查看: 7375|回复: 4
求在已有电路图基础上设计的函数信号发生器的程序
68黑币
我们的课设要求是设计一个能产生方波、正弦波、三角波、锯齿波四种波形,且频率、幅度均可调的函数信号发生器。
我们已经设计好了电路图,也参考了网上的一些程序,但是自己又不会改。求助大神,68个黑币是我的全部了。
我们使用AT89C52,DAC0832和LCD1602
希望大神在我们已有的电路图和程序的基础上帮我们编一下程
PS:以下程序可以实现产生三种波形和调频的功能,还差产生锯齿波、波形调幅和使用矩阵键盘这几个功能。
附录 程序清单(我们在网上找的程序,可供大神参考)
                 #include<reg52.h>
#define  uchar unsigned char
#define  uint  unsigned int
#define DAdata  P0        //DA数据端口
sbit DA_S1= P2^0;   // 控制DAC0832的8位输入寄存器,仅当都为0时,可以输出数据(处于直通状态),否则,输出将被锁存
sbit DA_S2= P2^1;   // 控制DAC0832的8位DAC寄存器,仅当都为0时,可以输出数据(处于直通状态),否则,输出将被锁存
sbit key=   P3^2;
uchar wavecount;    //'抽点'计数
uchar THtemp,TLtemp;//传递频率的中间变量
uchar judge=1;      //在方波输出函数中用于简单判别作用
uchar waveform;            //当其为0、1、2时,分别代表三种波
uchar code freq_unit[3]={10,50,200}; //三种波的频率单位
uchar idata wavefreq[3]={1,1,1};           //给每种波定义一个数组单元,用于存放单位频率的个数
uchar code  lcd_hang1[]={"Sine Wave       " "Triangle Wave   " "Square Wave     " "Select Wave:    " "press No.1 key! "};
uchar idata lcd_hang2[16]={"f=    Hz        "};
uchar code waveTH[]={
    0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xec,0xf6,0xf9,0xfb,0xfc,0xfc,0xfd,0xfd,0xfd,0xfe};
uchar code waveTL[]={
    0x06,0x8a,0x10,0x4e,0x78,0x93,0xa8,0xb3,0xbe,0xc6, //正弦波频率调整中间值
0xac,0xde,0x48,0x7a,0x99,0xaf,0xbb,0xc8,0xd0,0xde,        //三角波频率调整中间值
0x88,0x50,0x90,0x32,0x34,0xbe,0x4a,0xa3,0xe5,0x2c};
uchar code triangle_tab[]={         //每隔数字8,采取一次
0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58,0x60,0x68,0x70,0x78,
0x80,0x88,0x90,0x98,0xa0,0xa8,0xb0,0xb8,0xc0,0xc8,0xd0,0xd8,0xe0,0xe8,0xf0,0xf8,0xff,
0xf8,0xf0,0xe8,0xe0,0xd8,0xd0,0xc8,0xc0,0xb8,0xb0,0xa8,0xa0,0x98,0x90,0x88,0x80,
0x78,0x70,0x68,0x60,0x58,0x50,0x48,0x40,0x38,0x30,0x28,0x20,0x18,0x10,0x08,0x00};
uchar code sine_tab[256]={
//输出电压从0到最大值(正弦波1/4部分)
0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,0xae,0xb1,0xb4,0xb7,0xba,0xbc,
0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,
0xee,0xef,0xf1,0xf2,0xf4,0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
//输出电压从最大值到0(正弦波1/4部分)
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,0xf4,0xf2,0xf1,0xef,
0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,
0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,0xa8,0xa5,0xa2,0x9f,0x9c,0x99 ,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
//输出电压从0到最小值(正弦波1/4部分)
0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,0x51,0x4e,0x4c,0x48,0x45,0x43,
0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16 ,0x15,0x13,
0x11,0x10,0x0e,0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,0x00,0x00,0x00,0x00,
//输出电压从最小值到0(正弦波1/4部分)
0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,
0x11,0x13,0x15 ,0x16,0x18,0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,0x3d,
0x40,0x43,0x45,0x48,0x4c,0x4e,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80};
void delay(uchar z)
    uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void triangle_out()        //三角波输出
    DAdata=triangle_tab[wavecount++];
if(wavecount>64) wavecount=0;
DA_S1=0;  //打开8位输入寄存器
DA_S1=1;  //关闭8位输入寄存器
void sine_out()         //正弦波输出
    DAdata=sine_tab[wavecount++];
void square_out()  //方波输出
    judge=~judge;
    if(judge==1) DAdata=0xff;
else  DAdata=0x00;
/************1602液晶的相关函数*************/
#define lcd_ports P1
sbit rs=P2^2;
sbit rw=P2^3;
sbit lcden=P2^4;
void write_com(uchar com)
rs=0;        //置零,表示写指令
lcden=0;
lcd_ports=com;
delay(5);
lcden=1;
delay(5);
lcden=0;
void write_date(uchar date)
rs=1;        //置1,表示写数据(在指令所指的地方写数据)
lcden=0;
lcd_ports=date;
delay(5);
lcden=1;
delay(5);
lcden=0;
void disp_lcd(uchar addr,uchar *temp1)
uchar num;
write_com(addr);
delay(1);   //延时一会儿???
for(num=0;num<16;num++)
write_date(temp1[num]);//或者这样写write_date(*(temp1+num));
delay(1);
void init_lcd()
//uchar num;
lcden=0;  //可有可无???
rw=0;  //初始化一定要设置为零,表示写数据
write_com(0x38);  //使液晶显示点阵,为下面做准备
write_com(0x0c);  //初始设置
write_com(0x06);  //初始设置
write_com(0x01);  //清零
write_com(0x80);  //使指针指向第一行第一格
    disp_lcd(0x80,&lcd_hang1[3*16]);  //在第一行显示
    disp_lcd(0xc0,&lcd_hang1[4*16]);  //在第二行显示
/********************1602液晶函数声明结束*********************/
    uchar i=0;
DA_S2=0;    //使DAC寄存器处于直通状态
DAdata=0;
init_lcd();
    waveform=0;
TMOD=0x01;  //设置定时器0为16位工作方式
IT0=1;      //设置外部中断0为下降沿触发
ET0=1;      //开定时器中断
EX0=1;
EA=1;
//DAout(0xff);           //可输出TTL波形
//DAout(0x80);
//T_temp=32;
void timer0() interrupt 1
TH0=THtemp;
TL0=TLtemp;
if(waveform==0)      sine_out();
else if(waveform==1) triangle_out();
else if(waveform==2) square_out();
void key_int0() interrupt 0
    uchar keytemp;
uint total_freq; //总频率
EA=0; TR0=0;     //关总中断与定时器
delay(5);       //延时够吗???
if(key==0)       //确实有按键按下而引发中断
keytemp=P3&0xf0; //获取P3口高四位的值
switch(keytemp)
    case 0xe0:        //选择波形
     waveform++;
if(waveform>2) waveform=0;
break;
    case 0xd0:  //频率按规定单位依次增加
     wavefreq[waveform]++;
if(wavefreq[waveform]>10) wavefreq[waveform]=1; // /*这边要用“>10”,因为它比“=11”可靠
break;         //   性更高,使加数有个上限,不会一直加下去*/
    case 0xb0:  //频率按规定单位依次衰减
     wavefreq[waveform]--;
if(wavefreq[waveform]<1) wavefreq[waveform]=10; //这边要用“<1”,因为它比“=0”可靠性更高
break;
    case 0x70:    //TTL输出
     DA_S2=1; //使DAC寄存器关闭
break;
    THtemp=waveTH[waveform*10+(wavefreq[waveform]-1)]; //方括号中选取第几个数后,并把该值赋给T_temp
TLtemp=waveTL[waveform*10+(wavefreq[waveform]-1)];
    total_freq= wavefreq[waveform] * freq_unit[waveform]; //求输出频率(个数*单位)
    lcd_hang2[5]=total_freq%10+0x30;                 //在液晶中显示个位,(0x30 在液晶显示中表示数字0)
    total_freq/=10; lcd_hang2[4]=total_freq%10+0x30; //在液晶中显示时十位
    total_freq/=10; lcd_hang2[3]=total_freq%10+0x30; //在液晶中显示时百位
    total_freq/=10; lcd_hang2[2]=total_freq%10+0x30; //在液晶中显示时千位
    disp_lcd(0x80,&lcd_hang1[waveform*16]);  //在第一行显示
    disp_lcd(0xc0,lcd_hang2);  //在第二行显示
wavecount=0; //'抽点'计数清零
while(!key);
EA=1; TR0=1;     //开启总中断与定时器
函数信号发生器电路图
函数信号发生器电路图
收藏收藏1 分享淘帖 顶顶 踩踩
ID:82765 发表于 2017-6-26 16:53 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:82765 发表于 2017-6-26 16:55 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
ID:213573 发表于 2017-6-28 22:09 | 只看该作者
并未得到解决
ID:429887 发表于 2018-11-20 14:51 | 只看该作者
对啊 感觉帮助不大
