查看: 4563|回复: 5
stc89c51 `1602液晶 4*4矩阵,电子密码锁,按键没反应
大家好,我毕设做了电子密码锁,都做坏两块板了,但是还没实现功能.
我是照着别人之前做成功的板的做的,程序也是现成的,检查电路好多遍了,是照着焊的,也没短路,但是一通电后,显示屏就显示了图一,按键怎么按都没反应,求各位大神指导啊
ID:79247 发表于 2015-5-7 22:50 | 只看该作者
  1. #include <REG51.h>
  2. #include<intrins.h>
  3. #define LCM_Data  P0
  5. #define uint  unsigned int
  6. #define w 6                                //定义密码位数
  7. sbit lcd1602_rs=P2^7;
  8. sbit lcd1602_rw=P2^6;
  9. sbit lcd1602_en=P2^5;
  10. sbit Scl=P3^4;                        //24C02串行时钟
  11. sbit Sda=P3^5;                        //24C02串行数据
  12. sbit ALAM = P2^1;                //报警
  13. sbit KEY = P3^6;                //开锁
  14. sbit open_led=P2^2;                //开锁指示灯
  15. bit  operation=0;                //操作标志位
  16. bit  pass=0;                        //密码正确标志
  17. bit  ReInputEn=0;                //重置输入充许标志
  18. bit  s3_keydown=0;                //3秒按键标志位
  19. bit  key_disable=0;                //锁定键盘标志
  20. unsigned char countt0,second;        //t0中断计数器,秒计数器
  21. void Delay5Ms(void);
  22. unsigned char code a[]={0xFE,0xFD,0xFB,0xF7};        //控盘扫描控制表
  23. unsigned char code start_line[]        = {"password:       "};
  24. unsigned char code name[]                  = {"===Coded Lock==="};        //显示名称
  25. unsigned char code Correct[]         = {"     correct    "};        //输入正确
  26. unsigned char code Error[]           = {"      error     "};        //输入错误
  27. unsigned char code codepass[]        = {"      pass      "};
  28. unsigned char code LockOpen[]        = {"      open      "};        //OPEN
  29. unsigned char code SetNew[]         = {"SetNewWordEnable"};
  30. unsigned char code Input[]           = {"input:          "};        //INPUT
  31. unsigned char code ResetOK[]         = {"ResetPasswordOK "};
  32. unsigned char code initword[]        = {"Init password..."};
  33. unsigned char code Er_try[]                = {"error,try again!"};
  34. unsigned char code again[]                = {"input again     "};
  35. unsigned char InputData[6];        //输入密码暂存区
  36. unsigned char CurrentPassword[6]={1,3,1,4,2,0};        //当前密码值
  37. unsigned char TempPassword[6];
  38. unsigned char N=0;                                //密码输入位数记数
  39. unsigned char ErrorCont;                        //错误次数计数
  40. unsigned char CorrectCont;                        //正确输入计数
  41. unsigned char ReInputCont;                         //重新输入计数
  42. unsigned char code initpassword[6]={0,0,0,0,0,0};
  43. //=====================5ms延时==============================
  44. void Delay5Ms(void)
  45. {
  46.         unsigned int TempCyc = 5552;
  47.         while(TempCyc--);
  48. }
  49. //===================400ms延时==============================
  50. void Delay400Ms(void)
  51. {
  52. unsigned char TempCycA = 5;
  53. unsigned int TempCycB;
  54. while(TempCycA--)
  55. {
  56.   TempCycB=7269;
  57.   while(TempCycB--);
  58. }
  59. }
  60. //=============================================================================================
  61. //================================24C02========================================================
  62. //=============================================================================================
  63. void mDelay(uint t) //延时
  64. {
  65.         uchar i;
  66.            while(t--)
  67.            {
  68.                    for(i=0;i<125;i++)
  69.                    {;}
  70.            }
  71. }
  72.
  73. void Nop(void)                  //空操作
  74. {
  75.         _nop_();
  76.         _nop_();
  77.         _nop_();
  78.         _nop_();
  79. }
  80. /*起始条件*/
  81. void Start(void)
  82. {
  83.         Sda=1;
  84.         Scl=1;
  85.         Nop();
  86.         Sda=0;
  87.         Nop();
  88. }
  89. /*停止条件*/
  90. void Stop(void)
  91. {
  92.         Sda=0;
  93.         Scl=1;
  94.         Nop();
  95.         Sda=1;
  96.         Nop();
  97. }
  98. /*应答位*/
  99. void Ack(void)
  100. {
  101.         Sda=0;
  102.         Nop();
  103.         Scl=1;
  104.         Nop();
  105.         Scl=0;
  106. }
  107. /*反向应答位*/
  108. void NoAck(void)
  109. {
  110.         Sda=1;
  111.         Nop();
  112.         Scl=1;
  113.         Nop();
  114.         Scl=0;
  115. }
  116. /*发送数据子程序,Data为要求发送的数据*/
  117. void Send(uchar Data)
  118. {
  119.            uchar BitCounter=8;
  120.            uchar temp;
  121.            do
  122.            {
  123.                    temp=Data;
  124.                    Scl=0;
  125.                    Nop();
  126.                    if((temp&0x80)==0x80)
  127.                    Sda=1;
  128.                    else
  129.                    Sda=0;
  130.                    Scl=1;
  131.                    temp=Data<<1;
  132.                    Data=temp;
  133.                    BitCounter--;
  134.            }
  135.            while(BitCounter);
  136.            Scl=0;
  137. }
  138. /*读一字节的数据,并返回该字节值*/
  139. uchar Read(void)
  140. {
  141.     uchar temp=0;
  142.         uchar temp1=0;
  143.         uchar BitCounter=8;
  144.         Sda=1;
  145.         do{
  146.         Scl=0;
  147.         Nop();
  148.         Scl=1;
  149.         Nop();
  150.         if(Sda)
  151.         temp=temp|0x01;
  152.         else
  153.         temp=temp&0xfe;
  154.         if(BitCounter-1)
  155.         {
  156.         temp1=temp<<1;
  157.         temp=temp1;
  158.         }
  159.         BitCounter--;
  160.         }
  161.         while(BitCounter);
  162.         return(temp);
  163.         }
  164. void WrToROM(uchar Data[],uchar Address,uchar Num)
  165. {
  166.   uchar i;
  167.   uchar *PData;
  168.   PData=Data;
  169.   for(i=0;i<Num;i++)
  170.   {
  171.   Start();
  172.   Send(0xa0);
  173.   Ack();
  174.   Send(Address+i);
  175.   Ack();
  176.   Send(*(PData+i));
  177.   Ack();
  178.   Stop();
  179.   mDelay(20);
  180.   }
  181. }
  182. void RdFromROM(uchar Data[],uchar Address,uchar Num)
  183. {
  184.   uchar i;
  185.   uchar *PData;
  186.   PData=Data;
  187.   for(i=0;i<Num;i++)
  188.   {
  189.   Start();
  190.   Send(0xa0);
  191.   Ack();
  192.   Send(Address+i);
  193.   Ack();
  194.   Start();
  195.   Send(0xa1);
  196.   Ack();
  197.   *(PData+i)=Read();
  198.   Scl=0;
  199.   NoAck();
  200.   Stop();
  201.   }
  202. }
  203. //==================================================================================================
  204. //=======================================LCD1602====================================================
  205. //==================================================================================================
  206. #define yi 0x80 //LCD第一行的初始位置,因为LCD1602字符地址首位D7恒定为1(100000000=80)
  207. #define er 0x80+0x40 //LCD第二行初始位置(因为第二行第一个字符位置地址是0x40)
  208. //----------------延时函数,后面经常调用----------------------
  209. void delay(uint xms)//延时函数,有参函数
  210. {
  211.         uint x,y;
  212.         for(x=xms;x>0;x--)
  213.          for(y=110;y>0;y--);
  214. }
  215. //--------------------------写指令---------------------------
  216. write_1602com(uchar com)//****液晶写入指令函数****
  217. {
  218.         lcd1602_rs=0;//数据/指令选择置为指令
  219.         lcd1602_rw=0; //读写选择置为写
  220.         P0=com;//送入数据
  221.         delay(1);
  222.         lcd1602_en=1;//拉高使能端,为制造有效的下降沿做准备
  223.         delay(1);
  224.         lcd1602_en=0;//en由高变低,产生下降沿,液晶执行命令
  225. }
  226. //-------------------------写数据-----------------------------
  227. write_1602dat(uchar dat)//***液晶写入数据函数****
  228. {
  229.         lcd1602_rs=1;//数据/指令选择置为数据
  230.         lcd1602_rw=0; //读写选择置为写
  231.         P0=dat;//送入数据
  232.         delay(1);
  233.         lcd1602_en=1; //en置高电平,为制造下降沿做准备
  234.         delay(1);
  235.         lcd1602_en=0; //en由高变低,产生下降沿,液晶执行命令
  236. }
  237. //-------------------------初始化-------------------------
  238. void lcd_init(void)
  239. {
  240.         write_1602com(0x38);//设置液晶工作模式,意思:16*2行显示,5*7点阵,8位数据
  241.         write_1602com(0x0c);//开显示不显示光标
  242.         write_1602com(0x06);//整屏不移动,光标自动右移
  243.         write_1602com(0x01);//清显示
  244. }
  245. //========================================================================================
  246. //=========================================================================================
  247. //==============将按键值编码为数值=========================
  248. unsigned char coding(unsigned char m)
  249. {
  250.         unsigned char k;
  251.
  252.         switch(m)
  253.         {
  254.                 case (0x11): k=1;break;
  255.                 case (0x21): k=2;break;
  256.                 case (0x41): k=3;break;
  257.                 case (0x81): k='A';break;
  258.                 case (0x12): k=4;break;
  259.                 case (0x22): k=5;break;
  260.                 case (0x42): k=6;break;
  261.                 case (0x82): k='B';break;
  262.                 case (0x14): k=7;break;
  263.                 case (0x24): k=8;break;
  264.                 case (0x44): k=9;break;
  265.                 case (0x84): k='C';break;
  266.                 case (0x18): k='*';break;
  267.                 case (0x28): k=0;break;
  268.                 case (0x48): k='#';break;
  269.                 case (0x88): k='D';break;
  270.         }
  271.         return(k);
  272. }
  273. //=====================按键检测并返回按键值===============================
  274. unsigned char keynum(void)
  275. {
  276.         unsigned char row,col,i;
  277.         P1=0xf0;
  278.         if((P1&0xf0)!=0xf0)
  279.         {
  280.                    Delay5Ms();
  281.         Delay5Ms();
  282.                    if((P1&0xf0)!=0xf0)
  283.                 {
  284.                     row=P1^0xf0;          //确定行线
  285.                         i=0;
  286.                         P1=a[i];                  //精确定位
  287.                         while(i<4)
  288.                         {
  289.                                  if((P1&0xf0)!=0xf0)
  290.                                   {
  291.                                            col=~(P1&0xff);          //确定列线
  292.                                            break;            //已定位后提前退出
  293.                                   }
  294.                                 else
  295.                                   {
  296.                                            i++;
  297.                                            P1=a[i];
  298.                                   }
  299.                         }
  300.                 }
  301.                 else
  302.                 {
  303.                         return 0;
  304.                 }
  305.
  306.                 while((P1&0xf0)!=0xf0);
  307.                 return (row|col);                         //行线与列线组合后返回
  308.         }
  309.         else return 0;                                 //无键按下时返回0
  310. }
  311. //=======================一声提示音,表示有效输入========================
  312. void OneAlam(void)
  313. {
  314.         ALAM=0;
  315.         Delay5Ms();
  316.     ALAM=1;
  317. }
  318. //========================二声提示音,表示操作成功========================
  319. void TwoAlam(void)
  320. {
  321.         ALAM=0;
  322.         Delay5Ms();
  323.     ALAM=1;
  324.     Delay5Ms();
  325.         ALAM=0;
  326.         Delay5Ms();
  327.     ALAM=1;
  328. }
  329. //========================三声提示音,表示错误========================
  330. void ThreeAlam(void)
  331. {
  332.         ALAM=0;
  333.         Delay5Ms();
  334.     ALAM=1;
  335.     Delay5Ms();
  336.         ALAM=0;
  337.         Delay5Ms();
  338.     ALAM=1;
  339.     Delay5Ms();
  340.         ALAM=0;
  341.         Delay5Ms();
  342.     ALAM=1;
  343. }
  344. //=====================显示输入的N个数字,用H代替以便隐藏============================
  345. void DisplayOne(void)
  346. {
  347. //        DisplayOneChar(9+N,1,'*');
  348.         write_1602com(yi+5+N);
  349.         write_1602dat('*');
  350. }
  351. //=======================显示提示输入=========================
  352. void DisplayChar(void)
  353. {
  354.         unsigned char i;
  355.         if(pass==1)
  356.         {
  357.                 //DisplayListChar(0,1,LockOpen);
  358.                 write_1602com(er);
  359.                 for(i=0;i<16;i++)
  360.                 {
  361.                         write_1602dat(LockOpen[i]);
  362.                 }
  363.         }
  364.         else
  365.         {
  366.                 if(N==0)
  367.                 {
  368.                         //DisplayListChar(0,1,Error);
  369.                         write_1602com(er);
  370.                         for(i=0;i<16;i++)
  371.                         {
  372.                                 write_1602dat(Error[i]);
  373.                         }
  374.                 }
  375.                 else
  376.                 {
  377.                         //DisplayListChar(0,1,start_line);
  378.                         write_1602com(er);
  379.                         for(i=0;i<16;i++)
  380.                         {
  381.                                 write_1602dat(start_line[i]);
  382.                         }
  383.                 }
  384.         }
  385. }
  386. void DisplayInput(void)
  387. {
  388.         unsigned char i;
  389.         if(CorrectCont==1)
  390.         {
  391.                 //DisplayListChar(0,0,Input);
  392.                 write_1602com(er);
  393.                 for(i=0;i<16;i++)
  394.                 {
  395.                         write_1602dat(Input[i]);
  396.                 }
  397.         }
  398. }
  399. //========================重置密码==================================================
  400. //==================================================================================
  401. void ResetPassword(void)
  402. {
  403.         unsigned char i;
  404.         unsigned char j;
  405.         if(pass==0)
  406.         {
  407.                 pass=0;
  408.                 DisplayChar();
  409.                 ThreeAlam();
  410.         }
  411.         else
  412.         {
  413.             if(ReInputEn==1)
  414.                 {
  415.                         if(N==6)
  416.                         {
  417.                                 ReInputCont++;
  418.                                 if(ReInputCont==2)
  419.                                 {
  420.                                         for(i=0;i<6;)
  421.                                         {
  422.                                                 if(TempPassword[i]==InputData[i])        //将两次输入的新密码作对比
  423.                                                         i++;
  424.                                                 else
  425.                                                 {
  426.                                                         //DisplayListChar(0,1,Error);
  427.                                                         write_1602com(er);
  428.                                                         for(j=0;j<16;j++)
  429.                                                         {
  430.        write_1602dat(Error[j]);
  431.                                                         }
  432.                                                         ThreeAlam();                        //错误提示
  433.                                                         pass=0;
  434.                                                         ReInputEn=0;                        //关闭重置功能,
  435.                                                         ReInputCont=0;
  436.                                                         DisplayChar();
  437.                                                         break;
  438.                                                 }
  439.                                         }
  440.                                         if(i==6)
  441.                                         {
  442.                                                 //DisplayListChar(0,1,ResetOK);
  443.                                                 write_1602com(er);
  444.                                                 for(j=0;j<16;j++)
  445.                                                 {
  446.                                                         write_1602dat(ResetOK[j]);
  447.                                                 }
  448.                                                 TwoAlam();                                //操作成功提示
  449.                                                  WrToROM(TempPassword,0,6);                //将新密码写入24C02存储
  450.                                                 ReInputEn=0;
  451.                                         }
  452.                                         ReInputCont=0;
  453.                                         CorrectCont=0;
  454.                                 }
  455.                                 else
  456.                                 {
  457.                                         OneAlam();
  458.                                         //DisplayListChar(0, 1, again);                 //显示再次输入一次
  459.                                         write_1602com(er);
  460.                                         for(j=0;j<16;j++)
  461.                                         {
  462.                                                 write_1602dat(again[j]);
  463.                                         }
  464.                                         for(i=0;i<6;i++)
  465.                                         {
  466.                                                 TempPassword[i]=InputData[i];                //将第一次输入的数据暂存起来
  467.                                         }
  468.                                 }
  469.                         N=0;                                                //输入数据位数计数器清零
  470.                    }
  471.             }
  472.         }
  473. }
  474. //=======================输入密码错误超过三过,报警并锁死键盘======================
  475. void Alam_KeyUnable(void)
  476. {
  477.         P1=0x00;
  478.         {
  479.                 ALAM=~ALAM;
  480.                 Delay5Ms();
  481.         }
  482. }
  483. //=======================取消所有操作============================================
  484. void Cancel(void)
  485. {
  486.         unsigned char i;
  487.         unsigned char j;
  488.         //DisplayListChar(0, 1, start_line);
  489.         write_1602com(er);
  490.         for(j=0;j<16;j++)
  491.         {
  492.                 write_1602dat(start_line[j]);
  493.         }
  494.         TwoAlam();                                //提示音
  495.         for(i=0;i<6;i++)
  496.         {
  497.                 InputData[i]=0;
  498.         }
  499.         KEY=1;                                        //关闭锁
  500.         ALAM=1;                                        //报警关
  501.         operation=0;                        //操作标志位清零
  502.         pass=0;                                        //密码正确标志清零
  503.         ReInputEn=0;                        //重置输入充许标志清零
  504.         ErrorCont=0;                        //密码错误输入次数清零
  505.         CorrectCont=0;                        //密码正确输入次数清零
  506.         ReInputCont=0;                        //重置密码输入次数清零
  507.         open_led=1;
  508.         s3_keydown=0;
  509.         key_disable=0;
  510.         N=0;                                        //输入位数计数器清零
  511. }
  512. //==========================确认键,并通过相应标志位执行相应功能===============================
  513. void Ensure(void)
  514. {
  515.         unsigned char i,j;
  516.         RdFromROM(CurrentPassword,0,6);                                         //从24C02里读出存储密码
  517.     if(N==6)
  518.         {
  519.             if(ReInputEn==0)                                                        //重置密码功能未开启
  520.                 {
  521.                         for(i=0;i<6;)
  522.                            {
  523.                                 if(CurrentPassword[i]==InputData[i])
  524.                                 {
  525.                                         i++;
  526.                                 }
  527.                                 else
  528.                                 {
  529.                                         ErrorCont++;
  530.                                         if(ErrorCont==3)                        //错误输入计数达三次时,报警并锁定键盘
  531.                                         {
  532.                                                 write_1602com(er);
  533.                                                 for(i=0;i<16;i++)
  534.                                                 {
  535.                                                         write_1602dat(Error[i]);
  536.                                                 }
  537.                                                 do
  538.                                                 Alam_KeyUnable();
  539.                                                 while(1);
  540.                                         }
  541.                                         else
  542.                                         {
  543.                                                 TR0=1;                                //开启定时
  544.                                                 key_disable=1;                        //锁定键盘
  545.                                                 pass=0;
  546.                                                 break;
  547.                                         }
  548.                                 }
  549.                         }
  550.                         if(i==6)
  551.                         {
  552.                                 CorrectCont++;
  553.                                 if(CorrectCont==1)                                //正确输入计数,当只有一次正确输入时,开锁,
  554.                                 {
  555.                                         //DisplayListChar(0,1,LockOpen);
  556.                                         write_1602com(er);
  557.                                         for(j=0;j<16;j++)
  558.                                         {
  559.                                                 write_1602dat(LockOpen[j]);
  560.                                         }
  561.                                         TwoAlam();                        //操作成功提示音
  562.                                         KEY=0;        //开锁
  563.                                         pass=1;        //置正确标志位
  564.                                         TR0=1;        //开启定时
  565.                                         open_led=0;        //开锁指示灯亮
  566.                                         for(j=0;j<6;j++)        //将输入清除
  567.                                         {
  568.                                                 InputData[i]=0;
  569.                                         }
  570.                                 }
  571.                                 else        //当两次正确输入时,开启重置密码功能
  572.                                 {
  573.                                         //DisplayListChar(0,1,SetNew);
  574.                                         write_1602com(er);
  575.                                         for(j=0;j<16;j++)
  576.                                         {
  577.                                                 write_1602dat(SetNew[j]);
  578.                                         }
  579.                                         TwoAlam();        //操作成功提示
  580.                                         ReInputEn=1;        //允许重置密码输入
  581.                                         CorrectCont=0;        //正确计数器清零
  582.                                 }
  583.                           }
  584.
  585.                         else                        //=========================当第一次使用或忘记密码时可以用131420对其密码初始化============
  586.                         {
  587.                                 if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
  588.                                    {
  589.                                         WrToROM(initpassword,0,6);                                 //强制将初始密码写入24C02存储
  590.                                         //DisplayListChar(0,1,initword);                        //显示初始化密码
  591.                                         write_1602com(er);
  592.                                         for(j=0;j<16;j++)
  593.                                         {
  594.                                                 write_1602dat(initword[j]);
  595.                                         }
  596.                                         TwoAlam();
  597.                                         Delay400Ms();
  598.                                         TwoAlam();
  599.                                         N=0;
  600.                                 }
  601.                                 else
  602.                                 {
  603.                                         //DisplayListChar(0,1,Error);
  604.                                         write_1602com(er);
  605.                                         for(j=0;j<16;j++)
  606.                                         {
  607.                                                 write_1602dat(Error[j]);
  608.                                         }
  609.                                         ThreeAlam();        //错误提示音
  610.                                         pass=0;
  611.                                 }
  612.                         }
  613.                 }
  614.                 else        //当已经开启重置密码功能时,而按下开锁键,
  615.                 {
  616.                         //DisplayListChar(0,1,Er_try);
  617.                         write_1602com(er);
  618.                         for(j=0;j<16;j++)
  619.                         {
  620.                                 write_1602dat(Er_try[j]);
  621.                         }
  622.                         ThreeAlam();
  623.                 }
  624.         }
  625.         else
  626.         {
  627.                 //DisplayListChar(0,1,Error);
  628.                 write_1602com(er);
  629.                 for(j=0;j<16;j++)
  630.                 {
  631.                         write_1602dat(Error[j]);
  632.                 }
  633.                 ThreeAlam();        //错误提示音
  634.                 pass=0;
  635.         }
  636.
  637.         N=0;        //将输入数据计数器清零,为下一次输入作准备
  638.         operation=1;
  639. }
  640. //==============================主函数===============================
  641. void main(void)
  642. {
  643.         unsigned char KEY,NUM;
  644.         unsigned char i,j;
  645.         P1=0xFF;
  646.         TMOD=0x11;
  647.         TL0=0xB0;
  648.         TH0=0x3C;
  649.         EA=1;
  650.         ET0=1;
  651.         TR0=0;
  652.         Delay400Ms();         //启动等待,等LCM讲入工作状态
  653.         lcd_init();         //LCD初始化
  654.         write_1602com(yi);//日历显示固定符号从第一行第0个位置之后开始显示
  655.         for(i=0;i<16;i++)
  656.         {
  657.                 write_1602dat(name[i]);//向液晶屏写日历显示的固定符号部分
  658.         }
  659.         write_1602com(er);//时间显示固定符号写入位置,从第2个位置后开始显示
  660.         for(i=0;i<16;i++)
  661.         {
  662.                 write_1602dat(start_line[i]);//写显示时间固定符号,两个冒号
  663.         }
  664.         write_1602com(er+9);        //设置光标位置
  665.         write_1602com(0x0f);        //设置光标为闪烁
  666.         Delay5Ms(); //延时片刻(可不要)
  667.         N=0;        //初始化数据输入位数
  668.         while(1)
  669.         {
  670.                 if(key_disable==1)
  671.                         Alam_KeyUnable();
  672.                 else
  673.                         ALAM=1;        //关报警
  674.                 KEY=keynum();
  675.                 if(KEY!=0)
  676.                 {
  677.                         if(key_disable==1)
  678.                         {
  679.                                 second=0;
  680.                         }
  681.                         else
  682.                         {
  683.                                 NUM=coding(KEY);
  684.                                 {
  685.                                         switch(NUM)
  686.                                         {
  687.                                                 case ('A'):         ;                                         break;
  688.                                                 case ('B'):                ;                                     break;
  689.                                                 case ('C'):         ;                                         break;
  690.                                                 case ('D'): ResetPassword();                break;      //重新设置密码
  691.                                                 case ('*'): Cancel();                                break;      //取消当前输入
  692.                                                 case ('#'): Ensure();                                 break;           //确认键,
  693.                                                 default:
  694.                                                 {
  695.                                                         //DisplayListChar(0,1,Input);
  696.                                                         write_1602com(er);
  697.                                                         for(i=0;i<16;i++)
  698.                                                         {
  699.        write_1602dat(Input[i]);
  700.                                                         }
  701.                                                     operation=0;
  702.                                                         if(N<6)                                                           //当输入的密码少于6位时,接受输入并保存,大于6位时则无效。
  703.                                                         {
  704.        OneAlam();        //按键提示音
  705.        //DisplayOneChar(6+N,1,'*');
  706.        for(j=0;j<=N;j++)
  707.        {
  708.        write_1602com(er+6+j);
  709.        write_1602dat('*');
  710.        }
  711.        InputData[N]=NUM;
  712.        N++;
  713.                                                         }
  714.                                                         else        //输入数据位数大于6后,忽略输入
  715.                                                         {
  716.        N=6;
  717.        break;
  718.                                                         }
  719.                                                 }
  720.                                         }
  721.                                 }
  722.                         }
  723.                  }
  724.         }
  725. }
  726. //*********************************中断服务函数**************************************
  727. void  time0_int(void) interrupt 1
  728. {
  729.         TL0=0xB0;
  730.         TH0=0x3C;
  731.         //TR0=1;
  732.         countt0++;
  733.           if(countt0==20)
  734.            {
  735.                 countt0=0;
  736.                 second++;
  737.                 if(pass==1)
  738.                 {
  739.                         if(second==1)
  740.                         {
  741.                                 open_led=1;                        //关指示灯
  742.                                 TR0=0;                                //关定时器
  743.                                 TL0=0xB0;
  744.                                 TH0=0x3C;
  745.                                 second=0;
  746.                         }
  747.                 }
  748.                 else
  749.                 {
  750.                         if(second==3)
  751.                         {
  752.                                 TR0=0;
  753.                                 second=0;
  754.                                 key_disable=0;
  755.                                 s3_keydown=0;
  756.                                 TL0=0xB0;
  757.                                 TH0=0x3C;
  758.                         }
  759.                         else
  760.                             TR0=1;
  761.                 }
  762.
  763.            }
  764. }
ID:74484 发表于 2015-5-8 00:38 | 只看该作者
程序与焊接都没问题的话,只能想到一点,按键的线路连接和程序定义的引脚的是否一样。
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
ID:79309 发表于 2015-5-8 14:58 | 只看该作者
行扫开放,列线检测对否
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
ID:79309 发表于 2015-5-8 15:18 | 只看该作者
检查线路是否虚焊
参与人数 1黑币 +35 收起 理由
admin + 35 回帖助人的奖励!
ID:99459 发表于 2015-12-12 22:23 | 只看该作者
你编译通过了吗
