查看: 10786|回复: 22
四层电梯模拟程序与配套的proteus8.0的模拟程序
windows平台下的keil开发环境开发的以atmel51单片机开发的四层电梯模拟程序与配套的proteus8.0的模拟程序,编译通过。模拟程序运行无误 。其中包含的资料为 电梯程序c语言和电梯仿真的原理图
单片机源程序:
  1. #include <reg52.h>
  2. #define u8 unsigned char
  3. unsigned char seg_table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x00};
  4. unsigned char run,floor;
  5. bit ud,stop=0;
  6. sbit P06=P0^6;
  7. sbit P07=P0^7;
  8. sbit ulc=P2^0;
  9. sbit dlc=P2^1;
  10. sbit start=P2^2;
  11. sbit alrl=P2^3;
  12. sbit alrb=P2^4;
  13. void input()
  14. {
  15.         run|=((~P0)&0x3f);
  16.         if((P06==0)&&(ud==1))
  17.         run|=0x02;
  18.         if((P06==0)&&(ud==0))
  19.         run|=0x04;
  20.         if((P07==0)&&(ud==1))
  21.         run|=0x08;
  22.         if((P07==0)&&(ud==0))
  23.         run|=0x10;
  24. }
  25. void delay(int j)
  26. {
  27.   int i;
  28.   for(;j>0;j--)
  29.   {
  30.         input();
  31.         for(i=200;i>0;i--)
  32.         {
  33.           if(stop==1)
  34.           break;
  35.         }
  36.         if(stop==1)
  37.         break;
  38.   }
  39. }
  40. void StepMotor(bit a,u8 b)
  41. {
  42.   u8 x=0x80,i;
  43.   if(a==1)
  44.   {
  45.         ulc=0;
  46.         dlc=1;
  47.     for(i=0;i<b;i++)
  48.         {
  49.           if(x==0x10)
  50.             x=0x80;
  51.           else
  52.             x=x/2;
  53.           P3|=(x&0xf0);
  54.           delay(100);
  55.         }
  56.   }
  57.   else
  58.   {
  59.          ulc=1;
  60.          dlc=0;
  61.      for(i=0;i<b;i++)
  62.         {
  63.           if(x==0x80)
  64.             x=0x10;
  65.           else
  66.             x=x*2;
  67.           P3|=(x&0xf0);
  68.           delay(100);
  69.         }
  70.   }
  71. }
  72. void alarm()
  73. {
  74.   alrl=0;
  75.   while(1)
  76.   {
  77.     alrb = ~alrb;
  78.         delay(200);
  79.   }
  80. }
  81. void main()
  82. {
  83.         floor=1;
  84.         P1=seg_table[floor];
  85.         P0=0xff;
  86.         ud=1;
  87.         run=0;
  88.         ulc=1;
  89.         dlc=1;
  90.
  91.         alrl=1;
  92.     alrb=1;
  93.         TCON=0x01; //打开外部中断0,并设置为下降沿触发
  94.         IE=0x81;   //开总中断
  95.         while(1)
  96.         {
  97.              while(start==1)
  98.            {
  99.                   P1=seg_table[10];
  100.                   ulc=1;
  101.           dlc=1;
  102.            }
  103.                 input();
  104.                 switch(floor)
  105.                 {
  106.                   case 1:                                  //1
  107.                   {
  108.                         P1=seg_table[floor];
  109.
  110.                         if((run&0x01)==0x01)
  111.                         {
  112.                           delay(600);
  113.                           run&=0xfe;
  114.                         }
  115.                     if((run&0x3e)!=0)
  116.                         {
  117.                           StepMotor(1,5);
  118.                           floor=2;
  119.                           ud=1;
  120.                         }
  121.                         else
  122.                         {
  123.                           ulc=1;
  124.               dlc=1;
  125.                         }
  126.                   }         break;
  127.                   case 2:
  128.                   {
  129.                         P1=seg_table[floor];
  130.                     if(ud==1)                                 //2上
  131.                         {
  132.                           if((run&0x02)==0x02)
  133.                           {
  134.                             delay(600);
  135.                             run&=0xfd;
  136.                           }
  137.
  138.                       if((run&0x38)!=0)
  139.                           {
  140.                             StepMotor(1,5);
  141.                             floor=3;
  142.                           }
  143.                           else
  144.                           {
  145.                             ud=0;
  146.                                 ulc=1;
  147.                 dlc=1;
  148.                           }
  149.                         }
  150.                         else                                            //2下
  151.                         {
  152.                           if((run&0x04)==0x04)
  153.                           {
  154.                             delay(600);
  155.                             run&=0xfb;
  156.                           }
  157.
  158.                       if((run&0x01)!=0)
  159.                           {
  160.                             StepMotor(0,5);
  161.                             floor=1;
  162.                           }
  163.                           else
  164.                           {
  165.                             ud=1;
  166.                                 ulc=1;
  167.                 dlc=1;
  168.                           }
  169.                         }
  170.
  171.                   }         break;
  172.                   case 3:
  173.                   {
  174.                         P1=seg_table[floor];
  175.                     if(ud==1)                                 //3上
  176.                         {
  177.                           if((run&0x08)==0x08)
  178.                           {
  179.                             delay(600);
  180.                             run&=0xf7;
  181.                           }
  182.
  183.                       if((run&0x20)!=0)
  184.                           {
  185.                             StepMotor(1,5);
  186.                             floor=4;
  187.                           }
  188.                           else
  189.                           {
  190.                             ud=0;
  191.                             ulc=1;
  192.                 dlc=1;
  193.                           }
  194.                         }
  195.                         else                                  //3下
  196.                         {
  197.                           if((run&0x10)==0x10)
  198.                           {
  199.                             delay(600);
  200.                             run&=0xef;
  201.                           }
  202.
  203.                       if((run&0x07)!=0)
  204.                           {
  205.                             StepMotor(0,5);
  206.                             floor=2;
  207.                           }
  208.                           else
  209.                           {
  210.                             ud=1;
  211.                                 ulc=1;
  212.                 dlc=1;
  213.                           }
  214.                         }
  215.                   }        break;
  216.                   case 4:
  217.                   {
  218.                         P1=seg_table[floor];
  219.                         if((run&0x20)==0x20)
  220.                         {
  221.                             delay(600);
  222.                                   run&=0xdf;
  223.                         }
  224.
  225.                     if((run&0x1f)!=0)
  226.                         {
  227.                           StepMotor(0,5);
  228.                           floor=3;
  229.                           ud=0;
  230.                         }
  231.                         else
  232.                         {
  233.                           ulc=1;
  234.               dlc=1;
  235.                         }
  236.                   }
  237.                 }
  238.
  239.                 if(stop==1)
  240.                 {
  241.                   P1=seg_table[10];
  242.                   ulc=1;
  243.           dlc=1;
  244.                   alarm();
  245.                 }
  246.
  247.   }
  248. }
  249. void int0() interrupt 0
  250. {
  251.   stop=1;
  252. }
所有资料打包下载:
四层电梯模拟程序与proteus仿真.rar (106.52 KB, 下载次数: 225)
参与人数 2黑币 +75 收起 理由
lgyandtina + 5 很给力!
admin + 70 共享资料的黑币奖励!
收藏收藏6 分享淘帖 顶顶 踩踩
ID:128380 发表于 2016-11-25 17:52 来自触屏版 | 只看该作者
厉害啊啊啊
ID:153883 发表于 2016-12-11 14:22 来自触屏版 | 只看该作者
(⊙o⊙)(⊙o⊙)(⊙o⊙)
ID:146771 发表于 2017-1-15 22:04 | 只看该作者
能做出了很不容易啊
ID:160725 发表于 2017-1-16 09:21 | 只看该作者
运行错误呀
ID:161203 发表于 2017-1-16 15:06 | 只看该作者
没找到start呢?
ID:200583 发表于 2017-5-14 22:10 | 只看该作者
请问一下,为什么仿真不行啊?
ID:200583 发表于 2017-5-14 22:11 | 只看该作者
lzxdy 发表于 2017-1-16 15:06
没找到start呢?
我也是。。。
ID:204454 发表于 2017-5-24 20:31 | 只看该作者
我下下来的仿真也不能用  按键 没有反应
ID:262082 发表于 2017-12-20 15:37 | 只看该作者
为什么不能仿真
ID:67179 发表于 2017-12-25 10:21 | 只看该作者
谢谢分享!
ID:57831 发表于 2018-3-8 23:20 | 只看该作者
        很给力!
ID:273292 发表于 2018-3-9 08:39 | 只看该作者
不错,很给力,运行不了的可以加我
ID:353754 发表于 2018-6-18 17:11 | 只看该作者
xdl932365660 发表于 2018-3-9 08:39
不错,很给力,运行不了的可以加我
请问怎么运行??
ID:101342 发表于 2018-6-21 01:24 | 只看该作者
谢谢分享,下载来看看
ID:210588 发表于 2018-6-21 08:53 | 只看该作者
坑 !!仿真没有反应
ID:365929 发表于 2018-7-6 09:36 来自触屏版 | 只看该作者
怎么仿真啊?
ID:365929 发表于 2018-7-6 10:31 来自触屏版 | 只看该作者
不错,很给力,运行不了的可以加我
咋运行
ID:397520 发表于 2018-9-13 15:49 | 只看该作者
很给力
ID:383986 发表于 2018-9-14 20:37 | 只看该作者
仿真报错,运行不了
ID:388870 发表于 2018-9-19 09:43 | 只看该作者
谢谢分享!
ID:74293 发表于 2020-3-18 00:06 | 只看该作者
有没有能改5层的???
ID:286327 发表于 2020-5-6 17:33 | 只看该作者
仿真不了兄弟你这/?
