查看: 3950|回复: 0
基于NiosII处理器的sht20温湿度传感器测试
    本次测试所用到的温湿度传感器是盛思锐公司的sht20(IIC通信),可以同时测量温/湿度。详细介绍如下所示:
测试平台:ALINX 开发板AX301    FPGA芯片:Cyclone IV E:EP4CE10F17C8
所使用的软件:Quartus II 13.1 (64-bit);Nios ll-Eclipse 13.1
在这里我就不贴出BSP文件了。
Verilog顶层代码(我所搭建的qsys系统不只是包含sht20模块,还有其他的模块,仅供参考):
module nios2(
        input clk_50M,
        input rst_n,
        input uart_rxd,
        input epcs_flash_data0,
        input pio_key,
        output sdram_clk,
        output [12:0]sdram_addr,
        output [1:0]sdram_ba,
        output sdram_cas_n,
        output sdram_cke,
        output sdram_cs_n,
        output [1:0]sdram_dqm,
        output sdram_ras_n,
        output sdram_we_n,
        output uart_txd,
        output epcs_flash_dclk,
        output epcs_flash_sce,
        output epcs_flash_sdo,
        output [3:0]pio_led,
        output [5:0]sel,
        output [7:0]seg_led,
        output lcd_cs,
        output lcd_rs,
        output lcd_scl,
        output lcd_sda,
        output lcd_rst,
        inout [15:0]sdram_dq,
        inout i2c_scl,
        inout i2c_sda
wire clk_100M;
pll pll_inst (
        .inclk0(clk_50M),
        .c0    (clk_100M),
        .c1          (sdram_clk)
kernel u0 (
    .clk_clk                       (clk_100M),
    .reset_reset_n             (rst_n),
    .epcs_flash_dclk          (epcs_flash_dclk),
    .epcs_flash_sce           (epcs_flash_sce),
    .epcs_flash_sdo           (epcs_flash_sdo),
    .epcs_flash_data0        (epcs_flash_data0),
    .i2c_scl_pad_io            (i2c_scl),
    .i2c_sda_pad_io           (i2c_sda),
    .uart_rxd                     (uart_rxd),
    .uart_txd                     (uart_txd),
    .sdram_addr                (sdram_addr),
    .sdram_ba                   (sdram_ba),
    .sdram_cas_n              (sdram_cas_n),
    .sdram_cke                 (sdram_cke),
    .sdram_cs_n                (sdram_cs_n),
    .sdram_dq                  (sdram_dq),
    .sdram_dqm               (sdram_dqm),
    .sdram_ras_n             (sdram_ras_n),
    .sdram_we_n                (sdram_we_n),
    .pio_led_export                   (pio_led),
    .pio_key_export                   (~pio_key),
    .segled_controller_sel           (sel),
    .segled_controller_seg_led    (seg_led),
    .lcd_cs_export                      (lcd_cs),
    .lcd_rs_export                      (lcd_rs),
    .lcd_scl_export                     (lcd_scl),
    .lcd_sda_export                    (lcd_sda),
    .lcd_rst_export                     (lcd_rst)
endmodule
sht20_test.zip
410.14 KB, 下载次数: 16, 下载积分: 黑币 -5
eclipse的应用程序文件(C语言)
