查看: 2220|回复: 1
数码管定时实验
ID:128301 发表于 2016-6-27 15:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "system.h"
#include "altera_avalon_timer_regs.h"
#include "altera_avalon_pio_regs.h"
#include "alt_types.h"
#include "sys/alt_irq.h"
#include <unistd.h>
alt_u16 flag;    //毫秒定时计数器
alt_u16 second;     //秒计数器
//alt_u8 seg[16] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
alt_u8 seg[16] = {
        63, 6, 91, 79, 102, 109, 125, 7,
        127, 111, 119, 124, 57, 94, 121, 113
    };  // 0,1,2,....9, a, b, c, d, e,f
void delay(alt_u32 cnt);
void seg_dis(alt_u16 dis_num);
//毫秒定时中断函数
static void handle_Timer0_interrupts(void)
   IOWR_ALTERA_AVALON_TIMER_STATUS(TIMER_BASE,0);//清TO标志
    if(flag < 1000) flag =flag+1;
        flag = 0;
        second++;
        if(second==60) second=0;
//主函数
int main (void)
    flag = 0;
    second = 0;
    //IOWR_ALTERA_AVALON_PIO_DATA(LED_PIO_BASE,0x00);     //数码管位选管脚关闭
    //IOWR_ALTERA_AVALON_PIO_DATA(SEGCS4_PIO_BASE,0xf);   //数码管片选管脚关闭
   alt_irq_register(TIMER_IRQ,TIMER_BASE,handle_Timer0_interrupts);   //注册定时器中断函数
   IOWR_ALTERA_AVALON_TIMER_CONTROL(TIMER_BASE,7);     //启动timer允许中断,连续计数
       IOWR_ALTERA_AVALON_PIO_DATA(PIO_HEX0_BASE,seg[(flag%100)/10]);   //数码管位选显示变量second的个位
        //IOWR_ALTERA_AVALON_PIO_DATA(SEGCS4_PIO_BASE,0x7);   //数码管片选个位
        delay(2500);    //delay 5ms
        IOWR_ALTERA_AVALON_PIO_DATA(PIO_HEX1_BASE,seg[(flag%1000)/100]);
        IOWR_ALTERA_AVALON_PIO_DATA(PIO_HEX2_BASE,seg[(second%10)]);
        IOWR_ALTERA_AVALON_PIO_DATA(PIO_HEX3_BASE,seg[(second%100)/10]);
//延时函数(延时时间为(2+2*i)us)
    alt_u32 i =0;
    while(i < cnt)
        i++;
图5 参考程序
6、点击project->build project;
7、点击run->run as->NiosII hardware;观测结果;
ID:234344 发表于 2017-11-6 19:26 | 只看该作者
这是什么机子的?
