查看: 6685|回复: 13
51单片机电子密码锁程序错误
ID:157011 发表于 2016-12-22 22:32 | 显示全部楼层 |阅读模式
这是一个设计电子密码锁的程序
keil 编译时出现错误   求大神帮忙
  1. #include<reg51.h>
  2. #include<string.h>
  4. #define unit unsigned int
  5. uchar Pre_KeyNo=16,KeyNo=16;
  6. uchar code Title_Text[]="Your Password...";
  7. uchar DSY_BUFFER[10]="";
  8. uchar UserPassword[10]="";
  9. void LCD_Init();
  10. //void Display_String(uchar * str,uchar LineNo);
  11. void Display_String(uchar,x,uchar y,uchar *str);
  12. void IIC_24C04_Init();
  13. void Beep();
  14. uchar RecString(uchar Slave,uchar Subadder,uchar *Buffer,uchar N);
  15. uchar SendString(uchar Slave,uchar Subadder,uchar *Buffer,uchar N);
  16. uchar Keys_Scan();
  17. sbit LED_OPEN=P2^7;
  18. sbit BEEP=P3^7;
  19. void DelayMS(uint x)
  20. {
  21. uchar i;
  22. while (x--) for (i=0;i<120;i++);
  23. }
  24. void Beep()
  25. {
  26.   uchar i;
  27.   for(i=0;i<100;i++)
  28.   {
  29.    DelayMS(1);BEEP=~BEEP;
  30.    }
  31.   }
  32. void Clear_Password()
  33. {
  34. UserPassword[0]='\0';
  35. DSY_BUFFER[0]='\0';
  36. }
  37. void main()
  38. {
  39.   uchar i = 0;
  40.   uchar IIC_Password[10];///={"876543"};
  41.   uchar IS_Valid_User = 0;
  42.   P0 = 0xFF;
  43.   P1 = 0xFF;
  44.   P2 = 0xFF;
  45.   DelayMS(10);
  46.   LCD_Init();
  47.   IIC_24C04_Init();
  48.   Display_String(0,0,Title_Text);
  49.   RecString(0xa0,0,IIC_Password,6);
  50.   IIC_Password[6] ='\0';
  51.   while(1)
  52.   {
  53.    P1 = 0xF0;
  54.    if(P1!= 0xF0)KeyNo = Keys_Scan();
  55.    switch(KeyNo)
  56.    {
  57.     case0;case1;case2;case3;case4;
  58.         case5;case6;case7;case8;
  59.           if (i<= 5)
  60.           {
  61.            if(i==0)Display_String(0,1,"       ");
  62.            UserPassword[i] = KeyNo + '0';
  63.            UserPAssword[i+1] = '\0';
  64.            DSY_BUFFER[i] = '*';
  65.            DSY_BUFFER[i+1] = '\0';
  66.            Display_String(0,1,DSY_BUFFER);
  67.            i++;
  68.            }
  69.            break;
  70. case 11://按B键开锁
  71.        if(strcmp(UserPassword,IIC_Password)==0)
  72.            {
  73.             LED_OPEN = 0;
  74.                 Clear_PAssword();
  75.                 Display_String(0,1,"Unlock OK!     ");
  76.                 IS_Valid_User = 1;
  77.                 }
  78.                 else
  79.                 {
  80.                  LED_OPEN =1;
  81.                  Clear_Password();
  82.                  Display_String(0,1,"ERROR      ");
  83.                  IS_Valid_User = 0;
  84.                  }
  85.                  i = 0;
  86.                  break;
  87.   case 10://按A键上锁
  88.          LED_OPEN =1;
  89.                  Clear_Password();
  90.                  Display_String(0,0,Title_Text);
  91.                  Display_String(0,1,"       ");
  92.                  i = 0;
  93.                  IS_Valid_User = 0;
  94.                  break;
  95.   case 12://按C键设置新密码
  96.           //如果是合法用户则提示输入新密码
  97.                   if(!IS_Valid_User)Display_string(0,1,"No Rights!      ");
  98.                   else
  99.                   {i = 0;
  100.                    Display_String(0,0"New Password     ");
  101.                    Display_String(0,1,"                ");
  102.                    }
  103.                    break;
  104.         case 13://按13键保存新密码
  105.         if (!IS_Valid_User)Display_String(0,1,"No Right!     ");
  106.         else
  107.         {
  108.         SendString(0xa0,0,UserPassword,6);
  109.         for(i=0;i<7;i++)IIC_Password[i]=UserPassword[i];
  110.         //重新读入刚写的密码
  111.         //RecString(0xa0,0,IIC_Password,6);
  112.         //IIC_Password[6] = '\0';
  113.         i = 0;
  114.         Display_String(0,0,Title_Text);
  115.         Display_String(0,1"Password Saved");
  116.     }
  117.         break;
  118. case 15://按F键消除所以输入
  119.         i = 0;
  120.                 Clear_Password();
  121.                 Display_String(0,1,"           ");
  122.         }
  123.         Beep();
  124.         DelayMS(100);
  125.         P1 = 0xF0;
  126.         while(P1 !=0xF0);
  127.         while(P1 == 0xF0);
  128. }
  129. }
    RET
FINI:NOP
     END
新建文件夹.rar
4.73 KB, 下载次数: 11
ID:157057 发表于 2016-12-23 09:19 | 显示全部楼层
最好把工程弄上来。。
ID:157011 发表于 2016-12-23 16:29 | 显示全部楼层
fefen0 发表于 2016-12-23 09:19
最好把工程弄上来。。
嗯  已经上传了  求帮忙
ID:111634 发表于 2016-12-24 18:59 | 显示全部楼层
功能齐全的电子密码锁
⑴ 电路设计    …
⑵ 功能设计    …
⑶ 程序设计    …
⑷ Proteus仿真   …
电子密码锁1.rar (1.13 MB, 下载次数: 28)
ID:153199 发表于 2016-12-25 18:47 | 显示全部楼层
问题解决了吗
ID:157011 发表于 2016-12-27 21:01 | 显示全部楼层
还没有欸
ID:157576 发表于 2016-12-27 21:07 | 显示全部楼层
好高深。。。
ID:111634 发表于 2016-12-27 21:38 | 显示全部楼层
请对照正确有效的案例:功能齐全的电子密码锁
ID:157748 发表于 2016-12-27 22:43 | 显示全部楼层
把uint换成int行吗
ID:156744 发表于 2016-12-27 22:46 来自触屏版 | 显示全部楼层
zl2168 发表于 2016-12-24 18:59
功能齐全的电子密码锁
我想问一下你的这种没有上拉电阻的按键是怎么进行扫描的!
ID:111634 发表于 2016-12-28 22:44 | 显示全部楼层
P1~P3口内部有上拉电阻,P0口内部没有上拉电阻。
单片机应用不但要会编程序,而且要了解单片机片内I/O口硬件结构,还要懂电子技术。
ID:158544 发表于 2016-12-29 10:38 | 显示全部楼层
修改一下工程,或者上传下
ID:159928 发表于 2017-1-4 17:13 | 显示全部楼层
谢谢楼主分享
ID:271443 发表于 2018-1-4 16:17 | 显示全部楼层
最终代码还有没有呢,求分享
