查看: 3995|回复: 0
数码管的动态显示
ID:70976 发表于 2014-12-27 13:07 | 显示全部楼层 |阅读模式
/*数码管的动态显示不是那么难,只要屡败屡战就好*/
#include<reg52.h>
#define unit unsigned int
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
uchar code tableduan[]={
0xfe,0xfd,0xfb,
uchar a,b,c;
  TMOD=1;
  TH0=(65536-1000)/256;
  TL0=(65536-1000)%256;
  EA=1;  //开中断
   ET0=1;  //开定时器中断;
  TR0=1;  //开定时器;
  a=0;
  b=0;
  c=0;
     if(a==5)
       a=0;
       P0=tableduan[c];
       c++;
       P2=table[b++];
          if(c==3)
              c=0;
              b=0;
void time_0() interrupt 1
  a++;
