查看: 4047|回复: 4
带I2C记忆的电子密码锁protues仿真及程序
I2C芯片
带记忆的电子密码锁仿真工程文件及程序下载:
电子密码锁 - I2C芯片.zip (78.97 KB, 下载次数: 46)
源程序:
  1. #include<reg51.h>
  2. #include"24c02.h"
  3. #include"1602.h"
  4. #include"keyscan.h"
  5. sbit GRE=P2^2;
  6. sbit RED=P2^3;
  7. uchar num,shu;
  8. uchar code table[]="please input key";
  9. uchar code you[]="you left ";
  10. uchar code chance[]=" chance";
  11. uchar code wait[]="please wait 5s";
  12. uchar code change[]="you can change";
  13. uchar code the[]="the key";
  14. uchar code please[]="please input";
  15. uchar code new[]=" the new key";
  16. uchar code ok[]="ok try again";
  17. uchar  key1[6]={1,2,3,4};
  18. uchar  key[6];
  19. uchar key_xin[6];
  20. char key0=0;
  21. char a,b,chan,c_xin=0;
  22. void delayms1(uint xms)
  23. {
  24.         uint i,j;
  25.         for(i=0;i<xms;i++)
  26.                 for(j=0;j<110;j++);
  27. }
  28. void main()
  29. {
  30.         init_24c02();
  31.         if(read(0xa0,0)!=0xff)
  32.         key1[0]=read(0xa0,0);
  33.         if(read(0xa0,1)!=0xff)
  34.         key1[1]=read(0xa0,1);
  35.         if(read(0xa0,2)!=0xff)
  36.         key1[2]=read(0xa0,2);
  37.         if(read(0xa0,3)!=0xff)
  38.         key1[3]=read(0xa0,3);
  39.         init_1602();
  40.         write_com(0x80);
  41.         for(num=0;num<16;num++)
  42.         {
  43.                 write_date(table[num]);
  44.                 delayms1(5);
  45.         }
  46.         delayms1(1000);
  47.         write_com(0x01);
  48.         write_com(0x80);
  49.         while(1)
  50.         {
  51.                 shu=keyscan();
  52.                 switch(shu)
  53.                 {
  54.                         case 7:
  55.                                 write_date('7');
  56.                                 if(c_xin%2==0)
  57.                                 key[key0++]=7;
  58.                                 else
  59.                                 key_xin[key0++]=7;
  60.                                 break;
  61.                         case 8:
  62.                                 write_date('8');
  63.                                 if(c_xin%2==0)
  64.                             key[key0++]=8;
  65.                                 else
  66.                                 key_xin[key0++]=8;
  67.                                 break;
  68.                         case 9:
  69.                                 write_date('9');
  70.                                 if(c_xin%2==0)
  71.                                 key[key0++]=9;
  72.                                 else
  73.                                 key_xin[key0++]=9;
  74.                                 break;
  75.                         case 4:
  76.                                 write_date('4');
  77.                                 if(c_xin%2==0)
  78.                                 key[key0++]=4;
  79.                                 else
  80.                                 key_xin[key0++]=4;
  81.                                 break;
  82.                         case 5:
  83.                                 write_date('5');
  84.                                 if(c_xin%2==0)
  85.                                 key[key0++]=5;
  86.                                 else
  87.                                 key_xin[key0++]=5;
  88.                                 break;
  89.                         case 6:
  90.                                 write_date('6');
  91.                                 if(c_xin%2==0)
  92.                                 key[key0++]=6;
  93.                                 else
  94.                                 key_xin[key0++]=6;
  95.                                 break;
  96.                         case 1:
  97.                                 write_date('1');
  98.                                 if(c_xin%2==0)
  99.                                 key[key0++]=1;
  100.                                 else
  101.                                 key_xin[key0++]=1;
  102.                                 break;
  103.                         case 2:
  104.                                 write_date('2');
  105.                                 if(c_xin%2==0)
  106.                                 key[key0++]=2;
  107.                                 else
  108.                                 key_xin[key0++]=2;
  109.                                 break;
  110.                         case 3:
  111.                                 write_date('3');
  112.                                 if(c_xin%2==0)
  113.                                 key[key0++]=3;
  114.                                 else
  115.                                 key_xin[key0++]=3;
  116.                                 break;
  117.                         case 0:
  118.                                 write_date('0');
  119.                                 if(c_xin%2==0)
  120.                                 key[key0++]=0;
  121.                                 else
  122.                                 key_xin[key0++]=0;
  123.                                 break;
  124.                         case 'w':
  125.                                 key0=0;
  126.                                 break;
  127.                         case '=':
  128.                                 c_xin++;
  129.                                 if(c_xin%2==1)
  130.                            {
  131.                                         write_com(0x01);
  132.                                         for(b=0;b<12;b++)
  133.                                         {
  134.                                                 write_date(please[b]);
  135.                                                 delayms1(25);
  136.                                         }
  137.                                         write_com(0x80+0x40);
  138.                                         for(b=0;b<12;b++)
  139.                                         {
  140.                                                 write_date(new[b]);
  141.                                                 delayms1(25);
  142.                                         }
  143.                                         delayms1(1500);
  144.                                         write_com(0x01);
  145.                           }
  146.                           else
  147.                           {
  148.                                   write(0xa0,0,key_xin[0]);
  149.                                 write(0xa0,1,key_xin[1]);
  150.                                 write(0xa0,2,key_xin[2]);
  151.                                 write(0xa0,3,key_xin[3]);
  152.                                 write_com(0x01);
  153.                                   for(b=0;b<12;b++)
  154.                                 {
  155.                                         write_date(ok[b]);
  156.                                         delayms(25);
  157.                                 }
  158.                                 delayms1(1500);
  159.                                 write_com(0x01);
  160.                                 key0=0;
  161.                           }
  162.                                 break;
  163.                 }
  164.                 if(key0==4&&c_xin%2==0)
  165.                 {
  166.                         delayms1(500);
  167.                         if(c_xin==0)
  168.                         {
  169.                                 for(a=key0-1;a>=0;a--)
  170.                                 {
  171.                                         if(key[a]!=key1[a])
  172.                                         break;
  173.                                 }
  174.                         }
  175.                         else
  176.                         {
  177.                                 for(a=key0-1;a>=0;a--)
  178.                                 {
  179.                                         if(key[a]!=key_xin[a])
  180.                                         break;
  181.                                 }
  182.                         }
  183.                     key0=0;
  184.                         if(a>=0)
  185.                         {
  186.                                 write_com(0x01);
  187.                                 write_date('e');
  188.                                 write_date('r');
  189.                                 write_date('r');
  190.                                 write_date('o');
  191.                                 write_date('r');
  192.                                 GRE=1;
  193.                                 RED=0;
  194.                                 delayms1(600);
  195.                                 write_com(0x01);
  196.                                 chan++;
  197.                                 if(chan<3)
  198.                                 {
  199.                                         for(b=0;b<9;b++)
  200.                                         {
  201.                                                 write_date(you[b]);
  202.                                                 delayms1(1);
  203.                                         }
  204.                                         write_date(0x30+3-chan);
  205.                                         for(b=0;b<7;b++)
  206.                                         {
  207.                                                 write_date(chance[b]);
  208.                                                 delayms1(10);
  209.                                         }
  210.                                         delayms1(1000);
  211.                                         write_com(0x01);
  212.                                 }
  213.                                 else
  214.                                 {
  215.                                         chan=0;
  216.                                         for(b=0;b<14;b++)
  217.                                         {
  218.                                                 write_date(wait[b]);
  219.                                                 delayms1(100);
  220.                                         }
  221.                                         delayms1(5000);
  222.                                         write_com(0x01);
  223.                                 }
  224.                         }
  225.                         else
  226.                         {
  227.                                 write_com(0x01);
  228.                                 write_date('r');
  229.                                 write_date('i');
  230.                                 write_date('g');
  231.                                 write_date('h');
  232.                                 write_date('t');
  233.                                 GRE=0;
  234.                                 RED=1;
  235.                                 delayms1(1000);
  236.                                 write_com(0x01);
  237.                                 for(b=0;b<14;b++)
  238.                                 {
  239.                                         write_date(change[b]);
  240.                                         delayms1(25);
  241.                                 }
  242.                                         write_com(0x80+0x40);
  243.                                 for(b=0;b<7;b++)
  244.                                 {
  245.                                         write_date(the[b]);
  246.                                         delayms1(25);
  247.                                 }
  248.                         }
  249.                 }
  250.         }
  251. }
ID:154674 发表于 2016-12-22 08:51 | 只看该作者
bucuocbucuo
ID:156738 发表于 2016-12-27 21:29 | 只看该作者
真的好厉害啊
ID:305410 发表于 2018-4-12 20:05 | 只看该作者
请问下,这个程序能不能更改为设置八位密码呢?可以的话在那里更改?
ID:288379 发表于 2018-4-13 21:21 | 只看该作者
赞一个
