查看: 5148|回复: 3
AVR 单片机初值计算
使用芯片 AT Mega16     外部晶振 4.00MHz
定时器1   (16位定时器)寄存器 TCCR1B = 0x04 设定 256预分频
要利用定时器定时1秒
1,4000000 / 256 = 15625    说明定时器每当 1/15625 秒 就会触发一次中断
2,65535 - 15625 = 49910    计算出要累加多少次才能在1秒后出发定时器1的溢出中断
3,49910 <==> C2 F6           将计算后的值换算成16进制
4, TCNT1H = 0xC2 ;             对寄存器赋值
       TCNT1L = 0xF6 ;
例如用16位定时器TIMER1,4MHZ晶振,256分频,100ms定时,如何求得初值赋给TCNT1?
65536-(4M/256)*0.1=63973.5
其中,4M是晶体频率,0.1是定时时长单位秒。
对于8位的定时器
T=(2^8-计数初值)*晶振周期*分频数=(2^8-计数初值)/晶振频率*分频数
计数初值=2^8-T/晶振周期/分频数=2^8-T*晶振频率/分频数
因为AVR一指令 一周期
收藏收藏3 分享淘帖 顶 踩
来自 4#
ID:690448 发表于 2020-11-19 18:52 | 只看该作者
ICC-AVR application builder  点几下鼠标就可完成
推荐大家试一试
  1. //ICC-AVR application builder : 2020/11/19 18:50:34
  2. // Target : M16
  3. // Crystal: 4.0000Mhz
  4. #include <iom16v.h>
  5. #include <macros.h>
  6. void port_init(void)
  7. {
  8. PORTA = 0x00;
  9. DDRA  = 0x00;
  10. PORTB = 0x00;
  11. DDRB  = 0x00;
  12. PORTC = 0x00; //m103 output only
  13. DDRC  = 0x00;
  14. PORTD = 0x00;
  15. DDRD  = 0x00;
  16. }
  17. //TIMER1 initialize - prescale:256
  18. // WGM: 0) Normal, TOP=0xFFFF
  19. // desired value: 1Sec
  20. // actual value:  1.000Sec (0.0%)
  21. void timer1_init(void)
  22. {
  23. TCCR1B = 0x00; //stop
  24. TCNT1H = 0xC2; //setup
  25. TCNT1L = 0xF7;
  26. OCR1AH = 0x3D;
  27. OCR1AL = 0x09;
  28. OCR1BH = 0x3D;
  29. OCR1BL = 0x09;
  30. ICR1H  = 0x3D;
  31. ICR1L  = 0x09;
  32. TCCR1A = 0x00;
  33. TCCR1B = 0x04; //start Timer
  34. }
  35. #pragma interrupt_handler timer1_ovf_isr:iv_TIM1_OVF
  36. void timer1_ovf_isr(void)
  37. {
  38. //TIMER1 has overflowed
  39. TCNT1H = 0xC2; //reload counter high value
  40. TCNT1L = 0xF7; //reload counter low value
  41. }
  42. //call this routine to initialize all peripherals
  43. void init_devices(void)
  44. {
  45. //stop errant interrupts until set up
  46. CLI(); //disable all interrupts
  47. port_init();
  48. timer1_init();
  49. MCUCR = 0x00;
  50. GICR  = 0x00;
  51. TIMSK = 0x04; //timer interrupt sources
  52. SEI(); //re-enable interrupts
  53. //all peripherals are now initialized
  54. }
  55. //
  56. void main(void)
  57. {
  58. init_devices();
  59. //insert your functional code here...
  60. }
admin + 50 回帖助人的奖励!
ID:739227 发表于 2020-4-27 19:30 | 只看该作者
非常好!不错!非常感谢楼主
ID:808608 发表于 2020-10-10 14:23 | 只看该作者
非常好!不错!非常感谢师傅
