查看: 2658|回复: 1
求助:用按键锁定数码管显示重量问题?
ID:45225 发表于 2016-6-11 21:58 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
各位大神!我用STC12LE5A60S2单片机和HX711编写了一个电子秤程序,我想通过一只按键按一次锁定数码管显示的重量,再按一次解除锁定,进入正常显示。我试了下,断开hx711的DOUT或者PD_SCK或者同时断开均可达到目的,但不知C程序如何编写,试了很多方法均不行,敬请个位大神给点思路,谢谢!!下面是程序:请大家帮忙看看!谢谢指教!
#include<reg52.h>
#include<intrins.h>
uint Lheight;
uint compensate;
uchar discode[4]={0,0,0,0};
extern void LedDisplay(void);
sbit P10= P1^0;   //按键
sbit  hx711_dout=P3^6;
sbit  hx711_sck=P3^7;
extern unsigned char discode[4];
uchar  code Dis_7[10]= {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90 };//0,1,2,3,4,5,6,7,8,9
uchar code scan_con[4]= {0xfe,0xfd,0xfb,0xf7 };
unsigned int ReadCount(void);
// 延时 MS
void delay(uint x)
     uchar j;
    while(x--)
     for(j=0;j<125;j++)
//延时 500US
void delay500us(void)
    unsigned char a,b;
     for(b=7l;b>0;b--)
         for(a=2;a>0;a--);
//hx711 us延时
void delay_hx711_us(void)
   _nop_();
   _nop_();
//数码管显示
     uchar k;
    for(k=0;k<4;k++)
         P0=Dis_7[discode[k]];
         P2=scan_con[k];
         delay500us();
         P2=0xff;
// 按钮
void ButtonScan(void)
   if(!P10)
      delay(10);
   if(!P10)
          compensate=ReadCount();//
//读重量值,并A/D转换,返回 (hx711驱动程序)
        unsigned long Count;
        uint ADval;
        uchar i;
        hx711_dout=1;
        delay_hx711_us();
        hx711_sck=0;
        Count=0;
        while(hx711_dout)
        LedDisplay();
        for(i=0;i<24;i++)
                hx711_sck=1;
                Count=Count<<1;
                hx711_sck=0;
                if(hx711_dout)
                   Count++;
          hx711_sck=1;
          delay_hx711_us();
          Count=Count^0x800000;         //第25个脉冲下降沿来时转换数据
          hx711_sck=0;
          ADval=(float)(Count>>8);
          return(ADval);
//分解
void discode0(void)
        discode[0]=Lheight%10;
        discode[1]=(Lheight%100)/10;
        discode[2]=(Lheight%1000)/100;
        discode[3]=(Lheight%10000)/1000;
//读取重量值
void WeighWork(void)
     float Tempheight;
     uint a;
     a=ReadCount();
     if(a<=compensate)
            Lheight=0;             //校0
     else Lheight=a-compensate;
     discode0();                 //调用数值分解函数
     Lheight=discode[3]*1000+discode[2]*100+discode[1]*10+discode[0];
      Tempheight=(float)(Lheight/0.822);
     Lheight=(float)(Tempheight);   // 将Tempheight转浮点型
void main(void)
        P10=1;
        delay(1000);
        compensate=ReadCount()+1;
//                 ReadCount();
                WeighWork();
                LedDisplay();
                ButtonScan();
ID:45225 发表于 2016-6-12 21:27 | 只看该作者
希望能得到大神们的帮助!(问题已解决)
