose=3 data= 10
#               143450  f_clk=1 p=        1 choose=3 data= 10
#               143500  f_clk=0 p=        1 choose=3 data= 10
#               143550  f_clk=1 p=        1 choose=3 data=  5
#               143600  f_clk=0 p=        1 choose=3 data=  5
#               143650  f_clk=1 p=        1 choose=3 data=  5
#               143700  f_clk=0 p=        1 choose=3 data=  5
#               143750  f_clk=1 p=        1 choose=3 data=  0
#               143800  f_clk=0 p=        1 choose=3 data=  0
#               143850  f_clk=1 p=        1 choose=3 data=  0
#               143900  f_clk=0 p=        1 choose=3 data=  0
#               143950  f_clk=1 p=        1 choose=3 data= 75
#               144000  f_clk=0 p=        1 choose=3 data= 75
#               144050  f_clk=1 p=        1 choose=3 data= 75
#               144100  f_clk=0 p=        1 choose=3 data= 75
#               144150  f_clk=1 p=        1 choose=3 data= 70
#               144200  f_clk=0 p=        1 choose=3 data= 70
#               144250  f_clk=1 p=        1 choose=3 data= 70
#               144300  f_clk=0 p=        1 choose=3 data= 70
#               144350  f_clk=1 p=        1 choose=3 data= 65
#               144400  f_clk=0 p=        1 choose=3 data= 65
#               144450  f_clk=1 p=        1 choose=3 data= 65
#               144500  f_clk=0 p=        1 choose=3 data= 65
#               144550  f_clk=1 p=        1 choose=3 data= 60
#               144600  f_clk=0 p=        1 choose=3 data= 60
#               144650  f_clk=1 p=        1 choose=3 data= 60
#               144700  f_clk=0 p=        1 choose=3 data= 60
#               144750  f_clk=1 p=        1 choose=3 data= 55
#               144800  f_clk=0 p=        1 choose=3 data= 55
#               144850  f_clk=1 p=        1 choose=3 data= 55
#               144900  f_clk=0 p=        1 choose=3 data= 55
#               144950  f_clk=1 p=        1 choose=3 data= 50
#               145000  f_clk=0 p=        1 choose=3 data= 50
#               145050  f_clk=1 p=        1 choose=3 data= 50
#               145100  f_clk=0 p=        1 choose=3 data= 50
#               145150  f_clk=1 p=        1 choose=3 data= 45
#               145200  f_clk=0 p=        1 choose=3 data= 45
#               145250  f_clk=1 p=        1 choose=3 data= 45
#               145300  f_clk=0 p=        1 choose=3 data= 45
#               145350  f_clk=1 p=        1 choose=3 data= 40
#               145400  f_clk=0 p=        1 choose=3 data= 40
#               145450  f_clk=1 p=        1 choose=3 data= 40
#               145500  f_clk=0 p=        1 choose=3 data= 40
#               145550  f_clk=1 p=        1 choose=3 data= 35
#               145600  f_clk=0 p=        1 choose=3 data= 35
#               145650  f_clk=1 p=        1 choose=3 data= 35
#               145700  f_clk=0 p=        1 choose=3 data= 35
#               145750  f_clk=1 p=        1 choose=3 data= 30
#               145800  f_clk=0 p=        1 choose=3 data= 30
#               145850  f_clk=1 p=        1 choose=3 data= 30
#               145900  f_clk=0 p=        1 choose=3 data= 30
#               145950  f_clk=1 p=        1 choose=3 data= 25
#               146000  f_clk=0 p=        1 choose=3 data= 25
#               146050  f_clk=1 p=        1 choose=3 data= 25
#               146100  f_clk=0 p=        1 choose=3 data= 25
#               146150  f_clk=1 p=        1 choose=3 data= 20
#               146200  f_clk=0 p=        1 choose=3 data= 20
#               146250  f_clk=1 p=        1 choose=3 data= 20
#               146300  f_clk=0 p=        1 choose=3 data= 20
#               146350  f_clk=1 p=        1 choose=3 data= 15
#               146400  f_clk=0 p=        1 choose=3 data= 15
#               146450  f_clk=1 p=        1 choose=3 data= 15
#               146500  f_clk=0 p=        1 choose=3 data= 15
#               146550  f_clk=1 p=        1 choose=3 data= 10
#               146600  f_clk=0 p=        1 choose=3 data= 10
#               146650  f_clk=1 p=        1 choose=3 data= 10
#               146700  f_clk=0 p=        1 choose=3 data= 10
#               146750  f_clk=1 p=        1 choose=3 data=  5
#               146800  f_clk=0 p=        1 choose=3 data=  5
#               146850  f_clk=1 p=        1 choose=3 data=  5
#               146900  f_clk=0 p=        1 choose=3 data=  5
#               146950  f_clk=1 p=        1 choose=3 data=  0
#               147000  f_clk=0 p=        1 choose=3 data=  0
#               147050  f_clk=1 p=        1 choose=3 data=  0
#               147100  f_clk=0 p=        1 choose=3 data=  0
#               147150  f_clk=1 p=        1 choose=3 data= 75
#               147200  f_clk=0 p=        1 choose=3 data= 75
#               147250  f_clk=1 p=        1 choose=3 data= 75
#               147300  f_clk=0 p=        1 choose=3 data= 75
#               147350  f_clk=1 p=        1 choose=3 data= 70
#               147400  f_clk=0 p=        1 choose=3 data= 70
#               147450  f_clk=1 p=        1 choose=3 data= 70
#               147500  f_clk=0 p=        1 choose=3 data= 70
#               147550  f_clk=1 p=        1 choose=3 data= 65
#               147600  f_clk=0 p=        1 choose=3 data= 65
#               147650  f_clk=1 p=        1 choose=3 data= 65
#               147700  f_clk=0 p=        1 choose=3 data= 65
#               147750  f_clk=1 p=        1 choose=3 data= 60
#               147800  f_clk=0 p=        1 choose=3 data= 60
#               147850  f_clk=1 p=        1 choose=3 data= 60
#               147900  f_clk=0 p=        1 choose=3 data= 60
#               147950  f_clk=1 p=        1 choose=3 data= 55
#               148000  f_clk=0 p=        1 choose=3 data= 55
#               148050  f_clk=1 p=        1 choose=3 data= 55
#               148100  f_clk=0 p=        1 choose=3 data= 55
#               148150  f_clk=1 p=        1 choose=3 data= 50
#               148200  f_clk=0 p=        1 choose=3 data= 50
#               148250  f_clk=1 p=        1 choose=3 data= 50
#               148300  f_clk=0 p=        1 choose=3 data= 50
#               148350  f_clk=1 p=        1 choose=3 data= 45
#               148400  f_clk=0 p=        1 choose=3 data= 45
#               148450  f_clk=1 p=        1 choose=3 data= 45
#               148500  f_clk=0 p=        1 choose=3 data= 45
#               148550  f_clk=1 p=        1 choose=3 data= 40
#               148600  f_clk=0 p=        1 choose=3 data= 40
#               148650  f_clk=1 p=        1 choose=3 data= 40
#               148700  f_clk=0 p=        1 choose=3 data= 40
#               148750  f_clk=1 p=        1 choose=3 data= 35
#               148800  f_clk=0 p=        1 choose=3 data= 35
#               148850  f_clk=1 p=        1 choose=3 data= 35
#               148900  f_clk=0 p=        1 choose=3 data= 35
#               148950  f_clk=1 p=        1 choose=3 data= 30
#               149000  f_clk=0 p=        1 choose=3 data= 30
#               149050  f_clk=1 p=        1 choose=3 data= 30
#               149100  f_clk=0 p=        1 choose=3 data= 30
#               149150  f_clk=1 p=        1 choose=3 data= 25
#               149200  f_clk=0 p=        1 choose=3 data= 25
#               149250  f_clk=1 p=        1 choose=3 data= 25
#               149300  f_clk=0 p=        1 choose=3 data= 25
#               149350  f_clk=1 p=        1 choose=3 data= 20
#               149400  f_clk=0 p=        1 choose=3 data= 20
#               149450  f_clk=1 p=        1 choose=3 data= 20
#               149500  f_clk=0 p=        1 choose=3 data= 20
#               149550  f_clk=1 p=        1 choose=3 data= 15
#               149600  f_clk=0 p=        1 choose=3 data= 15
#               149650  f_clk=1 p=        1 choose=3 data= 15
#               149700  f_clk=0 p=        1 choose=3 data= 15
#               149750  f_clk=1 p=        1 choose=3 data= 10
#               149800  f_clk=0 p=        1 choose=3 data= 10
#               149850  f_clk=1 p=        1 choose=3 data= 10
#               149900  f_clk=0 p=        1 choose=3 data= 10
#               149950  f_clk=1 p=        1 choose=3 data=  5
#               150000  f_clk=0 p=        1 choose=3 data=  5
#               150050  f_clk=1 p=        1 choose=3 data=  5
#               150100  f_clk=0 p=        1 choose=3 data=  5
#               150150  f_clk=1 p=        1 choose=3 data=  0
#               150200  f_clk=0 p=        1 choose=3 data=  0
#               150250  f_clk=1 p=        1 choose=3 data=  0
#               150300  f_clk=0 p=        1 choose=3 data=  0
#               150350  f_clk=1 p=        1 choose=3 data= 75
#               150400  f_clk=0 p=        1 choose=3 data= 75
#               150450  f_clk=1 p=        1 choose=3 data= 75
#               150500  f_clk=0 p=        1 choose=3 data= 75
#               150550  f_clk=1 p=        1 choose=3 data= 70
#               150600  f_clk=0 p=        1 choose=3 data= 70
#               150650  f_clk=1 p=        1 choose=3 data= 70
#               150700  f_clk=0 p=        1 choose=3 data= 70
#               150750  f_clk=1 p=        1 choose=3 data= 65
#               150800  f_clk=0 p=        1 choose=3 data= 65
#               150850  f_clk=1 p=        1 choose=3 data= 65
#               150900  f_clk=0 p=        1 choose=3 data= 65
#               150950  f_clk=1 p=        1 choose=3 data= 60
#               151000  f_clk=0 p=        1 choose=3 data= 60
#               151050  f_clk=1 p=        1 choose=3 data= 60
#               151100  f_clk=0 p=        1 choose=3 data= 60
#               151150  f_clk=1 p=        1 choose=3 data= 55
#               151200  f_clk=0 p=        1 choose=3 data= 55
#               151250  f_clk=1 p=        1 choose=3 data= 55
#               151300  f_clk=0 p=        1 choose=3 data= 55
#               151350  f_clk=1 p=        1 choose=3 data= 50
#               151400  f_clk=0 p=        1 choose=3 data= 50
#               151450  f_clk=1 p=        1 choose=3 data= 50
#               151500  f_clk=0 p=        1 choose=3 data= 50
#               151550  f_clk=1 p=        1 choose=3 data= 45
#               151600  f_clk=0 p=        1 choose=3 data= 45
#               151650  f_clk=1 p=        1 choose=3 data= 45
#               151700  f_clk=0 p=        1 choose=3 data= 45
#               151750  f_clk=1 p=        1 choose=3 data= 40
#               151800  f_clk=0 p=        1 choose=3 data= 40
#               151850  f_clk=1 p=        1 choose=3 data= 40
#               151900  f_clk=0 p=        1 choose=3 data= 40
#               151950  f_clk=1 p=        1 choose=3 data= 35
#               152000  f_clk=0 p=        1 choose=3 data= 35
#               152050  f_clk=1 p=        1 choose=3 data= 35
#               152100  f_clk=0 p=        1 choose=3 data= 35
#               152150  f_clk=1 p=        1 choose=3 data= 30
#               152200  f_clk=0 p=        1 choose=3 data= 30
#               152250  f_clk=1 p=        1 choose=3 data= 30
#               152300  f_clk=0 p=        1 choose=3 data= 30
#               152350  f_clk=1 p=        1 choose=3 data= 25
#               152400  f_clk=0 p=        1 choose=3 data= 25
#               152450  f_clk=1 p=        1 choose=3 data= 25
#               152500  f_clk=0 p=        1 choose=3 data= 25
#               152550  f_clk=1 p=        1 choose=3 data= 20
#               152600  f_clk=0 p=        1 choose=3 data= 20
#               152650  f_clk=1 p=        1 choose=3 data= 20
#               152700  f_clk=0 p=        1 choose=3 data= 20
#               152750  f_clk=1 p=        1 choose=3 data= 15
#               152800  f_clk=0 p=        1 choose=3 data= 15
#               152850  f_clk=1 p=        1 choose=3 data= 15
#               152900  f_clk=0 p=        1 choose=3 data= 15
#               152950  f_clk=1 p=        1 choose=3 data= 10
#               153000  f_clk=0 p=        1 choose=3 data= 10
#               153050  f_clk=1 p=        1 choose=3 data= 10
#               153100  f_clk=0 p=        1 choose=3 data= 10
#               153150  f_clk=1 p=        1 choose=3 data=  5
#               153200  f_clk=0 p=        1 choose=3 data=  5
#               153250  f_clk=1 p=        1 choose=3 data=  5
#               153300  f_clk=0 p=        1 choose=3 data=  5
#               153350  f_clk=1 p=        1 choose=3 data=  0
#               153400  f_clk=0 p=        1 choose=3 data=  0
#               153450  f_clk=1 p=        1 choose=3 data=  0
#               153500  f_clk=0 p=        1 choose=3 data=  0
#               153550  f_clk=1 p=        1 choose=3 data= 75
#               153600  f_clk=0 p=        1 choose=3 data= 75
#               153650  f_clk=1 p=        1 choose=3 data= 75
#               153700  f_clk=0 p=        1 choose=3 data= 75
#               153750  f_clk=1 p=        1 choose=3 data= 70
#               153800  f_clk=0 p=        1 choose=3 data= 70
#               153850  f_clk=1 p=        1 choose=3 data= 70
#               153900  f_clk=0 p=        1 choose=3 data= 70
#               153950  f_clk=1 p=        1 choose=3 data= 65
#               154000  f_clk=0 p=        1 choose=3 data= 65
#               154050  f_clk=1 p=        1 choose=3 data= 65
#               154100  f_clk=0 p=        1 choose=3 data= 65
#               154150  f_clk=1 p=        1 choose=3 data= 60
#               154200  f_clk=0 p=        1 choose=3 data= 60
#               154250  f_clk=1 p=        1 choose=3 data= 60
#               154300  f_clk=0 p=        1 choose=3 data= 60
#               154350  f_clk=1 p=        1 choose=3 data= 55
#               154400  f_clk=0 p=        1 choose=3 data= 55
#               154450  f_clk=1 p=        1 choose=3 data= 55
#               154500  f_clk=0 p=        1 choose=3 data= 55
#               154550  f_clk=1 p=        1 choose=3 data= 50
#               154600  f_clk=0 p=        1 choose=3 data= 50
#               154650  f_clk=1 p=        1 choose=3 data= 50
#               154700  f_clk=0 p=        1 choose=3 data= 50
#               154750  f_clk=1 p=        1 choose=3 data= 45
#               154800  f_clk=0 p=        1 choose=3 data= 45
#               154850  f_clk=1 p=        1 choose=3 data= 45
#               154900  f_clk=0 p=        1 choose=3 data= 45
#               154950  f_clk=1 p=        1 choose=3 data= 40
#               155000  f_clk=0 p=        1 choose=3 data= 40
#               155050  f_clk=1 p=        1 choose=3 data= 40
#               155100  f_clk=0 p=        1 choose=3 data= 40
#               155150  f_clk=1 p=        1 choose=3 data= 35
#               155200  f_clk=0 p=        1 choose=3 data= 35
#               155250  f_clk=1 p=        1 choose=3 data= 35
#               155300  f_clk=0 p=        1 choose=3 data= 35
#               155350  f_clk=1 p=        1 choose=3 data= 30
#               155400  f_clk=0 p=        1 choose=3 data= 30
#               155450  f_clk=1 p=        1 choose=3 data= 30
#               155500  f_clk=0 p=        1 choose=3 data= 30
#               155550  f_clk=1 p=        1 choose=3 data= 25
#               155600  f_clk=0 p=        1 choose=3 data= 25
#               155650  f_clk=1 p=        1 choose=3 data= 25
#               155700  f_clk=0 p=        1 choose=3 data= 25
#               155750  f_clk=1 p=        1 choose=3 data= 20
#               155800  f_clk=0 p=        1 choose=3 data= 20
#               155850  f_clk=1 p=        1 choose=3 data= 20
#               155900  f_clk=0 p=        1 choose=3 data= 20
#               155950  f_clk=1 p=        1 choose=3 data= 15
#               156000  f_clk=0 p=        1 choose=3 data= 15
#               156050  f_clk=1 p=        1 choose=3 data= 15
#               156100  f_clk=0 p=        1 choose=3 data= 15
#               156150  f_clk=1 p=        1 choose=3 data= 10
#               156200  f_clk=0 p=        1 choose=3 data= 10
#               156250  f_clk=1 p=        1 choose=3 data= 10
#               156300  f_clk=0 p=        1 choose=3 data= 10
#               156350  f_clk=1 p=        1 choose=3 data=  5
#               156400  f_clk=0 p=        1 choose=3 data=  5
#               156450  f_clk=1 p=        1 choose=3 data=  5
#               156500  f_clk=0 p=        1 choose=3 data=  5
#               156550  f_clk=1 p=        1 choose=3 data=  0
#               156600  f_clk=0 p=        1 choose=3 data=  0
#               156650  f_clk=1 p=        1 choose=3 data=  0
#               156700  f_clk=0 p=        1 choose=3 data=  0
#               156750  f_clk=1 p=        1 choose=3 data= 75
#               156800  f_clk=0 p=        1 choose=3 data= 75
#               156850  f_clk=1 p=        1 choose=3 data= 75
#               156900  f_clk=0 p=        1 choose=3 data= 75
#               156950  f_clk=1 p=        1 choose=3 data= 70
#               157000  f_clk=0 p=        1 choose=3 data= 70
#               157050  f_clk=1 p=        1 choose=3 data= 70
#               157100  f_clk=0 p=        1 choose=3 data= 70
#               157150  f_clk=1 p=        1 choose=3 data= 65
#               157200  f_clk=0 p=        1 choose=3 data= 65
#               157250  f_clk=1 p=        1 choose=3 data= 65
#               157300  f_clk=0 p=        1 choose=3 data= 65
#               157350  f_clk=1 p=        1 choose=3 data= 60
#               157400  f_clk=0 p=        1 choose=3 data= 60
#               157450  f_clk=1 p=        1 choose=3 data= 60
#               157500  f_clk=0 p=        1 choose=3 data= 60
#               157550  f_clk=1 p=        1 choose=3 data= 55
#               157600  f_clk=0 p=        1 choose=3 data= 55
#               157650  f_clk=1 p=        1 choose=3 data= 55
#               157700  f_clk=0 p=        1 choose=3 data= 55
#               157750  f_clk=1 p=        1 choose=3 data= 50
#               157800  f_clk=0 p=        1 choose=3 data= 50
#               157850  f_clk=1 p=        1 choose=3 data= 50
#               157900  f_clk=0 p=        1 choose=3 data= 50
#               157950  f_clk=1 p=        1 choose=3 data= 45
#               158000  f_clk=0 p=        1 choose=3 data= 45
#               158050  f_clk=1 p=        1 choose=3 data= 45
#               158100  f_clk=0 p=        1 choose=3 data= 45
#               158150  f_clk=1 p=        1 choose=3 data= 40
#               158200  f_clk=0 p=        1 choose=3 data= 40
#               158250  f_clk=1 p=        1 choose=3 data= 40
#               158300  f_clk=0 p=        1 choose=3 data= 40
#               158350  f_clk=1 p=        1 choose=3 data= 35
#               158400  f_clk=0 p=        1 choose=3 data= 35
#               158450  f_clk=1 p=        1 choose=3 data= 35
#               158500  f_clk=0 p=        1 choose=3 data= 35
#               158550  f_clk=1 p=        1 choose=3 data= 30
#               158600  f_clk=0 p=        1 choose=3 data= 30
#               158650  f_clk=1 p=        1 choose=3 data= 30
#               158700  f_clk=0 p=        1 choose=3 data= 30
#               158750  f_clk=1 p=        1 choose=3 data= 25
#               158800  f_clk=0 p=        1 choose=3 data= 25
#               158850  f_clk=1 p=        1 choose=3 data= 25
#               158900  f_clk=0 p=        1 choose=3 data= 25
#               158950  f_clk=1 p=        1 choose=3 data= 20
#               159000  f_clk=0 p=        1 choose=3 data= 20
#               159050  f_clk=1 p=        1 choose=3 data= 20
#               159100  f_clk=0 p=        1 choose=3 data= 20
#               159150  f_clk=1 p=        1 choose=3 data= 15
#               159200  f_clk=0 p=        1 choose=3 data= 15
#               159250  f_clk=1 p=        1 choose=3 data= 15
#               159300  f_clk=0 p=        1 choose=3 data= 15
#               159350  f_clk=1 p=        1 choose=3 data= 10
#               159400  f_clk=0 p=        1 choose=3 data= 10
#               159450  f_clk=1 p=        1 choose=3 data= 10
#               159500  f_clk=0 p=        1 choose=3 data= 10
#               159550  f_clk=1 p=        1 choose=3 data=  5
#               159600  f_clk=0 p=        1 choose=3 data=  5
#               159650  f_clk=1 p=        1 choose=3 data=  5
#               159700  f_clk=0 p=        1 choose=3 data=  5
#               159750  f_clk=1 p=        1 choose=3 data=  0
#               159800  f_clk=0 p=        1 choose=3 data=  0
#               159850  f_clk=1 p=        1 choose=3 data=  0
#               159900  f_clk=0 p=        1 choose=3 data=  0
#               159950  f_clk=1 p=        1 choose=3 data= 75
#               160000  f_clk=0 p=        5 choose=0 data=  0
#               160050  f_clk=1 p=        5 choose=0 data=  0
#               160100  f_clk=0 p=        5 choose=0 data=  0
#               160150  f_clk=1 p=        5 choose=0 data=  0
#               160200  f_clk=0 p=        5 choose=0 data=  0
#               160250  f_clk=1 p=        5 choose=0 data=  0
#               160300  f_clk=0 p=        5 choose=0 data=  0
#               160350  f_clk=1 p=        5 choose=0 data=  0
#               160400  f_clk=0 p=        5 choose=0 data=  0
#               160450  f_clk=1 p=        5 choose=0 data=  0
#               160500  f_clk=0 p=        5 choose=0 data=  0
#               160550  f_clk=1 p=        5 choose=0 data= 41
#               160600  f_clk=0 p=        5 choose=0 data= 41
#               160650  f_clk=1 p=        5 choose=0 data= 41
#               160700  f_clk=0 p=        5 choose=0 data= 41
#               160750  f_clk=1 p=        5 choose=0 data= 41
#               160800  f_clk=0 p=        5 choose=0 data= 41
#               160850  f_clk=1 p=        5 choose=0 data= 41
#               160900  f_clk=0 p=        5 choose=0 data= 41
#               160950  f_clk=1 p=        5 choose=0 data= 41
#               161000  f_clk=0 p=        5 choose=0 data= 41
#               161050  f_clk=1 p=        5 choose=0 data= 41
#               161100  f_clk=0 p=        5 choose=0 data= 41
#               161150  f_clk=1 p=        5 choose=0 data= 74
#               161200  f_clk=0 p=        5 choose=0 data= 74
#               161250  f_clk=1 p=        5 choose=0 data= 74
#               161300  f_clk=0 p=        5 choose=0 data= 74
#               161350  f_clk=1 p=        5 choose=0 data= 74
#               161400  f_clk=0 p=        5 choose=0 data= 74
#               161450  f_clk=1 p=        5 choose=0 data= 74
#               161500  f_clk=0 p=        5 choose=0 data= 74
#               161550  f_clk=1 p=        5 choose=0 data= 74
#               161600  f_clk=0 p=        5 choose=0 data= 74
#               161650  f_clk=1 p=        5 choose=0 data= 74
#               161700  f_clk=0 p=        5 choose=0 data= 74
#               161750  f_clk=1 p=        5 choose=0 data= 95
#               161800  f_clk=0 p=        5 choose=0 data= 95
#               161850  f_clk=1 p=        5 choose=0 data= 95
#               161900  f_clk=0 p=        5 choose=0 data= 95
#               161950  f_clk=1 p=        5 choose=0 data= 95
#               162000  f_clk=0 p=        5 choose=0 data= 95
#               162050  f_clk=1 p=        5 choose=0 data= 95
#               162100  f_clk=0 p=        5 choose=0 data= 95
#               162150  f_clk=1 p=        5 choose=0 data= 95
#               162200  f_clk=0 p=        5 choose=0 data= 95
#               162250  f_clk=1 p=        5 choose=0 data= 95
#               162300  f_clk=0 p=        5 choose=0 data= 95
#               162350  f_clk=1 p=        5 choose=0 data= 99
#               162400  f_clk=0 p=        5 choose=0 data= 99
#               162450  f_clk=1 p=        5 choose=0 data= 99
#               162500  f_clk=0 p=        5 choose=0 data= 99
#               162550  f_clk=1 p=        5 choose=0 data= 99
#               162600  f_clk=0 p=        5 choose=0 data= 99
#               162650  f_clk=1 p=        5 choose=0 data= 99
#               162700  f_clk=0 p=        5 choose=0 data= 99
#               162750  f_clk=1 p=        5 choose=0 data= 99
#               162800  f_clk=0 p=        5 choose=0 data= 99
#               162850  f_clk=1 p=        5 choose=0 data= 99
#               162900  f_clk=0 p=        5 choose=0 data= 99
#               162950  f_clk=1 p=        5 choose=0 data= 87
#               163000  f_clk=0 p=        5 choose=0 data= 87
#               163050  f_clk=1 p=        5 choose=0 data= 87
#               163100  f_clk=0 p=        5 choose=0 data= 87
#               163150  f_clk=1 p=        5 choose=0 data= 87
#               163200  f_clk=0 p=        5 choose=0 data= 87
#               163250  f_clk=1 p=        5 choose=0 data= 87
#               163300  f_clk=0 p=        5 choose=0 data= 87
#               163350  f_clk=1 p=        5 choose=0 data= 87
#               163400  f_clk=0 p=        5 choose=0 data= 87
#               163450  f_clk=1 p=        5 choose=0 data= 87
#               163500  f_clk=0 p=        5 choose=0 data= 87
#               163550  f_clk=1 p=        5 choose=0 data= 58
#               163600  f_clk=0 p=        5 choose=0 data= 58
#               163650  f_clk=1 p=        5 choose=0 data= 58
#               163700  f_clk=0 p=        5 choose=0 data= 58
#               163750  f_clk=1 p=        5 choose=0 data= 58
#               163800  f_clk=0 p=        5 choose=0 data= 58
#               163850  f_clk=1 p=        5 choose=0 data= 58
#               163900  f_clk=0 p=        5 choose=0 data= 58
#               163950  f_clk=1 p=        5 choose=0 data= 58
#               164000  f_clk=0 p=        5 choose=0 data= 58
#               164050  f_clk=1 p=        5 choose=0 data= 58
#               164100  f_clk=0 p=        5 choose=0 data= 58
#               164150  f_clk=1 p=        5 choose=0 data= 21
#               164200  f_clk=0 p=        5 choose=0 data= 21
#               164250  f_clk=1 p=        5 choose=0 data= 21
#               164300  f_clk=0 p=        5 choose=0 data= 21
#               164350  f_clk=1 p=        5 choose=0 data= 21
#               164400  f_clk=0 p=        5 choose=0 data= 21
#               164450  f_clk=1 p=        5 choose=0 data= 21
#               164500  f_clk=0 p=        5 choose=0 data= 21
#               164550  f_clk=1 p=        5 choose=0 data= 21
#               164600  f_clk=0 p=        5 choose=0 data= 21
#               164650  f_clk=1 p=        5 choose=0 data= 21
#               164700  f_clk=0 p=        5 choose=0 data= 21
#               164750  f_clk=1 p=        5 choose=0 data=235
#               164800  f_clk=0 p=        5 choose=0 data=235
#               164850  f_clk=1 p=        5 choose=0 data=235
#               164900  f_clk=0 p=        5 choose=0 data=235
#               164950  f_clk=1 p=        5 choose=0 data=235
#               165000  f_clk=0 p=        5 choose=0 data=235
#               165050  f_clk=1 p=        5 choose=0 data=235
#               165100  f_clk=0 p=        5 choose=0 data=235
#               165150  f_clk=1 p=        5 choose=0 data=235
#               165200  f_clk=0 p=        5 choose=0 data=235
#               165250  f_clk=1 p=        5 choose=0 data=235
#               165300  f_clk=0 p=        5 choose=0 data=235
#               165350  f_clk=1 p=        5 choose=0 data=198
#               165400  f_clk=0 p=        5 choose=0 data=198
#               165450  f_clk=1 p=        5 choose=0 data=198
#               165500  f_clk=0 p=        5 choose=0 data=198
#               165550  f_clk=1 p=        5 choose=0 data=198
#               165600  f_clk=0 p=        5 choose=0 data=198
#               165650  f_clk=1 p=        5 choose=0 data=198
#               165700  f_clk=0 p=        5 choose=0 data=198
#               165750  f_clk=1 p=        5 choose=0 data=198
#               165800  f_clk=0 p=        5 choose=0 data=198
#               165850  f_clk=1 p=        5 choose=0 data=198
#               165900  f_clk=0 p=        5 choose=0 data=198
#               165950  f_clk=1 p=        5 choose=0 data=169
#               166000  f_clk=0 p=        5 choose=0 data=169
#               166050  f_clk=1 p=        5 choose=0 data=169
#               166100  f_clk=0 p=        5 choose=0 data=169
#               166150  f_clk=1 p=        5 choose=0 data=169
#               166200  f_clk=0 p=        5 choose=0 data=169
#               166250  f_clk=1 p=        5 choose=0 data=169
#               166300  f_clk=0 p=        5 choose=0 data=169
#               166350  f_clk=1 p=        5 choose=0 data=169
#               166400  f_clk=0 p=        5 choose=0 data=169
#               166450  f_clk=1 p=        5 choose=0 data=169
#               166500  f_clk=0 p=        5 choose=0 data=169
#               166550  f_clk=1 p=        5 choose=0 data=157
#               166600  f_clk=0 p=        5 choose=0 data=157
#               166650  f_clk=1 p=        5 choose=0 data=157
#               166700  f_clk=0 p=        5 choose=0 data=157
#               166750  f_clk=1 p=        5 choose=0 data=157
#               166800  f_clk=0 p=        5 choose=0 data=157
#               166850  f_clk=1 p=        5 choose=0 data=157
#               166900  f_clk=0 p=        5 choose=0 data=157
#               166950  f_clk=1 p=        5 choose=0 data=157
#               167000  f_clk=0 p=        5 choose=0 data=157
#               167050  f_clk=1 p=        5 choose=0 data=157
#               167100  f_clk=0 p=        5 choose=0 data=157
#               167150  f_clk=1 p=        5 choose=0 data=161
#               167200  f_clk=0 p=        5 choose=0 data=161
#               167250  f_clk=1 p=        5 choose=0 data=161
#               167300  f_clk=0 p=        5 choose=0 data=161
#               167350  f_clk=1 p=        5 choose=0 data=161
#               167400  f_clk=0 p=        5 choose=0 data=161
#               167450  f_clk=1 p=        5 choose=0 data=161
#               167500  f_clk=0 p=        5 choose=0 data=161
#               167550  f_clk=1 p=        5 choose=0 data=161
#               167600  f_clk=0 p=        5 choose=0 data=161
#               167650  f_clk=1 p=        5 choose=0 data=161
#               167700  f_clk=0 p=        5 choose=0 data=161
#               167750  f_clk=1 p=        5 choose=0 data=182
#               167800  f_clk=0 p=        5 choose=0 data=182
#               167850  f_clk=1 p=        5 choose=0 data=182
#               167900  f_clk=0 p=        5 choose=0 data=182
#               167950  f_clk=1 p=        5 choose=0 data=182
#               168000  f_clk=0 p=        5 choose=0 data=182
#               168050  f_clk=1 p=        5 choose=0 data=182
#               168100  f_clk=0 p=        5 choose=0 data=182
#               168150  f_clk=1 p=        5 choose=0 data=182
#               168200  f_clk=0 p=        5 choose=0 data=182
#               168250  f_clk=1 p=        5 choose=0 data=182
#               168300  f_clk=0 p=        5 choose=0 data=182
#               168350  f_clk=1 p=        5 choose=0 data=215
#               168400  f_clk=0 p=        5 choose=0 data=215
#               168450  f_clk=1 p=        5 choose=0 data=215
#               168500  f_clk=0 p=        5 choose=0 data=215
#               168550  f_clk=1 p=        5 choose=0 data=215
#               168600  f_clk=0 p=        5 choose=0 data=215
#               168650  f_clk=1 p=        5 choose=0 data=215
#               168700  f_clk=0 p=        5 choose=0 data=215
#               168750  f_clk=1 p=        5 choose=0 data=215
#               168800  f_clk=0 p=        5 choose=0 data=215
#               168850  f_clk=1 p=        5 choose=0 data=215
#               168900  f_clk=0 p=        5 choose=0 data=215
#               168950  f_clk=1 p=        5 choose=0 data=  0
#               169000  f_clk=0 p=        5 choose=0 data=  0
#               169050  f_clk=1 p=        5 choose=0 data=  0
#               169100  f_clk=0 p=        5 choose=0 data=  0
#               169150  f_clk=1 p=        5 choose=0 data=  0
#               169200  f_clk=0 p=        5 choose=0 data=  0
#               169250  f_clk=1 p=        5 choose=0 data=  0
#               169300  f_clk=0 p=        5 choose=0 data=  0
#               169350  f_clk=1 p=        5 choose=0 data=  0
#               169400  f_clk=0 p=        5 choose=0 data=  0
#               169450  f_clk=1 p=        5 choose=0 data=  0
#               169500  f_clk=0 p=        5 choose=0 data=  0
#               169550  f_clk=1 p=        5 choose=0 data=  0
#               169600  f_clk=0 p=        5 choose=0 data=  0
#               169650  f_clk=1 p=        5 choose=0 data=  0
#               169700  f_clk=0 p=        5 choose=0 data=  0
#               169750  f_clk=1 p=        5 choose=0 data=  0
#               169800  f_clk=0 p=        5 choose=0 data=  0
#               169850  f_clk=1 p=        5 choose=0 data=  0
#               169900  f_clk=0 p=        5 choose=0 data=  0
#               169950  f_clk=1 p=        5 choose=0 data=  0
#               170000  f_clk=0 p=        5 choose=0 data=  0
#               170050  f_clk=1 p=        5 choose=0 data=  0
#               170100  f_clk=0 p=        5 choose=0 data=  0
#               170150  f_clk=1 p=        5 choose=0 data= 41
#               170200  f_clk=0 p=        5 choose=0 data= 41
#               170250  f_clk=1 p=        5 choose=0 data= 41
#               170300  f_clk=0 p=        5 choose=0 data= 41
#               170350  f_clk=1 p=        5 choose=0 data= 41
#               170400  f_clk=0 p=        5 choose=0 data= 41
#               170450  f_clk=1 p=        5 choose=0 data= 41
#               170500  f_clk=0 p=        5 choose=0 data= 41
#               170550  f_clk=1 p=        5 choose=0 data= 41
#               170600  f_clk=0 p=        5 choose=0 data= 41
#               170650  f_clk=1 p=        5 choose=0 data= 41
#               170700  f_clk=0 p=        5 choose=0 data= 41
#               170750  f_clk=1 p=        5 choose=0 data= 74
#               170800  f_clk=0 p=        5 choose=0 data= 74
#               170850  f_clk=1 p=        5 choose=0 data= 74
#               170900  f_clk=0 p=        5 choose=0 data= 74
#               170950  f_clk=1 p=        5 choose=0 data= 74
#               171000  f_clk=0 p=        5 choose=0 data= 74
#               171050  f_clk=1 p=        5 choose=0 data= 74
#               171100  f_clk=0 p=        5 choose=0 data= 74
#               171150  f_clk=1 p=        5 choose=0 data= 74
#               171200  f_clk=0 p=        5 choose=0 data= 74
#               171250  f_clk=1 p=        5 choose=0 data= 74
#               171300  f_clk=0 p=        5 choose=0 data= 74
#               171350  f_clk=1 p=        5 choose=0 data= 95
#               171400  f_clk=0 p=        5 choose=0 data= 95
#               171450  f_clk=1 p=        5 choose=0 data= 95
#               171500  f_clk=0 p=        5 choose=0 data= 95
#               171550  f_clk=1 p=        5 choose=0 data= 95
#               171600  f_clk=0 p=        5 choose=0 data= 95
#               171650  f_clk=1 p=        5 choose=0 data= 95
#               171700  f_clk=0 p=        5 choose=0 data= 95
#               171750  f_clk=1 p=        5 choose=0 data= 95
#               171800  f_clk=0 p=        5 choose=0 data= 95
#               171850  f_clk=1 p=        5 choose=0 data= 95
#               171900  f_clk=0 p=        5 choose=0 data= 95
#               171950  f_clk=1 p=        5 choose=0 data= 99
#               172000  f_clk=0 p=        5 choose=0 data= 99
#               172050  f_clk=1 p=        5 choose=0 data= 99
#               172100  f_clk=0 p=        5 choose=0 data= 99
#               172150  f_clk=1 p=        5 choose=0 data= 99
#               172200  f_clk=0 p=        5 choose=0 data= 99
#               172250  f_clk=1 p=        5 choose=0 data= 99
#               172300  f_clk=0 p=        5 choose=0 data= 99
#               172350  f_clk=1 p=        5 choose=0 data= 99
#               172400  f_clk=0 p=        5 choose=0 data= 99
#               172450  f_clk=1 p=        5 choose=0 data= 99
#               172500  f_clk=0 p=        5 choose=0 data= 99
#               172550  f_clk=1 p=        5 choose=0 data= 87
#               172600  f_clk=0 p=        5 choose=0 data= 87
#               172650  f_clk=1 p=        5 choose=0 data= 87
#               172700  f_clk=0 p=        5 choose=0 data= 87
#               172750  f_clk=1 p=        5 choose=0 data= 87
#               172800  f_clk=0 p=        5 choose=0 data= 87
#               172850  f_clk=1 p=        5 choose=0 data= 87
#               172900  f_clk=0 p=        5 choose=0 data= 87
#               172950  f_clk=1 p=        5 choose=0 data= 87
#               173000  f_clk=0 p=        5 choose=0 data= 87
#               173050  f_clk=1 p=        5 choose=0 data= 87
#               173100  f_clk=0 p=        5 choose=0 data= 87
#               173150  f_clk=1 p=        5 choose=0 data= 58
#               173200  f_clk=0 p=        5 choose=0 data= 58
#               173250  f_clk=1 p=        5 choose=0 data= 58
#               173300  f_clk=0 p=        5 choose=0 data= 58
#               173350  f_clk=1 p=        5 choose=0 data= 58
#               173400  f_clk=0 p=        5 choose=0 data= 58
#               173450  f_clk=1 p=        5 choose=0 data= 58
#               173500  f_clk=0 p=        5 choose=0 data= 58
#               173550  f_clk=1 p=        5 choose=0 data= 58
#               173600  f_clk=0 p=        5 choose=0 data= 58
#               173650  f_clk=1 p=        5 choose=0 data= 58
#               173700  f_clk=0 p=        5 choose=0 data= 58
#               173750  f_clk=1 p=        5 choose=0 data= 21
#               173800  f_clk=0 p=        5 choose=0 data= 21
#               173850  f_clk=1 p=        5 choose=0 data= 21
#               173900  f_clk=0 p=        5 choose=0 data= 21
#               173950  f_clk=1 p=        5 choose=0 data= 21
#               174000  f_clk=0 p=        5 choose=0 data= 21
#               174050  f_clk=1 p=        5 choose=0 data= 21
#               174100  f_clk=0 p=        5 choose=0 data= 21
#               174150  f_clk=1 p=        5 choose=0 data= 21
#               174200  f_clk=0 p=        5 choose=0 data= 21
#               174250  f_clk=1 p=        5 choose=0 data= 21
#               174300  f_clk=0 p=        5 choose=0 data= 21
#               174350  f_clk=1 p=        5 choose=0 data=235
#               174400  f_clk=0 p=        5 choose=0 data=235
#               174450  f_clk=1 p=        5 choose=0 data=235
#               174500  f_clk=0 p=        5 choose=0 data=235
#               174550  f_clk=1 p=        5 choose=0 data=235
#               174600  f_clk=0 p=        5 choose=0 data=235
#               174650  f_clk=1 p=        5 choose=0 data=235
#               174700  f_clk=0 p=        5 choose=0 data=235
#               174750  f_clk=1 p=        5 choose=0 data=235
#               174800  f_clk=0 p=        5 choose=0 data=235
#               174850  f_clk=1 p=        5 choose=0 data=235
#               174900  f_clk=0 p=        5 choose=0 data=235
#               174950  f_clk=1 p=        5 choose=0 data=198
#               175000  f_clk=0 p=        5 choose=0 data=198
#               175050  f_clk=1 p=        5 choose=0 data=198
#               175100  f_clk=0 p=        5 choose=0 data=198
#               175150  f_clk=1 p=        5 choose=0 data=198
#               175200  f_clk=0 p=        5 choose=0 data=198
#               175250  f_clk=1 p=        5 choose=0 data=198
#               175300  f_clk=0 p=        5 choose=0 data=198
#               175350  f_clk=1 p=        5 choose=0 data=198
#               175400  f_clk=0 p=        5 choose=0 data=198
#               175450  f_clk=1 p=        5 choose=0 data=198
#               175500  f_clk=0 p=        5 choose=0 data=198
#               175550  f_clk=1 p=        5 choose=0 data=169
#               175600  f_clk=0 p=        5 choose=0 data=169
#               175650  f_clk=1 p=        5 choose=0 data=169
#               175700  f_clk=0 p=        5 choose=0 data=169
#               175750  f_clk=1 p=        5 choose=0 data=169
#               175800  f_clk=0 p=        5 choose=0 data=169
#               175850  f_clk=1 p=        5 choose=0 data=169
#               175900  f_clk=0 p=        5 choose=0 data=169
#               175950  f_clk=1 p=        5 choose=0 data=169
#               176000  f_clk=0 p=        5 choose=0 data=169
#               176050  f_clk=1 p=        5 choose=0 data=169
#               176100  f_clk=0 p=        5 choose=0 data=169
#               176150  f_clk=1 p=        5 choose=0 data=157
#               176200  f_clk=0 p=        5 choose=0 data=157
#               176250  f_clk=1 p=        5 choose=0 data=157
#               176300  f_clk=0 p=        5 choose=0 data=157
#               176350  f_clk=1 p=        5 choose=0 data=157
#               176400  f_clk=0 p=        5 choose=0 data=157
#               176450  f_clk=1 p=        5 choose=0 data=157
#               176500  f_clk=0 p=        5 choose=0 data=157
#               176550  f_clk=1 p=        5 choose=0 data=157
#               176600  f_clk=0 p=        5 choose=0 data=157
#               176650  f_clk=1 p=        5 choose=0 data=157
#               176700  f_clk=0 p=        5 choose=0 data=157
#               176750  f_clk=1 p=        5 choose=0 data=161
#               176800  f_clk=0 p=        5 choose=0 data=161
#               176850  f_clk=1 p=        5 choose=0 data=161
#               176900  f_clk=0 p=        5 choose=0 data=161
#               176950  f_clk=1 p=        5 choose=0 data=161
#               177000  f_clk=0 p=        5 choose=0 data=161
#               177050  f_clk=1 p=        5 choose=0 data=161
#               177100  f_clk=0 p=        5 choose=0 data=161
#               177150  f_clk=1 p=        5 choose=0 data=161
#               177200  f_clk=0 p=        5 choose=0 data=161
#               177250  f_clk=1 p=        5 choose=0 data=161
#               177300  f_clk=0 p=        5 choose=0 data=161
#               177350  f_clk=1 p=        5 choose=0 data=182
#               177400  f_clk=0 p=        5 choose=0 data=182
#               177450  f_clk=1 p=        5 choose=0 data=182
#               177500  f_clk=0 p=        5 choose=0 data=182
#               177550  f_clk=1 p=        5 choose=0 data=182
#               177600  f_clk=0 p=        5 choose=0 data=182
#               177650  f_clk=1 p=        5 choose=0 data=182
#               177700  f_clk=0 p=        5 choose=0 data=182
#               177750  f_clk=1 p=        5 choose=0 data=182
#               177800  f_clk=0 p=        5 choose=0 data=182
#               177850  f_clk=1 p=        5 choose=0 data=182
#               177900  f_clk=0 p=        5 choose=0 data=182
#               177950  f_clk=1 p=        5 choose=0 data=215
#               178000  f_clk=0 p=        5 choose=0 data=215
#               178050  f_clk=1 p=        5 choose=0 data=215
#               178100  f_clk=0 p=        5 choose=0 data=215
#               178150  f_clk=1 p=        5 choose=0 data=215
#               178200  f_clk=0 p=        5 choose=0 data=215
#               178250  f_clk=1 p=        5 choose=0 data=215
#               178300  f_clk=0 p=        5 choose=0 data=215
#               178350  f_clk=1 p=        5 choose=0 data=215
#               178400  f_clk=0 p=        5 choose=0 data=215
#               178450  f_clk=1 p=        5 choose=0 data=215
#               178500  f_clk=0 p=        5 choose=0 data=215
#               178550  f_clk=1 p=        5 choose=0 data=  0
#               178600  f_clk=0 p=        5 choose=0 data=  0
#               178650  f_clk=1 p=        5 choose=0 data=  0
#               178700  f_clk=0 p=        5 choose=0 data=  0
#               178750  f_clk=1 p=        5 choose=0 data=  0
#               178800  f_clk=0 p=        5 choose=0 data=  0
#               178850  f_clk=1 p=        5 choose=0 data=  0
#               178900  f_clk=0 p=        5 choose=0 data=  0
#               178950  f_clk=1 p=        5 choose=0 data=  0
#               179000  f_clk=0 p=        5 choose=0 data=  0
#               179050  f_clk=1 p=        5 choose=0 data=  0
#               179100  f_clk=0 p=        5 choose=0 data=  0
#               179150  f_clk=1 p=        5 choose=0 data=  0
#               179200  f_clk=0 p=        5 choose=0 data=  0
#               179250  f_clk=1 p=        5 choose=0 data=  0
#               179300  f_clk=0 p=        5 choose=0 data=  0
#               179350  f_clk=1 p=        5 choose=0 data=  0
#               179400  f_clk=0 p=        5 choose=0 data=  0
#               179450  f_clk=1 p=        5 choose=0 data=  0
#               179500  f_clk=0 p=        5 choose=0 data=  0
#               179550  f_clk=1 p=        5 choose=0 data=  0
#               179600  f_clk=0 p=        5 choose=0 data=  0
#               179650  f_clk=1 p=        5 choose=0 data=  0
#               179700  f_clk=0 p=        5 choose=0 data=  0
#               179750  f_clk=1 p=        5 choose=0 data= 41
#               179800  f_clk=0 p=        5 choose=0 data= 41
#               179850  f_clk=1 p=        5 choose=0 data= 41
#               179900  f_clk=0 p=        5 choose=0 data= 41
#               179950  f_clk=1 p=        5 choose=0 data= 41
#               180000  f_clk=0 p=        5 choose=1 data=200
#               180050  f_clk=1 p=        5 choose=1 data=200
#               180100  f_clk=0 p=        5 choose=1 data=200
#               180150  f_clk=1 p=        5 choose=1 data=200
#               180200  f_clk=0 p=        5 choose=1 data=200
#               180250  f_clk=1 p=        5 choose=1 data=200
#               180300  f_clk=0 p=        5 choose=1 data=200
#               180350  f_clk=1 p=        5 choose=1 data=200
#               180400  f_clk=0 p=        5 choose=1 data=200
#               180450  f_clk=1 p=        5 choose=1 data=200
#               180500  f_clk=0 p=        5 choose=1 data=200
#               180550  f_clk=1 p=        5 choose=1 data=200
#               180600  f_clk=0 p=        5 choose=1 data=200
#               180650  f_clk=1 p=        5 choose=1 data=200
#               180700  f_clk=0 p=        5 choose=1 data=200
#               180750  f_clk=1 p=        5 choose=1 data=200
#               180800  f_clk=0 p=        5 choose=1 data=200
#               180850  f_clk=1 p=        5 choose=1 data=200
#               180900  f_clk=0 p=        5 choose=1 data=200
#               180950  f_clk=1 p=        5 choose=1 data=200
#               181000  f_clk=0 p=        5 choose=1 data=200
#               181050  f_clk=1 p=        5 choose=1 data=200
#               181100  f_clk=0 p=        5 choose=1 data=200
#               181150  f_clk=1 p=        5 choose=1 data=200
#               181200  f_clk=0 p=        5 choose=1 data=200
#               181250  f_clk=1 p=        5 choose=1 data=200
#               181300  f_clk=0 p=        5 choose=1 data=200
#               181350  f_clk=1 p=        5 choose=1 data=200
#               181400  f_clk=0 p=        5 choose=1 data=200
#               181450  f_clk=1 p=        5 choose=1 data=200
#               181500  f_clk=0 p=        5 choose=1 data=200
#               181550  f_clk=1 p=        5 choose=1 data=200
#               181600  f_clk=0 p=        5 choose=1 data=200
#               181650  f_clk=1 p=        5 choose=1 data=200
#               181700  f_clk=0 p=        5 choose=1 data=200
#               181750  f_clk=1 p=        5 choose=1 data=200
#               181800  f_clk=0 p=        5 choose=1 data=200
#               181850  f_clk=1 p=        5 choose=1 data=200
#               181900  f_clk=0 p=        5 choose=1 data=200
#               181950  f_clk=1 p=        5 choose=1 data=200
#               182000  f_clk=0 p=        5 choose=1 data=200
#               182050  f_clk=1 p=        5 choose=1 data=200
#               182100  f_clk=0 p=        5 choose=1 data=200
#               182150  f_clk=1 p=        5 choose=1 data=200
#               182200  f_clk=0 p=        5 choose=1 data=200
#               182250  f_clk=1 p=        5 choose=1 data=200
#               182300  f_clk=0 p=        5 choose=1 data=200
#               182350  f_clk=1 p=        5 choose=1 data=200
#               182400  f_clk=0 p=        5 choose=1 data=200
#               182450  f_clk=1 p=        5 choose=1 data=200
#               182500  f_clk=0 p=        5 choose=1 data=200
#               182550  f_clk=1 p=        5 choose=1 data=200
#               182600  f_clk=0 p=        5 choose=1 data=200
#               182650  f_clk=1 p=        5 choose=1 data=200
#               182700  f_clk=0 p=        5 choose=1 data=200
#               182750  f_clk=1 p=        5 choose=1 data=200
#               182800  f_clk=0 p=        5 choose=1 data=200
#               182850  f_clk=1 p=        5 choose=1 data=200
#               182900  f_clk=0 p=        5 choose=1 data=200
#               182950  f_clk=1 p=        5 choose=1 data=200
#               183000  f_clk=0 p=        5 choose=1 data=200
#               183050  f_clk=1 p=        5 choose=1 data=200
#               183100  f_clk=0 p=        5 choose=1 data=200
#               183150  f_clk=1 p=        5 choose=1 data=200
#               183200  f_clk=0 p=        5 choose=1 data=200
#               183250  f_clk=1 p=        5 choose=1 data=200
#               183300  f_clk=0 p=        5 choose=1 data=200
#               183350  f_clk=1 p=        5 choose=1 data=200
#               183400  f_clk=0 p=        5 choose=1 data=200
#               183450  f_clk=1 p=        5 choose=1 data=200
#               183500  f_clk=0 p=        5 choose=1 data=200
#               183550  f_clk=1 p=        5 choose=1 data=200
#               183600  f_clk=0 p=        5 choose=1 data=200
#               183650  f_clk=1 p=        5 choose=1 data=200
#               183700  f_clk=0 p=        5 choose=1 data=200
#               183750  f_clk=1 p=        5 choose=1 data=200
#               183800  f_clk=0 p=        5 choose=1 data=200
#               183850  f_clk=1 p=        5 choose=1 data=200
#               183900  f_clk=0 p=        5 choose=1 data=200
#               183950  f_clk=1 p=        5 choose=1 data=  0
#               184000  f_clk=0 p=        5 choose=1 data=  0
#               184050  f_clk=1 p=        5 choose=1 data=  0
#               184100  f_clk=0 p=        5 choose=1 data=  0
#               184150  f_clk=1 p=        5 choose=1 data=  0
#               184200  f_clk=0 p=        5 choose=1 data=  0
#               184250  f_clk=1 p=        5 choose=1 data=  0
#               184300  f_clk=0 p=        5 choose=1 data=  0
#               184350  f_clk=1 p=        5 choose=1 data=  0
#               184400  f_clk=0 p=        5 choose=1 data=  0
#               184450  f_clk=1 p=        5 choose=1 data=  0
#               184500  f_clk=0 p=        5 choose=1 data=  0
#               184550  f_clk=1 p=        5 choose=1 data=  0
#               184600  f_clk=0 p=        5 choose=1 data=  0
#               184650  f_clk=1 p=        5 choose=1 data=  0
#               184700  f_clk=0 p=        5 choose=1 data=  0
#               184750  f_clk=1 p=        5 choose=1 data=  0
#               184800  f_clk=0 p=        5 choose=1 data=  0
#               184850  f_clk=1 p=        5 choose=1 data=  0
#               184900  f_clk=0 p=        5 choose=1 data=  0
#               184950  f_clk=1 p=        5 choose=1 data=  0
#               185000  f_clk=0 p=        5 choose=1 data=  0
#               185050  f_clk=1 p=        5 choose=1 data=  0
#               185100  f_clk=0 p=        5 choose=1 data=  0
#               185150  f_clk=1 p=        5 choose=1 data=  0
#               185200  f_clk=0 p=        5 choose=1 data=  0
#               185250  f_clk=1 p=        5 choose=1 data=  0
#               185300  f_clk=0 p=        5 choose=1 data=  0
#               185350  f_clk=1 p=        5 choose=1 data=  0
#               185400  f_clk=0 p=        5 choose=1 data=  0
#               185450  f_clk=1 p=        5 choose=1 data=  0
#               185500  f_clk=0 p=        5 choose=1 data=  0
#               185550  f_clk=1 p=        5 choose=1 data=  0
#               185600  f_clk=0 p=        5 choose=1 data=  0
#               185650  f_clk=1 p=        5 choose=1 data=  0
#               185700  f_clk=0 p=        5 choose=1 data=  0
#               185750  f_clk=1 p=        5 choose=1 data=  0
#               185800  f_clk=0 p=        5 choose=1 data=  0
#               185850  f_clk=1 p=        5 choose=1 data=  0
#               185900  f_clk=0 p=        5 choose=1 data=  0
#               185950  f_clk=1 p=        5 choose=1 data=  0
#               186000  f_clk=0 p=        5 choose=1 data=  0
#               186050  f_clk=1 p=        5 choose=1 data=  0
#               186100  f_clk=0 p=        5 choose=1 data=  0
#               186150  f_clk=1 p=        5 choose=1 data=  0
#               186200  f_clk=0 p=        5 choose=1 data=  0
#               186250  f_clk=1 p=        5 choose=1 data=  0
#               186300  f_clk=0 p=        5 choose=1 data=  0
#               186350  f_clk=1 p=        5 choose=1 data=  0
#               186400  f_clk=0 p=        5 choose=1 data=  0
#               186450  f_clk=1 p=        5 choose=1 data=  0
#               186500  f_clk=0 p=        5 choose=1 data=  0
#               186550  f_clk=1 p=        5 choose=1 data=  0
#               186600  f_clk=0 p=        5 choose=1 data=  0
#               186650  f_clk=1 p=        5 choose=1 data=  0
#               186700  f_clk=0 p=        5 choose=1 data=  0
#               186750  f_clk=1 p=        5 choose=1 data=  0
#               186800  f_clk=0 p=        5 choose=1 data=  0
#               186850  f_clk=1 p=        5 choose=1 data=  0
#               186900  f_clk=0 p=        5 choose=1 data=  0
#               186950  f_clk=1 p=        5 choose=1 data=  0
#               187000  f_clk=0 p=        5 choose=1 data=  0
#               187050  f_clk=1 p=        5 choose=1 data=  0
#               187100  f_clk=0 p=        5 choose=1 data=  0
#               187150  f_clk=1 p=        5 choose=1 data=  0
#               187200  f_clk=0 p=        5 choose=1 data=  0
#               187250  f_clk=1 p=        5 choose=1 data=  0
#               187300  f_clk=0 p=        5 choose=1 data=  0
#               187350  f_clk=1 p=        5 choose=1 data=  0
#               187400  f_clk=0 p=        5 choose=1 data=  0
#               187450  f_clk=1 p=        5 choose=1 data=  0
#               187500  f_clk=0 p=        5 choose=1 data=  0
#               187550  f_clk=1 p=        5 choose=1 data=  0
#               187600  f_clk=0 p=        5 choose=1 data=  0
#               187650  f_clk=1 p=        5 choose=1 data=  0
#               187700  f_clk=0 p=        5 choose=1 data=  0
#               187750  f_clk=1 p=        5 choose=1 data=  0
#               187800  f_clk=0 p=        5 choose=1 data=  0
#               187850  f_clk=1 p=        5 choose=1 data=  0
#               187900  f_clk=0 p=        5 choose=1 data=  0
#               187950  f_clk=1 p=        5 choose=1 data=  0
#               188000  f_clk=0 p=        5 choose=1 data=  0
#               188050  f_clk=1 p=        5 choose=1 data=  0
#               188100  f_clk=0 p=        5 choose=1 data=  0
#               188150  f_clk=1 p=        5 choose=1 data=  0
#               188200  f_clk=0 p=        5 choose=1 data=  0
#               188250  f_clk=1 p=        5 choose=1 data=  0
#               188300  f_clk=0 p=        5 choose=1 data=  0
#               188350  f_clk=1 p=        5 choose=1 data=  0
#               188400  f_clk=0 p=        5 choose=1 data=  0
#               188450  f_clk=1 p=        5 choose=1 data=  0
#               188500  f_clk=0 p=        5 choose=1 data=  0
#               188550  f_clk=1 p=        5 choose=1 data=  0
#               188600  f_clk=0 p=        5 choose=1 data=  0
#               188650  f_clk=1 p=        5 choose=1 data=  0
#               188700  f_clk=0 p=        5 choose=1 data=  0
#               188750  f_clk=1 p=        5 choose=1 data=200
#               188800  f_clk=0 p=        5 choose=1 data=200
#               188850  f_clk=1 p=        5 choose=1 data=200
#               188900  f_clk=0 p=        5 choose=1 data=200
#               188950  f_clk=1 p=        5 choose=1 data=200
#               189000  f_clk=0 p=        5 choose=1 data=200
#               189050  f_clk=1 p=        5 choose=1 data=200
#               189100  f_clk=0 p=        5 choose=1 data=200
#               189150  f_clk=1 p=        5 choose=1 data=200
#               189200  f_clk=0 p=        5 choose=1 data=200
#               189250  f_clk=1 p=        5 choose=1 data=200
#               189300  f_clk=0 p=        5 choose=1 data=200
#               189350  f_clk=1 p=        5 choose=1 data=200
#               189400  f_clk=0 p=        5 choose=1 data=200
#               189450  f_clk=1 p=        5 choose=1 data=200
#               189500  f_clk=0 p=        5 choose=1 data=200
#               189550  f_clk=1 p=        5 choose=1 data=200
#               189600  f_clk=0 p=        5 choose=1 data=200
#               189650  f_clk=1 p=        5 choose=1 data=200
#               189700  f_clk=0 p=        5 choose=1 data=200
#               189750  f_clk=1 p=        5 choose=1 data=200
#               189800  f_clk=0 p=        5 choose=1 data=200
#               189850  f_clk=1 p=        5 choose=1 data=200
#               189900  f_clk=0 p=        5 choose=1 data=200
#               189950  f_clk=1 p=        5 choose=1 data=200
#               190000  f_clk=0 p=        5 choose=1 data=200
#               190050  f_clk=1 p=        5 choose=1 data=200
#               190100  f_clk=0 p=        5 choose=1 data=200
#               190150  f_clk=1 p=        5 choose=1 data=200
#               190200  f_clk=0 p=        5 choose=1 data=200
#               190250  f_clk=1 p=        5 choose=1 data=200
#               190300  f_clk=0 p=        5 choose=1 data=200
#               190350  f_clk=1 p=        5 choose=1 data=200
#               190400  f_clk=0 p=        5 choose=1 data=200
#               190450  f_clk=1 p=        5 choose=1 data=200
#               190500  f_clk=0 p=        5 choose=1 data=200
#               190550  f_clk=1 p=        5 choose=1 data=200
#               190600  f_clk=0 p=        5 choose=1 data=200
#               190650  f_clk=1 p=        5 choose=1 data=200
#               190700  f_clk=0 p=        5 choose=1 data=200
#               190750  f_clk=1 p=        5 choose=1 data=200
#               190800  f_clk=0 p=        5 choose=1 data=200
#               190850  f_clk=1 p=        5 choose=1 data=200
#               190900  f_clk=0 p=        5 choose=1 data=200
#               190950  f_clk=1 p=        5 choose=1 data=200
#               191000  f_clk=0 p=        5 choose=1 data=200
#               191050  f_clk=1 p=        5 choose=1 data=200
#               191100  f_clk=0 p=        5 choose=1 data=200
#               191150  f_clk=1 p=        5 choose=1 data=200
#               191200  f_clk=0 p=        5 choose=1 data=200
#               191250  f_clk=1 p=        5 choose=1 data=200
#               191300  f_clk=0 p=        5 choose=1 data=200
#               191350  f_clk=1 p=        5 choose=1 data=200
#               191400  f_clk=0 p=        5 choose=1 data=200
#               191450  f_clk=1 p=        5 choose=1 data=200
#               191500  f_clk=0 p=        5 choose=1 data=200
#               191550  f_clk=1 p=        5 choose=1 data=200
#               191600  f_clk=0 p=        5 choose=1 data=200
#               191650  f_clk=1 p=        5 choose=1 data=200
#               191700  f_clk=0 p=        5 choose=1 data=200
#               191750  f_clk=1 p=        5 choose=1 data=200
#               191800  f_clk=0 p=        5 choose=1 data=200
#               191850  f_clk=1 p=        5 choose=1 data=200
#               191900  f_clk=0 p=        5 choose=1 data=200
#               191950  f_clk=1 p=        5 choose=1 data=200
#               192000  f_clk=0 p=        5 choose=1 data=200
#               192050  f_clk=1 p=        5 choose=1 data=200
#               192100  f_clk=0 p=        5 choose=1 data=200
#               192150  f_clk=1 p=        5 choose=1 data=200
#               192200  f_clk=0 p=        5 choose=1 data=200
#               192250  f_clk=1 p=        5 choose=1 data=200
#               192300  f_clk=0 p=        5 choose=1 data=200
#               192350  f_clk=1 p=        5 choose=1 data=200
#               192400  f_clk=0 p=        5 choose=1 data=200
#               192450  f_clk=1 p=        5 choose=1 data=200
#               192500  f_clk=0 p=        5 choose=1 data=200
#               192550  f_clk=1 p=        5 choose=1 data=200
#               192600  f_clk=0 p=        5 choose=1 data=200
#               192650  f_clk=1 p=        5 choose=1 data=200
#               192700  f_clk=0 p=        5 choose=1 data=200
#               192750  f_clk=1 p=        5 choose=1 data=200
#               192800  f_clk=0 p=        5 choose=1 data=200
#               192850  f_clk=1 p=        5 choose=1 data=200
#               192900  f_clk=0 p=        5 choose=1 data=200
#               192950  f_clk=1 p=        5 choose=1 data=200
#               193000  f_clk=0 p=        5 choose=1 data=200
#               193050  f_clk=1 p=        5 choose=1 data=200
#               193100  f_clk=0 p=        5 choose=1 data=200
#               193150  f_clk=1 p=        5 choose=1 data=200
#               193200  f_clk=0 p=        5 choose=1 data=200
#               193250  f_clk=1 p=        5 choose=1 data=200
#               193300  f_clk=0 p=        5 choose=1 data=200
#               193350  f_clk=1 p=        5 choose=1 data=200
#               193400  f_clk=0 p=        5 choose=1 data=200
#               193450  f_clk=1 p=        5 choose=1 data=200
#               193500  f_clk=0 p=        5 choose=1 data=200
#               193550  f_clk=1 p=        5 choose=1 data=  0
#               193600  f_clk=0 p=        5 choose=1 data=  0
#               193650  f_clk=1 p=        5 choose=1 data=  0
#               193700  f_clk=0 p=        5 choose=1 data=  0
#               193750  f_clk=1 p=        5 choose=1 data=  0
#               193800  f_clk=0 p=        5 choose=1 data=  0
#               193850  f_clk=1 p=        5 choose=1 data=  0
#               193900  f_clk=0 p=        5 choose=1 data=  0
#               193950  f_clk=1 p=        5 choose=1 data=  0
#               194000  f_clk=0 p=        5 choose=1 data=  0
#               194050  f_clk=1 p=        5 choose=1 data=  0
#               194100  f_clk=0 p=        5 choose=1 data=  0
#               194150  f_clk=1 p=        5 choose=1 data=  0
#               194200  f_clk=0 p=        5 choose=1 data=  0
#               194250  f_clk=1 p=        5 choose=1 data=  0
#               194300  f_clk=0 p=        5 choose=1 data=  0
#               194350  f_clk=1 p=        5 choose=1 data=  0
#               194400  f_clk=0 p=        5 choose=1 data=  0
#               194450  f_clk=1 p=        5 choose=1 data=  0
#               194500  f_clk=0 p=        5 choose=1 data=  0
#               194550  f_clk=1 p=        5 choose=1 data=  0
#               194600  f_clk=0 p=        5 choose=1 data=  0
#               194650  f_clk=1 p=        5 choose=1 data=  0
#               194700  f_clk=0 p=        5 choose=1 data=  0
#               194750  f_clk=1 p=        5 choose=1 data=  0
#               194800  f_clk=0 p=        5 choose=1 data=  0
#               194850  f_clk=1 p=        5 choose=1 data=  0
#               194900  f_clk=0 p=        5 choose=1 data=  0
#               194950  f_clk=1 p=        5 choose=1 data=  0
#               195000  f_clk=0 p=        5 choose=1 data=  0
#               195050  f_clk=1 p=        5 choose=1 data=  0
#               195100  f_clk=0 p=        5 choose=1 data=  0
#               195150  f_clk=1 p=        5 choose=1 data=  0
#               195200  f_clk=0 p=        5 choose=1 data=  0
#               195250  f_clk=1 p=        5 choose=1 data=  0
#               195300  f_clk=0 p=        5 choose=1 data=  0
#               195350  f_clk=1 p=        5 choose=1 data=  0
#               195400  f_clk=0 p=        5 choose=1 data=  0
#               195450  f_clk=1 p=        5 choose=1 data=  0
#               195500  f_clk=0 p=        5 choose=1 data=  0
#               195550  f_clk=1 p=        5 choose=1 data=  0
#               195600  f_clk=0 p=        5 choose=1 data=  0
#               195650  f_clk=1 p=        5 choose=1 data=  0
#               195700  f_clk=0 p=        5 choose=1 data=  0
#               195750  f_clk=1 p=        5 choose=1 data=  0
#               195800  f_clk=0 p=        5 choose=1 data=  0
#               195850  f_clk=1 p=        5 choose=1 data=  0
#               195900  f_clk=0 p=        5 choose=1 data=  0
#               195950  f_clk=1 p=        5 choose=1 data=  0
#               196000  f_clk=0 p=        5 choose=1 data=  0
#               196050  f_clk=1 p=        5 choose=1 data=  0
#               196100  f_clk=0 p=        5 choose=1 data=  0
#               196150  f_clk=1 p=        5 choose=1 data=  0
#               196200  f_clk=0 p=        5 choose=1 data=  0
#               196250  f_clk=1 p=        5 choose=1 data=  0
#               196300  f_clk=0 p=        5 choose=1 data=  0
#               196350  f_clk=1 p=        5 choose=1 data=  0
#               196400  f_clk=0 p=        5 choose=1 data=  0
#               196450  f_clk=1 p=        5 choose=1 data=  0
#               196500  f_clk=0 p=        5 choose=1 data=  0
#               196550  f_clk=1 p=        5 choose=1 data=  0
#               196600  f_clk=0 p=        5 choose=1 data=  0
#               196650  f_clk=1 p=        5 choose=1 data=  0
#               196700  f_clk=0 p=        5 choose=1 data=  0
#               196750  f_clk=1 p=        5 choose=1 data=  0
#               196800  f_clk=0 p=        5 choose=1 data=  0
#               196850  f_clk=1 p=        5 choose=1 data=  0
#               196900  f_clk=0 p=        5 choose=1 data=  0
#               196950  f_clk=1 p=        5 choose=1 data=  0
#               197000  f_clk=0 p=        5 choose=1 data=  0
#               197050  f_clk=1 p=        5 choose=1 data=  0
#               197100  f_clk=0 p=        5 choose=1 data=  0
#               197150  f_clk=1 p=        5 choose=1 data=  0
#               197200  f_clk=0 p=        5 choose=1 data=  0
#               197250  f_clk=1 p=        5 choose=1 data=  0
#               197300  f_clk=0 p=        5 choose=1 data=  0
#               197350  f_clk=1 p=        5 choose=1 data=  0
#               197400  f_clk=0 p=        5 choose=1 data=  0
#               197450  f_clk=1 p=        5 choose=1 data=  0
#               197500  f_clk=0 p=        5 choose=1 data=  0
#               197550  f_clk=1 p=        5 choose=1 data=  0
#               197600  f_clk=0 p=        5 choose=1 data=  0
#               197650  f_clk=1 p=        5 choose=1 data=  0
#               197700  f_clk=0 p=        5 choose=1 data=  0
#               197750  f_clk=1 p=        5 choose=1 data=  0
#               197800  f_clk=0 p=        5 choose=1 data=  0
#               197850  f_clk=1 p=        5 choose=1 data=  0
#               197900  f_clk=0 p=        5 choose=1 data=  0
#               197950  f_clk=1 p=        5 choose=1 data=  0
#               198000  f_clk=0 p=        5 choose=1 data=  0
#               198050  f_clk=1 p=        5 choose=1 data=  0
#               198100  f_clk=0 p=        5 choose=1 data=  0
#               198150  f_clk=1 p=        5 choose=1 data=  0
#               198200  f_clk=0 p=        5 choose=1 data=  0
#               198250  f_clk=1 p=        5 choose=1 data=  0
#               198300  f_clk=0 p=        5 choose=1 data=  0
#               198350  f_clk=1 p=        5 choose=1 data=200
#               198400  f_clk=0 p=        5 choose=1 data=200
#               198450  f_clk=1 p=        5 choose=1 data=200
#               198500  f_clk=0 p=        5 choose=1 data=200
#               198550  f_clk=1 p=        5 choose=1 data=200
#               198600  f_clk=0 p=        5 choose=1 data=200
#               198650  f_clk=1 p=        5 choose=1 data=200
#               198700  f_clk=0 p=        5 choose=1 data=200
#               198750  f_clk=1 p=        5 choose=1 data=200
#               198800  f_clk=0 p=        5 choose=1 data=200
#               198850  f_clk=1 p=        5 choose=1 data=200
#               198900  f_clk=0 p=        5 choose=1 data=200
#               198950  f_clk=1 p=        5 choose=1 data=200
#               199000  f_clk=0 p=        5 choose=1 data=200
#               199050  f_clk=1 p=        5 choose=1 data=200
#               199100  f_clk=0 p=        5 choose=1 data=200
#               199150  f_clk=1 p=        5 choose=1 data=200
#               199200  f_clk=0 p=        5 choose=1 data=200
#               199250  f_clk=1 p=        5 choose=1 data=200
#               199300  f_clk=0 p=        5 choose=1 data=200
#               199350  f_clk=1 p=        5 choose=1 data=200
#               199400  f_clk=0 p=        5 choose=1 data=200
#               199450  f_clk=1 p=        5 choose=1 data=200
#               199500  f_clk=0 p=        5 choose=1 data=200
#               199550  f_clk=1 p=        5 choose=1 data=200
#               199600  f_clk=0 p=        5 choose=1 data=200
#               199650  f_clk=1 p=        5 choose=1 data=200
#               199700  f_clk=0 p=        5 choose=1 data=200
#               199750  f_clk=1 p=        5 choose=1 data=200
#               199800  f_clk=0 p=        5 choose=1 data=200
#               199850  f_clk=1 p=        5 choose=1 data=200
#               199900  f_clk=0 p=        5 choose=1 data=200
#               199950  f_clk=1 p=        5 choose=1 data=200
#               200000  f_clk=0 p=        5 choose=2 data= 10
#               200050  f_clk=1 p=        5 choose=2 data= 10
#               200100  f_clk=0 p=        5 choose=2 data= 10
#               200150  f_clk=1 p=        5 choose=2 data= 15
#               200200  f_clk=0 p=        5 choose=2 data= 15
#               200250  f_clk=1 p=        5 choose=2 data= 15
#               200300  f_clk=0 p=        5 choose=2 data= 15
#               200350  f_clk=1 p=        5 choose=2 data= 15
#               200400  f_clk=0 p=        5 choose=2 data= 15
#               200450  f_clk=1 p=        5 choose=2 data= 15
#               200500  f_clk=0 p=        5 choose=2 data= 15
#               200550  f_clk=1 p=        5 choose=2 data= 15
#               200600  f_clk=0 p=        5 choose=2 data= 15
#               200650  f_clk=1 p=        5 choose=2 data= 15
#               200700  f_clk=0 p=        5 choose=2 data= 15
#               200750  f_clk=1 p=        5 choose=2 data= 20
#               200800  f_clk=0 p=        5 choose=2 data= 20
#               200850  f_clk=1 p=        5 choose=2 data= 20
#               200900  f_clk=0 p=        5 choose=2 data= 20
#               200950  f_clk=1 p=        5 choose=2 data= 20
#               201000  f_clk=0 p=        5 choose=2 data= 20
#               201050  f_clk=1 p=        5 choose=2 data= 20
#               201100  f_clk=0 p=        5 choose=2 data= 20
#               201150  f_clk=1 p=        5 choose=2 data= 20
#               201200  f_clk=0 p=        5 choose=2 data= 20
#               201250  f_clk=1 p=        5 choose=2 data= 20
#               201300  f_clk=0 p=        5 choose=2 data= 20
#               201350  f_clk=1 p=        5 choose=2 data= 25
#               201400  f_clk=0 p=        5 choose=2 data= 25
#               201450  f_clk=1 p=        5 choose=2 data= 25
#               201500  f_clk=0 p=        5 choose=2 data= 25
#               201550  f_clk=1 p=        5 choose=2 data= 25
#               201600  f_clk=0 p=        5 choose=2 data= 25
#               201650  f_clk=1 p=        5 choose=2 data= 25
#               201700  f_clk=0 p=        5 choose=2 data= 25
#               201750  f_clk=1 p=        5 choose=2 data= 25
#               201800  f_clk=0 p=        5 choose=2 data= 25
#               201850  f_clk=1 p=        5 choose=2 data= 25
#               201900  f_clk=0 p=        5 choose=2 data= 25
#               201950  f_clk=1 p=        5 choose=2 data= 30
#               202000  f_clk=0 p=        5 choose=2 data= 30
#               202050  f_clk=1 p=        5 choose=2 data= 30
#               202100  f_clk=0 p=        5 choose=2 data= 30
#               202150  f_clk=1 p=        5 choose=2 data= 30
#               202200  f_clk=0 p=        5 choose=2 data= 30
#               202250  f_clk=1 p=        5 choose=2 data= 30
#               202300  f_clk=0 p=        5 choose=2 data= 30
#               202350  f_clk=1 p=        5 choose=2 data= 30
#               202400  f_clk=0 p=        5 choose=2 data= 30
#               202450  f_clk=1 p=        5 choose=2 data= 30
#               202500  f_clk=0 p=        5 choose=2 data= 30
#               202550  f_clk=1 p=        5 choose=2 data= 35
#               202600  f_clk=0 p=        5 choose=2 data= 35
#               202650  f_clk=1 p=        5 choose=2 data= 35
#               202700  f_clk=0 p=        5 choose=2 data= 35
#               202750  f_clk=1 p=        5 choose=2 data= 35
#               202800  f_clk=0 p=        5 choose=2 data= 35
#               202850  f_clk=1 p=        5 choose=2 data= 35
#               202900  f_clk=0 p=        5 choose=2 data= 35
#               202950  f_clk=1 p=        5 choose=2 data= 35
#               203000  f_clk=0 p=        5 choose=2 data= 35
#               203050  f_clk=1 p=        5 choose=2 data= 35
#               203100  f_clk=0 p=        5 choose=2 data= 35
#               203150  f_clk=1 p=        5 choose=2 data= 40
#               203200  f_clk=0 p=        5 choose=2 data= 40
#               203250  f_clk=1 p=        5 choose=2 data= 40
#               203300  f_clk=0 p=        5 choose=2 data= 40
#               203350  f_clk=1 p=        5 choose=2 data= 40
#               203400  f_clk=0 p=        5 choose=2 data= 40
#               203450  f_clk=1 p=        5 choose=2 data= 40
#               203500  f_clk=0 p=        5 choose=2 data= 40
#               203550  f_clk=1 p=        5 choose=2 data= 40
#               203600  f_clk=0 p=        5 choose=2 data= 40
#               203650  f_clk=1 p=        5 choose=2 data= 40
#               203700  f_clk=0 p=        5 choose=2 data= 40
#               203750  f_clk=1 p=        5 choose=2 data= 45
#               203800  f_clk=0 p=        5 choose=2 data= 45
#               203850  f_clk=1 p=        5 choose=2 data= 45
#               203900  f_clk=0 p=        5 choose=2 data= 45
#               203950  f_clk=1 p=        5 choose=2 data= 45
#               204000  f_clk=0 p=        5 choose=2 data= 45
#               204050  f_clk=1 p=        5 choose=2 data= 45
#               204100  f_clk=0 p=        5 choose=2 data= 45
#               204150  f_clk=1 p=        5 choose=2 data= 45
#               204200  f_clk=0 p=        5 choose=2 data= 45
#               204250  f_clk=1 p=        5 choose=2 data= 45
#               204300  f_clk=0 p=        5 choose=2 data= 45
#               204350  f_clk=1 p=        5 choose=2 data= 50
#               204400  f_clk=0 p=        5 choose=2 data= 50
#               204450  f_clk=1 p=        5 choose=2 data= 50
#               204500  f_clk=0 p=        5 choose=2 data= 50
#               204550  f_clk=1 p=        5 choose=2 data= 50
#               204600  f_clk=0 p=        5 choose=2 data= 50
#               204650  f_clk=1 p=        5 choose=2 data= 50
#               204700  f_clk=0 p=        5 choose=2 data= 50
#               204750  f_clk=1 p=        5 choose=2 data= 50
#               204800  f_clk=0 p=        5 choose=2 data= 50
#               204850  f_clk=1 p=        5 choose=2 data= 50
#               204900  f_clk=0 p=        5 choose=2 data= 50
#               204950  f_clk=1 p=        5 choose=2 data= 55
#               205000  f_clk=0 p=        5 choose=2 data= 55
#               205050  f_clk=1 p=        5 choose=2 data= 55
#               205100  f_clk=0 p=        5 choose=2 data= 55
#               205150  f_clk=1 p=        5 choose=2 data= 55
#               205200  f_clk=0 p=        5 choose=2 data= 55
#               205250  f_clk=1 p=        5 choose=2 data= 55
#               205300  f_clk=0 p=        5 choose=2 data= 55
#               205350  f_clk=1 p=        5 choose=2 data= 55
#               205400  f_clk=0 p=        5 choose=2 data= 55
#               205450  f_clk=1 p=        5 choose=2 data= 55
#               205500  f_clk=0 p=        5 choose=2 data= 55
#               205550  f_clk=1 p=        5 choose=2 data= 60
#               205600  f_clk=0 p=        5 choose=2 data= 60
#               205650  f_clk=1 p=        5 choose=2 data= 60
#               205700  f_clk=0 p=        5 choose=2 data= 60
#               205750  f_clk=1 p=        5 choose=2 data= 60
#               205800  f_clk=0 p=        5 choose=2 data= 60
#               205850  f_clk=1 p=        5 choose=2 data= 60
#               205900  f_clk=0 p=        5 choose=2 data= 60
#               205950  f_clk=1 p=        5 choose=2 data= 60
#               206000  f_clk=0 p=        5 choose=2 data= 60
#               206050  f_clk=1 p=        5 choose=2 data= 60
#               206100  f_clk=0 p=        5 choose=2 data= 60
#               206150  f_clk=1 p=        5 choose=2 data= 65
#               206200  f_clk=0 p=        5 choose=2 data= 65
#               206250  f_clk=1 p=        5 choose=2 data= 65
#               206300  f_clk=0 p=        5 choose=2 data= 65
#               206350  f_clk=1 p=        5 choose=2 data= 65
#               206400  f_clk=0 p=        5 choose=2 data= 65
#               206450  f_clk=1 p=        5 choose=2 data= 65
#               206500  f_clk=0 p=        5 choose=2 data= 65
#               206550  f_clk=1 p=        5 choose=2 data= 65
#               206600  f_clk=0 p=        5 choose=2 data= 65
#               206650  f_clk=1 p=        5 choose=2 data= 65
#               206700  f_clk=0 p=        5 choose=2 data= 65
#               206750  f_clk=1 p=        5 choose=2 data= 70
#               206800  f_clk=0 p=        5 choose=2 data= 70
#               206850  f_clk=1 p=        5 choose=2 data= 70
#               206900  f_clk=0 p=        5 choose=2 data= 70
#               206950  f_clk=1 p=        5 choose=2 data= 70
#               207000  f_clk=0 p=        5 choose=2 data= 70
#               207050  f_clk=1 p=        5 choose=2 data= 70
#               207100  f_clk=0 p=        5 choose=2 data= 70
#               207150  f_clk=1 p=        5 choose=2 data= 70
#               207200  f_clk=0 p=        5 choose=2 data= 70
#               207250  f_clk=1 p=        5 choose=2 data= 70
#               207300  f_clk=0 p=        5 choose=2 data= 70
#               207350  f_clk=1 p=        5 choose=2 data= 75
#               207400  f_clk=0 p=        5 choose=2 data= 75
#               207450  f_clk=1 p=        5 choose=2 data= 75
#               207500  f_clk=0 p=        5 choose=2 data= 75
#               207550  f_clk=1 p=        5 choose=2 data= 75
#               207600  f_clk=0 p=        5 choose=2 data= 75
#               207650  f_clk=1 p=        5 choose=2 data= 75
#               207700  f_clk=0 p=        5 choose=2 data= 75
#               207750  f_clk=1 p=        5 choose=2 data= 75
#               207800  f_clk=0 p=        5 choose=2 data= 75
#               207850  f_clk=1 p=        5 choose=2 data= 75
#               207900  f_clk=0 p=        5 choose=2 data= 75
#               207950  f_clk=1 p=        5 choose=2 data=  0
#               208000  f_clk=0 p=        5 choose=2 data=  0
#               208050  f_clk=1 p=        5 choose=2 data=  0
#               208100  f_clk=0 p=        5 choose=2 data=  0
#               208150  f_clk=1 p=        5 choose=2 data=  0
#               208200  f_clk=0 p=        5 choose=2 data=  0
#               208250  f_clk=1 p=        5 choose=2 data=  0
#               208300  f_clk=0 p=        5 choose=2 data=  0
#               208350  f_clk=1 p=        5 choose=2 data=  0
#               208400  f_clk=0 p=        5 choose=2 data=  0
#               208450  f_clk=1 p=        5 choose=2 data=  0
#               208500  f_clk=0 p=        5 choose=2 data=  0
#               208550  f_clk=1 p=        5 choose=2 data=  5
#               208600  f_clk=0 p=        5 choose=2 data=  5
#               208650  f_clk=1 p=        5 choose=2 data=  5
#               208700  f_clk=0 p=        5 choose=2 data=  5
#               208750  f_clk=1 p=        5 choose=2 data=  5
#               208800  f_clk=0 p=        5 choose=2 data=  5
#               208850  f_clk=1 p=        5 choose=2 data=  5
#               208900  f_clk=0 p=        5 choose=2 data=  5
#               208950  f_clk=1 p=        5 choose=2 data=  5
#               209000  f_clk=0 p=        5 choose=2 data=  5
#               209050  f_clk=1 p=        5 choose=2 data=  5
#               209100  f_clk=0 p=        5 choose=2 data=  5
#               209150  f_clk=1 p=        5 choose=2 data= 10
#               209200  f_clk=0 p=        5 choose=2 data= 10
#               209250  f_clk=1 p=        5 choose=2 data= 10
#               209300  f_clk=0 p=        5 choose=2 data= 10
#               209350  f_clk=1 p=        5 choose=2 data= 10
#               209400  f_clk=0 p=        5 choose=2 data= 10
#               209450  f_clk=1 p=        5 choose=2 data= 10
#               209500  f_clk=0 p=        5 choose=2 data= 10
#               209550  f_clk=1 p=        5 choose=2 data= 10
#               209600  f_clk=0 p=        5 choose=2 data= 10
#               209650  f_clk=1 p=        5 choose=2 data= 10
#               209700  f_clk=0 p=        5 choose=2 data= 10
#               209750  f_clk=1 p=        5 choose=2 data= 15
#               209800  f_clk=0 p=        5 choose=2 data= 15
#               209850  f_clk=1 p=        5 choose=2 data= 15
#               209900  f_clk=0 p=        5 choose=2 data= 15
#               209950  f_clk=1 p=        5 choose=2 data= 15
#               210000  f_clk=0 p=        5 choose=2 data= 15
#               210050  f_clk=1 p=        5 choose=2 data= 15
#               210100  f_clk=0 p=        5 choose=2 data= 15
#               210150  f_clk=1 p=        5 choose=2 data= 15
#               210200  f_clk=0 p=        5 choose=2 data= 15
#               210250  f_clk=1 p=        5 choose=2 data= 15
#               210300  f_clk=0 p=        5 choose=2 data= 15
#               210350  f_clk=1 p=        5 choose=2 data= 20
#               210400  f_clk=0 p=        5 choose=2 data= 20
#               210450  f_clk=1 p=        5 choose=2 data= 20
#               210500  f_clk=0 p=        5 choose=2 data= 20
#               210550  f_clk=1 p=        5 choose=2 data= 20
#               210600  f_clk=0 p=        5 choose=2 data= 20
#               210650  f_clk=1 p=        5 choose=2 data= 20
#               210700  f_clk=0 p=        5 choose=2 data= 20
#               210750  f_clk=1 p=        5 choose=2 data= 20
#               210800  f_clk=0 p=        5 choose=2 data= 20
#               210850  f_clk=1 p=        5 choose=2 data= 20
#               210900  f_clk=0 p=        5 choose=2 data= 20
#               210950  f_clk=1 p=        5 choose=2 data= 25
#               211000  f_clk=0 p=        5 choose=2 data= 25
#               211050  f_clk=1 p=        5 choose=2 data= 25
#               211100  f_clk=0 p=        5 choose=2 data= 25
#               211150  f_clk=1 p=        5 choose=2 data= 25
#               211200  f_clk=0 p=        5 choose=2 data= 25
#               211250  f_clk=1 p=        5 choose=2 data= 25
#               211300  f_clk=0 p=        5 choose=2 data= 25
#               211350  f_clk=1 p=        5 choose=2 data= 25
#               211400  f_clk=0 p=        5 choose=2 data= 25
#               211450  f_clk=1 p=        5 choose=2 data= 25
#               211500  f_clk=0 p=        5 choose=2 data= 25
#               211550  f_clk=1 p=        5 choose=2 data= 30
#               211600  f_clk=0 p=        5 choose=2 data= 30
#               211650  f_clk=1 p=        5 choose=2 data= 30
#               211700  f_clk=0 p=        5 choose=2 data= 30
#               211750  f_clk=1 p=        5 choose=2 data= 30
#               211800  f_clk=0 p=        5 choose=2 data= 30
#               211850  f_clk=1 p=        5 choose=2 data= 30
#               211900  f_clk=0 p=        5 choose=2 data= 30
#               211950  f_clk=1 p=        5 choose=2 data= 30
#               212000  f_clk=0 p=        5 choose=2 data= 30
#               212050  f_clk=1 p=        5 choose=2 data= 30
#               212100  f_clk=0 p=        5 choose=2 data= 30
#               212150  f_clk=1 p=        5 choose=2 data= 35
#               212200  f_clk=0 p=        5 choose=2 data= 35
#               212250  f_clk=1 p=        5 choose=2 data= 35
#               212300  f_clk=0 p=        5 choose=2 data= 35
#               212350  f_clk=1 p=        5 choose=2 data= 35
#               212400  f_clk=0 p=        5 choose=2 data= 35
#               212450  f_clk=1 p=        5 choose=2 data= 35
#               212500  f_clk=0 p=        5 choose=2 data= 35
#               212550  f_clk=1 p=        5 choose=2 data= 35
#               212600  f_clk=0 p=        5 choose=2 data= 35
#               212650  f_clk=1 p=        5 choose=2 data= 35
#               212700  f_clk=0 p=        5 choose=2 data= 35
#               212750  f_clk=1 p=        5 choose=2 data= 40
#               212800  f_clk=0 p=        5 choose=2 data= 40
#               212850  f_clk=1 p=        5 choose=2 data= 40
#               212900  f_clk=0 p=        5 choose=2 data= 40
#               212950  f_clk=1 p=        5 choose=2 data= 40
#               213000  f_clk=0 p=        5 choose=2 data= 40
#               213050  f_clk=1 p=        5 choose=2 data= 40
#               213100  f_clk=0 p=        5 choose=2 data= 40
#               213150  f_clk=1 p=        5 choose=2 data= 40
#               213200  f_clk=0 p=        5 choose=2 data= 40
#               213250  f_clk=1 p=        5 choose=2 data= 40
#               213300  f_clk=0 p=        5 choose=2 data= 40
#               213350  f_clk=1 p=        5 choose=2 data= 45
#               213400  f_clk=0 p=        5 choose=2 data= 45
#               213450  f_clk=1 p=        5 choose=2 data= 45
#               213500  f_clk=0 p=        5 choose=2 data= 45
#               213550  f_clk=1 p=        5 choose=2 data= 45
#               213600  f_clk=0 p=        5 choose=2 data= 45
#               213650  f_clk=1 p=        5 choose=2 data= 45
#               213700  f_clk=0 p=        5 choose=2 data= 45
#               213750  f_clk=1 p=        5 choose=2 data= 45
#               213800  f_clk=0 p=        5 choose=2 data= 45
#               213850  f_clk=1 p=        5 choose=2 data= 45
#               213900  f_clk=0 p=        5 choose=2 data= 45
#               213950  f_clk=1 p=        5 choose=2 data= 50
#               214000  f_clk=0 p=        5 choose=2 data= 50
#               214050  f_clk=1 p=        5 choose=2 data= 50
#               214100  f_clk=0 p=        5 choose=2 data= 50
#               214150  f_clk=1 p=        5 choose=2 data= 50
#               214200  f_clk=0 p=        5 choose=2 data= 50
#               214250  f_clk=1 p=        5 choose=2 data= 50
#               214300  f_clk=0 p=        5 choose=2 data= 50
#               214350  f_clk=1 p=        5 choose=2 data= 50
#               214400  f_clk=0 p=        5 choose=2 data= 50
#               214450  f_clk=1 p=        5 choose=2 data= 50
#               214500  f_clk=0 p=        5 choose=2 data= 50
#               214550  f_clk=1 p=        5 choose=2 data= 55
#               214600  f_clk=0 p=        5 choose=2 data= 55
#               214650  f_clk=1 p=        5 choose=2 data= 55
#               214700  f_clk=0 p=        5 choose=2 data= 55
#               214750  f_clk=1 p=        5 choose=2 data= 55
#               214800  f_clk=0 p=        5 choose=2 data= 55
#               214850  f_clk=1 p=        5 choose=2 data= 55
#               214900  f_clk=0 p=        5 choose=2 data= 55
#               214950  f_clk=1 p=        5 choose=2 data= 55
#               215000  f_clk=0 p=        5 choose=2 data= 55
#               215050  f_clk=1 p=        5 choose=2 data= 55
#               215100  f_clk=0 p=        5 choose=2 data= 55
#               215150  f_clk=1 p=        5 choose=2 data= 60
#               215200  f_clk=0 p=        5 choose=2 data= 60
#               215250  f_clk=1 p=        5 choose=2 data= 60
#               215300  f_clk=0 p=        5 choose=2 data= 60
#               215350  f_clk=1 p=        5 choose=2 data= 60
#               215400  f_clk=0 p=        5 choose=2 data= 60
#               215450  f_clk=1 p=        5 choose=2 data= 60
#               215500  f_clk=0 p=        5 choose=2 data= 60
#               215550  f_clk=1 p=        5 choose=2 data= 60
#               215600  f_clk=0 p=        5 choose=2 data= 60
#               215650  f_clk=1 p=        5 choose=2 data= 60
#               215700  f_clk=0 p=        5 choose=2 data= 60
#               215750  f_clk=1 p=        5 choose=2 data= 65
#               215800  f_clk=0 p=        5 choose=2 data= 65
#               215850  f_clk=1 p=        5 choose=2 data= 65
#               215900  f_clk=0 p=        5 choose=2 data= 65
#               215950  f_clk=1 p=        5 choose=2 data= 65
#               216000  f_clk=0 p=        5 choose=2 data= 65
#               216050  f_clk=1 p=        5 choose=2 data= 65
#               216100  f_clk=0 p=        5 choose=2 data= 65
#               216150  f_clk=1 p=        5 choose=2 data= 65
#               216200  f_clk=0 p=        5 choose=2 data= 65
#               216250  f_clk=1 p=        5 choose=2 data= 65
#               216300  f_clk=0 p=        5 choose=2 data= 65
#               216350  f_clk=1 p=        5 choose=2 data= 70
#               216400  f_clk=0 p=        5 choose=2 data= 70
#               216450  f_clk=1 p=        5 choose=2 data= 70
#               216500  f_clk=0 p=        5 choose=2 data= 70
#               216550  f_clk=1 p=        5 choose=2 data= 70
#               216600  f_clk=0 p=        5 choose=2 data= 70
#               216650  f_clk=1 p=        5 choose=2 data= 70
#               216700  f_clk=0 p=        5 choose=2 data= 70
#               216750  f_clk=1 p=        5 choose=2 data= 70
#               216800  f_clk=0 p=        5 choose=2 data= 70
#               216850  f_clk=1 p=        5 choose=2 data= 70
#               216900  f_clk=0 p=        5 choose=2 data= 70
#               216950  f_clk=1 p=        5 choose=2 data= 75
#               217000  f_clk=0 p=        5 choose=2 data= 75
#               217050  f_clk=1 p=        5 choose=2 data= 75
#               217100  f_clk=0 p=        5 choose=2 data= 75
#               217150  f_clk=1 p=        5 choose=2 data= 75
#               217200  f_clk=0 p=        5 choose=2 data= 75
#               217250  f_clk=1 p=        5 choose=2 data= 75
#               217300  f_clk=0 p=        5 choose=2 data= 75
#               217350  f_clk=1 p=        5 choose=2 data= 75
#               217400  f_clk=0 p=        5 choose=2 data= 75
#               217450  f_clk=1 p=        5 choose=2 data= 75
#               217500  f_clk=0 p=        5 choose=2 data= 75
#               217550  f_clk=1 p=        5 choose=2 data=  0
#               217600  f_clk=0 p=        5 choose=2 data=  0
#               217650  f_clk=1 p=        5 choose=2 data=  0
#               217700  f_clk=0 p=        5 choose=2 data=  0
#               217750  f_clk=1 p=        5 choose=2 data=  0
#               217800  f_clk=0 p=        5 choose=2 data=  0
#               217850  f_clk=1 p=        5 choose=2 data=  0
#               217900  f_clk=0 p=        5 choose=2 data=  0
#               217950  f_clk=1 p=        5 choose=2 data=  0
#               218000  f_clk=0 p=        5 choose=2 data=  0
#               218050  f_clk=1 p=        5 choose=2 data=  0
#               218100  f_clk=0 p=        5 choose=2 data=  0
#               218150  f_clk=1 p=        5 choose=2 data=  5
#               218200  f_clk=0 p=        5 choose=2 data=  5
#               218250  f_clk=1 p=        5 choose=2 data=  5
#               218300  f_clk=0 p=        5 choose=2 data=  5
#               218350  f_clk=1 p=        5 choose=2 data=  5
#               218400  f_clk=0 p=        5 choose=2 data=  5
#               218450  f_clk=1 p=        5 choose=2 data=  5
#               218500  f_clk=0 p=        5 choose=2 data=  5
#               218550  f_clk=1 p=        5 choose=2 data=  5
#               218600  f_clk=0 p=        5 choose=2 data=  5
#               218650  f_clk=1 p=        5 choose=2 data=  5
#               218700  f_clk=0 p=        5 choose=2 data=  5
#               218750  f_clk=1 p=        5 choose=2 data= 10
#               218800  f_clk=0 p=        5 choose=2 data= 10
#               218850  f_clk=1 p=        5 choose=2 data= 10
#               218900  f_clk=0 p=        5 choose=2 data= 10
#               218950  f_clk=1 p=        5 choose=2 data= 10
#               219000  f_clk=0 p=        5 choose=2 data= 10
#               219050  f_clk=1 p=        5 choose=2 data= 10
#               219100  f_clk=0 p=        5 choose=2 data= 10
#               219150  f_clk=1 p=        5 choose=2 data= 10
#               219200  f_clk=0 p=        5 choose=2 data= 10
#               219250  f_clk=1 p=        5 choose=2 data= 10
#               219300  f_clk=0 p=        5 choose=2 data= 10
#               219350  f_clk=1 p=        5 choose=2 data= 15
#               219400  f_clk=0 p=        5 choose=2 data= 15
#               219450  f_clk=1 p=        5 choose=2 data= 15
#               219500  f_clk=0 p=        5 choose=2 data= 15
#               219550  f_clk=1 p=        5 choose=2 data= 15
#               219600  f_clk=0 p=        5 choose=2 data= 15
#               219650  f_clk=1 p=        5 choose=2 data= 15
#               219700  f_clk=0 p=        5 choose=2 data= 15
#               219750  f_clk=1 p=        5 choose=2 data= 15
#               219800  f_clk=0 p=        5 choose=2 data= 15
#               219850  f_clk=1 p=        5 choose=2 data= 15
#               219900  f_clk=0 p=        5 choose=2 data= 15
#               219950  f_clk=1 p=        5 choose=2 data= 20
#               220000  f_clk=0 p=        5 choose=3 data= 55
#               220050  f_clk=1 p=        5 choose=3 data= 55
#               220100  f_clk=0 p=        5 choose=3 data= 55
#               220150  f_clk=1 p=        5 choose=3 data= 55
#               220200  f_clk=0 p=        5 choose=3 data= 55
#               220250  f_clk=1 p=        5 choose=3 data= 55
#               220300  f_clk=0 p=        5 choose=3 data= 55
#               220350  f_clk=1 p=        5 choose=3 data= 55
#               220400  f_clk=0 p=        5 choose=3 data= 55
#               220450  f_clk=1 p=        5 choose=3 data= 55
#               220500  f_clk=0 p=        5 choose=3 data= 55
#               220550  f_clk=1 p=        5 choose=3 data= 50
#               220600  f_clk=0 p=        5 choose=3 data= 50
#               220650  f_clk=1 p=        5 choose=3 data= 50
#               220700  f_clk=0 p=        5 choose=3 data= 50
#               220750  f_clk=1 p=        5 choose=3 data= 50
#               220800  f_clk=0 p=        5 choose=3 data= 50
#               220850  f_clk=1 p=        5 choose=3 data= 50
#               220900  f_clk=0 p=        5 choose=3 data= 50
#               220950  f_clk=1 p=        5 choose=3 data= 50
#               221000  f_clk=0 p=        5 choose=3 data= 50
#               221050  f_clk=1 p=        5 choose=3 data= 50
#               221100  f_clk=0 p=        5 choose=3 data= 50
#               221150  f_clk=1 p=        5 choose=3 data= 45
#               221200  f_clk=0 p=        5 choose=3 data= 45
#               221250  f_clk=1 p=        5 choose=3 data= 45
#               221300  f_clk=0 p=        5 choose=3 data= 45
#               221350  f_clk=1 p=        5 choose=3 data= 45
#               221400  f_clk=0 p=        5 choose=3 data= 45
#               221450  f_clk=1 p=        5 choose=3 data= 45
#               221500  f_clk=0 p=        5 choose=3 data= 45
#               221550  f_clk=1 p=        5 choose=3 data= 45
#               221600  f_clk=0 p=        5 choose=3 data= 45
#               221650  f_clk=1 p=        5 choose=3 data= 45
#               221700  f_clk=0 p=        5 choose=3 data= 45
#               221750  f_clk=1 p=        5 choose=3 data= 40
#               221800  f_clk=0 p=        5 choose=3 data= 40
#               221850  f_clk=1 p=        5 choose=3 data= 40
#               221900  f_clk=0 p=        5 choose=3 data= 40
#               221950  f_clk=1 p=        5 choose=3 data= 40
#               222000  f_clk=0 p=        5 choose=3 data= 40
#               222050  f_clk=1 p=        5 choose=3 data= 40
#               222100  f_clk=0 p=        5 choose=3 data= 40
#               222150  f_clk=1 p=        5 choose=3 data= 40
#               222200  f_clk=0 p=        5 choose=3 data= 40
#               222250  f_clk=1 p=        5 choose=3 data= 40
#               222300  f_clk=0 p=        5 choose=3 data= 40
#               222350  f_clk=1 p=        5 choose=3 data= 35
#               222400  f_clk=0 p=        5 choose=3 data= 35
#               222450  f_clk=1 p=        5 choose=3 data= 35
#               222500  f_clk=0 p=        5 choose=3 data= 35
#               222550  f_clk=1 p=        5 choose=3 data= 35
#               222600  f_clk=0 p=        5 choose=3 data= 35
#               222650  f_clk=1 p=        5 choose=3 data= 35
#               222700  f_clk=0 p=        5 choose=3 data= 35
#               222750  f_clk=1 p=        5 choose=3 data= 35
#               222800  f_clk=0 p=        5 choose=3 data= 35
#               222850  f_clk=1 p=        5 choose=3 data= 35
#               222900  f_clk=0 p=        5 choose=3 data= 35
#               222950  f_clk=1 p=        5 choose=3 data= 30
#               223000  f_clk=0 p=        5 choose=3 data= 30
#               223050  f_clk=1 p=        5 choose=3 data= 30
#               223100  f_clk=0 p=        5 choose=3 data= 30
#               223150  f_clk=1 p=        5 choose=3 data= 30
#               223200  f_clk=0 p=        5 choose=3 data= 30
#               223250  f_clk=1 p=        5 choose=3 data= 30
#               223300  f_clk=0 p=        5 choose=3 data= 30
#               223350  f_clk=1 p=        5 choose=3 data= 30
#               223400  f_clk=0 p=        5 choose=3 data= 30
#               223450  f_clk=1 p=        5 choose=3 data= 30
#               223500  f_clk=0 p=        5 choose=3 data= 30
#               223550  f_clk=1 p=        5 choose=3 data= 25
#               223600  f_clk=0 p=        5 choose=3 data= 25
#               223650  f_clk=1 p=        5 choose=3 data= 25
#               223700  f_clk=0 p=        5 choose=3 data= 25
#               223750  f_clk=1 p=        5 choose=3 data= 25
#               223800  f_clk=0 p=        5 choose=3 data= 25
#               223850  f_clk=1 p=        5 choose=3 data= 25
#               223900  f_clk=0 p=        5 choose=3 data= 25
#               223950  f_clk=1 p=        5 choose=3 data= 25
#               224000  f_clk=0 p=        5 choose=3 data= 25
#               224050  f_clk=1 p=        5 choose=3 data= 25
#               224100  f_clk=0 p=        5 choose=3 data= 25
#               224150  f_clk=1 p=        5 choose=3 data= 20
#               224200  f_clk=0 p=        5 choose=3 data= 20
#               224250  f_clk=1 p=        5 choose=3 data= 20
#               224300  f_clk=0 p=        5 choose=3 data= 20
#               224350  f_clk=1 p=        5 choose=3 data= 20
#               224400  f_clk=0 p=        5 choose=3 data= 20
#               224450  f_clk=1 p=        5 choose=3 data= 20
#               224500  f_clk=0 p=        5 choose=3 data= 20
#               224550  f_clk=1 p=        5 choose=3 data= 20
#               224600  f_clk=0 p=        5 choose=3 data= 20
#               224650  f_clk=1 p=        5 choose=3 data= 20
#               224700  f_clk=0 p=        5 choose=3 data= 20
#               224750  f_clk=1 p=        5 choose=3 data= 15
#               224800  f_clk=0 p=        5 choose=3 data= 15
#               224850  f_clk=1 p=        5 choose=3 data= 15
#               224900  f_clk=0 p=        5 choose=3 data= 15
#               224950  f_clk=1 p=        5 choose=3 data= 15
#               225000  f_clk=0 p=        5 choose=3 data= 15
#               225050  f_clk=1 p=        5 choose=3 data= 15
#               225100  f_clk=0 p=        5 choose=3 data= 15
#               225150  f_clk=1 p=        5 choose=3 data= 15
#               225200  f_clk=0 p=        5 choose=3 data= 15
#               225250  f_clk=1 p=        5 choose=3 data= 15
#               225300  f_clk=0 p=        5 choose=3 data= 15
#               225350  f_clk=1 p=        5 choose=3 data= 10
#               225400  f_clk=0 p=        5 choose=3 data= 10
#               225450  f_clk=1 p=        5 choose=3 data= 10
#               225500  f_clk=0 p=        5 choose=3 data= 10
#               225550  f_clk=1 p=        5 choose=3 data= 10
#               225600  f_clk=0 p=        5 choose=3 data= 10
#               225650  f_clk=1 p=        5 choose=3 data= 10
#               225700  f_clk=0 p=        5 choose=3 data= 10
#               225750  f_clk=1 p=        5 choose=3 data= 10
#               225800  f_clk=0 p=        5 choose=3 data= 10
#               225850  f_clk=1 p=        5 choose=3 data= 10
#               225900  f_clk=0 p=        5 choose=3 data= 10
#               225950  f_clk=1 p=        5 choose=3 data=  5
#               226000  f_clk=0 p=        5 choose=3 data=  5
#               226050  f_clk=1 p=        5 choose=3 data=  5
#               226100  f_clk=0 p=        5 choose=3 data=  5
#               226150  f_clk=1 p=        5 choose=3 data=  5
#               226200  f_clk=0 p=        5 choose=3 data=  5
#               226250  f_clk=1 p=        5 choose=3 data=  5
#               226300  f_clk=0 p=        5 choose=3 data=  5
#               226350  f_clk=1 p=        5 choose=3 data=  5
#               226400  f_clk=0 p=        5 choose=3 data=  5
#               226450  f_clk=1 p=        5 choose=3 data=  5
#               226500  f_clk=0 p=        5 choose=3 data=  5
#               226550  f_clk=1 p=        5 choose=3 data=  0
#               226600  f_clk=0 p=        5 choose=3 data=  0
#               226650  f_clk=1 p=        5 choose=3 data=  0
#               226700  f_clk=0 p=        5 choose=3 data=  0
#               226750  f_clk=1 p=        5 choose=3 data=  0
#               226800  f_clk=0 p=        5 choose=3 data=  0
#               226850  f_clk=1 p=        5 choose=3 data=  0
#               226900  f_clk=0 p=        5 choose=3 data=  0
#               226950  f_clk=1 p=        5 choose=3 data=  0
#               227000  f_clk=0 p=        5 choose=3 data=  0
#               227050  f_clk=1 p=        5 choose=3 data=  0
#               227100  f_clk=0 p=        5 choose=3 data=  0
#               227150  f_clk=1 p=        5 choose=3 data= 75
#               227200  f_clk=0 p=        5 choose=3 data= 75
#               227250  f_clk=1 p=        5 choose=3 data= 75
#               227300  f_clk=0 p=        5 choose=3 data= 75
#               227350  f_clk=1 p=        5 choose=3 data= 75
#               227400  f_clk=0 p=        5 choose=3 data= 75
#               227450  f_clk=1 p=        5 choose=3 data= 75
#               227500  f_clk=0 p=        5 choose=3 data= 75
#               227550  f_clk=1 p=        5 choose=3 data= 75
#               227600  f_clk=0 p=        5 choose=3 data= 75
#               227650  f_clk=1 p=        5 choose=3 data= 75
#               227700  f_clk=0 p=        5 choose=3 data= 75
#               227750  f_clk=1 p=        5 choose=3 data= 70
#               227800  f_clk=0 p=        5 choose=3 data= 70
#               227850  f_clk=1 p=        5 choose=3 data= 70
#               227900  f_clk=0 p=        5 choose=3 data= 70
#               227950  f_clk=1 p=        5 choose=3 data= 70
#               228000  f_clk=0 p=        5 choose=3 data= 70
#               228050  f_clk=1 p=        5 choose=3 data= 70
#               228100  f_clk=0 p=        5 choose=3 data= 70
#               228150  f_clk=1 p=        5 choose=3 data= 70
#               228200  f_clk=0 p=        5 choose=3 data= 70
#               228250  f_clk=1 p=        5 choose=3 data= 70
#               228300  f_clk=0 p=        5 choose=3 data= 70
#               228350  f_clk=1 p=        5 choose=3 data= 65
#               228400  f_clk=0 p=        5 choose=3 data= 65
#               228450  f_clk=1 p=        5 choose=3 data= 65
#               228500  f_clk=0 p=        5 choose=3 data= 65
#               228550  f_clk=1 p=        5 choose=3 data= 65
#               228600  f_clk=0 p=        5 choose=3 data= 65
#               228650  f_clk=1 p=        5 choose=3 data= 65
#               228700  f_clk=0 p=        5 choose=3 data= 65
#               228750  f_clk=1 p=        5 choose=3 data= 65
#               228800  f_clk=0 p=        5 choose=3 data= 65
#               228850  f_clk=1 p=        5 choose=3 data= 65
#               228900  f_clk=0 p=        5 choose=3 data= 65
#               228950  f_clk=1 p=        5 choose=3 data= 60
#               229000  f_clk=0 p=        5 choose=3 data= 60
#               229050  f_clk=1 p=        5 choose=3 data= 60
#               229100  f_clk=0 p=        5 choose=3 data= 60
#               229150  f_clk=1 p=        5 choose=3 data= 60
#               229200  f_clk=0 p=        5 choose=3 data= 60
#               229250  f_clk=1 p=        5 choose=3 data= 60
#               229300  f_clk=0 p=        5 choose=3 data= 60
#               229350  f_clk=1 p=        5 choose=3 data= 60
#               229400  f_clk=0 p=        5 choose=3 data= 60
#               229450  f_clk=1 p=        5 choose=3 data= 60
#               229500  f_clk=0 p=        5 choose=3 data= 60
#               229550  f_clk=1 p=        5 choose=3 data= 55
#               229600  f_clk=0 p=        5 choose=3 data= 55
#               229650  f_clk=1 p=        5 choose=3 data= 55
#               229700  f_clk=0 p=        5 choose=3 data= 55
#               229750  f_clk=1 p=        5 choose=3 data= 55
#               229800  f_clk=0 p=        5 choose=3 data= 55
#               229850  f_clk=1 p=        5 choose=3 data= 55
#               229900  f_clk=0 p=        5 choose=3 data= 55
#               229950  f_clk=1 p=        5 choose=3 data= 55
#               230000  f_clk=0 p=        5 choose=3 data= 55
#               230050  f_clk=1 p=        5 choose=3 data= 55
#               230100  f_clk=0 p=        5 choose=3 data= 55
#               230150  f_clk=1 p=        5 choose=3 data= 50
#               230200  f_clk=0 p=        5 choose=3 data= 50
#               230250  f_clk=1 p=        5 choose=3 data= 50
#               230300  f_clk=0 p=        5 choose=3 data= 50
#               230350  f_clk=1 p=        5 choose=3 data= 50
#               230400  f_clk=0 p=        5 choose=3 data= 50
#               230450  f_clk=1 p=        5 choose=3 data= 50
#               230500  f_clk=0 p=        5 choose=3 data= 50
#               230550  f_clk=1 p=        5 choose=3 data= 50
#               230600  f_clk=0 p=        5 choose=3 data= 50
#               230650  f_clk=1 p=        5 choose=3 data= 50
#               230700  f_clk=0 p=        5 choose=3 data= 50
#               230750  f_clk=1 p=        5 choose=3 data= 45
#               230800  f_clk=0 p=        5 choose=3 data= 45
#               230850  f_clk=1 p=        5 choose=3 data= 45
#               230900  f_clk=0 p=        5 choose=3 data= 45
#               230950  f_clk=1 p=        5 choose=3 data= 45
#               231000  f_clk=0 p=        5 choose=3 data= 45
#               231050  f_clk=1 p=        5 choose=3 data= 45
#               231100  f_clk=0 p=        5 choose=3 data= 45
#               231150  f_clk=1 p=        5 choose=3 data= 45
#               231200  f_clk=0 p=        5 choose=3 data= 45
#               231250  f_clk=1 p=        5 choose=3 data= 45
#               231300  f_clk=0 p=        5 choose=3 data= 45
#               231350  f_clk=1 p=        5 choose=3 data= 40
#               231400  f_clk=0 p=        5 choose=3 data= 40
#               231450  f_clk=1 p=        5 choose=3 data= 40
#               231500  f_clk=0 p=        5 choose=3 data= 40
#               231550  f_clk=1 p=        5 choose=3 data= 40
#               231600  f_clk=0 p=        5 choose=3 data= 40
#               231650  f_clk=1 p=        5 choose=3 data= 40
#               231700  f_clk=0 p=        5 choose=3 data= 40
#               231750  f_clk=1 p=        5 choose=3 data= 40
#               231800  f_clk=0 p=        5 choose=3 data= 40
#               231850  f_clk=1 p=        5 choose=3 data= 40
#               231900  f_clk=0 p=        5 choose=3 data= 40
#               231950  f_clk=1 p=        5 choose=3 data= 35
#               232000  f_clk=0 p=        5 choose=3 data= 35
#               232050  f_clk=1 p=        5 choose=3 data= 35
#               232100  f_clk=0 p=        5 choose=3 data= 35
#               232150  f_clk=1 p=        5 choose=3 data= 35
#               232200  f_clk=0 p=        5 choose=3 data= 35
#               232250  f_clk=1 p=        5 choose=3 data= 35
#               232300  f_clk=0 p=        5 choose=3 data= 35
#               232350  f_clk=1 p=        5 choose=3 data= 35
#               232400  f_clk=0 p=        5 choose=3 data= 35
#               232450  f_clk=1 p=        5 choose=3 data= 35
#               232500  f_clk=0 p=        5 choose=3 data= 35
#               232550  f_clk=1 p=        5 choose=3 data= 30
#               232600  f_clk=0 p=        5 choose=3 data= 30
#               232650  f_clk=1 p=        5 choose=3 data= 30
#               232700  f_clk=0 p=        5 choose=3 data= 30
#               232750  f_clk=1 p=        5 choose=3 data= 30
#               232800  f_clk=0 p=        5 choose=3 data= 30
#               232850  f_clk=1 p=        5 choose=3 data= 30
#               232900  f_clk=0 p=        5 choose=3 data= 30
#               232950  f_clk=1 p=        5 choose=3 data= 30
#               233000  f_clk=0 p=        5 choose=3 data= 30
#               233050  f_clk=1 p=        5 choose=3 data= 30
#               233100  f_clk=0 p=        5 choose=3 data= 30
#               233150  f_clk=1 p=        5 choose=3 data= 25
#               233200  f_clk=0 p=        5 choose=3 data= 25
#               233250  f_clk=1 p=        5 choose=3 data= 25
#               233300  f_clk=0 p=        5 choose=3 data= 25
#               233350  f_clk=1 p=        5 choose=3 data= 25
#               233400  f_clk=0 p=        5 choose=3 data= 25
#               233450  f_clk=1 p=        5 choose=3 data= 25
#               233500  f_clk=0 p=        5 choose=3 data= 25
#               233550  f_clk=1 p=        5 choose=3 data= 25
#               233600  f_clk=0 p=        5 choose=3 data= 25
#               233650  f_clk=1 p=        5 choose=3 data= 25
#               233700  f_clk=0 p=        5 choose=3 data= 25
#               233750  f_clk=1 p=        5 choose=3 data= 20
#               233800  f_clk=0 p=        5 choose=3 data= 20
#               233850  f_clk=1 p=        5 choose=3 data= 20
#               233900  f_clk=0 p=        5 choose=3 data= 20
#               233950  f_clk=1 p=        5 choose=3 data= 20
#               234000  f_clk=0 p=        5 choose=3 data= 20
#               234050  f_clk=1 p=        5 choose=3 data= 20
#               234100  f_clk=0 p=        5 choose=3 data= 20
#               234150  f_clk=1 p=        5 choose=3 data= 20
#               234200  f_clk=0 p=        5 choose=3 data= 20
#               234250  f_clk=1 p=        5 choose=3 data= 20
#               234300  f_clk=0 p=        5 choose=3 data= 20
#               234350  f_clk=1 p=        5 choose=3 data= 15
#               234400  f_clk=0 p=        5 choose=3 data= 15
#               234450  f_clk=1 p=        5 choose=3 data= 15
#               234500  f_clk=0 p=        5 choose=3 data= 15
#               234550  f_clk=1 p=        5 choose=3 data= 15
#               234600  f_clk=0 p=        5 choose=3 data= 15
#               234650  f_clk=1 p=        5 choose=3 data= 15
#               234700  f_clk=0 p=        5 choose=3 data= 15
#               234750  f_clk=1 p=        5 choose=3 data= 15
#               234800  f_clk=0 p=        5 choose=3 data= 15
#               234850  f_clk=1 p=        5 choose=3 data= 15
#               234900  f_clk=0 p=        5 choose=3 data= 15
#               234950  f_clk=1 p=        5 choose=3 data= 10
#               235000  f_clk=0 p=        5 choose=3 data= 10
#               235050  f_clk=1 p=        5 choose=3 data= 10
#               235100  f_clk=0 p=        5 choose=3 data= 10
#               235150  f_clk=1 p=        5 choose=3 data= 10
#               235200  f_clk=0 p=        5 choose=3 data= 10
#               235250  f_clk=1 p=        5 choose=3 data= 10
#               235300  f_clk=0 p=        5 choose=3 data= 10
#               235350  f_clk=1 p=        5 choose=3 data= 10
#               235400  f_clk=0 p=        5 choose=3 data= 10
#               235450  f_clk=1 p=        5 choose=3 data= 10
#               235500  f_clk=0 p=        5 choose=3 data= 10
#               235550  f_clk=1 p=        5 choose=3 data=  5
#               235600  f_clk=0 p=        5 choose=3 data=  5
#               235650  f_clk=1 p=        5 choose=3 data=  5
#               235700  f_clk=0 p=        5 choose=3 data=  5
#               235750  f_clk=1 p=        5 choose=3 data=  5
#               235800  f_clk=0 p=        5 choose=3 data=  5
#               235850  f_clk=1 p=        5 choose=3 data=  5
#               235900  f_clk=0 p=        5 choose=3 data=  5
#               235950  f_clk=1 p=        5 choose=3 data=  5
#               236000  f_clk=0 p=        5 choose=3 data=  5
#               236050  f_clk=1 p=        5 choose=3 data=  5
#               236100  f_clk=0 p=        5 choose=3 data=  5
#               236150  f_clk=1 p=        5 choose=3 data=  0
#               236200  f_clk=0 p=        5 choose=3 data=  0
#               236250  f_clk=1 p=        5 choose=3 data=  0
#               236300  f_clk=0 p=        5 choose=3 data=  0
#               236350  f_clk=1 p=        5 choose=3 data=  0
#               236400  f_clk=0 p=        5 choose=3 data=  0
#               236450  f_clk=1 p=        5 choose=3 data=  0
#               236500  f_clk=0 p=        5 choose=3 data=  0
#               236550  f_clk=1 p=        5 choose=3 data=  0
#               236600  f_clk=0 p=        5 choose=3 data=  0
#               236650  f_clk=1 p=        5 choose=3 data=  0
#               236700  f_clk=0 p=        5 choose=3 data=  0
#               236750  f_clk=1 p=        5 choose=3 data= 75
#               236800  f_clk=0 p=        5 choose=3 data= 75
#               236850  f_clk=1 p=        5 choose=3 data= 75
#               236900  f_clk=0 p=        5 choose=3 data= 75
#               236950  f_clk=1 p=        5 choose=3 data= 75
#               237000  f_clk=0 p=        5 choose=3 data= 75
#               237050  f_clk=1 p=        5 choose=3 data= 75
#               237100  f_clk=0 p=        5 choose=3 data= 75
#               237150  f_clk=1 p=        5 choose=3 data= 75
#               237200  f_clk=0 p=        5 choose=3 data= 75
#               237250  f_clk=1 p=        5 choose=3 data= 75
#               237300  f_clk=0 p=        5 choose=3 data= 75
#               237350  f_clk=1 p=        5 choose=3 data= 70
#               237400  f_clk=0 p=        5 choose=3 data= 70
#               237450  f_clk=1 p=        5 choose=3 data= 70
#               237500  f_clk=0 p=        5 choose=3 data= 70
#               237550  f_clk=1 p=        5 choose=3 data= 70
#               237600  f_clk=0 p=        5 choose=3 data= 70
#               237650  f_clk=1 p=        5 choose=3 data= 70
#               237700  f_clk=0 p=        5 choose=3 data= 70
#               237750  f_clk=1 p=        5 choose=3 data= 70
#               237800  f_clk=0 p=        5 choose=3 data= 70
#               237850  f_clk=1 p=        5 choose=3 data= 70
#               237900  f_clk=0 p=        5 choose=3 data= 70
#               237950  f_clk=1 p=        5 choose=3 data= 65
#               238000  f_clk=0 p=        5 choose=3 data= 65
#               238050  f_clk=1 p=        5 choose=3 data= 65
#               238100  f_clk=0 p=        5 choose=3 data= 65
#               238150  f_clk=1 p=        5 choose=3 data= 65
#               238200  f_clk=0 p=        5 choose=3 data= 65
#               238250  f_clk=1 p=        5 choose=3 data= 65
#               238300  f_clk=0 p=        5 choose=3 data= 65
#               238350  f_clk=1 p=        5 choose=3 data= 65
#               238400  f_clk=0 p=        5 choose=3 data= 65
#               238450  f_clk=1 p=        5 choose=3 data= 65
#               238500  f_clk=0 p=        5 choose=3 data= 65
#               238550  f_clk=1 p=        5 choose=3 data= 60
#               238600  f_clk=0 p=        5 choose=3 data= 60
#               238650  f_clk=1 p=        5 choose=3 data= 60
#               238700  f_clk=0 p=        5 choose=3 data= 60
#               238750  f_clk=1 p=        5 choose=3 data= 60
#               238800  f_clk=0 p=        5 choose=3 data= 60
#               238850  f_clk=1 p=        5 choose=3 data= 60
#               238900  f_clk=0 p=        5 choose=3 data= 60
#               238950  f_clk=1 p=        5 choose=3 data= 60
#               239000  f_clk=0 p=        5 choose=3 data= 60
#               239050  f_clk=1 p=        5 choose=3 data= 60
#               239100  f_clk=0 p=        5 choose=3 data= 60
#               239150  f_clk=1 p=        5 choose=3 data= 55
#               239200  f_clk=0 p=        5 choose=3 data= 55
#               239250  f_clk=1 p=        5 choose=3 data= 55
#               239300  f_clk=0 p=        5 choose=3 data= 55
#               239350  f_clk=1 p=        5 choose=3 data= 55
#               239400  f_clk=0 p=        5 choose=3 data= 55
#               239450  f_clk=1 p=        5 choose=3 data= 55
#               239500  f_clk=0 p=        5 choose=3 data= 55
#               239550  f_clk=1 p=        5 choose=3 data= 55
#               239600  f_clk=0 p=        5 choose=3 data= 55
#               239650  f_clk=1 p=        5 choose=3 data= 55
#               239700  f_clk=0 p=        5 choose=3 data= 55
#               239750  f_clk=1 p=        5 choose=3 data= 50
#               239800  f_clk=0 p=        5 choose=3 data= 50
#               239850  f_clk=1 p=        5 choose=3 data= 50
#               239900  f_clk=0 p=        5 choose=3 data= 50
#               239950  f_clk=1 p=        5 choose=3 data= 50
# ** Note: $finish    : E:/wave producer/wave_producer_tp.v(32)
#    Time: 240 us  Iteration: 0  Instance: /wave_producer_tp
# 1
# Break at E:/wave producer/wave_producer_tp.v line 32
全部文件下载: verilog final.zip (210.71 KB, 下载次数: 39)
参与人数 2黑币 +55 收起 理由
全全权权 + 5 很给力!
收藏收藏2 分享淘帖 顶顶 踩踩
ID:382318 发表于 2019-5-27 19:28 | 只看该作者
没毛病
