查看: 2131|回复: 1
请问下我16*16点阵显示一个汉字的程序有问题吗?
ID:710261 发表于 2020-6-26 14:05 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
50黑币
1个74154驱动阴极,2个74595驱动阳级,为什么我仿真出来的“二”这个字的上下两横反复跳?速度一会快一会儿慢程序如下:
#include <reg52.h>
//#include <intrins.h>
sbit DS=P2^4;
sbit SH=P2^5;
sbit ST=P2^6;
sbit A_port=P1^0;
sbit B_port=P1^1;
sbit C_port=P1^2;
sbit D_port=P1^3;
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xF8,0x0F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xC0,0x01,0xFF,0xFF,
*///二
uchar dian_H[]={
0xF8,0xFF,0xFF,0xFF,
0xFF,0xFF,0xC0,0xFF,
0xFF,0xFF,0xFF,0xFF
};//列码高8位
uchar dian_L[]={
0xFF,0xFF,0x01,0xFF,
0xFF,0xFF,0xFF,0xFF
};//列码低8位
/*列选函数*/
void Sendbyte(uint dat1,uint dat2)//dat1为列码低八位,dat2为高八位
        uchar i;
        ST=0;
                        for(i=0;i<8;i++)//将列码低八位发送至595的移位寄存器
                                SH=0;
                                        if(dat1&0x01)
                                                DS=1;
                                                DS=0;//取列码的最低位,若为1则DS输入1,若为0则DS输入0
                                SH=1;
                                dat1=dat1>>1;
                        for(i=0;i<8;i++)//将列码高八位发送至595的移位寄存器
                                SH=0;
                                        if(dat2&0x01)
                                                DS=1;
                                                DS=0;
                                SH=1;
                                dat2=dat2>>1;
        ST=1;
/*行选函数*/
void HX(uchar hang)
        switch (hang)
  case 0:
   D_port = 0; C_port = 0; B_port = 0; A_port = 0;//选第1行
   break;
  case 1:
   D_port = 0; C_port = 0; B_port = 0; A_port = 1;//选第2行
   break;
  case 2:
   D_port = 0; C_port = 0; B_port = 1; A_port = 0;//选第3行
   break;
  case 3:
   D_port = 0; C_port = 0; B_port = 1; A_port = 1;//选第4行
   break;
  case 4:
   D_port = 0; C_port = 1; B_port = 0; A_port = 0;//选第5行
   break;
  case 5:
   D_port = 0; C_port = 1; B_port = 0; A_port = 1;//选第6行
   break;
  case 6:
   D_port = 0; C_port = 1; B_port = 1; A_port = 0;//选第7行
   break;
  case 7:
   D_port = 0; C_port = 1; B_port = 1; A_port = 1;//选第8行
   break;
  case 8:
   D_port = 1; C_port = 0; B_port = 0; A_port = 0;//选第9行
   break;
  case 9:
   D_port = 1; C_port = 0; B_port = 0; A_port = 1;//选第10行
   break;
  case 10:
   D_port = 1; C_port = 0; B_port = 1; A_port = 0;//选第11行
   break;
  case 11:
   D_port = 1; C_port = 0; B_port = 1; A_port = 1;//选第12行
   break;
  case 12:
   D_port = 1; C_port = 1; B_port = 0; A_port = 0;//选第13行
   break;
  case 13:
   D_port = 1; C_port = 1; B_port = 0; A_port = 1;//选第14行
   break;
  case 14:
   D_port = 1; C_port = 1; B_port = 1; A_port = 0;//选第15行
   break;
  case 15:
   D_port = 1; C_port = 1; B_port = 1; A_port = 1;//选第16行
   break;
/*主函数*/
  uchar j;
                for(j=0;j<16;j++)
                        Sendbyte(dian_L[j],dian_H[j]);
                        HX(j);
收藏收藏1 分享淘帖 顶 踩
ID:710261 发表于 2020-6-26 14:33 | 只看该作者
是不是频率的问题啊吗,怎么通过编程设置他动态扫描的频率啊
