查看: 3086|回复: 2
数码管中断定时0---99
ID:148885 发表于 2016-12-9 21:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
typedef   unsigned char  uchar;
typedef   unsigned int   uint;
uchar  Count,Sec,shift,n;
uchar code  LEDData[ ] = {0xC0,0xF9,0xA4,0xB0,0x99,0x92,
                          0x82,0xF8,0x80,0x90,0xff};
uchar data  display[2];
主函数
main()
   P0 = 0xff;            //端口初始化
   P2 = 0xff;
   Count = 0x00;
   Sec = 0x00;
   n = 0x00;
   shift = 0xfe;         //送位码初值
   TMOD = 0x01;
   TH0 = 0x4c;           //50ms定时
   TL0 = 0x00;
   ET0 = 1;
   T2CON = 0x00;         //设置T2CON寄存器
   TH2 = 0xf8;           //2ms定时
   TL2 = 0xcc;
   ET2 = 1;              //启用Timer2中断
   EA = 1;               //总中断允许
   TR2 = 1;              //启动定时器2
   TR0 = 1;              //启动定时器0
   while(1) ;
  Timer0中断函数 (负责定时)
void Timer0() interrupt 1
   TL0 = 0x00;
   ++Count;                  //中断计数单元加1
   if(Count == 20)           //50ms×20=1s
     Count = 0;              //清中断计数单元
     ++Sec;                  //秒单元加1
     if(Sec == 100)
     Sec = 0;                //清秒单元
  Timer2中断函数 (负责数码管显示)
void  timer2() interrupt 5
   TR2 = 0;
   TF2 = 0;                      //手工清中断标志
   TH2 = 0xf8;                   //2ms定时常数
   TL2 = 0xcc;
   if(n >= 2)                    //两位数码管显示
     n = 0;
     shift = 0x7f;               //送位码初值
     P2 = 0xff;                  //关闭显示
     display[0] = Sec%10;          //个位
     display[1] = Sec/10;          //十位
     P0 = LEDData[display[n++]];   //送段码
     P2 = shift;                   //送位码
     shift = (shift>>1)|0x80;      //调整位码
   TR2 = 1;
ID:150555 发表于 2016-12-9 22:12 | 只看该作者
你想表达什么?
ID:138155 发表于 2016-12-10 08:52 | 只看该作者
没有看明白程序完整吗
