查看: 9050|回复: 4
adc0831模数转换 电路图+51单片机程序
ID:75005 发表于 2015-3-21 16:58 | 显示全部楼层 |阅读模式
补交作业!!!!!
#include <reg52.h>
#include <intrins.h>
sbit ser=P1^0;
sbit sck=P1^1;
sbit rck=P1^2;
sbit lcdrs=P1^4;
sbit lcdrw=P1^5;
sbit lcden=P1^6;
sbit dat=P2^2;
sbit sclk=P2^1;
sbit cs=P2^0;
sbit rled=P2^6;
sbit gled=P2^7;
uchar e,f,g;
void delay(uint a)
        uint x,y;
        for(x=a;x>0;x--)
          for(y=110;y>0;y--);
  unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
void timeinit()
        TMOD=0x21;
        TH1=0XFD;
        TH1=0XFD;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        TR1=1;
        ET0=1;        TR0=1;
uchar adc0831()
        uint i,temp;
            dat=1;
        _nop_();
        _nop_();                sclk=0;
        _nop_();
        _nop_();
        cs=0;
        _nop_();
        _nop_();
        sclk=1;
        _nop_();
        _nop_();
        sclk=0;
        _nop_();
        _nop_();
        sclk=1;
        _nop_();
        _nop_();   sclk=0;
        for(i=0;i<8;i++)
                _nop_();
                _nop_();
                temp=temp<<1;
                if(dat)
                temp=temp|dat;
                sclk=1;
                _nop_();
                _nop_();
                sclk=0;
        cs=1;
        return (temp);
void lcdwrite_com(uchar com)
        lcdrs=0;
        lcdrw=0;
        P0=com;
        delay(15);
        lcden=1;
        delay(15);
        lcden=0;
void lcdwrite_date(uchar date)
        lcdrs=1;
        lcdrw=0;
        P0=date;
        delay(15);
        lcden=1;
        delay(15);
        lcden=0;
void lcd1602_init()
        lcden=0;
        lcdwrite_com(0x38);
        lcdwrite_com(0x0f);
        lcdwrite_com(0x06);
        lcdwrite_com(0x01);
        lcdwrite_com(0x80);
void lcd1602_gd()
        lcdwrite_date(0x30+1);lcdwrite_com(0x80+0x01);lcdwrite_date(':');
        lcdwrite_com(0x80+0x07);lcdwrite_date('v');
        lcdwrite_com(0x80+0x09);
        lcdwrite_date(0x30+2);        lcdwrite_com(0x80+0x0a);lcdwrite_date(':');
        lcdwrite_com(0x80+0x40);
        lcdwrite_date(0x30+3);        lcdwrite_com(0x80+0x41);lcdwrite_date(':');
        lcdwrite_com(0x80+0x49);
        lcdwrite_date(0x30+4);        lcdwrite_com(0x80+0x4a);lcdwrite_date(':');
void lcd1602_ry()
    uint i,ad,jg1,jg2,jg3,jg4;
        ad=adc0831();
//        ad=ad/51*100;
        jg1=ad/51;
        jg2='.';
        jg3=ad%51*10/51;
        jg4=ad%51*10%51*10/51;
        lcdwrite_com(0x80+0x03);
        lcdwrite_date(0x30+jg1);
        lcdwrite_date(jg2);
        lcdwrite_date(0x30+jg3);
        lcdwrite_date(0x30+jg4);
void senddata(uchar a)
        uchar x,i;
        x=a;
        for(i=0;i<8;i++)
                   ser=(bit)(x&0x80);
                x=x<<1;
                sck=0;
                delay(1);
                sck=1;
        rck=0;
        delay(1);
        rck=1;
    timeinit();
        lcd1602_init();
        lcd1602_gd();        //  lcd1602_ry();
          senddata(table[f]);
                if((f%2)==0)
                        rled=1;
                        gled=0;
                        rled=0;
                        gled=1;
          if(f) lcd1602_ry();//while(1);
void time0()interrupt 1
        TL0=(65536-50000)%266;
        e++;  g=!g;
        if(e>=20)
                e=0;
                f++;
                if(f>9)f=0;
ID:157018 发表于 2016-12-22 22:42 | 显示全部楼层
请问 void senddata(uchar a)
这个子函数的作用是什么?
ID:157018 发表于 2016-12-22 22:43 | 显示全部楼层
这个子函数的作用是什么?
这个子函数的作用是什么?
ID:21069 发表于 2018-12-8 20:38 | 显示全部楼层
处理数据用,因为ADC0831给单片机传数据是一个位个位的传,单片机要的是字节数据(8个位),看这里for(i=0;i<8;i++)
                   ser=(bit)(x&0x80);
                x=x<<1;
                sck=0;
                delay(1);
                sck=1;
其中这句是关键 ser=(bit)(x&0x80);有时我们的数据是一个P/I口的一个位在传,有时是整个P/I口I在传
