查看: 399|回复: 0
基于stm32单片机的智能家居系统程序
ID:755173 发表于 2026-4-14 08:53 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "total_wifi.h"
#include "pub_sub_message.h"
#include "DMA_adc.h"
#include "show.h"
#include "time4.h"
#include "usart3.h"
#include "infrared.h"
#include "dht11.h"
#include "motorrun.h"
void data_caiji(void);
void ctrl_auto(void);
extern char SubcribePack_flag;
unsigned int SystemTimer = 0;
unsigned int TEHUTimer = 0;
extern __IO uint16_t ADC_ConvertedValue[NOFCHANEL];
int Learn_IR_ctrl[5] = {0xFA, 0xFD, 0x01, 0x00, 0xDF};
int IR_ctrl_on[5] = {0xFA, 0xFD, 0x02, 0x00, 0xDF};
int IR_ctrl_off[5] = {0xFA, 0xFD, 0x02, 0x01, 0xDF };
u8 light, ppm, co;
u16 adc_light, adc_ppm, adc_co;
u8 tem, hum, people;
u8 PPM_MAX = 50, co_MAX = 50;
int main(void)
    Delay_Init();
    Usart1_Init(9600);
    uart3_init(9600);
    KEY_Init();
    KEY_Exti_Init();
    ADCx_Init();
    OLED_Init();
    WiFi_ResetIO_Init();
    AliIoT_Parameter_Init();
    LED_Init();
    MOTOR_Init();
    DHT11_Init();
    TIM2_ENABLE_200MS();
                                                data_caiji();
u8 people_num_sta,people_num;
    if(IO_A5_IN_STA)
                        printf("1");
                        people_num=1;
                        if(people_num!=people_num_sta)
                                people_num_sta=people_num;
                                people++;
                {        printf("0");
                        people_num_sta=0;
    adc_light = Get_Adc_Average(0, 10);
    if(adc_light > 4000)adc_light = 4000;
    light = (100 - (adc_light / 40));
    adc_ppm = Get_Adc_Average(1, 10);
    ppm = adc_ppm * 99 / 4096;
    ppm = ppm >= 99 ? 99 : ppm;
    adc_co = Get_Adc_Average(2, 10);
    co = adc_co * 99 / 4096;
    co = co >= 99 ? 99 : co;
    DHT11_Read_Data(&hum, &tem);
u8 auto_flag ;
u8 ppm_beep, ppm_beep_sta;
u8 co_beep, co_beep_sta;
    char temp[500];
    if(auto_flag)
        if(ppm > PPM_MAX)
            BEEP = !BEEP;
            ppm_beep = 1;
                                                Delay_Ms(30);
            if(ppm_beep != ppm_beep_sta)
                show_num = 4;
                ppm_beep_sta = ppm_beep;
                if(SubcribePack_flag)
                    sprintf(temp, "{\"method\":\"thing.event.property.post\",\"id\":\"203302322\",\"params\":{\""identifier10"\":1},\"version\":\"1.0.0\"}");
                    MQTT_PublishQs0(P_TOPIC_NAME, temp, strlen(temp));
        else if(ppm < PPM_MAX)
            BEEP = 1;
            ppm_beep = 0;
                show_num = 0;
                    sprintf(temp, "{\"method\":\"thing.event.property.post\",\"id\":\"203302322\",\"params\":{\""identifier10"\":0},\"version\":\"1.0.0\"}");
        if(co > co_MAX)
            BEEP = !BEEP;
                                                Delay_Ms(30);
            co_beep = 1;
            show_num = 4;
            if(co_beep != co_beep_sta)
                co_beep_sta = co_beep;
                    sprintf(temp, "{\"method\":\"thing.event.property.post\",\"id\":\"203302322\",\"params\":{\""identifier11"\":1},\"version\":\"1.0.0\"}");
        else if(co < co_MAX)
            BEEP = 1;
            co_beep = 0;
                show_num = 0;
                    sprintf(temp, "{\"method\":\"thing.event.property.post\",\"id\":\"203302322\",\"params\":{\""identifier11"\":0},\"version\":\"1.0.0\"}");
